Utilisation De Fibaro:call En Fonction Du Module Commandé
mprinfo
Utilisation de fibaro:call en fonction du module commandé
Voici un lien qui vous donnera les actions que l'on peut utiliser pour chaque type de modules fibaro
http://www.fibarouk.co.uk/support/lua/actions-use-fibarocall-api/
close
Application pour : blind
Description:
Closes a blind.
Usage:
This action takes no arguments.
Exemple:
-- Close the blind with the device ID of 94
fibaro:call(94, "close")
open
Description:
Opens a blind.
Usage:
Exemple:
-- Open the blind with the device ID of 94
fibaro:call(94, "open")
pressButton
Application pour : virtual_device
Description:
Triggers a virtual device button press.
Usage:
This action takes one argument.
  • The number of the button to be pressed.  Each element of a virtual device has a unique number starting from 1.  If your virtual device has two labels followed by two buttons, the buttons will be numbered 3 and 4.
Exemple:
-- Trigger a button press of button 3 of
-- the virtual device with an ID of 358
fibaro:call(358, "pressButton", "3")
sendDefinedEmailNotification
Application pour : HC_user
Description:
Sends a notification to the email address associated with a user.
Usage:
  • The id of the notification to be sent.
Exemple:
1-- Send notification 2 via email to the
-- address associated with user 107.
fibaro:call(107, "sendDefinedEmailNotification", "2")
sendDefinedPushNotification
Application pour : iOS_device
Description:
Sends a push notification to a device.
Usage:
Exemple:
-- Send notification 2 via push to modile device number 10.
fibaro:call(10, "sendDefinedPushNotification", "2")
sendDefinedSMSNotification
Description:
Sends an SMS notification to a phone number.
Usage:
This action takes two arguments.
  • The phone number to send the message to.
This should be in the form xxyyyyyyyyy where xx = country code and yyyyyyyyy = phone number.
Exemple:
-- Send notification 3 via SMS to device number +441234567890.
fibaro:call(2, "sendDefinedSMSNotification", "441234567890", "3")
sendEmail
Description:
Sends an email to the email address associated with a user.
Usage:
  • The subject of the email.
  • The message body of the email.
Exemple:
-- Send an email to the email address associated with user 2.
local subject = "This is the subject of the email."
local message = "This is the body of the email.\nWith a line break."
fibaro:call(2, "sendEmail", subject, message)
sendPhotoToEmail
Application pour : IP_camera
Description:
Sends a still image from a camera to a specified email address.
Usage:
  • The email address to send the image to.
Exemple:
-- Send an image from camera 120 to someone@this.address.
fibaro:call(120, "sendPhotoToEmail", "someone@this.address")
sendPhotoToUser
Description:
Sends a still image from a camera to the email address associated with a user.
Usage:
  • The id number of the user to send the image to.
Exemple:
-- the email address associated with user 2.
fibaro:call(120, "sendPhotoToUser", "2")
sendPush
Description:
Sends a push notification to an iOS device.
The device must have connected with the Home Centre recently, however once this connection has been made the app can be closed.
Usage:
  • The message to be pushed to the device.
Exemple:
-- Send a push notification to the iOS device with the ID of 10
fibaro:call(10, 'sendPush', 'This is the message to be pushed.')
setArmed
Application pour : motion_sensor, door_sensor, window_sensor, smoke_sensor
Description:
Arms or disarms a device.
Usage:
  • The armed state of the device. 0 = disarmed, 1 = armed.
Exemple:
-- Arm the door sensor with device ID of 174
fibaro:call(174, "setArmed", "1")
-- Disarm the door sensor with device ID of 174
fibaro:call(174, "setArmed", "0")
setB
Application pour : rgb_driver
Description:
Sets the brightness of the blue channel of an rgb_driver.
Usage:
  • The brightness (0-99) of the channel.
Exemple:
-- Set the brightness of the blue channel of device 81 to 56%
fibaro:call(81, "setB", "56")
setColor
Description:
Sets the colour of an rgb_driver.
This is done by setting the brightness of the red, green, blue and white channels.
Usage:
This action takes four arguments.
  • The brightness (0-99) of the red channel.
  • The brightness (0-99) of the green channel.
  • The brightness (0-99) of the blue channel.
  • The brightness (0-99) of the white channel.
Even if the device is in RGB mode, the white channel needs to be specified – in this case, just use 0.
Exemple:
-- Set the colour of device 81 to a blue-indigo colour
-- (60% red, 23% green, 99% blue, 0% white)
fibaro:call(81, "setColor", "60", "23", "99", "0")
setG
Description:
Sets the brightness of the green channel of an rgb_driver.
Usage:
Exemple:
-- Set the brightness of the green channel of device 81 to 56%
fibaro:call(81, "setG", "56")
setProperty
Description:
Sets value of the elements of a virtual device (labels and sliders).
Usage:
  • The name of the element.
  • The value to set the element to.
Exemple:
-- Set the content of Label1 in virtual device 1170 to 'program 1'
fibaro:call(1170, "setProperty", "ui.Label1.value", "program 1")
-- Set the value of Slider1 in virtual device 1170 to 45
fibaro:call(1170, "setProperty", "ui.Slider1.value", "45")
setR
Description:
Sets the brightness of the red channel of an rgb_driver.
Usage:
Exemple:
-- Set the brightness of the red channel of device 81 to 56%
fibaro:call(81, "setR", "56")
setSlider
Description:
Triggers a change in the value of a virtual device slider.
Usage:
  • The number of the slider to be changed.  Each element of a virtual device has a unique number starting from 1.  If your virtual device has two labels followed by two buttons and then a slider, the slider will be numbered 5.
  • The value (0-99) to set the slider to.
Exemple:
-- Set the slider with an ID of 2 of the
-- virtual device with an ID of 334 to 50%
fibaro:call(334, "setSlider", "2", "50")
setTargetLevel
Application pour : thermostat_setpoint
Description:
Sets the target temperature of a thermostat_setpoint.
Usage:
  • A temperature in degrees.
Exemple:
-- Set the target temperature of device 117 to 18 degrees.
fibaro:call(117, "setTargetLevel", "18")
setTime
Description:
Sets the value of the timeStamp property of the thermostat_setpoint.
Usage:
  • A timestamp.
Exemple:
-- Set the timeStamp of the thermostat_setpoint
-- with device ID of 117 to 2 hours from now.
fibaro:call(117, "setTime", tonumber(os.time()) + 120*60)
setValue
Application pour : dimmable_light, blind, rgb_driver
Description:
Sets the brightness of a dimmable_light or rgb_driver or sets the position of a blind.
When changing the brightness of rgb_drivers, all channels are set to the same level (white light).
Usage:
  • A value (0-99) representing the brightness of the light or position of the blind.
    For a blind, 0 = fully closed, 99 = fully open.
Exemple:
-- Set the brightness of the light with device ID of 68 to 25%.
fibaro:call(68, "setvalue", "25")
-- Set the position of the blind with the device ID of 94 to 75% open.
fibaro:call(94, "setvalue", "75")
setW
Description:
Sets the brightness of the white channel of an rgb_driver.
Usage:
Exemple:
-- Set the brightness of the white channel of device 81 to 56%
fibaro:call(81, "setW", "56")
startProgram
Description:
Instruct the rgb_driver to play one of the preconfigured colour programmes.
Usage:
  • The light programme number to run.
Exemple:
-- Start programme number 2 ("storm") on device number 81
fibaro:call(81, "startProgram", "2")
stop
Description:
Stops the movement of a blind.
Usage:
Exemple:
-- Stop the blind with the device ID of 94
fibaro:call(94, "stop")
turnOff
Application pour : binary_light, dimmable_light, rgb_driver
Description:
Turns off a device.
Usage:
Exemple:
-- Turn off device number 58.
fibaro:call(58, "turnOff")
turnOn
Description:
Turns on a device.
Usage:
Exemple:
-- Turn on device number 58.
fibaro:call(58, "turnOn")
  • Upvote 6
On peut compléter avec ceci:
Les commandes en noir ne réponde pas àfibaro:call mais àl'API "callAction" dont on trouve un bon descriptif ici: http://tutoriels.domotique-store.fr/content/49/45/fr/api-commander-le-home-center-par-des-requ%C3%AAtes-http.html
  • 3 ans après...
oh Yeahhhhhh je me faisais chier avec les sendpushdefinednitifcations.... mais là avec le send push je suis chaud.... c'est 100 fois mieux ! bcp plus facile à gérer ! oh je suis content.... je vais revoir mon pleind e truc !
LUA en force quand meme :)
merci pour l'article !
--[[ Lumière du séjour --]]
if
 ( tonumber(fibaro:getValue(171, "value")) > 0 )
  or
 ( tonumber(fibaro:getValue(166, "value")) > 0 )
then
	fibaro:call(531, "sendPush", "Une des lumières du séjour est allumée");
    --fibaro:call(293, "sendDefinedPushNotification", "31");
ça change tout !  en plus j'ai fais un OR :) pooooop poooop pooooop @Nico je fais pas que du bloc maintenant LOOOL :p
