mprinfo Posté(e) le 3 novembre 2016 Signaler Posté(e) le 3 novembre 2016 Utilisation de fibaro:call en fonction du module commandé Voici un lien qui vous donnera les actions que l'on peut utiliser pour chaque type de modules fibaro http://www.fibarouk.co.uk/support/lua/actions-use-fibarocall-api/ armed close firmwareUpdate open pollingDeadDevice pollingTimeSec pressButton requestNodeNeighborUpdate resetMeter sendDefinedEmailNotification sendDefinedPushNotification sendDefinedSMSNotification sendEmail sendGlobalEmailNotifications sendGlobalPushNotifications sendGlobalSMSNotifications sendPhotoToEmail sendPhotoToUser sendPush sendSipUserID setArmed setB setColor setG setProperty setProtectionLocalAndRF setR setSipDisplayName setSipUserID setSipUserPassword setSlider setTargetLevel setTime setValue setValue2 setW startProgram stop turnOff turnOn close Application pour : blind Description: Closes a blind. Usage: This action takes no arguments. Exemple: -- Close the blind with the device ID of 94 fibaro:call(94, "close") open Application pour : blind Description: Opens a blind. Usage: This action takes no arguments. Exemple: -- Open the blind with the device ID of 94 fibaro:call(94, "open") pressButton Application pour : virtual_device Description: Triggers a virtual device button press. Usage: This action takes one argument. The number of the button to be pressed. Each element of a virtual device has a unique number starting from 1. If your virtual device has two labels followed by two buttons, the buttons will be numbered 3 and 4. Exemple: -- Trigger a button press of button 3 of -- the virtual device with an ID of 358 fibaro:call(358, "pressButton", "3") sendDefinedEmailNotification Application pour : HC_user Description: Sends a notification to the email address associated with a user. Usage: This action takes one argument. The id of the notification to be sent. Exemple: 1-- Send notification 2 via email to the -- address associated with user 107. fibaro:call(107, "sendDefinedEmailNotification", "2") sendDefinedPushNotification Application pour : iOS_device Description: Sends a push notification to a device. Usage: This action takes one argument. The id of the notification to be sent. Exemple: -- Send notification 2 via push to modile device number 10. fibaro:call(10, "sendDefinedPushNotification", "2") sendDefinedSMSNotification Application pour : HC_user Description: Sends an SMS notification to a phone number. Usage: This action takes two arguments. The phone number to send the message to.This should be in the form xxyyyyyyyyy where xx = country code and yyyyyyyyy = phone number. The id of the notification to be sent. Exemple: -- Send notification 3 via SMS to device number +441234567890. fibaro:call(2, "sendDefinedSMSNotification", "441234567890", "3") sendEmail Application pour : HC_user Description: Sends an email to the email address associated with a user. Usage: This action takes two arguments. The subject of the email. The message body of the email. Exemple: -- Send an email to the email address associated with user 2. local subject = "This is the subject of the email." local message = "This is the body of the email.\nWith a line break." fibaro:call(2, "sendEmail", subject, message) sendPhotoToEmail Application pour : IP_camera Description: Sends a still image from a camera to a specified email address. Usage: This action takes one argument. The email address to send the image to. Exemple: -- Send an image from camera 120 to someone@this.address. fibaro:call(120, "sendPhotoToEmail", "someone@this.address") sendPhotoToUser Application pour : IP_camera Description: Sends a still image from a camera to the email address associated with a user. Usage: This action takes one argument. The id number of the user to send the image to. Exemple: -- Send an image from camera 120 to -- the email address associated with user 2. fibaro:call(120, "sendPhotoToUser", "2") sendPush Application pour : iOS_device Description: Sends a push notification to an iOS device. The device must have connected with the Home Centre recently, however once this connection has been made the app can be closed. Usage: This action takes one argument. The message to be pushed to the device. Exemple: -- Send a push notification to the iOS device with the ID of 10 fibaro:call(10, 'sendPush', 'This is the message to be pushed.') setArmed Application pour : motion_sensor, door_sensor, window_sensor, smoke_sensor Description: Arms or disarms a device. Usage: This action takes one argument. The armed state of the device. 0 = disarmed, 1 = armed. Exemple: -- Arm the door sensor with device ID of 174 fibaro:call(174, "setArmed", "1") -- Disarm the door sensor with device ID of 174 fibaro:call(174, "setArmed", "0") setB Application pour : rgb_driver Description: Sets the brightness of the blue channel of an rgb_driver. Usage: This action takes one argument. The brightness (0-99) of the channel. Exemple: -- Set the brightness of the blue channel of device 81 to 56% fibaro:call(81, "setB", "56") setColor Application pour : rgb_driver Description: Sets the colour of an rgb_driver. This is done by setting the brightness of the red, green, blue and white channels. Usage: This action takes four arguments. The brightness (0-99) of the red channel. The brightness (0-99) of the green channel. The brightness (0-99) of the blue channel. The brightness (0-99) of the white channel. Even if the device is in RGB mode, the white channel needs to be specified – in this case, just use 0. Exemple: -- Set the colour of device 81 to a blue-indigo colour -- (60% red, 23% green, 99% blue, 0% white) fibaro:call(81, "setColor", "60", "23", "99", "0") setG Application pour : rgb_driver Description: Sets the brightness of the green channel of an rgb_driver. Usage: This action takes one argument. The brightness (0-99) of the channel. Exemple: -- Set the brightness of the green channel of device 81 to 56% fibaro:call(81, "setG", "56") setProperty Application pour : virtual_device Description: Sets value of the elements of a virtual device (labels and sliders). Usage: This action takes two arguments. The name of the element. The value to set the element to. Exemple: -- Set the content of Label1 in virtual device 1170 to 'program 1' fibaro:call(1170, "setProperty", "ui.Label1.value", "program 1") -- Set the value of Slider1 in virtual device 1170 to 45 fibaro:call(1170, "setProperty", "ui.Slider1.value", "45") setR Application pour : rgb_driver Description: Sets the brightness of the red channel of an rgb_driver. Usage: This action takes one argument. The brightness (0-99) of the channel. Exemple: -- Set the brightness of the red channel of device 81 to 56% fibaro:call(81, "setR", "56") setSlider Application pour : virtual_device Description: Triggers a change in the value of a virtual device slider. Usage: This action takes two arguments. The number of the slider to be changed. Each element of a virtual device has a unique number starting from 1. If your virtual device has two labels followed by two buttons and then a slider, the slider will be numbered 5. The value (0-99) to set the slider to. Exemple: -- Set the slider with an ID of 2 of the -- virtual device with an ID of 334 to 50% fibaro:call(334, "setSlider", "2", "50") setTargetLevel Application pour : thermostat_setpoint Description: Sets the target temperature of a thermostat_setpoint. Usage: This action takes one argument. A temperature in degrees. Exemple: -- Set the target temperature of device 117 to 18 degrees. fibaro:call(117, "setTargetLevel", "18") setTime Application pour : thermostat_setpoint Description: Sets the value of the timeStamp property of the thermostat_setpoint. Usage: This action takes one argument. A timestamp. Exemple: -- Set the timeStamp of the thermostat_setpoint -- with device ID of 117 to 2 hours from now. fibaro:call(117, "setTime", tonumber(os.time()) + 120*60) setValue Application pour : dimmable_light, blind, rgb_driver Description: Sets the brightness of a dimmable_light or rgb_driver or sets the position of a blind. When changing the brightness of rgb_drivers, all channels are set to the same level (white light). Usage: This action takes one argument. A value (0-99) representing the brightness of the light or position of the blind. For a blind, 0 = fully closed, 99 = fully open. Exemple: -- Set the brightness of the light with device ID of 68 to 25%. fibaro:call(68, "setvalue", "25") -- Set the position of the blind with the device ID of 94 to 75% open. fibaro:call(94, "setvalue", "75") setW Application pour : rgb_driver Description: Sets the brightness of the white channel of an rgb_driver. Usage: This action takes one argument. The brightness (0-99) of the channel. Exemple: -- Set the brightness of the white channel of device 81 to 56% fibaro:call(81, "setW", "56") startProgram Application pour : rgb_driver Description: Instruct the rgb_driver to play one of the preconfigured colour programmes. Usage: This action takes one argument. The light programme number to run. Exemple: -- Start programme number 2 ("storm") on device number 81 fibaro:call(81, "startProgram", "2") stop Application pour : blind Description: Stops the movement of a blind. Usage: This action takes no arguments. Exemple: -- Stop the blind with the device ID of 94 fibaro:call(94, "stop") turnOff Application pour : binary_light, dimmable_light, rgb_driver Description: Turns off a device. Usage: This action takes no arguments. Exemple: -- Turn off device number 58. fibaro:call(58, "turnOff") turnOn Application pour : binary_light, dimmable_light, rgb_driver Description: Turns on a device. Usage: This action takes no arguments. Exemple: -- Turn on device number 58. fibaro:call(58, "turnOn") 6
pepite Posté(e) le 3 novembre 2016 Signaler Posté(e) le 3 novembre 2016 Merci @mprinfo Très bonne idée.
mprinfo Posté(e) le 3 novembre 2016 Auteur Signaler Posté(e) le 3 novembre 2016 j'attends @jojo pour la traduction
Berale64 Posté(e) le 3 novembre 2016 Signaler Posté(e) le 3 novembre 2016 On voit qu'il fait froid dans l'Est. On est mieux au chaud derrière l'ordi. Bravo. Joli boulot. 1
Berale64 Posté(e) le 3 novembre 2016 Signaler Posté(e) le 3 novembre 2016 On peut compléter avec ceci: Les commandes en noir ne réponde pas àfibaro:call mais àl'API "callAction" dont on trouve un bon descriptif ici: http://tutoriels.domotique-store.fr/content/49/45/fr/api-commander-le-home-center-par-des-requ%C3%AAtes-http.html
sebcbien Posté(e) le 4 novembre 2016 Signaler Posté(e) le 4 novembre 2016 beau boulôt, merci MPR !!! 1
Peter Posté(e) le 5 novembre 2016 Signaler Posté(e) le 5 novembre 2016 super tuto j'épingle en favoris cela fera un pense bête merci MPR
Fanou Posté(e) le 8 novembre 2016 Signaler Posté(e) le 8 novembre 2016 Super. Cool merci Envoyé de mon SM-G928F en utilisant Tapatalk
jojo Posté(e) le 11 novembre 2016 Signaler Posté(e) le 11 novembre 2016 je suis content de passer en revue tous les posts non encore lus. Heureusement que j'ai vu celui-ci ! Merci
Twentycents Posté(e) le 9 décembre 2019 Signaler Posté(e) le 9 décembre 2019 oh Yeahhhhhh je me faisais chier avec les sendpushdefinednitifcations.... mais là avec le send push je suis chaud.... c'est 100 fois mieux ! bcp plus facile à gérer ! oh je suis content.... je vais revoir mon pleind e truc ! LUA en force quand meme merci pour l'article !
Twentycents Posté(e) le 9 décembre 2019 Signaler Posté(e) le 9 décembre 2019 --[[ Lumière du séjour --]] local startSource = fibaro:getSourceTrigger(); if ( tonumber(fibaro:getValue(171, "value")) > 0 ) or ( tonumber(fibaro:getValue(166, "value")) > 0 ) then fibaro:call(531, "sendPush", "Une des lumières du séjour est allumée"); --fibaro:call(293, "sendDefinedPushNotification", "31"); ça change tout ! en plus j'ai fais un OR pooooop poooop pooooop @Nico je fais pas que du bloc maintenant LOOOL :p 1
