LA nouvelle version stable est sortie il y a quelque minutes.
 Software Changes List 4.090:
Version 4.090
This update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.
Important!
Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.
Resolved issues:
- #0003578 Danfoss thermostat shows unreal value
- #0003883 No reports from Northq Gas Meter NQ-92021
- Update progress bar stops on 30%
- Virtual Device code works after device deletion
- Satel sensors do not report lastBreached value
- #0003605 #0003962 #0003962 Weather is not updating (weather information provider changed to yr.no)
- Trigger information is brought back to the way it operated in 4.080
- #0003094 Alarm panel doesn't record change of alarm state
- #0003958 Virtual Device main loop hangs
- #0003303 Remote Gateway synchronization moves devices to Unassigned
- Protection Command Class not working on devices without template
- 503 error when deleting section in some cases
- Malfunction of RGBW when changing controlled device to RGB
- NaN displayed in device serial number
- Scene Activation not working when triggered multiple times by the same id
- Mobile applications: Change of devices order not possible for non-admin users
- Philips Hue plugin does not allow new user configuration. Reinstall existing plugin to enable fix
- Wind speed available in weather conditions computed incorrectly - value too low
- Services Restart called from 503 error page not working
- Multiple Virtual Devices working simultaneously may cause 503 error
- Virtual Devices hang
- Scenes do not trigger when RAM usage is above 75%. Threshold moved to 90%
- Device hierarchy not displaying properly for Dimmer 2 in advanced configuration
- FIBARO Swipe imported by Gateway Connection not working properly
- Z-Wave Weather templates lacking for devices of other manufacturers
New devices support:
- #0003488 Aeon Labs Multisensor GEN 5
- #0003244 Zwave.me Keyfob GEN 5
- MCO MH10 PM2.5 Monitor
- MCO MH9 CO2 Monitor
- Aspire RF9518
- Aspire RF9534
- Aspire RF9536
- Leviton VRI06-1L
- Leviton VRI10-1L
- Leviton VRE06-1L
- Leviton VRF01-1L
- Leviton VRS15-1L
- Leviton VRS05-1L
- Leviton VRCS2-MR
- Leviton VRCS4-MR
- Leviton VRCZ4-MR
- Leviton VRCZ4-MO
- Leviton VRCS1-1L
- Leviton VRCZ1-1L
- Vitrum Think Simple IV Scenari
- Secure SWM301
Other improvements:
- Battery devices now work on default wake up interval when included
- Serial number is now displayed in advanced configuration of devices that declare it
- Setpoint thermostats capabilities are flexibly adapted when device is included
- Added support for Fibaro Button
- #0003844 Confirmation pop-up is now displayed when restoring or deleting backup
- Favicon added
- Satus bar is scrolled with page
- Notification Center is available directly on the status bar
- Firmware Update - wireless update of Z-Wave devices: Motion Sensor, Dimmer and Wall Plug. Availability of update for each device is showed in Notification Center and Advanced Configuration. Run update only when devices is in close range from controller (ca. 2 m). Process can take up to 30 minutes, depending on Z-Wave traffic and devices queued for update. Details on whole procedure can be found in notification displayed before every device update.
- #0001660, 0003525 Shutdown and reboot actions available from Lua scene, more information can be found on developer.fibaro.com
- New, configurable scenes triggering modes available in each scene advanced configuration:
Automatic - scene gets triggered either by one of defined triggers (device state, global variable etc.) or manually, by 'Run' button
Manual - scene executes only manually by 'Run' button
Disabled - scene is inactive, does not get triggered and cannot be run manually
Visibility - scene can be hidden in all interfaces (mobile apps, web interface)
In connection to this change there are new Lua API functions, more information can be found on developer.fibaro.com
- Other minor fixes
ben pas moi ... restée bloquée à  10% j'ai tenté un simple refresh de safari et il a mis un temps dingue à  redémarrer mais maintenant à  première vue ça marcherait
Hi all
Mise à  jour effectuée
Pour moi, comme d'habitude RAS, tout est OK
Bonne soirée à  vous tous
  Le 07/07/2016 à 14:58, anthonylegrec a dit :
Par contre l'update notifier
http://www.domotique-fibaro.fr/index.php/topic/698-update-notifier-gardez-votre-hc2-fibaro-%C3%A0-jour/
Ne m'a pas averti de la mise a jour...
Quelqu'un d'autre a eu ce souci?
J'imagine un blocage du VD :( Tu viens de quelle version de HC2 ?
Bon comme dab, je clic et je reviens dans 1h et espèrent que le chat ne vas pas bugué
  Le 07/07/2016 à 17:11, Krikroff a dit :
J'ai eu le même soucis j'étais en 4.083
  Le 07/07/2016 à 17:58, mprinfo a dit :
Pas de problème de mon côté
Mais d'une installation àl'autre ... Et sans clairement en identifier la cause !
Envoyé de mon smartphone
Cette nouvelle stable m'a l'air d'être la v4.083 beta rebadgée en stable, je ne vois aucune nouveauté dans le changelog.
Je l'installerai demain je pense.
