Bonjour a vous , j'ai essayé de mettre cet code en LUA  dans ma HC2 (vers 4.080) avec l'aide de IFTTT si il y'a une porte/fenêtre ouverte , on peut couper la chaleur tant qu'une porte ou fenêtre est ouverte .
239 value   --here you add your sensor ID and the word value. This section is checking for changes in the    			 --value field for your sensors to start below code. I am using 3 door/window sensors
%% globals
local PorteCuisine  --defining variables for window sensor
local NestSetpoint
local param1
local key
PorteCuisine = fibaro:getValue(239, 'value') --this will pull a current state(value) of the sensor
											  --1 is on and 0 is off
NestSetpoint = fibaro:getValue(111, "setpointTemp2")  --this is a current temperature you have set on Nest
if (PorteCuisine == '1') then
	param1 = "17"  --this is the termperature you want to be set when windows/door are open
if (PorteCuisine == '0') then
	fibaro:debug(NestSetpoint)
  	param1 = NestSetpoint    -- once all door/windows are closed, temperature will be set to previous set.
	fibaro:debug(param1)
         --this section is used to send command to IFTTT with required Nest temperature
        key = "GWG27en7Bm6x5UHaAxOF6"  --use your key from the Maker channel on IFTTT
	function PushData(key, event, param1)
	local httpClient = net.HTTPClient({ timeout = 2000 });
	local url = 'https://maker.ifttt.com/trigger/set_nest_temperature/with/key/'..key..'?value1='..param1;
	--debug url
	print(url);
	httpClient:request(url, {
	success = function(response)
		if tonumber(response.status) == 200 then
			print("Updated at " .. os.date());
		else
			print("Error " .. response.status)
	end,
	error = function(err)
	print('error = ' .. err)
	end,
	options = {
	method = 'GET'
	PushData(key, event, param1);
[DEBUG] 13:41:32: 17
[DEBUG] 13:41:32: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=17
[DEBUG] 13:41:33: Updated at Sat Mar 26 13:41:33 2016
[DEBUG] 13:45:42: 23
[DEBUG] 13:45:42: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=23
[DEBUG] 13:45:43: Updated at Sat Mar 26 13:45:43 2016
[DEBUG] 13:46:10: 23
[DEBUG] 13:46:10: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=23
[DEBUG] 13:46:10: Updated at Sat Mar 26 13:46:10 2016
[DEBUG] 14:52:14: 23
[DEBUG] 14:52:14: 17
[DEBUG] 14:52:14: https://maker.ifttt.com/trigger/set_nest_temperature/with/key/GWG27en7Bm6x5UHaAxOF6?value1=17
[DEBUG] 14:52:15: Updated at Sat Mar 26 14:52:15 2016
 le problème est que j'ouvre ou je ferme la porte rien qui se passe sur Nest,
Es-ce que quelqu'un d'entre vous a une idée ...
Merci d'avance
