Krikroff
merci i-magin ;) mais ça ne marche pas pour moi qui utilise que la partie TTS, d'ailleurs si qqle un à  une idée je l'a prends avec plaisir ;)  :2:  :77:
Voici le code entier et on peut voir qu'a la ligne 260 j'ai remplacer par ce que tu as mis plus haut.
-- SONOS Text To Speech (TTS) - Give voice to your HC2 with SONOS wireless speakers
-- Version 0.0.4 pre-release
-- Copyright © 2014 Jean-Christophe Vermandé
selfId = fibaro:getSelfId();
ip = fibaro:get(selfId, 'IPAddress');
port = fibaro:get(selfId, 'TCPPort');
currentTransportState = "";
lastTransportState = "";
currentVolume = 0;
lastVolume = 0;
ttsVolumeIsDifferent = false;
urlencode = function(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n");
    str = string.gsub (str, "([^%w ])", function (c) return string.format ("%%%02X", string.byte(c)) end);
    str = string.gsub (str, " ", "+");
  return str;
createRequestBody = function(action, schema, data)
  return string.format("<u:%s xmlns:u=\"%s\">%s</u:%s>", action, schema, data, action);
reponseCallback = function(fnc, args)
  if (fnc == nil) then
    return nil;
  return fnc(args);
createSocket = function()
    -- Check IP and PORT before
  if (ip == nil or port == nil) then
    fibaro:debug("You must configure IPAddress and TCPPort first");
    return;
  local socket;
  local status, err = pcall(function()
      socket = Net.FTcpSocket(ip, port);
      socket:setReadTimeout(1000);
    end);
  if (status ~= nil and status ~= true) then
    fibaro:debug("socket status: " .. tostring(status or ''));
  if (err ~= nil) then
    fibaro:debug("socket err: " .. tostring(err or ''));
    return;
  return socket;
disposeSocket = function(socket)
  if (socket ~= nil) then
    socket:disconnect();
    socket = nil;
    return true;
  return false;
sendSoapMessage = function(url, service, action, args, callback, retry)
  local socket = createSocket();
  if (socket == nil) then
    return;
  retry = retry or 0
  -- prepare data
  local url = "POST " .. url .. " HTTP/1.1";
  local soapaction = "SOAPACTION: \"" .. service .. "#" .. action.name .. "\"";
  local body = createRequestBody(action.name, action.service, tostring(args or ""));
  local envelope = "<?xml version=\"1.0\" encoding=\"utf-8\"?><s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\"><s:Body>" .. body .. "</s:Body></s:Envelope>";
  local ctl = "Content-Length: " .. string.len(envelope);
  local payload = url .. "\r\n" .. ctl .. "\r\n" .. soapaction .. "\r\n" .. "\r\n" .. envelope;
  -- write data
  local bytes, errorcode = socket:write(payload);
  if (errorcode == 0) then
    local state, errorcode = socket:read();
      if (string.len(state or "") > 0) then
        -- callback
        if (callback ~= nil) then
          reponseCallback(callback, state);
        -- dispose ...
        disposeSocket(socket);
        return true;
      else
        fibaro:debug("Error: Invalid response. response length: " .. string.len(state or ""));
    else
      if (retry < 5) then
        fibaro:debug("retry #"..retry.." action: " .. action.name);
        return sendSoapMessage(url, service, action, args, callback, (retry + 1));
      else
        fibaro:debug("Error: Code returned "..tostring(errorcode or ""));
  elseif (errorcode == 2) then
    fibaro:debug("Error: You must check your IP and PORT settings.");
  else
    if (retry < 5) then
    else
  -- dispose ...
  -- default response
  return false;
stop = function()
    -- control url
    "/MediaRenderer/AVTransport/Control",
    -- service type
    "urn:schemas-upnp-org:service:AVTransport:1",
    -- action
    { name = "Stop", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    -- soap body data (options)
    "<InstanceID>0</InstanceID><Speed>1</Speed>",
      -- callback (options)
    function(response)
      fibaro:debug("stop sent");
    end);
unMute = function()
    -- control url
    "/MediaRenderer/RenderingControl/Control",
    -- service type
    "urn:schemas-upnp-org:service:RenderingControl:1",
    -- action
    { name = "SetMute", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel><DesiredMute>0</DesiredMute>",
    function(response)
      fibaro:debug("unMute sent");
    end);
play = function(duration)
    -- control url
    -- service type
    -- action
    { name = "Play", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    function(response)
      if (duration ~= nil) then
        fibaro:debug("play sent for " .. duration .. " seconds");
        fibaro:sleep(duration);
        stop();
      else
        fibaro:debug("play sent");
        local n = 0;
        currentTransportState = "TRANSITIONING";
        while (currentTransportState == "TRANSITIONING") do
          if (n > 10) then break end;
          getTransportState();
          fibaro:debug(currentTransportState);
          fibaro:sleep(5000);
          n = n + 1;
        local i = 0;
        currentTransportState = "PLAYING";
        while (currentTransportState == "PLAYING") do
          if (i > 10) then break end;
          fibaro:sleep(2000);
          i = i + 1;
        fibaro:sleep(1000);
        stop();
      -- update volume with value before tts if different
      if (ttsVolumeIsDifferent == true) then
          setVolume(lastVolume);
    end);
setVolume = function(value)
    -- control url
    -- service type
    -- action
    { name = "SetVolume", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>" .. tostring(value) .. "</DesiredVolume>",
    function(response)
      fibaro:debug("Volume set: " .. value);
    end);
getVolume = function()
  fibaro:log("Get volume, please wait...");
    -- control url
    -- service type
    -- action
    { name = "GetVolume", service = "urn:schemas-upnp-org:service:RenderingControl:1" },
    "<InstanceID>0</InstanceID><Channel>Master</Channel>",
    function(response)
      currentVolume = tonumber(response:match("<CurrentVolume>(.+)</CurrentVolume>") or 0);
    end);
getTransportState = function()
    -- control url
    -- service type
    -- action
    { name = "GetTransportInfo", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    "<InstanceID>0</InstanceID>",
    function(response)
      currentTransportState = response:match("<CurrentTransportState>(.+)</CurrentTransportState>") or "";
    end);
playTTS = function(lng, message, duration, volume)
    -- control url
    -- service type
    -- action
    { name = "SetAVTransportURI", service = "urn:schemas-upnp-org:service:AVTransport:1" },
    --"<InstanceID>0</InstanceID>,<CurrentURI>x-rincon-mp3radio://translate.google.com/translate_tts?tl=".. lng .. "&a" .. "mp;q=" .. urlencode(message) .. "</CurrentURI>,<CurrentURIMetaData></CurrentURIMetaData>",
    "<InstanceID>0</InstanceID>,<CurrentURI>x-rincon-mp3radio://translate.google.com/translate_tts?ie=UTF-8,client=t".."&a".."mp;tl=".. (lng or "fr") .. "&a" .. "mp;q=" .. (urlEncode(message or "") or "message") .. "</CurrentURI><CurrentURIMetaData>"..Sonos:createMetaData("TSS by Google...").."</CurrentURIMetaData>",
    function(response)
      -- retrieve current transport state
      lastTransportState = currentTransportState;
      -- unmute before
      unMute();
      -- retrieve volume
      getVolume();
      lastVolume = currentVolume;
      -- set tts volume if <> with current
      if (volume ~= nil and volume ~= currentVolume) then
          setVolume(volume);
        ttsVolumeIsDifferent = true;
      -- play tts
      fibaro:debug("tts: " .. message);
        play(duration);
      else
        play();
    end);
playTTS("fr", "Attention, les volets du sejour et de la cuisine vont se fermer", nil, 50);
J'ai partagé ma bidouille dès que j'ai constaté le bon fonctionnement, mais en précisant que c'était "dans l'attente du retour de @Krikroff"  ;)
Ensuite,  j'ai constaté que j'aurais peut-être dà» proposer ce code :
"<InstanceID>0</InstanceID><CurrentURI>x-rincon-mp3radio://translate.google.com/translate_tts?ie=UTF-8".."&a".."mp;client=".."t" .."&a".."mp;tl=".. (lng or "fr") .. "&a" .. "mp;q=" .. (urlEncode(message or "") or "message") .. "</CurrentURI><CurrentURIMetaData>"..Sonos:createMetaData("TSS by Google...").."</CurrentURIMetaData>",
Mais je vous propose d'attendre @Krikroff qui va nous donner la bonne solution...
@Rocketlud, je ne connaissais pas le code de @Krikroff que tu présentes ... une ancienne version TTS avant son module virtuel ?
Je suppose :
- qu'il fonctionnait avant la modification de Google qui exige un code "captcha" ?
- que tu as lancé le débogage ?
Tu peux essayer ceci :
"<InstanceID>0</InstanceID>,<CurrentURI>x-rincon-mp3radio://translate.google.com/translate_tts?client=".."t" .."&a".."mp;tl=".. lng .. "&a" .. "mp;q=" .. urlencode(message) .. "</CurrentURI>,<CurrentURIMetaData></CurrentURIMetaData>",
  • Upvote 2
LOL, sorry Pascal, j'avais pas compris que la question était pour moi   :3:
Je l'ai trouver sur le fofo, mais je ne sais plus ou , trop de soleil dans le nord, on a pas l'habitude, ça chauffe trop le cerveau  :2:
  • 3 semaines après...
@jojo:
Bon après recherche, rebelote ce matin.
Effectivement, c'est j'ai des soucis avec le wifi de ma freebox qui "disparait" de temps àautre donc les Sonos étaient déconnectés.
Prochaine étape: créer un script qui vérifie que le réseau wifi est ok et sinon rédémarrer automatiquement la FB.
J'utilise le PCL pour imprimer sur mon imprimante laser, mais j'ai jamais testé sur les Sonos :94:
Plus sérieusement, ce qui est génial avec les Sonos c'est qu'on a le choix Wifi ou Ethernet, et clairement le fil ça change la vie. Puisque j'en parle, même mon imprimante fonctionne beaucoup mieux depuis qu'elle est en filaire. Le Wifi c'est bien pour les appareils mobiles, mais peu adapté aux équipements fixes, et encore moins aux équipements qui doivent échanger une grosse quantité de données (PC qui télécharge, webcam, pc home-cinéma, sonos).
En plus avec les Sonos, une fois câblé en filaire, on peut désactiver la gestion du Wi-Fi, ils ont pensé à  tout !
@sakkhho, vu que rems ne veut pas te répondre  ;)  je te dis oui le tts fonctionne bien sur le playbar et la qualité du playbar est bonne vu son faible encombrement.
@benji, yes un support mural existe pour la playbar environ 50€
