igstik Posté(e) le 5 octobre 2015 Signaler Partager Posté(e) le 5 octobre 2015 Hello. I'm from Russia, and most do not speak French. I really would like to be a full member of the Forum, but I couldn't figure out how to do it. I myself am engaged in industrial automation, and now at home I have set fibaro + HC2.Want to explore possible solutions and examples of programming in this area.What you need to do to become a member of the Forum, not visitor. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Berale64 Posté(e) le 6 octobre 2015 Signaler Partager Posté(e) le 6 octobre 2015 Hello igstik Welcome on the Domotique-Fibaro forum. You can participate to our forum in the english section here : http://www.domotique...nglish-section/ You can ask all your questions and also share your experience. On the right side, use the button "commencer un sujet" to start a new topic. Here some rules of the forum: (This is a google translate page) https://translate.google.com/translate?sl=fr&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fwww.domotique-fibaro.fr%2Findex.php%2Ftopic%2F56-r%25C3%25A8gles-%25C3%25A0-respecter%2F&edit-text= Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Moicphil Posté(e) le 6 octobre 2015 Signaler Partager Posté(e) le 6 octobre 2015 Hi! Welcome on this board. This forum is in French, but you can start a topic in " : > English Section Useful links : > La Home Center pour les nuls ! > Index des tutos du forum > Envie de décrire et partager votre installation ou projet ? c'est ici For help questions, thank you for posting in categories "Support". Good read on Domotique-Fibaro.fr Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
igstik Posté(e) le 13 octobre 2015 Auteur Signaler Partager Posté(e) le 13 octobre 2015 Thank you very much. If I appear interesting stuff, then I'll be here will spread.But so far only learn) Merci beaucoup. Si je me présente des choses intéressantes, alors je vais être là se propage. Mais jusqu'à présent seulement apprendre) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
