jojo Posté(e) le 9 septembre 2015 Signaler Posté(e) le 9 septembre 2015 en fait je crois que je n'ai pas reçu le bon son. Celui qu'il me faudrait est celui du device "WXT Clim Panel", le dernier de ta capture d'écran.
CharlesO Posté(e) le 10 septembre 2015 Auteur Signaler Posté(e) le 10 septembre 2015 {"id":52, "name":"ZXT Clim Panel", "roomID":20, "type":"com.fibaro.setPoint", "baseType":"com.fibaro.hvac", "enabled":true, "visible":true, "isPlugin":false, "parentId":51, "remoteGatewayId":0, "interfaces":["battery", "zwave", "zwaveSwitchAll"], "properties":{"parameters":[{"id":25, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}, {"id":26, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}, {"id":27, "lastReportedValue":471, "lastSetValue":471, "size":2, "value":471}, {"id":28, "lastReportedValue":255, "lastSetValue":255, "size":1, "value":255}, {"id":32, "lastReportedValue":255, "lastSetValue":255, "size":1, "value":255}, {"id":33, "lastReportedValue":1, "lastSetValue":1, "size":1, "value":1}, {"id":35, "lastReportedValue":0, "lastSetValue":0, "size":4, "value":0}, {"id":37, "lastReportedValue":0, "lastSetValue":0, "size":1, "value":0}], "zwaveCompany":"Remotec Technology Ltd", "zwaveInfo":"6,3,42", "zwaveVersion":"1.12", "pollingTimeSec":0, "batteryLevel":"0", "batteryLowNotification":"true", "configured":"true", "dead":"false", "defInterval":"0", "deviceControlType":"0", "deviceIcon":"71", "emailNotificationID":"0", "emailNotificationType":"0", "endPointId":"0", "liliOffCommand":"", "liliOnCommand":"", "log":"", "logTemp":"", "manufacturer":"", "markAsDead":"true", "maxInterval":"0", "minInterval":"0", "mode":"2", "model":"", "nodeId":"6", "parametersTemplate":"417", "productInfo":"82,84,1,1,131,119,1,12", "pushNotificationID":"0", "pushNotificationType":"0", "remoteGatewayId":"0", "saveLogs":"true", "smsNotificationID":"0", "smsNotificationType":"0", "stepInterval":"0", "supportedModes":"1,2,8,10", "switchAllMode":"SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", "targetLevel":"23.00", "unit":"C", "useTemplate":"true", "userDescription":"", "value":"23.00"}, "actions":{"reconfigure":0, "setInterval":1, "setSetpointMode":1, "setThermostatSetpoint":2}, "created":1440263369, "modified":1440263369, "sortOrder":99} Salut et merci !!!! Le voila :
CharlesO Posté(e) le 10 septembre 2015 Auteur Signaler Posté(e) le 10 septembre 2015 Mais Jojo comme je te l ai dit plus haut je n ai pas de problem au niveau du zxt car je peut ajouter une scene en utilisant les blocs graphiques mais le probleme est sur le nest car je ne peut pas cree de scene avec lui je voudrais choisir une temperature et un mode apartire du nest et que le fibaro l execute merci Jojo
jojo Posté(e) le 10 septembre 2015 Signaler Posté(e) le 10 septembre 2015 c'est clair qu'en mode bloc ce ne sera pas possible, mais en LUA on devrait y arriver
jojo Posté(e) le 10 septembre 2015 Signaler Posté(e) le 10 septembre 2015 Dans un premier temps, je te propose ceci pour voir si on peut commenter le setpoint de ton ZXT par LUA local zxt120_ID = 52 local SetPoint = 50 local HC2 = Net.FHttp("127.0.0.1",11111) -- préparation du nouveau json NewJson = '{"properties":{"value":'..SetPoint..'"}}' -- écriture du nouveau json -- écriture du nouveau json payload = "/api/devices/" ..zxt120_ID HC2:PUT(payload, NewJson) Ton ZXT devrait avoir la valeur mise dans la variable SetPoint (ici 50°C). Essaie avec différentes valeurs et vois ce que ça donne
CharlesO Posté(e) le 10 septembre 2015 Auteur Signaler Posté(e) le 10 septembre 2015 Jojo pourquoi on regle pas le probleme du nest en premier lieu ? c est juste une question
jojo Posté(e) le 10 septembre 2015 Signaler Posté(e) le 10 septembre 2015 je suis très confiant sur le fait que je puisse récupérer la valeur de consigne du Nest. De plus, j'en ai un chez moi, donc c'est facile pour moi de faire les tests. Par contre transférer cette valeur au ZXT, c'est moins clair pour moi, surtout que je n'en ais pas pour essayer ...
CharlesO Posté(e) le 10 septembre 2015 Auteur Signaler Posté(e) le 10 septembre 2015 ok bos pour le test donc je cree une scene en lua ou je rajout juste apres les 4 lignes par defaut, les tienes c est ca ? comment je verifie si ca marche ?
jojo Posté(e) le 10 septembre 2015 Signaler Posté(e) le 10 septembre 2015 tu ne crées pas une scène, mais un nouveau device virtuel. dans de DV, tu crées un bouton et tu y mes le code. Tu sauves. Et quand tu cliques sur le bouton, la température de consigne devrait être de 50°C sur ton ZXT. Tu peux faire différents tests avec différentes valeurs (en modifiant la variable SetPoint du DV) et tu vois si ton ZXT réagit comme attendu.
CharlesO Posté(e) le 10 septembre 2015 Auteur Signaler Posté(e) le 10 septembre 2015 ok ca marche a moitié ca change sur le label mais pas sur le combo box du module et donc n envoi pas l instruction au module
jojo Posté(e) le 10 septembre 2015 Signaler Posté(e) le 10 septembre 2015 sais-tu m'envoyer un screenshot (après avoir appuyé sur le bouton) pour que je visualise bien ainsi que le son (également après avoir appuyé sur le bouton)
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "50.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } le json
jojo Posté(e) le 11 septembre 2015 Signaler Posté(e) le 11 septembre 2015 cool, il me semble que avance. Essaie ceci, j'ai mis la consigne à48°C local zxt120_ID = 52 local SetPoint = 48 local HC2 = Net.FHttp("127.0.0.1",11111) -- préparation du nouveau json NewJson = '{"properties":{"value":'..SetPoint..'"}}' -- écriture du nouveau json -- écriture du nouveau json payload = "/api/devices/" ..zxt120_ID HC2:PUT(payload, NewJson) -- préparation du nouveau json NewJson = '{"properties":{"tagetLevel":'..SetPoint..'"}}' -- écriture du nouveau json -- écriture du nouveau json payload = "/api/devices/" ..zxt120_ID HC2:PUT(payload, NewJson) tu appuyes sur le bouton et me renvoie les même infos (photo + json) et tant qu'àfaire, tu me dis si ton ZXT àbien enclenché le chauffage ?
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "48.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } voila pour le json mais ca na pas envoyer l instruction a mon climatiseur
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 et voila la capture
jojo Posté(e) le 11 septembre 2015 Signaler Posté(e) le 11 septembre 2015 Je vient de voir une faute de frappe tagetLevel, au lien de targetLevel local zxt120_ID = 52 local SetPoint = 15 local HC2 = Net.FHttp("127.0.0.1",11111) -- préparation du nouveau json NewJson = '{"properties":{"value":'..SetPoint..'"}}' -- écriture du nouveau json -- écriture du nouveau json payload = "/api/devices/" ..zxt120_ID HC2:PUT(payload, NewJson) -- préparation du nouveau json NewJson = '{"properties":{"targetLevel":'..SetPoint..'"}}' -- écriture du nouveau json -- écriture du nouveau json payload = "/api/devices/" ..zxt120_ID HC2:PUT(payload, NewJson) Peux-tu réessayer avec ce code, le l'ai mis à15°C pour le climatiseur, mais il faudra peux-être également regarder pour modifier le mode climatiseur ou chauffage ?
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 photo et json { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "15.00", unit: "C", useTemplate: "true", userDescription: "", value: "15.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 }
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 ca n a toujours pas envoyer l instruction au boitier pour le chauffage si tu veux plus tard deja la clim c est super si ca marche avec le nest et qu il envoi l instruction
jojo Posté(e) le 11 septembre 2015 Signaler Posté(e) le 11 septembre 2015 d'après la photo tout semble ok. tout est à15°C. Alors regarde si en manuel tu peux commander ton boitier depuis ta Fibaro
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 oui en manuel quand je fais un changement ca fait un bip pour info : le boitier imite le signal de la telecommand et a chaque manipulation il renvoi tout les réglage je veux dire par la que si il était sur froid 22 et je le mes a 24 il envoi et froid et 24 si ca peut t aide merci encore (la il fait le changement dans le fibaro mais ne fait pas de bip donc l instruction n ait pas envoyer)
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 combien coute le zxt-120 chez toi ? et tu peut l avoir en combien de temp ?
jojo Posté(e) le 11 septembre 2015 Signaler Posté(e) le 11 septembre 2015 un zxt-120 coute 80€, et je pourrais l'avoir pour mardi, mais ce serait triste de faire un tel investissement sans garantie de résultat. on pourrait essayer différents json, pour essayer de comprendre 1) consigne en manuel à 24°C, photo json 2) consigne en manuel à 18°C, photo, json 3) consigne à 150C via le dernier code, photo, json
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "24.00", unit: "C", useTemplate: "true", userDescription: "", value: "24.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } a 24 :
CharlesO Posté(e) le 11 septembre 2015 Auteur Signaler Posté(e) le 11 septembre 2015 { id: 52, name: "ZXT Clim Panel", roomID: 20, type: "com.fibaro.setPoint", baseType: "com.fibaro.hvac", enabled: true, visible: true, isPlugin: false, parentId: 51, remoteGatewayId: 0, interfaces: [ "battery", "zwave", "zwaveSwitchAll" ], properties: { parameters: [ { id: 25, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 26, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 }, { id: 27, lastReportedValue: 471, lastSetValue: 471, size: 2, value: 471 }, { id: 28, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 32, lastReportedValue: 255, lastSetValue: 255, size: 1, value: 255 }, { id: 33, lastReportedValue: 1, lastSetValue: 1, size: 1, value: 1 }, { id: 35, lastReportedValue: 0, lastSetValue: 0, size: 4, value: 0 }, { id: 37, lastReportedValue: 0, lastSetValue: 0, size: 1, value: 0 } ], zwaveCompany: "Remotec Technology Ltd", zwaveInfo: "6,3,42", zwaveVersion: "1.12", pollingTimeSec: 0, batteryLevel: "0", batteryLowNotification: "true", configured: "true", dead: "false", defInterval: "0", deviceControlType: "0", deviceIcon: "71", emailNotificationID: "0", emailNotificationType: "0", endPointId: "0", liliOffCommand: "", liliOnCommand: "", log: "", logTemp: "", manufacturer: "", markAsDead: "true", maxInterval: "0", minInterval: "0", mode: "2", model: "", nodeId: "6", parametersTemplate: "417", productInfo: "82,84,1,1,131,119,1,12", pushNotificationID: "0", pushNotificationType: "0", remoteGatewayId: "0", saveLogs: "true", smsNotificationID: "0", smsNotificationType: "0", stepInterval: "0", supportedModes: "1,2,8,10", switchAllMode: "SWITCH_ALL_EXCLUDED_FROM_THE_ALL_ON_ALL_OFF_FUNCTIONALITY", targetLevel: "18.00", unit: "C", useTemplate: "true", userDescription: "", value: "18.00" }, actions: { reconfigure: 0, setInterval: 1, setSetpointMode: 1, setThermostatSetpoint: 2 }, created: 1440263369, modified: 1440263369, sortOrder: 100 } a 18 :
