Plap3014 Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 4.055 Beta Dispo avec beaucoup de mise a jour... Liste des modifications de la version beta 4.055:Version 4.055 BetaWARNING: Beta version is designed for user testing and soon should be released as official.> New Features:Setpoint and other thermostats are now available to use in block scenes and LUA editorNew "Barrier Operator" device type supportWeb interface performance improvements> New Devices Support:Z-Wave Thermostats:2gig CT100 v9.1RCS TBZ48 v1.2RCS TZ45 v2.41Honeywell #TH8320ZW01 v1.3 and v2.0Trane TZEMT400BB32MAA v2.15WEXCEL WT510 v2.4Other Z-Wave devices:Aeon Siren Gen5 v1.23Vision ZS6101EUThink Simple III EU DIMMER Wireless NWE030Modulo II DIN ON-OFF Wireless ZWD020/SLThink Simple III EU ON-OFF Wireless NWE030Think Simple I BS ON_OFF Wireless NWB010Think Simple IV BS ON-OFF Wireless NWB040Think Simple II BS ON/OFF Wireless NWB020Think Simple I BS Satellite Wireless NWB010Think Simple II BS Satellite Tapparelle Wireless NWB020Think Simple II BS Tapparelle Wireless NWB020Think Simple II EU DIMMER Wireless NWE020Think Simple II EU ON/OFF Wireless NWE020Think Simple IV EU ON/OFF Wireless ZWE040Think Simple II EU Satellite Tapparelle Wireless NWE020Think Simple III EU Satallite Wireless NWE030/SSThink Simple II EU Tapparelle Wireless NWE021Linear Garage Door OpenerCameras:HIKVISION IP Camera ds2cd2132iAxisGeoVisionSpecoGEN IVPlugins:Logitech HarmonyNest improvementsNetAtmo improvements> Resolved Issues:#0003434: Number missing in the scale#0003322: 4.047: Vision Security ZM1601 Z-Wave Siren#0003065: 4.037 RAM Graph day of the week wrong.Z-Wave engine stability and other improvementsDSC Alarm support improvementsWeb interface improvements for non-admin usersMagic Scenes editor visual improvementsSMS notifications can now be selected for every device typeEnergy and Temperature Panel improvementsSlider state synchronization in Virtual Devices> Known issues:- Using multichannel associations requires soft reconfiguration of devices- Android version of the Fibaro mobile app does not display icons for following devices properly:- NetAtmo Thermostat- NetAtmo Weather Station- Sonos- Inconsistencies in Satel interface.- Power Metering may not work properly for some devices- Alarm Panel doesn't work in some specific configurations- Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware. There will be added detailed information about supported firmware versions within plugins.- Breached sensor with Arm Delay causes instant alarm after being armed- Data range selection in event panel doesn't work properly- Devices imported via Gateway Connection may have no icons- Gateway Connection status of dead device between master and slave controller may be different- Devices not properly configured on 3.X may not be converted properly- On mobile clients devices may be visible in different categories than configured- Horstmann Thermostat HRT4-ZW higher battery usage in some cases- Doorlocks some functions may not work properly 1
Fredric Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 je viens juste de passer en V4.054, je vous laisse la primeur.
Fredric Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Désolé @Plap3014, j'était en train de créer le même poste et j'avais le copier coller des changement prêt à coller
Lazer Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Une mise àjour qui vise àfond le marché américain ! 1
Plap3014 Posté(e) le 12 août 2015 Auteur Signaler Posté(e) le 12 août 2015 Pas de problème @Frederic, Oui @Lazer! a suivre...
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Plugin Logitech Harmony, tient tient, je vais tester ça moi si j'ai le temps ce soir ! 2
mprinfo Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Les copains lorsque l'on annonce une mise a jour ne pas oublier de mettre le chang log dans le post 1 Merci Envoyé de mon SM-G900F en utilisant Tapatalk 1
Sp0oNy Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @Nico : grave ! Je m'étais dis que je ne mettrais pas cette Beta jusqu'à ce que je lise cette ligne. Donc ce soir, si le test de restauration fonctionne, je passe la beta.
Fredric Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @Plap3014, copie/colle les changements dans ton premier poste et je supprimerai le mien ensuite
mprinfo Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Merci Frédéric Mise a jour en cours chez moi Envoyé de mon SM-G900F en utilisant Tapatalk
mprinfo Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Mise a jour ok chez moi par contre il faut un certain temps à10% je pense qu'ils ont ajouté des tests
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Me fait juste chier de virer et remettre mes plugins persos...
mprinfo Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @nico c'est la même chanson àchanson fois lol Envoyé de mon SM-G900F en utilisant Tapatalk
HANSOLO Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @nico tu devrais faire un copier/coller de tes posts vu la fréquence des maj chez fibaro
Sp0oNy Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @Nico : je vais te faire passer le cap : Gratuit Logitech Harmony Fibar Group S.A. Compatible :iPad, iPhone, Android Phone, Android Tablet, Home Center 2 Version:1.0 Description Control even more devices in your house using Fibaro Home Center plugin for Logitech Harmony Home Hub. Using plugin you can control any devices compatible with Logitech Harmony Home Hub directly from Fibaro Home Center. Plugin allows to excecute any “activity†defined inside Home Hub manually or via Fibaro Home Center scenes. Experience benefits from powerful integration of both platforms.
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Alors ça c'est juste énorme, je suis juste deg, moi j'ai une harmony One... Snif. Tu me feras un retour sur ce que ça donne et qques screens si possible ? HAN et Mprinfo, oui, je sais, je suis lourd, mais bon je déspère qu'un gars de chez Fibaro lise ça et m'entende... D'ailleurs j'ai aussi relancé sur le fofo officiel il y a 10 jours, le topic est un peu parti en vrille du coup
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Mise àjour faite. Par contre vous avez aussi le bug du capteur principale qui est revenu ? C'était corrigé en 4.054 non ?
PITP2 Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Super jsuis concerné au moins par trois améliorations nest , netatmo , hikvison et harmony hub et pour ce dernier j'ai hâte de voir ce qu'ils ont fait car cela va être le pied si cela fonctionne bien
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Tu pourras jeter un oeil aux capteurs principaux, pour voir si c'est bien un retour en arrière ?
PITP2 Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 PAs de problème avec les capteurs principaux Le nest est toujours dans les choux pas de modification possible depuis l'interface Fibaro je vais tenter de supprimer le plugin et le ré installer
PITP2 Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 C'est pire après réinstallation du plugin nest Le device enfant n'est même pas créé ..
mprinfo Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 @nico moi ca me fait rire en plus ça veut dire que tu va bien si tu râles tu es sur que tu as oas des gênes de femme lol Envoyé de mon SM-G900F en utilisant Tapatalk
Nico Posté(e) le 12 août 2015 Signaler Posté(e) le 12 août 2015 Peut être... Pitp2, pige pas pourquoi j'ai le bug là du coup... Peut être parce que je ne suis pas passé par la 4.054. EDIT : Euh je me reconnecte là sur ma box après le repas, et ça fonctionne... Pige pas.
