J'ai toujours 10
J'utilise "centralSceneEvent".
Je vais changer les triggers pour "sceneActivation" pour voir...
Ben non, même pas de declenchement.
Voici les triggers :
{ operator = "any",
  conditions = { { id = 211,
                   isTrigger = true,
                   operator = "==",
                   property = "centralSceneEvent",
                   type = "device",
                   value = { keyAttribute = "Pressed",
                             keyId = 1 } },
                 { id = 211,
                   isTrigger = true,
                   operator = "==",
                   type = "device",
                             keyId = 2 } },
                  { id = 211,
                   isTrigger = true,
                   operator = "==",
                   type = "device",
                             keyId = 3 } },
                 { id = 211,
                   isTrigger = true,
                   operator = "==",
                   type = "device",
                             keyId = 4 } } } }
Je sne que je vais poursuivre tout ca demain, je commence à saturer...
Merci pour cette ligne.
Ca m'a l'air très intéressant, je vais décortiquer...
Demain matin - je n'y arriverai pas ce soir (plus assez clair...)
bon alors c'est pourri, je trouve pas l'équivalent de "anyValue" pour le CentralSceneEvent, mais ça marche bien
dans les trigger : (j'y ai mis tous les cas possibles)
  operator = "any",
  conditions = {
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed", keyId = 1}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed", keyId = 2}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed", keyId = 3}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed", keyId = 4}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Released", keyId = 1}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Released", keyId = 2}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Released", keyId = 3}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Released", keyId = 4}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "HeldDown", keyId = 1}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "HeldDown", keyId = 2}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "HeldDown", keyId = 3}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "HeldDown", keyId = 4}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed2", keyId = 1}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed2", keyId = 2}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed2", keyId = 3}},
      {id = 132, isTrigger = true, operator = "==", property = "centralSceneEvent", type = "device", value = {keyAttribute = "Pressed2", keyId = 4}},
pour exploiter le trigger dans la scène, on peut récupérer les infos comme cela :
print(sourceTrigger.value.keyId.." = "..sourceTrigger.value.keyAttribute)
Résultat :
[11.08.2020] [00:40:04] [DEBUG] [SCENE17076]: 1 = Pressed
[11.08.2020] [00:40:07] [DEBUG] [SCENE17076]: 1 = HeldDown
[11.08.2020] [00:40:08] [DEBUG] [SCENE17076]: 1 = Released
[11.08.2020] [00:40:11] [DEBUG] [SCENE17076]: 1 = Pressed2
EDIT :
Si j'ai trouvé comment simplifier les trigger : tout simplement :
  operator = "any",
  conditions = {
      {id = 132, isTrigger = true, operator = "!=", property = "centralSceneEvent", type = "device", value = {}},
Modifié par jjacques68
  • Thanks 1
Bon ben je viens de remplacer mes 4 scènes blocs par une seule scène LUA...
exemple
local NameScene = "Blue Remote"
local _KeyAttribute = sourceTrigger.value.keyAttribute
local _KeyId = sourceTrigger.value.keyId
fibaro.debug(NameScene, string.format("Scene starting with '%s' key %s", _KeyAttribute, _KeyId))
if     _KeyId == 1 and _KeyAttribute == "Pressed" then fibaro.call(133, "turnOn")
elseif _KeyId == 2 and _KeyAttribute == "Pressed" then fibaro.call({118,121}, "setValue", 99)
elseif _KeyId == 3 and _KeyAttribute == "Pressed" then fibaro.call(133, "turnOff")
elseif _KeyId == 4 and _KeyAttribute == "Pressed" then fibaro.call({118,121}, "turnOff")
else   fibaro.warning(NameScene, "Unknown actions")
  • Thanks 1
Tu est génial !
Je viens d'examiner ton code.
En fait ce que cherchais c'est bien cela
Et bien sûr "!=" est très élégant pour simplifier la détection (je me souviens maintenant avoir vu cet opérateur dans "Fibaro Manual HC3 - Scenes".
Je testerai dans quelques heures, je dois d'abord changer de puits ma pompe d'irrigation et tout ce qui va avec - je vais faire cela à la "fraîche".
En tout cas merci infiniment de ton aide :60: .
Je te tiens au courant bien sûr.
Bon, j'ai pas pu attendre !!!
Ca fonctionne super, je récupère enfin les numéros de touches.
Ensuite c'est du gâteau... :rolleyes:
Merci à nouveau :13:.
Je vais m'occuper de ma pompe l'esprit serein...
  • Haha 1
Voilà quelque chose de réglé avec brio.
Comme prévu j'ai installé ma pompe dans son nouveau puit (alimentée via un Aeon SmartSwitch).
Et du côté domotique (et même plus car j'habite dans une ancienne maison en troncs de sapin âgée d'environ un siècle) j'ai passé de la gaine entre les troncs
pour piloter l'éclairage extérieur.
J'ai toute l'électricité à refaire...
J'aurais bien mis une p'tite photo, mais je pense que je vais déborder du cadre de ce post... :D
  • 4 semaines après...
Bonjour à tous !
Cette télécommande existe maintenant depuis plus de 5 ans et je vois sur ce fil de discussion que certains d'entre vous l'ont utilisée dans différent scénarios, certains rencontrant des soucis d'association ou de réveil (piles...)
J'aimerais si possible avoir un retour d'usage sur la durée de ceux qui l'utilisent au quotidien : fiabilité, durée de vie des piles, réactivité de réception des ordres...
Je suis en particulier intéressé par des retours dans un environnement HC2 et FGR.
J'ai l'impression que Nodon a arrêté cette référence et même arrêté complètement le Zwave (plus rien sur leur site)
Merci d'avance pour le retour !
Pour ne pas continuer l'amalgame, mon retour se fait sur la soft remote et non l'octan remote.
(mais qui je pense sont les mêmes, mis à part le design)
Et bien concernant la pile, je n'ai encore pas souvenir de l'avoir changé, ou peut-être une fois en ... plusieurs années.
Concernant les loupés de com, il y en a de temps en temps, mais pas de quoi s'énerver. Franchement c'est largement satisfaisant.
C'est à mon avis, de très bonnes télécommandes, pour ne pas dire les meilleurs, et le design est sympa.
Je viens d'en acheter plusieurs (soft remote) avec les promo de chez domadoo, car comme tu le dis, elles ne sont plus fabriquées en zwave :(
J'ai donc fais mon petit stock... ;)
@Lazer Je sais que tu voulais en commander aussi... tu as réussi au final ?
J'ai ai 2 sur la HC2 qui fonctionnent très bien.
Je change les piles très peu souvent... Chaque année peut être...
Pour éviter les erreurs d'envoi des commandes, j'ai activé la led. Si elle clignote, je sais que l'ordre a été envoyé et reçu par la box.
Envoyé de mon RMX1993 en utilisant Tapatalk
Merci pour vos retours !
Donc pas de soucis de latence avec cette télécommande c'est vraiment réactif ?
Hello à tous,
Merci pour vos retours.
J'en ai acheté une pour tester et comme j'étais satisfait j'en ai commandé 5 de plus.
Tout est en place sur 3 volets dans mes chambres et c'est nickel.
Maintenant il faut que je trouve des FGR-222 car le 223 ne fonctionne pas comme je veux avec des moteurs filaires bubendorff : pas de remontée d'état si pas de consommation alors que le 22 le fait bien.
Donc quand j'utilise la télécommande, je n'ai pas de remontée d'état sur les mouvements du volet.
J'ai observé un truc dans la notice de la Nodon: ils disent que pour préserver les piles il est préférable d'utiliser des scènes à la place d'association directe.
Est-ce que quelqu'un sait pourquoi ?
Pour quelle raison l'association directe aurait une incidence sur la batterie de la télécommande ?
