maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 oui je voulais dire ip static, j'ai pas de plan je dois mettre les 2 lignes pour wlan ? NON. Mais tu peux la laisser, ça ne gêne pas.
pocket998 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 [FibaroHC2] Fetching Fibaro Home Center devices ... supi@raspberrypi:~ $ sudo su root@raspberrypi:/home/pi# cd /root root@raspberrypi:~# homebridge *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd ns_sd&e=node> *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not su pported (or only supported partially) in the Apple Bonjour compatibility layer o f Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libd ns_sd&e=node&f=DNSServiceRegister> Loaded plugin: homebridge-fibaro-hc2 Registering platform 'homebridge-fibaro-hc2.FibaroHC2' --- Loaded config.json with 0 accessories and 1 platforms. --- Loading 1 platforms... [FibaroHC2] Initializing FibaroHC2 platform... Scan this code with your HomeKit App on your iOS device to pair with Homebridge: ┌────────────┠│ 031-45-154 │ └────────────┘ Homebridge is running on port 51826. Plugin - DidFinishLaunching [FibaroHC2] Fetching Fibaro Home Center rooms ... [FibaroHC2] Server Listening... [FibaroHC2] Fetching Fibaro Home Center devices ... J'ai pas la même chose
pocket998 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Homebridge is running on port 51826. Plugin - DidFinishLaunching [FibaroHC2] Fetching Fibaro Home Center rooms ... [FibaroHC2] Server Listening... [FibaroHC2] Error getting data from Home Center: null undefined ^CGot SIGINT, shutting down Homebridge... Quand je lance homebridge il voit bien la HC2 car j'ai fais un reboot sur la HC2 et en même temps j'ai relancé homebridge et il m'a donné un message d'erreur.
maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Non, tout est parfait, les lignes supplémentaires, arrivent chaque fois que je donne un ordre. ou en es tu ? ou bloques tu ?
pocket998 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Quand j'ajoute sur eve je vois pas homebridge Envoyé de mon iPhone en utilisant Tapatalk
maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 tu as fait toute la séquence de Reset ci-dessus ?
pocket998 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Oui Envoyé de mon iPhone en utilisant Tapatalk
maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 as-tu redémarré ton iPhone, as-tu fais un reset de ton iPhone (Bouton Accueil + Power jusqu'àce que la pomme apparaisse) ?
CharlesO Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 salut a tous bon la dernier image uper fait le meme problème desoler
CharlesO Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 du charabia non stop et après 2 min : file name too long
maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Oui, pour en être sûr, je me suis fait une 2e carte avec celle-ci. De plus, Pocket 998 a un bon fonctionnement aussi.
maconly34 Posté(e) le 26 mars 2016 Signaler Posté(e) le 26 mars 2016 Es-tu sur un Rasp2B ? Avec quoi l'as-tu "Writé" ?
CharlesO Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 Rasp2B1G Write avec mac je le fait avec un pc je te tien au jus
maconly34 Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 Effectivement sur Mac j'ai aussi eu des soucis avec Apple-Pi Baker, je l'ai fait avec Windaube 7 sous Parallels Desktop
pocket998 Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 Hello, Moi j'ai pas pu mettre une 16 Go le programme pour mettre l'image me disait qu'il manquait quelques Mo, donc j'ai mi une 64 Go. La première fois que j'ai mis l'image j'avais rien (avec mac) La deuxième fois que j'ai mis l'image, la homebridge démarre (avec windows) Par contre il trouvent pas les devices
maconly34 Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 Avec Windaube pas de PB Tu es à jour sur l'iPhone ?
CharlesO Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 re bon resulta des cours: par windaube l'ecriture de l image marche je join mon eve au homebridge mais ... : je n'ai dqns eve que les VD et les scene je ne vois rien de mais module ou de mais piece maconly34 au secour !!!! merci
maconly34 Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 IDEM pour moi. J'en suis là. Heu moi je n'ai pas les scènes de la Box. C'est peut-être normal ???
CharlesO Posté(e) le 27 mars 2016 Signaler Posté(e) le 27 mars 2016 j'ai une solution je crois j'ai ajouter après "password": "PUT PASSWORD OF YOUR HC2 HERE" , "grouping": "PUT none OR room" } ], "accessories": [ ] pour moi tout marche je test
CharlesO Posté(e) le 28 mars 2016 Signaler Posté(e) le 28 mars 2016 salut a tous bon apres un redemarage du raspberry ... ca ne marche plus ! comme dab. ! je me suis .... a configure tout les pieces dans eve ex ... bref .
maconly34 Posté(e) le 28 mars 2016 Signaler Posté(e) le 28 mars 2016 Tu relances bien Homebridge après ton reboot ? Car moi j'ai déjàfait un dizaine de reboot et tout fonctionne.
ilcato Posté(e) le 29 mars 2016 Signaler Posté(e) le 29 mars 2016 Just published version 0.6.2 of the plugin. Added support for a new config parameter that allows to control the way in which the plugin checks the values of the characteristics that are updated outside the HomeKit world. Previously the plugin was polling the Fibaro Home Center every 2 seconds looking for updates. I think that this was the cause of the crashes of the Home Center that are described in the forum; probably because of a saturation of some internal logs files. I tested with some of you that were experiencing this problem a version of the plugin that completely disabled the polling and had the confirmation that the crashes were no more present. With this config.json parameter called "pollerperiod" you can: completely disable the polling by setting the parameter to 0 (the drawback of this is that if you have some triggers in HomeKit based on Home Center characteristic changes they will not fire and in order to view the real value of a characteristic in an HomeKit app you need to manually refresh the data. change the poller period from 1 second to 100 second. For those of you with the crash problem (I never experienced it) I suggest to change the value from the default of 2 second to an higher value in order to check if the problem disappear without loosing the capability of using HomeKit triggers or to have the changes happened outside of Homekit to be automatically reflected inside HomeKit This release corrects also a bug in the plugin that with iOs 9.3 make the blinds in some cases crashing. 2
971jmd Posté(e) le 29 mars 2016 Signaler Posté(e) le 29 mars 2016 bonjour a tous j'ai une question, j'ai telecharger l'image, mai avant de la copier sur ma SD je souhaite réaliser une image de ma SD et j'ai une message " disque n'est pas assez grand pour l'image spécifiée " j'utilise WIN32 disk image je clique bien sur READ avez vous une idée du probleme
