comment faire plus simple juste pour faire un teste avec mon iphone  ?
how simpler just to make a test with my iphone ?
turn off or turn on ID 274
a quoi correspond :
What is a :
    "bridge": {
        "name": "HomebridgeMAC",
        "username": "CC:22:3D:E3:CE:30",
        "port": 51826,
        "pin": "031-45-154"
  Le 29/01/2016 à 18:17, 971jmd a dit :
You can refer to the device by name:
for example if you have one of your FGP111 name XXX you can say:
"turn on XXX"
voici comment j'ai procédé pour l’installation
HERE ARE comment I proceeded to the installation of
Raspberry Pi 2 Model B
sudo apt-get update		ok
sudo apt-get upgrade		ok
sudo wget https://nodejs.org/dist/v4.0.0/node-v4.0.0-linux-armv7l.tar.gz		ok
tar -xvf node-v4.0.0-linux-armv7l.tar.gz			ok
 Kà¸r:
 cd node-v4.0.0-linux-armv7l		ok
 Kopier filer til USR/LOCAL
 sudo cp -R * /usr/local/			ok
node –v		ok
sudo apt-get install libavahi-compat-libdnssd-dev     ok
sudo npm install -g homebridge   ok
sudo npm install -g homebridge-fibaro-hc2   ok
cd /root/.homebridge    ok
sudo nano config.json  ok
  Le 29/01/2016 à 18:20, 971jmd a dit :
a quoi correspond :
What is a :
    "bridge": {
        "port": 51826,
        "pin": "031-45-154"
It's the base software on which the Fibaro Home Center plugin that I developed is based. It's called homebridge. With the previous parameter you are naming it HomebridgeMAC (a better name maybe HomebridgPI), you are assigning a username an access port and a PIN to bind the bridge to the HomeKit framework.
  Le 29/01/2016 à 18:29, ilcato a dit :
"turn on XXX"
ok i am good
"on_url": "http://192.168.0.5/api/callAction?deviceID=274&name=pressButton&arg1=1",
"off_url": "http://192.168.0.5/api/callAction?deviceID=274&name=pressButton&arg1=3",
j'ai fait le teste avec le code suivant mai ça ne fonctionne plus :
I have tested it with the following code in May that no longer works
	"bridge": {
		"port": 51826,
		"pin": "031-45-154"
	"description": "This is an example configuration file. You can use this as a template for creating your own configuration file.",
	"platforms": [{
			"platform": "FibaroHC2",
			"name": "FibaroHC2",
			"host": "192.168.0.5",
			"username": "xxxx",
			"password": "xxxx"
	"accessories": [{
		"accessory": "Http",
		"name": "cuisine",
		"description": "halogene",
		"on_url": "http://192.168.0.5/api/callAction?deviceID=268&name=setValue&arg1=100",
		"off_url": "http://192.168.0.5/api/callAction?deviceID=268&name=setValue&arg1=0",
		"username": "admin",
		"password": "admin",
		"http_method": "GET",
		"service": "Switch"
Pour simplifier les choses créé toi un utilisateur pour homebridge sur hc2 et donne lui accès àquelques modules seulement.
Meri très bonne idée.
Côté mobile je fonction avec àˆVE, par contre si je souhaite réaliser la même chose sur ma tablette ce n'est pas possible c'est l'un ou l'autre
J'ai essayé  mytouchHome par contre il ne trouve pas le bridge.
quel autre application fonctionne avec ce systeme ?
Tu as quelle tablette ?
Moi j'ai un iPad Air et ça tourne en parallèle de l'iPhone.
En revanche il faut attendre sur le second appareil que iCloud se synchronise... Ca prend des lustres ! J'ai attendu tellement longtemps la première fois que j'ai laissé tombé. Et le lendemain en reprenant la tablette HomeKit était fonctionnelle et Eve avait la même configuration que sur iPhone.
IPad Air
J,ai abandonné pour le moment ÈVE, quand je crée des pièces Je n'arrive àjouter mes commande dans les pièces.
Entre mytouchhome et Ève le quel fonctionne le mieux ?
HomeKit est LA brique logicielle qui permet chez Apple d'utiliser la domotique et par extension les appareils domotiques compatibles via Siri. Homebridge est un hack qui permet d'utiliser HomeKit de façon non officielle.
j'ai un autre probleme
Quand je demande à  SIRI d’allumé la lampe salon, elle l'allume très bien mai elle me réponde :
ça y est,  la lampe salon est male
ça fonctionne bien avec EVE  il y a quel que petit soucie encore. :P
Mai je souhaite savoir si on trouve d'autre application que EVE
Home - Smart Home Automation, c'est celui que je préfère. Il est très efficace notamment pour paramétrer les devices par room / sections etc...
