Shyrka973 Posté(e) le 29 juillet 2015 Signaler Posté(e) le 29 juillet 2015 4.053> New Features:- Fibaro Dimmer 2 support- Multichannel Associations support - to use that feature re-inclusion or soft reconfiguration is required- Notification Center in web interface - basic set of notifications is currently available, this feature will be developed- It is possible to choose whether the device should be added in secure mode - for devices other than doorlocks, sirens, roller blinds it is strongly advised to use non secure mode due to Z-Wave protocol performance- Secure update availability check via https- It is possible to interrupt the process of device reconfiguration- Reworded notification messages> New Plugins:- Planika - Bio Fireplace- New video cameras support (check on plugin list)> Resolved Issues:#0003316 Z-Wave communication breakdown after sending an empty argument#0002493 FortrezZ SSA2 siren no template#0002622 Home Center 2 is not supporting multichannel associations#0002706 Cant set parameters on Fibaro Sensor (FGMS)#0001705 POP_123665 Z-Wave UK Plug-in Switch plus Power Meter does not display measured power#0002052 MCOHOME touch panel switch#0002227 Association to Vitrum's slave button is not working#0002276 FGS-221 + WCD2 – cannot associate the second channel#0001771 Metering Report#0002432 unable to change any parameters on Home Energy Meter DSB28-ZWEU E2#0003345 Display truncated in 4.048Satel alarm disarming> Other changes:- Z-Wave Stability Improvements- Z-Wave Network Reconfiguration Improvement- Many other system improvements> Known issues:- Using multichannel associations requires soft reconfiguration of devices- Android version of the Fibaro mobile app does not display icons for following devices properly: - NetAtmo Thermostat - NetAtmo Weather Station - Sonos- Inconsistencies in Satel interface.- Power Metering may not work properly for some devices- Alarm Panel doesn't work in some specific configurations- Plugins for TV Sets of various manufacturers may not work with its newer firmware due to restrictions provided by new devices firmware. There will be added detailed information about supported firmware versions within plugins.- Breached sensor with Arm Delay causes instant alarm after being armed- Data range selection in event panel doesn't work properly- Devices imported via Gateway Connection may have no icons- Gateway Connection status of dead device between master and slave controller may be different- Devices not properly configured on 3.X may not be converted properly- On mobile clients devices may be visible in different categories than configured- Horstmann Thermostat HRT4-ZW higher battery usage in some cases- Doorlocks some functions may not work properlyIMPORTANT!After performing upgrade please re-save your time settings in Configuration -> Location page, since in some cases inappropriate time might be set. 1
Shyrka973 Posté(e) le 29 juillet 2015 Auteur Signaler Posté(e) le 29 juillet 2015 Mais ceux qui sont en 3.601 ne peuvent toujours pas passer en V4 Un problème de conversion de DB entre la V3 et V4. Cette mise à jour n'est proposée que pour ceux qui sont déjà en V4. 1
Nico Posté(e) le 29 juillet 2015 Signaler Posté(e) le 29 juillet 2015 Par contre bonne nouvelle, cela veut donc dire que les mises àjour sont suivies entre HC2 et HCL àquelques jours prêt. 1
raffoul Posté(e) le 30 juillet 2015 Signaler Posté(e) le 30 juillet 2015 Me concernant, je n'arrive pas à upgrader depuis HC2 4.049. J'obtiens le message : Accès refusé ! (403 Forbidden) Suis-je le seul ou d'autres ont également (eu) le même problème ?
Did Posté(e) le 30 juillet 2015 Signaler Posté(e) le 30 juillet 2015 Tu n'est pas au bon endroit, ici c'est un sujet pour la HCL, pour HC2, c'est ici. http://www.domotique-fibaro.fr/index.php/topic/5352-maj-4053-24072014/page-4
Kriek Posté(e) le 2 août 2015 Signaler Posté(e) le 2 août 2015 Hello, Il est écrit qu'est résolu le problème "Home Center 2 is not supporting multichannel associations". Qu'est ce que ce la veut dire ? Qu'on peut désormais associer un module déjà associé à un autre réseau z-wave ?
Yannick Posté(e) le 3 août 2015 Signaler Posté(e) le 3 août 2015 Aucun moyen de forcer cette mise à jour sur la HCL ?
Yannick Posté(e) le 25 août 2015 Signaler Posté(e) le 25 août 2015 salut à tous, Toujours pas de nouvelles sur l'Upgrade de la v3 vers la V4 ???
StarLord Posté(e) le 7 septembre 2015 Signaler Posté(e) le 7 septembre 2015 Salut, Franchement Fibaro ils abusent... Ils ont sorti des HCL en V4 et ils sont incapables de proposer une Mise à jour !!! J'ai une Zipabox et je me plaignais des updates qui sortent jamais mais au final Fibaro ce sont les memes ! Pour moi il n'y a rien de fiable dans ces BOXs Domotique, aucun constructeur qui propose un truc réellement fini. C'était mon coup de gueule lol @bientot.
jojo Posté(e) le 7 septembre 2015 Signaler Posté(e) le 7 septembre 2015 en fait Fibaro rencontre des difficulté avec la MIGRATION de v3 àV4. En effet, il y a énormément de choses qui ont changé entre la v3 et la v4. Sur la HC2, nous avons eu des tonnes de problèmes avec la migration. Mais la v4 en elle-même est stable. ils devraient peut-être proposer de pouvoir mettre àjour la HCL en V4, mais alors SANS migration de l'existant, et donc avec comme conséquence qu'il faille tout réinclure/refaire. Si tu es prêt àcela, tu peux leur proposer ?
StarLord Posté(e) le 7 septembre 2015 Signaler Posté(e) le 7 septembre 2015 C'est clair que si c'est juste une histoire de migration il devrait proposer cette solution alternative. Moi je suis à 100% partant C'est comme quand on change d'OS sur un PC, le mieux c'est de faire une install propre en nouvelle version. Comment tu penses que je peux les contacter ? par le support ??
jojo Posté(e) le 7 septembre 2015 Signaler Posté(e) le 7 septembre 2015 en effet, je les contacterais via le support à support@fibaro.com en leur expliquant que tu dois refarire toute ton installation, et qu'on t'a dis que la v4 apportait beaucoup de fonctionnalités et de possibilités d'évolutions futures (ils seront flattés)
Yannick Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 Salut @jojo si toutefois ils nous envoient un fichier pour l'Update, il serait nécessaire d'exclure tous les modules avant de flasher le Firmware non ? Sinon, impossible de les inclure dans une nouvelle bos quelle qu'elle soit ?
jojo Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 il y a toujours moyen de d'abord exclure le device avant de le réinclure (par exple, si tu achète un module d'occasion qui n'a pas préalablement été exclu)
Yannick Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 ah bon ??? je croyais que l'exclusion ne devait se faire que sur la box d'origine ? faut que je creuse ça alors !!
mprinfo Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 Non on peut exclure avec une autre box j'utilise souvent ma clef usb zwave pour exclure un module car c'est portatif par contre il faut supprimer le module àla main dans la box ou il est inclus Attention il faut parfois refaire plusieurs fois l'exclusion avec certains modules pour qu'il soit vraiment exclu J'ai plus de 30 recovery àmon actif donc l'exclusion et l'inclusion je connais lol d'ailleurs faut que je fasse un tutoriel la dessus car parfois si on si prend mal ça peut être incompréhensible Envoyé de mon SM-G900F en utilisant Tapatalk
Yannick Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 et bien fait voisin !!! je suis preneur !! 1
Yannick Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 Et ben non... ça fonctionne pas ! Ci-dessous leur réponse pour un passage sur la V4 à poil !
StarLord Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 Bonsoir, Même réponse que toi Yannick....
Dimitri Posté(e) le 8 septembre 2015 Signaler Posté(e) le 8 septembre 2015 Oui c'est bien dommage tout ça. Je suis franchement déçu de Fibaro... Ou tout du moins de ma HCL. Je vais aussi faire un mail. Peut être qu'àforce de recevoir du courrier ils se bougeront un peu... Envoyé de mon iPhone en utilisant Tapatalk
