Moicphil Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Mise à jour HC2 V4.045 Attention ! Cette mise à jour comporte quelques soucis au niveau de l'envoi de commandes " fibaro:call(id, turnxx) " en série Il est recommandé d'attendre un prochain hot fix. Pour contrer ce pb si vous avez installé cette 4.045, integrer dans la boucle de commande un " fibaro:sleep(200) " We have just released a new update - version 4.045 This version brings new feature and addressing some of issues reported by users.4.045> New functionalitiesPopup messages and notification center for mobile devices.It requires:- HC2: 4.045,- iPhone: 2.5,- iPad: 1.50,- Fibaro for Android Phone: 1.6,- Fibaro for Tablet: 1.3.Notice: Popup notification feature is supported by Home Center 2 from version 4.042 however it also requires support from mobile applications to work properly. Due to specific process of releasing mobile applications'updates, especially for iOS app, implementation of this feature has been released gradually and pop-up notifications can be available on some of the previous versions of mobile apps.> Resolved IssuesRedesigned and fixed support of RGB/RGBW modules0001992: FGK-101 with a DS18B200002315: 4.024 Diagnostic panel: tab "ZWAVE" should be spelled "Z-Wave"0002357: Last backup shows as N/A on Configuration General0002429: Temperature Panel saving error0002503: Not possible to set property of a virtual device containing " %"0002533: Alarmpanel - No actions when alarm is breached0002609: RGBW module does not work properly in IN/OUT mode0002619: Eventlog does not show dates.0002671: SONOS: display of radio in HC2 plugin differs from SONOS app0002826: Battery drain on Danfoss LC120002942: Qubino dimmers not showing actual value.0002970: Little error in the HCL interface0003038: 4.037 Backup from 4.037 not compatible with itself, backup "description" also shows under "version"0003146: Add Protection button for FGRM-2220003228: General Information Page0003244: ZWave.me KFOB_S Gen 5 Does not include, let alone work0003247: cannot change RGB keys & mode0003276: Bad support for Remotec ZXT-120 in HC2 v4.0420002218: RGBW 0-10V analog sensor not reporting0002417: FGRGBW 441M EU - cannot set parameters in newly included devices0002846: Cannot save advanced settings for any Fibaro RGBW devices0003126: FGRGBW 441M EU - device marked as dead0002675: Form elements are misaligned in device configuration0002190: FGRGBW 441M EU - cannot change device control type0003016: HC2 out of memory after a few hours of operation> Known issuesAndroid version of the Fibaro mobile app does not display icons for following devices properly:- NetAtmo Thermostat- NetAtmo Weather Station- SonosInconsistencies in Satel interface.Power Mettering may not work properly for some devicesAlarm Panel doesn't work in some specific configurationsPlugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.Breached sensor with Arm Delay causes instant alarm after being armedData range selection in event panel doesn't work properlyDevices imported via Gateway Connection may have no iconsGateway Connection status of dead device between master and slave controller may be differentDevices not properly configured on 3.X may not be converted properlyOn mobile clients devices may be visible in different categories than configuredHorstmann Thermostat HRT4-ZW higher battery usage in some casesDoorlocks some functions may not work properly 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Installation en cours 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Moicphil Posté(e) le 28 mai 2015 Auteur Signaler Partager Posté(e) le 28 mai 2015 Mise àjour faite...sans pb pour moi, tout fonctionne 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sakkhho Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Enfin un peu d animation !! Par contre semble pas avoir résolu le problème de la sirène ZW080 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 les plugin perso ont-ils disparus avec l'upgrade ? peut-on toujours en importer ? performances benchmark de Steven ? et son GEA, plus réactif ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 OK on verra ça ce week-end. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 je vais attendre un peu pour savoir si les plugin sont toujours ok la je vais continuer ma galère avec esxi @lazer tu as vu pour le FGRM222 on dirai qu'ils savent a quoi sert le paramétre 1 lol Backup 4.037 ??? 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 les plugin perso ont-ils disparus avec l'upgrade ? Oui peut-on toujours en importer ? oui ​ performances benchmark de Steven ? et son GEA, plus réactif ?je ne retrouve plus le lien de Steven avec le test mais de toute façon chez moi cela a toujours été presque instantané Pour le reste tout fonctionne. Le bug qui fait que si on n'a pas retiré une consommation prédéterminée dans le device la ligne correspondant disparaît lors d'un softreconfigure est toujours présent 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 il est ou krikroff manqué une mise a jour c'est vraiment pas son style Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Du coup il vaut mieux supprimer les plugins persos avant installation je pense, afin qu'ils ne restent pas derrière les anciennes versions des modules correspondant. Lien vers le commentaire Partager sur d’autres sites More sharing options...
HANSOLO Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Maj comme une lettre àla poste Lien vers le commentaire Partager sur d’autres sites More sharing options...
jmg38 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Bonjour, MAJ sans Pb. Toujours pas de géolocalisation possible!9a m'agace tjrs autant Cdt 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
jojo Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Du coup il vaut mieux supprimer les plugins persos avant installation je pense, afin qu'ils ne restent pas derrière les anciennes versions des modules correspondant. @Nico : le mieux serait de faire une réinstallation complète 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Va chi** Non, mais je sais que dans les Beta, c'était une recommandation de Fibaro de supprimer les plugins perso avant mise à jour. Or vu que les plugins persos n'ont pas évolués depuis, je dirai que c'est la même chose, d'ailleurs ils disparaissent bien. Donc pour moi derrière cela pourri la base, car ils vont y rester sans moyen de les supprimer. Et l'alerte de les supprimer ils ne la mettent pas, vu que personne n'ait censé en avoir. Après chacun fait comme il pense, mais je pense que c'est une sage recommandation et ne prend pas plus de temps. Sinon vous avez vu, ils parlent de HCL dans la mise à jour, cela voudrait dire que HC2 et HCL suivent les mêmes mises à jour désormais ? 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
sebcbien Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Pfff toujours des problèmes Satel je vois :-/ "inconsistencies" ... Un peu vague ... Sent from my phone Lien vers le commentaire Partager sur d’autres sites More sharing options...
charlyton Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 J'attend un peu avant de mettre àjour, mais je te communiquerais le résultat si tu ne veux pas te lancer. Envoyé de mon iPhone àl'aide de Tapatalk 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 @nico, oui oui je me souvenais le coup de la désinstallation des plugins avant upgrade mais je voulais voir comment cela réagissait avec cette nouvelle version. J'ai donc la réponse @sebcbien, j'y suis peut etre pour quelque chose pour la phrase "inconsistencies" pour la Satel Je suis en relation avec le support au sujet d'un problème de reconnexion entre la Satel et la Fibaro lors d'une perte réseau d'une durée conséquente (estimation 1 heure) Sinon pour le reste cela fonctionne vraiment bien maintenant. 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Berale64 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 On parle de Ipad 1.50 mais elle est pas dispo !!! ça marche avec la version actuelle ?? Lien vers le commentaire Partager sur d’autres sites More sharing options...
971jmd Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 bonjour pour il semblerai que les scéneactivation de GEA qui ne fonctionne plus Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 @jmd , Cela fonctionne chez moi pas de problème Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dyscus Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Bonjour, MAJ sans Pb. Toujours pas de géolocalisation possible!9a m'agace tjrs autant Cdt C'est clair, ils font de la publicité mensongère, ce sont des menteurs ! 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rocketlud Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Idem, comme une lettre à la poste A suivre Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Amélioration de la prise en charge des AEON LABS DSB09 - Compteur de consommation électrique Z-Wave avec 2 pinces ampèremétriques 60A "Smart Energy Sensor" Le paramétrage est aussi disponible Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Bon ben mise à jour OK, enfin presque, j'ai n'ai plus d'interface, mais pas d'erreur 503, les petits points bleus tournent en boucle même après reboot lol Une idee ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 28 mai 2015 Signaler Partager Posté(e) le 28 mai 2015 Vider le cache et te reconnecter. Sinon retenter en EN. Lien vers le commentaire Partager sur d’autres sites More sharing options...
