darklite44 Posté(e) le 25 mai 2015 Signaler Posté(e) le 25 mai 2015 Bonjour à tous, Je rencontre une erreur LUA avec le HC2 Toolkit Framework et je suis à court d'idée. Et vous ? Je voudrais afficher le contenu du body. [DEBUG] 15:59:04: ------------------------------------------------------------------------- [DEBUG] 15:59:04: -- HC2 Toolkit Framework version 1.0.3 [DEBUG] 15:59:04: -- Current interpreter version is Lua 5.1 [DEBUG] 15:59:04: -- Total memory in use by Lua: 213.90 Kbytes [DEBUG] 15:59:04: ------------------------------------------------------------------------- [DEBUG] 15:59:04: Toolkit.Debug loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Debug lib]: elapsed time: 0.000 cpu secs [DEBUG] 15:59:04: Toolkit.Collections.Queue loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Collections.Queue lib]: elapsed time: 0.010 cpu secs [DEBUG] 15:59:04: Toolkit.Net loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Net lib]: elapsed time: 0.000 cpu secs [DEBUG] 15:59:04: Toolkit.Crypto loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Crypto lib]: elapsed time: 0.000 cpu secs [DEBUG] 15:59:04: Toolkit.Crypto.Sha1 loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Crypto.Sha1 lib]: elapsed time: 0.010 cpu secs [DEBUG] 15:59:04: Toolkit.Crypto.Base64 loaded in memory... [DEBUG] 15:59:04: Benchmark [Toolkit.Crypto.Base64 lib]: elapsed time: 0.000 cpu secs [DEBUG] 15:59:04: Toolkit.Net.HttpRequest > Total memory in use by Lua: 217.26 Kbytes [DEBUG] 15:59:04: Toolkit.Net.HttpRequest > Create Session on port: 80, host: gestionbbox.lan [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::setReadTimeout > Timeout set to 1000 ms [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::request > /admin/index.htm with method GET [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::request > Add header [GET /admin/index.htm HTTP/1.1] [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::request > Add header [Host: gestionbbox.lan:80] [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::request > Add header [Accept-Language: fr-FR,fr;q=0.8,en-US;q=0.6,en;q=0.4] [DEBUG] 15:59:04: Toolkit.Net.HttpRequest::request > Add header [Accept: */*] [DEBUG] 15:59:05: Toolkit.Net.HttpRequest::receive > Length of result: 10007 [DEBUG] 15:59:05: Toolkit.Net.HttpRequest::receive > Status 200 [DEBUG] 15:59:05: Toolkit.Net.HttpRequest::receive > Length of headers reponse 186 [DEBUG] 15:59:05: raw #1:HTTP/1.1 200 OK [DEBUG] 15:59:05: raw #2:CONTENT-LANGUAGE: fr-FR,fr;q=0.8,en-US;q=0.6,en;q=0.4 [DEBUG] 15:59:05: raw #3:Content-type: text/html [DEBUG] 15:59:05: raw #4:Transfer-Encoding: chunked [DEBUG] 15:59:05: Toolkit.Net.HttpRequest::receive > Transfer-Encoding: chunked [DEBUG] 15:59:05: raw #5:Date: Mon, 25 May 2015 14:00:36 GMT [DEBUG] 15:59:05: raw #6:Server: Apache 1.3.29 [DEBUG] 15:59:05: Length of body reponse: 9820 [ERROR] 15:59:06: line 131: bad argument #2 to 'format' (no value) à‡a coince dans cette fonction -- trace(value, args...) -- (string) value: value to trace (can be a string template if args) -- (various) args: data used with template (in value parameter) trace = (function(self, value, ...) if (self.isTraceEnabled) then if (value~=nil) then return fibaro:debug(string.format(value, ...)); end end end), Et j'ai mis ça comme code : Toolkit.Net.isTraceEnabled = true; -- recuperation du token local HttpClient = Toolkit.Net.HttpRequest(BboxObject._host, 80); HttpClient:setReadTimeout(1000); local response, status, errorCode = HttpClient:request("GET", "/admin/index.htm", { "Accept-Language: fr-FR,fr;q=0.8,en-US;q=0.6,en;q=0.4", "Accept: */*", }, nil); HttpClient:disconnect(); HttpClient:dispose(); HttpClient = nil; Toolkit.Net.isTraceEnabled = false; local _return = false;
