Cool si le template est là.
C était pas mentionné dans le bugtracker.
Chez moi la sirène marche depuis le début quel que soit la version du firmware. Comme je suppose que tu as tout essayé (inclusion exclusion... )-> problème matériel ?
effectivement le template est la, mais pas correct
ca me donne
[15:00:10] ID 193: No report was received for parameter 37. The device might not have this parameter.
[15:00:13] ID 193: No report was received for parameter 37. The device might not have this parameter.
[15:00:16] ID 193: No report was received for parameter 37. The device might not have this parameter.
[15:00:19] ID 193: No report was received for parameter 80. The device might not have this parameter.
[15:00:22] ID 193: No report was received for parameter 80. The device might not have this parameter.
[15:00:25] ID 193: No report was received for parameter 80. The device might not have this parameter.
[15:00:29] ID 193: No report was received for parameter 200. The device might not have this parameter.
[15:00:32] ID 193: No report was received for parameter 200. The device might not have this parameter.
[15:00:35] ID 193: No report was received for parameter 200. The device might not have this parameter.
[15:00:38] ID 193: No report was received for parameter 252. The device might not have this parameter.
[15:00:41] ID 193: No report was received for parameter 252. The device might not have this parameter.
[15:00:44] ID 193: No report was received for parameter 252. The device might not have this parameter.
[15:00:47] ID 193: No report was received for parameter 255. The device might not have this parameter.
[15:00:50] ID 193: No report was received for parameter 255. The device might not have this parameter.
[15:00:53] ID 193: No report was received for parameter 255. The device might not have this parameter.
donc il arrive pas a adresser les valeurs...
et ma sirene ne sonne plus maintenant;
Salut sakkho désolé pour la sirène. j'ai mis le lien avec ma déclaration de bugtracker juste au dessus de ton message ou je décrits l'erreur que tu rencontrez... ç'est balo
Je me suis inclus dans le bugTracker.
Pour moi, j'ai le On/Off fonctionnel et je l'active via une scène LUA lors du déclenchement de l'alarme.
Je suis en 4.042
  • 3 semaines après...
ZW080 "Siren Gen5" : Sirène sur secteur avec batterie de secours - Aeotec by Aeon Labs
aeotec-zw080-sirene-sur-secteur-avec-bat
Cette nouvelle sirène AEOTEC ZW080 (Aeon LABS) est un véritable petit bijou associant design, compacité et technologies de dernière génération.
Très simple d'installation, elle se connecte sur une prise de courant et est protégée par une batterie de secours en cas de coupure.
  • Puissance sonore de 105dB à  1m.
  • Choix possible parmi 5 sonorités par paramètre Z-Wave.
  • Alarme visuelle à  l'aide de diodes blanches haute puissance.
  • Nouvelle version "Gen 5" ZWave+ (totalement compatible Z-Wave).
    • Cryptage AES 128 bits pour plus de sécurité*.
    • Meilleure distance de communication.
    • Fonction trame d'exploration "explorer frame" (facilite l'optimisation du réseau)*.
    • etc.
  • Fonction répéteur (routeur) permettant d'étendre la distance d'émission du réseau Z-Wave (encore plus efficace avec les autres modules Z-Wave Plus).
  • Distance théorique de communication (sans obstacle) avec des modules Z-Wave Plus: 50m max. sans obstacles ou 30m max. avec des modules Z-Wave.
* Ces fonctionnalités nécessitent une prise en charge par la box domotique ou le logiciel domotique (+ dongle Z-Wave) utilisé.
Manuel Sirène AEOTEC Gen5
non compatible en V4.042 (elle est bien inlcuse mais impossible de la faire sonner)
Il y a un bug dans le template qu ils ont voulu rajouter.
Avant cette version c était ok.
bug remonté àFibaro.
Je viens tout juste de tester en v4.047, et pour moi oui elle fonctionne comme en v3 : c'est à  dire un simple switch dans l'interface, qui active/désactive immédiatement la sirène.
Précisions : j'ai inclus cette sirène en v3, et je n'ai jamais fait de soft-reconfigure sur le module. Je ne sais pas quel serait le résultat d'un soft-reconfigure ou d'une réinclusion.
J'ai la même question que sakkho. si ça fonctionne en v4.47 je migre sinon je ne bouge plus :-) quelqu'un a l'information
Je viens d'acheter cette très belle sirène mais qui ne fonctionne pas chez moi. Je suis en V4.048
L'inclusion se passe très bien. Le module apparait en tant que switch ON/OFF, mais aucun son.
Quand je change le module d'état, j'ai bien le retour "transfert OK".
Je ne peut même pas tester si ma sirène fonctionne, ni écouter les différentes sonnerie.
Par contre j'ai bien les paramètres de choix des sonneries.
J'éspère que le problème va vite être résolu.
Faut-il faire une nouvelle réclamation auprès de Fibaro ?
Oui tu peux.
Je suis dans la même situation.
Avant la 4.042 (sans template) ça marchait bien.
Depuis pas de son.
On patiente ...
J'ai un signe de fibaro qui indique la prise en compte du sujet..... peut être une prochaine résolution. ..... pffffff il me fatigue.
Voici la réponse de la part de Fibaro :
Dear Sir,
Thank you for template. Now our software team can implement it to Home Center software. Thank you once again.
It should be available in one of next updates.
I am looking forward to hearing from you.
pour moi en 4.48 la sirène apparait en switch on/off elle sonne bien mais pas de template j'espère qu'il vont l'incorporait dans la prochaine mise a jour
Sur le blog de domadoo il ont fait un post présentant cette sirène avec la Home center.. Pour moi en 4.049 cela ne fonctionne toujours pas, elle ne sonne pas du tout..
Et vous ?
Pour moi elle fonctionne toujours aussi bien, mais je l'ai inclus en v3 et migré ensuite, donc c'est différent d'une nouvelle inclusion direct en v4.049
