Sorry, it is not possible to exclude specific devices from being collected wihin the virtual device.
The only way to exclude devices is to hide them in the graphical interface.... But you won't be able to see them anymore in your GUI.
This is a problem when i need to download the csv data from the myphp database...
Ok... i hope in a future upgrade :D
Thank you for your works!
What kind of server to you have for your database ?
I have a lot of devices, and my database is less than 200MB, I have very good performances when extracting data. I am running on a Web shared hosting.
Your server may have very very low performances.
Yes... my database it's about 120mb but when i download it in csv format it increase the size at 250mb...
For now it's not a big problem.. i think for the future. I have stored data just for two months.
But no problem. It'is ok!! ;)
Thank you
OK, it's normal, since CSV data is just text data, so the size is bigger.
I have a backup schedule that runs automaticaly every night, and extract all tables in CSV format, and I have no probem so far.
I use 2 home-made scripts :
- a PHP file running on the web server to extract data from DB
- a Shell file running on a Linux station, which download the file then copy it onto a NFS mount on the NAS.
The PHP file :
<?php
/*** File    : backup_sql.php                                               ***/
/*** Author  : Christophe DRIGET                                            ***/
/*** Version : 1.0                                                          ***/
/*** History : January 2016 : Initial release                               ***/
/*** Note    : Script to backup database                                    ***/
//*** Debug mode
define('DEBUG', false);
//*** Report all PHP errors
if (DEBUG)
	error_reporting(E_ALL | E_NOTICE | E_STRICT | E_DEPRECATED);
else
	error_reporting(E_ALL);
ini_set('display_errors', 'on');
//*** Generate exception for all errors
function exception_error_handler($errno, $errstr, $errfile, $errline ) {
	throw new ErrorException($errstr, $errno, 0, $errfile, $errline);
set_error_handler('exception_error_handler', E_ALL);
//*** Main loop
try {
	//*** Include necessary files
	require 'config.inc.php';
	//*** MySQL connection
	if ( ! isset($bdd) )
		$bdd = new PDO('mysql:host='.$server.';dbname='.$database.';charset=UTF8', $login, $password);
	//*** Get tables list
	$sql = $bdd->prepare("select TABLE_NAME from information_schema.tables where TABLE_TYPE='BASE TABLE' AND TABLE_NAME LIKE 'domotique%' OR TABLE_NAME LIKE 'teleinfo%'");
	$sql->execute();
	$tables = implode(' ', $sql->fetchAll(PDO::FETCH_COLUMN));
	if (DEBUG)
		echo $tables.'<br/>'.PHP_EOL;
	//*** Dump database
	$date = date('Ymd-His');
	$filename = $database.'.sql';
	$last_line = system('mysqldump --host='.$server.' --user='.$login.' --password='.$password.' '.$database.' '.$tables.' > '.$filename, $retval);
	if (DEBUG) {
		echo $last_line.'<br/>'.PHP_EOL;
		echo $retval.'<br/>'.PHP_EOL;
	if ( $retval == 0 ) {
		//*** Compress file
		if (file_exists($filename.'.gz'))
			unlink($filename.'.gz');
		system('gzip '.$filename, $retval);
		if ( $retval == 0 )
			echo $date;
		else
			throw new Exception('Cannot compress file');
	else
		throw new Exception('Cannot dump SQL');
//*** Exception handling
catch(Exception $e) {
	die('Error : '.$e->getMessage());
The Shell script :
#!/bin/bash
# Script  : backup_domotique.sh
# Author  : Christophe DRIGET
# Version : 1.0
# Date    : January 2016
# Website
SITE_URL="http://my.domain.com/path/to/domocharts"
BACKUP_URL="backup_sql.php"
FILE_URL="backup-sql.sql.gz"
# NAS
NAS_ADDRESS="1.2.3.4"
NAS_SHARE="/nfs/share"
NAS_PATH="/backup/directory"
MOUNT_POINT="/mnt/nfs"
# Email
MAIL_FROM="me@domain.com"
MAIL_TO="me@domain.com"
MAIL_SMTP="smtp.provider.com"
MAIL_SUBJECT="Mail subject"
# Perform backup
OUTPUT=`/usr/bin/curl --silent ${SITE_URL}/${BACKUP_URL}`
ERROR=`echo ${OUTPUT} | /bin/grep -c -i "error"`
if [ ${ERROR} -eq 0 ]
then
        # Mount NFS filesystem
        /bin/grep -qs "${MOUNT_POINT}" /proc/mounts
        if [ $? -ne 0 ]
        then
                /bin/mount -t nfs ${NAS_ADDRESS}:${NAS_SHARE} ${MOUNT_POINT}
                if [ $? -ne 0 ]
                then
                        /bin/date
                        echo "Error : cannot mount NFS filesystem"
                        echo "Error : cannot mount NFS filesystem" | /bin/mailx -r "${MAIL_FROM}" -s "${MAIL_SUBJECT}" -S smtp="${MAIL_SMTP}" "${MAIL_TO}"
                        exit 1
                fi
        fi
        # Download backup file
        /usr/bin/curl --silent ${SITE_URL}/${FILE_URL} > ${MOUNT_POINT}/${NAS_PATH}/domotique_${OUTPUT}.sql.gz
        if [ $? -ne 0 ]
        then
                /bin/date
                echo "Error : cannot download backup file"
                echo "Error : cannot download backup file" | /bin/mailx -r "${MAIL_FROM}" -s "${MAIL_SUBJECT}" -S smtp="${MAIL_SMTP}" "${MAIL_TO}"
        fi
        # Unmount NFS filesystem
        /bin/umount ${MOUNT_POINT}
else
        /bin/date
        echo "${OUTPUT}"
        # Send Email
        echo "${OUTPUT}" | /bin/mailx -r "${MAIL_FROM}" -s "${MAIL_SUBJECT}" -S smtp="${MAIL_SMTP}" "${MAIL_TO}"
        exit 99
fi
exit 0
And the crontab to launch the backup every night at 02:30 :
[root@redhat ~]# crontab -l
30 2 * * * /root/backup_domotique.sh >> /root/backup_domotique.out 2>&1
hi Lazer,
i add a MCO Co2 i push all buttton to vd, but i don't read a Co2 in a graph, i have error not device found. i see new temp ad humidity but no co2.. you have a idea? thanks
Can you share the JSON of your new device ?
I will try to integrate it in a future release of Domocharts.
For now, only Netatmo weather station is supported for CO2.
Ok tell me a procedure and i share asap
Inviato dal mio PLK-L01 utilizzando Tapatalk
this is a main device:
{"id":322,"name":"322","roomID":0,"type":"com.fibaro.zwaveDevice","baseType":"com.fibaro.device","enabled":true,"visible":false,"isPlugin":false,"parentId":1,"remoteGatewayId":0,"interfaces":["polling","zwave","zwaveAssociation","zwaveConfiguration","zwaveSlaveRouting"],"properties":{"associations":"[{\"endPointId\":0,\"groups\":[{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":1,\"singleChannel\":{\"max\":5,\"set\":[1],\"view\":[1]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":2,\"singleChannel\":{\"max\":1,\"set\":[1],\"view\":[1]}}]}]","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"28","deviceSpecificData":"","deviceSpecificIdType":"","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"parametersTemplate":"775","pollingInterval":"0","pollingTimeSec":0,"productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"","zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveSoftwareVersion":"{}","zwaveVersion":"1.2"},"actions":{"getParameter":1,"poll":0,"reconfigure":0,"setParameter":2},"created":1476965482,"modified":1476965482,"sortOrder":134}
Co2 sensor
{"id":323,"name":"Co2 camera letto","roomID":5,"type":"com.fibaro.multilevelSensor","baseType":"com.fibaro.sensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"47","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","unit":"ppm","useTemplate":"true","userDescription":"","value":"1949.00"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":135}
Temp sensor
{"id":324,"name":"Temperatura","roomID":5,"type":"com.fibaro.temperatureSensor","baseType":"com.fibaro.multilevelSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"30","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","offset":"0.00","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","showFireAlarm":"true","showFreezeAlarm":"false","smsNotificationID":"0","smsNotificationType":"0","unit":"C","useTemplate":"true","userDescription":"","value":"20.30"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":136}
humidity sensor
{"id":325,"name":"Umidità","roomID":5,"type":"com.fibaro.humiditySensor","baseType":"com.fibaro.multilevelSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["zwave"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"31","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","unit":"%","useTemplate":"true","userDescription":"","value":"63.00"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":137}
Gas sensor
{"id":326,"name":"322.0.3","roomID":5,"type":"com.fibaro.gasDetector","baseType":"com.fibaro.lifeDangerSensor","enabled":true,"visible":true,"isPlugin":false,"parentId":322,"remoteGatewayId":0,"interfaces":["fibaroBreach","zwave","zwaveAlarm"],"properties":{"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":2,"value":1000}],"zwaveCompany":"McoHome Technology Co., Ltd","zwaveInfo":"5,3,67","zwaveVersion":"1.2","pollingTimeSec":0,"alarmLevel":"0","alarmType":"0","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"21","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","lastBreached":"1476965495","liliOffCommand":"","liliOnCommand":"","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"95","parametersTemplate":"775","productInfo":"1,95,9,5,2,1,1,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","useTemplate":"true","userDescription":"","value":"true"},"actions":{"reconfigure":0},"created":1476965486,"modified":1476965486,"sortOrder":138}
Great ! thank you :)
But I don't give you a date for a future release, I don't work on this project for now....
  • 3 mois après...
Aucune idée, faudrait avoir le JSON avant.
Au pire ça sera toujours possible en passant par une variable globale.
i y a un VD sur le fofo officielle qui remonte les data et push vers EMONCMS
j'ai installé pour voir
 if useGasNorthQ == true then
    rgas, status, errorCode = HC2:GET("/api/devices/"..gasNorthQID)
      jsonTable4 = json.decode(rgas)
      gasValueNow = jsonTable4.properties.value
      g1 = os.time{year=year, month=month, day=day, hour=00, min=01, sec=00}
      if g1 > time then
        gasStartToday = (jsonTable4.properties.value)
        fibaro:setGlobal("gasStartToday", gasStartToday)
      vgasStartToday = fibaro:getGlobal("gasStartToday")
      gasToday = gasValueNow-vgasStartToday
      fibaro:setGlobal("gasToday", gasToday)
      -- Gas per hour
      if minute == 00 then
        gasStartHour = gasValueNow
        fibaro:setGlobal("gasStartHour", gasStartHour)
      if minute == 59 then
        gasStopHour = gasValueNow
        gasHour = gasStartHour - gasStopHour
        fibaro:setGlobal("gasHour", gasHour)
      else
        gasStartHour = fibaro:getGlobal("gasStartHour")
        gasHour = gasValueNow - gasStartHour
et donc il semble recuperer le JSON pour conso depuis 1heure, sur la journée.
le plus compliqué semble donc de savoir si mon compteur est compatible. mais ca semble le cas
ouais alors les cumuls de conso, remise à zero à intervalle régulier (heure, jour, etc) c'est galère car ce n'est pas géré par Domocharts, donc tu auras bien des courbes, mais le calcul de statistiques journalières sera foireux. J'ai le problème avec la sonde de pluie du plugin Netatmo.
Hello - donc comme je l'ai dit sur le poste, ce device pas tres populaire fonctionne bien
peut être un peu cher pour ce que c'est versus un capteur REEM + ecodevice mais bon, ca évité de tirer des cables pour le moment :-) et ca semble compter correctement.
donc le nec plus ultra sera de plotter tout ca :-)
@Lazer quelles sont les solutions que tu préconises ?
merci pour ton aide
Modifié par Sakkhho
yes comment deja ?
like that ?
{{"id":545,"name":"Compteur Gaz","roomID":11,
"isPlugin":false,
"parentId":544,
"interfaces":["battery","fibaroFirmwareUpdate","zwave","zwaveWakeup"],
"properties":
{"batteryLevel":100,"parameters":[{"id":1,"lastReportedValue":1000,"lastSetValue":1000,"size":4,"value":1000},
{"id":2,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1},
{"id":3,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},
{"id":4,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},
{"id":5,"lastReportedValue":0,"lastSetValue":0,"size":1,"value":0},
{"id":6,"lastReportedValue":5,"lastSetValue":5,"size":1,"value":5},
{"id":7,"lastReportedValue":10,"lastSetValue":10,"size":1,"value":10},
{"id":8,"lastReportedValue":900,"lastSetValue":900,"size":2,"value":900},
{"id":9,"lastReportedValue":2536834,"lastSetValue":2536834,"size":4,"value":2536834},
{"id":10,"lastReportedValue":3,"lastSetValue":3,"size":2,"value":3},
{"id":11,"lastReportedValue":0,"lastSetValue":0,"size":2,"value":0},
{"id":13,"lastReportedValue":1,"lastSetValue":1,"size":1,"value":1}],
"pollingTimeSec":0,"wakeUpTime":900,"zwaveCompany":"NorthQ","zwaveInfo":"3,3,28",
"zwaveVersion":"3.35","batteryLowNotification":"true","configured":"true","dead":"false",
"defInterval":"0","deviceControlType":"0","deviceIcon":"1044","emailNotificationID":"0",
"firmwareUpdate":"{\"info\":\"\",\"progress\":0,\"status\":\"UpToDate\",\"updateVersion\":\"3.35\"}",
"markAsDead":"true","maxInterval":"0","minInterval":"0","model":"",
"nodeId":"117","parametersTemplate":"353","productInfo":"0,150,0,16,0,1,3,35",
"serialNumber":"h'00001153","smsNotificationID":"0","smsNotificationType":"0",
"stepInterval":"0","unit":"m³","updateVersion":"","useTemplate":"true","userDescription":"",
"value":"25376.66"},"actions":{"abortUpdate":1,"reconfigure":0,"retryUpdate":1,"setInterval":1,"startUpdate":1,"updateFirmware":1},
"created":1486045011,"modified":1486045011,"sortOrder":259}
Modifié par Sakkhho
OK il va falloir créer de nouvelles tables pour gérer le gaz, que tu peux appeler domotique_gaz
Avec PHPmyadmin, il faut copier une table existante.
Ensuite il faut ajouter les informations nécessaire dans les fichiers, de mémoire dans :
- index.php
- config.js
C'est essentiellement du copier/coller des lignes de configurations déjà existantes.... tu te sens de te lancer seul là dedans ?
- index.php
- config.js
