Moicphil Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 mise à jour HC2 > 4.036 > Added Device Support: Zipato RGBW Bulb QEES Dimmer UNI 400W > Resolved Issues: #0002797: Not possible to enter "rooms" section! #0002830: Devices with no template cannot save parameters. #0002335: Zipato RGBW Bulb #0002857: TypeError: undefined is not an object (evaluating 'r.isTypeOf') #0002234: sceneActivation doesn't trigger with Zwave.me KeyFob in 4.022 #0002980: No Template for Fibaro FGSD-002 Unjustified push alarms about fire Improved support for Fibaro Smoke Sensor UBS Temperature is not visivble on iPhone/iPad client (was known issues) > Known Issues: After the update clearing browser cache could be required Power Mettering may not work properly for some devices RGBW Controler may not work propery when used in in/out mode Alarm Panel doesn't work in some specific configurations Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins. - Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly 2 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Did Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Ah, ils reprennent enfin un rythme plus soutenu. Lien vers le commentaire Partager sur d’autres sites More sharing options...
neliger Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Tiens, suite à cette mise à jour, j'ai une alerte me disant que certains modules (Fibaro) n'ont pas de template. Je cherche comment résoudre cela. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Bon j'installe ce soir du coup. Mais toujours pas de plugin... Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Ca bouge un peu sur le support des modules, c'est bien. Manque les Qubino quand même... Lien vers le commentaire Partager sur d’autres sites More sharing options...
quadal Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 mise a jour effectué ras pour le moment. mes zipato bulb fonctionnent. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sebbrunie1 Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Bonjour à Tous, a chaque changement de version, a chaque fois, dans les modules virtuel, j'ai des "" qui se mettent dans l'adresse ip.... Du coup il ns ne fonctionnent plus et je dois les retirer module par module.... Quelqu'un à une solution? Merci Sébastien Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Bon finalement mise à jour encours... Seb, j'ai jamais eu ça... EDIT : Hum, j'ai perdu 90% de mes modules au reboot, c'est quoi cette cheize !!!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
neliger Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 EDIT : Hum, j'ai perdu 90% de mes modules au reboot, c'est quoi cette cheize !!!! Vide le cache de ton navigateur, j'ai eu cette blagounette aussi Lien vers le commentaire Partager sur d’autres sites More sharing options...
trainkill666 Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 @ Seb J'ai également eu le problème lors du passage 3.60 à4.035. Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Toujours pas de template pour Qubino FP... mais aussi pour interrupteur SwiidInter et .... Smoke Sensor 2 (FGSD-002) Rectificatif pour le Smoke Sensor 2 (FGSD-002)... lire la suite de ce post Lien vers le commentaire Partager sur d’autres sites More sharing options...
tcheri Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 (modifié) Toujours pas de template pour Qubino FP... mais aussi pour interrupteur SwiidInter et .... Smoke Sensor 2 (FGSD-002) ni pour Aeon-Labs Modifié le 13 mars 2015 par Moicphil Bonjour, inutile de citer le message situé juste au dessus. Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Oui ! pour éviter la crise cardiaque : touche F5 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Je le fais tout le temps le vidage de cache, mais là cela persiste. Seul solution pour le moment, me connecter sur l'interface anglaise... EDIT : Après reboot de la HC2 et revidage du cache, c'est ok... Chelou, jamais eu ça, pourtant j'en ai fais des mises à jour Lien vers le commentaire Partager sur d’autres sites More sharing options...
neliger Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 (modifié) Je le fais tout le temps le vidage de cache, mais là cela persiste. Seul solution pour le moment, me connecter sur l'interface anglaise... EDIT : Après reboot de la HC2 et revidage du cache, c'est ok... Chelou, jamais eu ça, pourtant j'en ai fais des mises à jour Je suppose que tu utilises FireFox, ce navigateur a sa propre définition du cache, et sa façon d'ignorer les demandes de rafraichissement de l'utilisateur. Modifié le 13 mars 2015 par Moicphil Bonjour, merci de ne pas citer un message situé juste au dessus. Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Je vois dans les problèmes résolus : #0002980: No Template for Fibaro FGSD-002 Je vais donc regarder de plus près des infos contradictoires : - j'obtiens le message "L´appareil ne dispose pas d´un modèle ce qui pourrait avoir des fonctionnalités limitées, veuillez contacter le support technique afin d´ajouter le modèle de ce dispositif." - j'ai la liste des paramètres. Mais je les avais saisies à la main hier, sans les voir apparaître ? ... et comme ils ont résolus le point suivant "#0002830: Devices with no template cannot save parameters" A suivre Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Non, je suis sur IE11, jamais eu de soucis. Bon, peut être un ratage, je ne sais pas. Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Bonne nouvelle pour le Smoke Sensor 2 (FGSD-002) Je vais écrire l'info au bon endroit du forum Lien vers le commentaire Partager sur d’autres sites More sharing options...
Fanou Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 @i-magin... coool enfin pour vous heureux possésseur de HC2... Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Ah ! on ne lit jamais assez les informations... moi, le premier : > Known Issues: After the update clearing browser cache could be required Lien vers le commentaire Partager sur d’autres sites More sharing options...
pepite Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 bon ben mise a jour ce soir ;-) Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Tiens, suite à cette mise à jour, j'ai une alerte me disant que certains modules (Fibaro) n'ont pas de template. Je cherche comment résoudre cela. Un conseil amical : découvrir le forum, n'hésites pas à chercher.... Voici la réponse à ta question : ICI Une précision : un bon nombre de demandes d'intégration de modules ont déjà été faites à Fibaro Lien vers le commentaire Partager sur d’autres sites More sharing options...
neliger Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 J'avais vu ce sujet avant de poster, oui, mais ces modules avaient un template avant la mise à jour. Ce serait étrange d'envoyer ces données à Fibaro pour un de leur propre module, non ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
i-magin Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Précises nous de quels modules il s'agit pour que l'on compare Lien vers le commentaire Partager sur d’autres sites More sharing options...
neliger Posté(e) le 13 mars 2015 Signaler Partager Posté(e) le 13 mars 2015 Il s'agit de presque tous (mais pas tous étrangement) mes capteurs d'ouverture de porte FGK-103, d'une télécommande 4 boutons Aeonlabs et de mes WallPlug FGWPE-101. Il n'y a qu'après la mise à jour que cette alerte de manque de template est apparue. J'avoue que je ne sais pas bien comment se gèrent ces templates, donc je n'ai pas ce qu'il faut pour comprendre de quelle façon ils auraient pu disparaitre de la box, à moins d'une erreur lors de la mise à jour. Lien vers le commentaire Partager sur d’autres sites More sharing options...
