HANSOLO Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 V4.032 hotfix dispo ce matin... This version is hot fixing version addressing some of issues reported by users.4.032 HotfixNew Functionalities:Polling setting available in Netatmo and Philips HUE pluginsResolved Issues:#0002409: Netatmo plugin doesn't work properly#0002487: Samsung Tv Plugin stops working after some time#0002528: Samsung TV plugin, SmartHub button does not work#0002590: Everspring AN145 Bulb Reconfiguration ProblemVoIP icon upload fixFix for Danfoss 1.1 soft-reconfigurationOther Z-Wave fixesDevice Support:#0002262: Benext Dimmer#0002308: Everspring AN145RCS EM-52ZWZ-Wave.Me Wall Controller WALLCKnown issues:After the update clearing browser cache could be requiredPower Mettering may not work properly for some devicesUBS Temperature is not visivble on iPhone/iPad clientRGBW Controler may not work propery when used in in/out modeAlarm Panel doesn't work in some specific configurationsPlugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.-Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.Breached sensor with Arm Delay causes instant alarm after being armedData range selection in event panel doesn't work properlyDevices imported via Gateway Connection may have no iconsGateway Connection status of dead device between master and slave controller may be differentDevices not properly configured on 3.X may not be converted properlyReconfiguration may not work properly in some casesOn mobile clients devices may be visible in different categories than configuredAdvanced settings for some imported devices may not work properlyHorstmann Thermostat HRT4-ZW higher battery usage in some casesDoorlocks - some functions may not work properly
Shad Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Tu m'as grillé toi. pour cette MAJ, à voir ce que veut dire z-wave fixes.
Krikroff Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Punaise 25 minutes que j'essaie de poster depuis mon smartphone, merci HANSOLO !!! enfin le Netatmo.... Envoyé de mon smartphone
carfnann Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 En cours, tiens ils supportent les benext dimmer! Mon issue va donc être cloturee Envoyé de mon iPhone àl'aide de Tapatalk
HANSOLO Posté(e) le 20 janvier 2015 Auteur Signaler Posté(e) le 20 janvier 2015 Gros doigts, petit téléphone = pas pratique
carfnann Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Bizarre j'ai fait un soft reconfigure de med 2 benext et pas mieux... Toujours pas de template Envoyé de mon iPhone àl'aide de Tapatalk
razowski Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Update passée, rien à signaler après 10 minutes On verra la suite, par-contre, la liste des bugs corrigés est pas très longue... Mais le principe d'un fix chaque semaine c'est assez plaisant, on sent que ça avance même si ça va pas vite.
Bouliboule Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Bonne nouvelle pour moi apparemment 2 soucis réglés: netatmo (à tester) et le double inter zwave.me. Je reviens vers vous ce soir. Bonne journée à tous
Krikroff Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Le 20/01/2015 à 08:14, HANSOLO a dit : Gros doigts, petit téléphone = pas pratique même pas, juste impossible de mettre un flag topic avec tapatalk mais pas grave, tu étais au rdv Envoyé de mon smartphone
Sakkhho Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 rien pour les DANFOSS ? edit; pas reveillé ce matin, il y a bien qq chose :-)
Alexis S. Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Une question le passage àla V 4.xxx. La 3.6 devait être passée pour faire la transition 3->4 mais elle n'est plus dispo. Est-ce que cela pose un problème de passer de 3,59 à4.032? Est-ce que ceux qui utilisent la 4.031 (ou 32) trouve la version suffisamment stable ou me conseillez vous d'attendre un peu pour une install en production?
Cardane Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Je suis en 4.31 depuis 15 jours et tout fonctionne bien, mis àpart l'accès distant àpartir d'un pc (ça marche sur iphone). Même le plugin Netatmo fonctionne correctement. J'ai juste deux modules AEON pour lesquels il n'y a pas de templates, mais ça ne pose pas de gros problèmes
fab971 Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Migration 4.031 --> 4.032 OK. Rien à signaler. Il faut dire que je n'avais pas de problèmes par rapport aux modules que je possède. Seul mon keyfob DSA22 qui n'a pas de template mais fonctionne correctement.
pepite Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Bonjour, Chanceux, moi c'est l'inverse, fonctionne sur PC mais pas sur iphone, donc pas de notifications..c'est chiant..et pas de news du support Citation mis à part l'accès distant à partir d'un pc (ça marche sur iphone)
fab971 Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Moi sur ça fonctionne àdistance sur PC et également sur iphone. Par contre, il semble y avoir un problème avec les notifications. Il faudra donner plus de détails sur les problèmes car ce n'est peut-être pas un bug mais un problème de configuration.
carfnann Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Ce qui est dingue c'est que tu fais un tour dans le bugzilla, les issues sont toujours ouvertes! voir même pas affectée... a quoi ca leur sert bugzilla si il ne font pas le suivi... lol A oui c'est vrai, ils vont se mettre en mode Agile...
Krikroff Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 @carfnann, j'ai moi aussi du mal à comprendre ... Toi tu veux postuler pour être Scrum Master (Pour ceux qui ne comprennent pas, non non je n'insulte pas carfnann ... )
carfnann Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Lol non merci je me fait déjàassez insulter en tant qu'architecte... Mais ne pas s'y méprendre j'adore la methodo Agile, j'ai fait parti d'une équipe. Mais on met de l'agile a tout les sauces... La je suis sur un projet SAP avec plus de 250pers en mode agile, une hérésie pour moi. Bon sinon cette 4.032 des retours positifs? Mon issue 2262 est Tjs la... Ne tarmo c'est mieux? J'ai hâté de rentrer pour tester mon wall controller Envoyé de mon iPhone àl'aide de Tapatalk
mprinfo Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Le 20/01/2015 à 09:35, Alexis S. a dit : Une question le passage àla V 4.xxx. La 3.6 devait être passée pour faire la transition 3->4 mais elle n'est plus dispo. Est-ce que cela pose un problème de passer de 3,59 à4.032? Est-ce que ceux qui utilisent la 4.031 (ou 32) trouve la version suffisamment stable ou me conseillez vous d'attendre un peu pour une install en production? Si tout fonction reste en 3.6 Envoyé de mon GT-I9305 en utilisant Tapatalk
Cardane Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 j'essaie de faire la mise à jour à distance mais je reçois un message d'accès interdit ... c'est normal ça ? je suis à 200 km de la maison, pas envie de faire la route pour une mise à jour :-) 1
forumAD Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Messieurs, Dans le change log, Fibaro indique ceci: "Fix for Danfoss 1.1 soft-reconfiguration" Quelqu'un saurait me dire ce que ça signifie? Est ce que c''est pour remonter les températures mesurées par le danfoss dans HC2? Merci de votre aimable réponse.
Alain56 Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Bonjour à tous, Quelqu'un a testé la keyfob2, elle fonctionne sous cette version? Merci
razowski Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Ils en ferment même qui sont pas résolus... Du gros n'importe quoi
jojo Posté(e) le 20 janvier 2015 Signaler Posté(e) le 20 janvier 2015 Fibaro avance , mais la liste des known issues reste longue. Si on y ajoute les unknown issue. Je reste en 3.600 (même si tout ne va pas non plus). Courageux, mais pas téméraire ...
