V4.032 hotfix dispo ce matin...
This version is hot fixing version addressing some of issues reported by users.
4.032 Hotfix
New Functionalities:
Polling setting available in Netatmo and Philips HUE plugins
Resolved Issues:
#0002409: Netatmo plugin doesn't work properly
#0002487: Samsung Tv Plugin stops working after some time
#0002528: Samsung TV plugin, SmartHub button does not work
#0002590: Everspring AN145 Bulb Reconfiguration Problem
VoIP icon upload fix
Fix for Danfoss 1.1 soft-reconfiguration
Other Z-Wave fixes
Device Support:
#0002262: Benext Dimmer
#0002308: Everspring AN145
RCS EM-52ZW
Z-Wave.Me Wall Controller WALLC
Known issues:
After the update clearing browser cache could be required
Power Mettering may not work properly for some devices
UBS Temperature is not visivble on iPhone/iPad client
RGBW Controler may not work propery when used in in/out mode
Alarm Panel doesn't work in some specific configurations
Plugins for TV Sets of various manufacturers may not work with its newes firmware due to restricions provided by new devices firmware. There will be added detalied information about suported firmwave versions within plugins.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks - some functions may not work properly
Punaise 25 minutes que j'essaie de poster depuis mon smartphone, merci HANSOLO !!!
enfin le Netatmo....
Envoyé de mon smartphone
Update passée, rien à  signaler après 10 minutes  :2:  On verra la suite, par-contre, la liste des bugs corrigés est pas très longue... Mais le principe d'un fix chaque semaine c'est assez plaisant, on sent que ça avance même si ça va pas vite.
Bonne nouvelle pour moi apparemment 2 soucis réglés: netatmo (à  tester) et le double inter zwave.me.
Je reviens vers vous ce soir. Bonne journée à  tous
Gros doigts, petit téléphone = pas pratique
même pas, juste impossible de mettre un flag topic avec tapatalk mais pas grave, tu étais au rdv
Une question le passage àla V 4.xxx. La 3.6 devait être passée pour faire la transition 3->4 mais elle n'est plus dispo. Est-ce que cela pose un problème de passer de 3,59 à4.032?
Est-ce que ceux qui utilisent la 4.031 (ou 32) trouve la version suffisamment stable ou me conseillez vous d'attendre un peu pour une install en production?
Je suis en 4.31 depuis 15 jours et tout fonctionne bien, mis àpart l'accès distant àpartir d'un pc (ça marche sur iphone). Même le plugin Netatmo fonctionne correctement.
J'ai juste deux modules AEON pour lesquels il n'y a pas de templates, mais ça ne pose pas de gros problèmes
Migration 4.031 --> 4.032  OK.
Rien à  signaler. Il faut dire que je n'avais pas de problèmes par rapport aux modules que je possède.
Seul mon keyfob DSA22 qui n'a pas de template mais fonctionne correctement.
Chanceux, moi c'est l'inverse, fonctionne sur PC mais pas sur iphone, donc pas de notifications..c'est chiant..et pas de news du support
mis à  part l'accès distant à  partir d'un pc (ça marche sur iphone)
Moi sur ça fonctionne àdistance sur PC et également sur iphone. Par contre, il semble y avoir un problème avec les notifications.
Il faudra donner plus de détails sur les problèmes car ce n'est peut-être pas un bug mais un problème de configuration.
Ce qui est dingue c'est que tu fais un tour dans le bugzilla, les issues sont toujours ouvertes! voir même pas affectée...
a quoi ca leur sert bugzilla si il ne font pas le suivi... lol
A oui c'est vrai, ils vont se mettre en mode Agile... :P
@carfnann, j'ai moi aussi du mal à  comprendre :rolleyes: ...
Toi tu veux postuler pour être Scrum Master :D  (Pour ceux qui ne comprennent pas, non non je n'insulte pas carfnann ... )
Lol non merci je me fait déjàassez insulter en tant qu'architecte... Mais ne pas s'y méprendre j'adore la methodo Agile, j'ai fait parti d'une équipe. Mais on met de l'agile a tout les sauces... La je suis sur un projet SAP avec plus de 250pers en mode agile, une hérésie pour moi.
Bon sinon cette 4.032 des retours positifs? Mon issue 2262 est Tjs la...
Ne tarmo c'est mieux?
J'ai hâté de rentrer pour tester mon wall controller
Si tout fonction reste en 3.6
Envoyé de mon GT-I9305 en utilisant Tapatalk
j'essaie de faire la mise à  jour à  distance mais je reçois un message d'accès interdit ...  c'est normal ça ?
je suis à  200 km de la maison, pas envie de faire la route pour une mise à  jour :-)
Messieurs,
Dans le change log, Fibaro indique ceci: "Fix for Danfoss 1.1 soft-reconfiguration"
Quelqu'un saurait me dire ce que ça signifie?
Est ce que c''est pour remonter les températures mesurées par le danfoss dans HC2?
Merci de votre aimable réponse.
Fibaro avance  :) , mais la liste des known issues reste longue. Si on y ajoute les unknown issue. Je reste en 3.600 (même si tout ne va pas non plus).
Courageux, mais pas téméraire ...
