sebcbien Posté(e) le 3 février 2015 Auteur Signaler Posté(e) le 3 février 2015 Un copain m'a demandé d'ajouter la possibilité d'avoir des lampes sélectionnées qui resteraient allumées en permanence durant toute la simulation... C'est une bonne suggestion permettant de coller encore mieux àla réalité. Voici un debug pour se faire une idée: [DEBUG] 23:42:39: Presence Simulator | v2.6.0 [DEBUG] 23:42:39: -------------------------------- [DEBUG] 23:42:39: Not starting Simulation (Simu_presence = 0) [DEBUG] 23:42:39: Presence Simulator is Terminated [DEBUG] 23:42:52: Presence Simulator | v2.6.0 [DEBUG] 23:42:52: -------------------------------- [DEBUG] 23:42:52: It s sunset time -> Simulation ON [DEBUG] 23:42:52: Turning On always on lights: [DEBUG] 23:42:52: Device: Bureau On [DEBUG] 23:42:52: Now randomizing other lights... [DEBUG] 23:42:53: light ID:Cellier status:99 [DEBUG] 23:42:53: entering loop of 6.25 minutes [DEBUG] 23:43:16: exiting loop of 6.25 minutes [DEBUG] 23:43:16: TurnOff All lights! [DEBUG] 23:43:16: Device: Salle De Bain Off [DEBUG] 23:43:16: Device: Hall Off [DEBUG] 23:43:16: Device: Cellier Off [DEBUG] 23:43:16: Device: Chambre Amis Off [DEBUG] 23:43:16: Device: Bureau Off [DEBUG] 23:43:16: Manual Light Settings: Turned On light: Hall [DEBUG] 23:43:16: Simulation is deactivated [DEBUG] 23:43:16: Presence Simulator is Terminated [DEBUG] 23:43:16: Simu = 0, Exit from scene Et voici le code: --[[ %% autostart %% properties %% globals Simu_presence --]] --------------------------------- -- YAPS Presence Simulator V2.6.1 -- SebcBien -- Février 2015 --------------------------------- --V2.6.1 -- Added naming of devices in the debug during simulation --V2.6.0 -- Added the possibility to select always on light during simulation --V2.5.0 -- fixed simulation starting if restarted between endtime & midnight --v2.4.1 -- fixed big bug simulator restarting after end time --V2.3.1 -- small notification and debug changes --V2.3 -- Rewriting the engine -- now relaunch automatically the next day, even if Simu_presence has not changed --V2.2 -- Added Manual Stop variable -- added list of mobiles if (fibaro:countScenes() > 1) then --fibaro:debug("More than one scene active, exiting!"); fibaro:abort(); end --------------------- USER SETTINGS -------------------------------- local id = { LAMPE_SDB = 16, LAMPE_CH_AMIS = 24, LAMPE_SALON = 45, LAMPE_BUREAU = 49, LAMPE_HALL = 52, LAMPE_CELLIER = 56, LAMPE_CH_EMILIEN = 58, PHONE_NEXUS_5 = 53, PHONE_NEXUS_4 = 104 } local stop_hour = "01"; -- Hour when you want simulation to stop local stop_minute = "10"; -- Minute of the hour you want simulation to stop -- note 1: the script will not exit while waiting the random time of the last light turned on. So end time can be longer than specified end time -- note 2: if the global variable changes during the same wait time as above, it will exit immediately (when back home while simulation runs) local rndmaxtime = 15; -- random time of light change in minutes --> here each device is on maximum 30min local ID_devices_lights_always_on = {id["LAMPE_BUREAU"]} -- IDs of lights who will always stay on during simulation local ID_devices_lights = {id["LAMPE_SDB"],id["LAMPE_HALL"],id["LAMPE_CELLIER"],id["LAMPE_CH_AMIS"]} -- IDs of lights to use in simulation --local ID_devices_lights = {id["LAMPE_BUREAU"],id["LAMPE_CELLIER"]} -- Reduced set for test purposes local activatePush = true; -- activate push when simulation starts and stops --local ID_Smartphones = {id["PHONE_NEXUS_5"],id["PHONE_NEXUS_4"]}; local ID_Smartphones = {id["PHONE_NEXUS_5"]}; -- list of device receiving Push local ID_On_After_Simu = 0; -- If next line is commented, no light will turn on after simulation ends local ID_On_After_Simu = id["LAMPE_HALL"]; -- Only One ID of a light to turn on after simulation ends. Comment this line to turn off this feature --------------------- USER SETTINGS END ---------------------------- ----------------------ADVANCED SETTINGS----------------------------- local showStandardDebugInfo = true; -- Debug shown in white local showExtraDebugInfo = false; -- Debug shown in orange local numbers_lights = #ID_devices_lights; -- numbers of light devices listed above local manualOveride = fibaro:getGlobal("overideSimuSunset"); -- if = 1 then the simulation is forced -------------------------------------------------------------------- -------------------- DO NOT CHANGE CODE BELOW ---------------------- -------------------------------------------------------------------- local version = "2.6.1"; local simu = fibaro:getGlobal("Simu_presence"); --value of the global value: simulation is on or off local start_simu = fibaro:getValue(1, "sunsetHour"); --Start simulation when sunset local endtime; local wait_for_tomorrow = 1; local NotifLoop = 30; SimulatorPresenceEngine = {}; -- FONCTIONS Debug = function ( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span")); end ExtraDebug = function (debugMessage) if ( showExtraDebugInfo ) then Debug( "orange", debugMessage); end end StandardDebug = function (debugMessage) if ( showStandardDebugInfo ) then Debug( "white", debugMessage); end end round = function (num, idp) local mult = 10^(idp or 0) return math.floor(num * mult + 0.5) / mult end -- Push message to mobile pushMessage = function (sendPush) if (activatePush) then for i=1, #ID_Smartphones do fibaro:call(tonumber(ID_Smartphones[i]), 'sendPush', sendPush); ExtraDebug("Push message ("..sendPush..") sent to mobile: "..tonumber(ID_Smartphones[i])); end end end -- Calculate endtime function SimulatorPresenceEngine:EndTimeCalc() local start = os.date("%H:%M") local time = os.time() local date = os.date("*t", time) local year = date.year local month = date.month local day = date.day endtime = os.time{year=year, month=month, day=day, hour=stop_hour, min=stop_minute, sec=sec} -- to calculate when it's daytime local currentHour = os.date("*t") local sunrise = tonumber(string.sub (fibaro:getValue(1,'sunriseHour'), 1 , 2) ) * 60 + tonumber(string.sub(fibaro:getValue(1,'sunriseHour'), 4) ) local sunset = tonumber(string.sub (fibaro:getValue(1,'sunsetHour'), 1 , 2) ) * 60 + tonumber(string.sub(fibaro:getValue(1,'sunsetHour'), 4) ) local now = currentHour.hour * 60 + currentHour.min; --ExtraDebug ("debug info: Sunrise : " .. sunrise .. " Sunset : "..sunset .. " Now : " ..now); --ExtraDebug ("debug info: Current OS Time" ..os.time()) --ExtraDebug ("debug info: Original planed EndTime " ..endtime) --ExtraDebug ("debug info: os.date: "..os.date("%H:%M").. " sunrisehour: "..fibaro:getValue(1, "sunriseHour")) if ((wait_for_tomorrow == 0) and (endtime < os.time())) then -- if endtime is gone and it's the first launch of simulator endtime = endtime + 24*60*60 -- add 24h at endtime after the night is gone start_simu = fibaro:getValue(1, "sunsetHour"); -- recalculate for next day ExtraDebug ("Added 24H to Endtime (first start ending after midnignt)"); ExtraDebug ("Recalculated Simulation StartHour (Sunset): " .. start_simu); wait_for_tomorrow = 1 end if (wait_for_tomorrow == 1 and (endtime < os.time()) and ((now >= sunrise) and (now <= sunset))) then -- if it looping days and endtime is gone and we are daytime endtime = endtime + 24*60*60 -- add 24h at endtime after the night is gone start_simu = fibaro:getValue(1, "sunsetHour"); -- recalculate for next day ExtraDebug ("Added One Day to Endtime: " .. endtime); ExtraDebug ("Recalculated Simulation StartHour (Sunset): " .. start_simu); end --ExtraDebug ("debug info: Recalculated planed EndTime " ..endtime) end -- Simulate Presence Main function SimulatorPresenceEngine:Launch() pushMessage("Lights simulation started, will stop at: "..stop_hour..":"..stop_minute) ExtraDebug("Lights simulation started, will stop at: "..stop_hour..":"..stop_minute ); SimulatorPresenceEngine:TurnOn(ID_devices_lights_always_on); while ((os.time() <= endtime) and (simu == "1")) or ((manualOveride == "1")) do -- original code: while ((os.time() <= endtime) and (simu == "1")) or ((os.time() <= endtime) and (simu == "1") and (manualOveride == "1")) do if time == endtime then StandardDebug("time and endtime same value -> end") end local random_light = tonumber(ID_devices_lights[math.random(numbers_lights)]) --choose a random light in the list local lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light in the list -- turn on the light if off or turn off if on if tonumber(lightstatus) == 0 then fibaro:call(random_light, 'turnOn') else fibaro:call(random_light, 'turnOff') end fibaro:sleep(1000); --necessary to get back the new status, because HC2 is too fast :-) lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light after his update StandardDebug('light ID:'.. fibaro:getName(random_light) ..' status:'..lightstatus); local sleeptime = math.random(rndmaxtime*60000) --random sleep StandardDebug("entering loop of " .. round(sleeptime/60000,2) .. " minutes"); -- This modification allows to exit the scene if the Simu_presence global var changes to 0 during the random sleep local counterexitsimu = 200 while (counterexitsimu > 0) do counterexitsimu = counterexitsimu - 1; test_presence_state = fibaro:getGlobal("Simu_presence"); simu = tonumber(test_presence_state); --verify the global value, if the virtual device is deactivated, the scene stops. --fibaro:debug("simu var state : " .. simu); if simu == 0 then counterexitsimu = 0 end fibaro:sleep(sleeptime/200); end StandardDebug("exiting loop of " .. round(sleeptime/60000,2) .. " minutes"); local sleeptimemin = math.abs(sleeptime/60000) --StandardDebug('sleeptime:'..sleeptimemin); simu = fibaro:getGlobal("Simu_presence"); --verify the global value, if the virtual device is deactivated, the scene stops. manualOveride = fibaro:getGlobalValue("overideSimuSunset"); end end function SimulatorPresenceEngine:EndSimulation() SimulatorPresenceEngine:TurnOff(ID_devices_lights,ID_devices_lights_always_on); Debug("red","Simulation is deactivated"); if (simu == "1") then Debug("grey", "Presence Simulator will Restart tomorrow around ".. fibaro:getValue(1, "sunsetHour")); pushMessage("Presence Simulator will Restart tomorrow around ".. fibaro:getValue(1, "sunsetHour")); wait_for_tomorrow = 1 -- will make EndTimeCalc add 24h to endtime during daytime end end function SimulatorPresenceEngine:ExitSimulation() Debug("red","Presence Simulator is Terminated"); pushMessage("Presence Simulator is Terminated"); end -- Switch off devices in the list function SimulatorPresenceEngine:TurnOff(group,group2) Debug("red","TurnOff All lights!"); local name, id2; local ID_devices_group = group; for i=1, #ID_devices_group do id2 = tonumber(ID_devices_group[i]); fibaro:call(id2, "turnOff"); name = fibaro:getName(id2); if (name == nil or name == string.char(0)) then name = "Unknown" end StandardDebug("Device: " .. name .. " Off "); end local ID_devices_group = group2; for i=1, #ID_devices_group do id2 = tonumber(ID_devices_group[i]); fibaro:call(id2, "turnOff"); name = fibaro:getName(id2); if (name == nil or name == string.char(0)) then name = "Unknown" end StandardDebug("Device: " .. name .. " Off "); end if ID_On_After_Simu ~= 0 then fibaro:call(ID_On_After_Simu, "turnOn"); name = fibaro:getName(ID_On_After_Simu); if (name == nil or name == string.char(0)) then name = "Unknown" end Debug("red","Manual Light Settings: Turned On light: " .. name); end end -- Switch on devices in the list function SimulatorPresenceEngine:TurnOn(group) Debug("red","Turning On always on lights:"); local name, id2; local ID_devices_group = group; for i=1, #ID_devices_group do id2 = tonumber(ID_devices_group[i]); fibaro:call(id2, "turnOn"); name = fibaro:getName(id2); if (name == nil or name == string.char(0)) then name = "Unknown" end StandardDebug("Device: " .. name .. " On "); end Debug("red","Now randomizing other lights..."); end Debug("green", "Presence Simulator | v" .. version ); Debug( "green", "--------------------------------"); if tonumber(stop_hour) <= 12 then wait_for_tomorrow = 0 end -- if stop hour is between 00 and 12h then will consider that stop hour is before midnight ------------------------ Main Loop ---------------------------------- if (simu == "0") then Debug("red","Not starting Simulation (Simu_presence = 0)"); SimulatorPresenceEngine:ExitSimulation(); fibaro:abort(); end pushMessage("Scheduled Simulation starting time: " .. start_simu); ExtraDebug("Today's sunset is at "..fibaro:getValue(1, "sunsetHour").." - End of Simulation at "..stop_hour..":"..stop_minute); while (simu=="1" or simu=="0" ) do SimulatorPresenceEngine:EndTimeCalc(); -- local start_simu = "00:01" -- uncomment this line when testing to force a start hour (for the first loop) if (os.date("%H:%M") >= start_simu) then -- define if nighttime (sunset) sunset = 1 else sunset = 0 end if (simu == "1") then if sunset == 1 and (os.time() <= endtime) then Debug("grey", "It's sunset time -> Simulation ON"); SimulatorPresenceEngine:Launch(); SimulatorPresenceEngine:EndSimulation(); end if manualOveride == "1" then Debug("grey", "Manual Override Activated -> Simulation ON"); SimulatorPresenceEngine:Launch(); SimulatorPresenceEngine:EndSimulation(); end --fibaro:debug("sunset: "..sunset .. "endtime: " .. endtime .. "ostime: " .. os.time()); if manualOveride == "0" and sunset == 0 and NotifLoop == 30 then Debug("grey", "Waiting for next Sunset -> Simulation OFF."); end end if sunset == 1 and (os.time() >= endtime) and (os.time() <= (endtime + 60)) then Debug("grey","Simulation ended for this night."); end if (simu == "0") then -- Condition to end simulation SimulatorPresenceEngine:ExitSimulation(); Debug("red","Simu = 0, Exit from scene"); fibaro:abort(); end if NotifLoop <= 30 then if NotifLoop == 30 then NotifLoop = 0 end if NotifLoop == 0 then ExtraDebug("Looping to check for changes every 2min") end NotifLoop = NotifLoop + 1 end fibaro:sleep(2*60*1000); simu = fibaro:getGlobal("Simu_presence"); manualOveride = fibaro:getGlobal("overideSimuSunset"); end 1
jojo Posté(e) le 17 février 2015 Signaler Posté(e) le 17 février 2015 GENIAL : quand je vois ça, je me dis que tu aurais bien plus mérité que moi de gagner le concours du membre du mois de janvier. La preuve : j'ai une bête question. A quoi sert le statut "marche forcée" / "Overide" ? Là , on a fait une simulation de présence pour le soir. Y aurait-il moyen de faire qqch de similaire le matin ? entre 6h00 et le lever du soleil ou 7h30 ?
pepite Posté(e) le 17 février 2015 Signaler Posté(e) le 17 février 2015 yes, encore mieux, faut que je pense àmettre YAPS ;-) beau boulot encore !! :) :60:
pepite Posté(e) le 17 février 2015 Signaler Posté(e) le 17 février 2015 @jojo : pour moi le override te permet de lancer la simu en dehors de l'horaire de depart prévu ;-) mais laissons @sebcbien répondre ;-) @sebcbien : question pratique : tu trouves vraiment que les VD ne servent qu'a odifier des VG et après tout en mode scene ?
sebcbien Posté(e) le 17 février 2015 Auteur Signaler Posté(e) le 17 février 2015 GENIAL : quand je vois ça, je me dis que tu aurais bien plus mérité que moi de gagner le concours du membre du mois de janvier. La preuve : j'ai une bête question. A quoi sert le statut "marche forcée" / "Overide" ? Là , on a fait une simulation de présence pour le soir. Y aurait-il moyen de faire qqch de similaire le matin ? entre 6h00 et le lever du soleil ou 7h30 ? Pas de problème, je t'envoie mon adresse par mp pour que tu m'envoie ton lot ? La marche forcée, c'est pour forcer la simulation de présence en dehors des heures prévues. Pour le moment, professionnellement j'ai énormément de charge et j'ai du mal à faire le perso... dit autrement: je ne saurais pas me replonger dedans avant qq semaines.. Mais ce que tu peux faire comme work around, avec GEA activer la marche forcée avec overideSimuSunset et la désactiver au lever du soleil
sebcbien Posté(e) le 17 février 2015 Auteur Signaler Posté(e) le 17 février 2015 @sebcbien : question pratique : tu trouves vraiment que les VD ne servent qu'a odifier des VG et après tout en mode scene ? Bah je trouve ça très simple, pas d'id de boutons nécessaires pour commander des VD... Donc le code est portable et migrable très facilement... Modifier le VD aussi, ajouter un bouton ou un caption avant ceux existants ne va pas modifier la numérotation. et les VG son lisible et modifiables par d'autres scripts, scènes etc.
jojo Posté(e) le 17 février 2015 Signaler Posté(e) le 17 février 2015 @sebcbien, merci de ta réponse. La marche forcée, c'est pour forcer la simulation de présence en dehors des heures prévues. c'est quand les heures prévues ?: du couché du soleil (ligne 72) à l'heure de fin programmée (lignes 48-49) ? Et donc la marche forcée, c'est 24h/24 ? J'ai bien compris ? Ton tuto me donne pleins d'autres idées. Puis-je faire plusieurs copies de la scène ? Je pense à une scène du couché du soleil à 22h30 avec certaines lumières, et une autre de 22h30 à 2h00 avec d'autres lampes, une 3° pour le matin avec encore d'autres lampes ? Merci encore, c'est grandiose : quand je met l'alarme, ça met la variable Simu_presence à 1 et à 0 quand je la retire. Plus besoin d'y penser ;-)
pepite Posté(e) le 19 février 2015 Signaler Posté(e) le 19 février 2015 @sebcbien : merci. Je vais essayer de prendre les bonnes habitudes. SCENES en LUA VG : j'ai bien compris l'importance hihihi, ca donne enormement de possibilites a priori les Vd pour modifier les VG et lancer les scenes en fonction @jojo moi je dirais oui pour les scenes diffferentes mais bonjour l'usine a gaz a gerer alors que Yaps fait ca tres bien en 1 scene, change l h'eure de debut non ? 1
jojo Posté(e) le 19 février 2015 Signaler Posté(e) le 19 février 2015 Je pense que c'est possible sans faire d'usine à gaz et changer tout le code 1/ pourquoi est-ce que je veux faire ça ? car entre le coucher du soleil et 20h00 je suis à la cuisine => cuisine allumée en continu, et 1 ou 2 autres lampes qui se modifient car entre 20h et 22h30 je suis devant la TV => salon allumé en continu, et 1 ou 2 autres lampes qui se modifient le matin entre 6h et 7h30 on elève => SdB et cuisine ... Je pense qu'il est possible de faire cela simplement 1/ 3 scénarios (matin; fin pm et soir) => 3 fois la scènes (avec un autre nom) 2/ dédoubler les VG, et modifier le début de la scène pour qu'il aille lire la bonne variable 3/ modifier légèrement la scène pour que l'heure de départ ne soit plus le sunset, mais une valeur fixe 4/ dans le VD : ajuster les VG à mettre à jour
sebcbien Posté(e) le 19 février 2015 Auteur Signaler Posté(e) le 19 février 2015 @sebcbien, merci de ta réponse. c'est quand les heures prévues ?: du couché du soleil (ligne 72) à l'heure de fin programmée (lignes 48-49) ? Et donc la marche forcée, c'est 24h/24 ? J'ai bien compris ? Oui Je pense que c'est possible sans faire d'usine à gaz et changer tout le code 1/ pourquoi est-ce que je veux faire ça ? car entre le coucher du soleil et 20h00 je suis à la cuisine => cuisine allumée en continu, et 1 ou 2 autres lampes qui se modifient car entre 20h et 22h30 je suis devant la TV => salon allumé en continu, et 1 ou 2 autres lampes qui se modifient le matin entre 6h et 7h30 on elève => SdB et cuisine ... Je pense qu'il est possible de faire cela simplement 1/ 3 scénarios (matin; fin pm et soir) => 3 fois la scènes (avec un autre nom) 2/ dédoubler les VG, et modifier le début de la scène pour qu'il aille lire la bonne variable 3/ modifier légèrement la scène pour que l'heure de départ ne soit plus le sunset, mais une valeur fixe 4/ dans le VD : ajuster les VG à mettre à jour Je ne comprends pas bien, tu veux faire de la simulation de présence quand tu est là ??
jojo Posté(e) le 19 février 2015 Signaler Posté(e) le 19 février 2015 Je ne comprends pas bien, tu veux faire de la simulation de présence quand tu est là ?? Non, je ne veux pas faire de la simulation de présence quand je suis là , mais il faut que ce soit le plus réaliste possible. => la lumière allumée en continu dans la cuisine à l'heure de table, puis à la TV en soirée, c'est plus réaliste. Et le matin tôt en semaine, c'est sympa, c'est comme si j'allais travailler. Est-ce que ma proposition de réalisation tient la route ?
pepite Posté(e) le 19 février 2015 Signaler Posté(e) le 19 février 2015 ca a l'air de tenir la route, je trouve ca sympa d'essayer d'etre au plus proche de ce qui se passe effectivement lorsque tu es la. Mais je me demande toujours : quand moi je pars, je baisse les volets ;-), pas vous ? je veux faire aussi de la simu en mon absence mais quid des volets ? Avez-vous des fenetres sans volets ?
sebcbien Posté(e) le 19 février 2015 Auteur Signaler Posté(e) le 19 février 2015 @jojo Ok, oui, ça tiens la route... Ceci dit, je ne pense pas que des voleurs vont venir plusieurs jours étudier les habitudes des gens qu'ils veulent dérober, style la grande évasion @pepite, pas de volets chez moi, triple vitrage
jojo Posté(e) le 19 février 2015 Signaler Posté(e) le 19 février 2015 ca a l'air de tenir la route, je trouve ca sympa d'essayer d'etre au plus proche de ce qui se passe effectivement lorsque tu es la. Mais je me demande toujours : quand moi je pars, je baisse les volets ;-), pas vous ? je veux faire aussi de la simu en mon absence mais quid des volets ? Avez-vous des fenetres sans volets ? Pepite, j'ai pas de volets => la question ne se pose pas pour moi J'utilise la simulation de présence de sebcbien de la manière suivante : si l'alarme (non HC2) est activée (cela veux dire que je suis absent pour 1 soir ou 3 mois) la simul de présence démarre et avec les 3 scénarios éventuellement. lorsque je coupe l'alarme, la variable se remet à 0 et tout s'arrête. => c'est génial, je n'ai à penser à rien ! Par ailleurs, j'ai une variable Vacance = Oui/non, que maintenant que j'ai une HC2, je pourrai utiliser pour désactiver/ré-activer le chauffage. Elle pourrait également être utilisée pour gérer l'ouverture et la fermeture automatique des volets.
forumAD Posté(e) le 23 février 2015 Signaler Posté(e) le 23 février 2015 Hello, Est ce possible d'ajouter dans le module de simulation de présence, des paramètres pour pouvoir allumer son sonos et diffuser de la musique pendant x temps? ça serait vraiment le pied. @sebcbien, te connaissant, j'imagine que c'est dans tes plans d'évolution futurs?
jojo Posté(e) le 23 février 2015 Signaler Posté(e) le 23 février 2015 si allumer ta sono est un simple interrupteur (comme un WP par exple), il suffit de le déclarer comme une lampe ...
sebcbien Posté(e) le 25 février 2015 Auteur Signaler Posté(e) le 25 février 2015 Hello, Est ce possible d'ajouter dans le module de simulation de présence, des paramètres pour pouvoir allumer son sonos et diffuser de la musique pendant x temps? ça serait vraiment le pied. @sebcbien, te connaissant, j'imagine que c'est dans tes plans d'évolution futurs? J'ai un peu réfléchi à cette demande pour sonos et je me suis dit que si j'y accède je n'ai pas fini. ... Et tu peux déclencher -mes volets -mon arrosage -ma sonos -mon ampli Pioneer... etc Ce que je propose c'est 3 paramètres: - nom d'une VG - valeur à y stocker en début de simulation - valeur à y stocker en fin de simulation. libre à vous de surveiller cette variable dans une scène ou mainloop d'un virtual device et déclencher n'importe quelle action. La solution de jojo est bonne mais ne convient que pour des appareils et il auront un comportement aléatoire, comme les lampes.
forumAD Posté(e) le 25 février 2015 Signaler Posté(e) le 25 février 2015 Merci pour vos réponses; mais pour l'histoire des VG et leur stockage, pourrais-tu nous donner un exemple?
sebcbien Posté(e) le 25 février 2015 Auteur Signaler Posté(e) le 25 février 2015 si je modifie une VG dans mon script de simulation, une autre scène (GEA par exemple) peut être déclenchée. ensuite d'après le contenu de cette VG, une action peut être décidée. exemple: http://www.domotique-fibaro.fr/index.php/topic/2143-showroom-configs-gea/ quand la VG phone_GG_present change, le script se lance grâce à : %% globals Phone_GG_Present puis une action est décidée grâce à cette ligne gea: ---------------DETECTION PRESENCE-------------- -- Signale GG at Home GEA peux se déclencher sur un changement de valeur d'une variable global GEA.add({"Global", "Phone_GG_Present", "1"}, -1, "Presence GG est maintenant à #value#", {{"Portable", 53}, {"Time", "00:01", "23:59"}}) GEA.add({"Global", "Phone_GG_Present", "0"}, -1, "Presence GG est maintenant à #value#", {{"Portable", 53}, {"Time", "00:01", "23:59"}})
forumAD Posté(e) le 25 février 2015 Signaler Posté(e) le 25 février 2015 Bonne idée; Je vais essayer tout ça et je te tiens au courant!
sebcbien Posté(e) le 26 février 2015 Auteur Signaler Posté(e) le 26 février 2015 Ce we j'aurai probablement un peu de temps pour faire ça. Sent From my Vic20
jojo Posté(e) le 3 mars 2015 Signaler Posté(e) le 3 mars 2015 @sebcbien, Est-ce que ton simulateur de présence est compatible avec la v4.x (ce sera mon trigger pour migrer ou pas) ?
sebcbien Posté(e) le 3 mars 2015 Auteur Signaler Posté(e) le 3 mars 2015 Petit être, mais jamais testé et je ne suis pas prêt de passer en v4 avec les lenteurs de gea... Sent From my Vic20
zaboul Posté(e) le 29 mars 2015 Signaler Posté(e) le 29 mars 2015 Bonjour, Je voulais utiliser le script mais sans l'utilisation de la fonction "always on". Qu faut il que je mette dans la variable pour que cela ne crashe pas. sinon j'ai aussi une question lua. J'ai bien compris que la variable globale "simu-presence" est declare au debut du script. Mais je ne comprends pas trop pourquoi la variable "overideSimuSunset" ne l'est pas. Merci d'avance Xavier
