Il y a 16 heures, mprinfo a dit :
Le réveil des vieux@Jojo apparaît est@Did sort d hibernation emoji1787.pngemoji23.png
c'est peut-être parce qu'il aime les chats (noirs) ?
Hello,
J'ai toujours un souci que mes lampes ne s'eteignent pas a la fin de la simulation quand la simulation rest en route pour le lendemain. Voici mon script:
%% autostart
%% globals
Simu_presence
local version = "3.6.1";
-- YAPS Presence Simulation by SebcBien
-- August 2015
-- modifications Hue de Pepite, merci!
if (fibaro:countScenes() > 1) then
    fibaro:debug("Scene already active! Aborting this new instance !!");
    fibaro:abort();
-------------------- USER SETTINGS --------------------------------
local id = {
LAMPE_SALON_SPOT	= 855,
LAMPE_TOILETTE		= 544,
LAMPE_TABLE			= 197,
LAMPE_CUISINE		= 813,
LAMPE_HALL			= 878,
LAMPE_LED_SALON		= 890,
LAMPE_ESCALIER		= 213,
PHONE_PAPA			= 1290,
LAMPE_GARAGE		= 826
local Stop_hour = "01";     -- Hour when you want Simulation to stop
local Stop_minute = "05";    -- Minute of the hour you want Simulation to stop
-- note 1: the script will not exit while waiting the random time of the last light turned on. So end time can be longer than specified end time. (even more with var Random_max_TurnOff_duration)
-- note 2: if the global variable changes during the same wait time as above, it will exit immediately (when back home while Simulation runs)
local Sunset_offset = -15    -- number of minutes before or after sunset to activate Simulation
local Random_max_duration = 18;   -- random time of light change in minutes --> here each device is on maximum 30min
local Random_max_TurnOff_duration = 22; -- random time to add at the stop hour+stop minute so the Simulation can be more variable (0 to deactivate)
local Lights_always_on = {} -- IDs of lights who will always stay on during Simulation - leave empty array if none -> {}
local Random_lights = {id["LAMPE_SALON_SPOT"],id["LAMPE_HALL"],id["LAMPE_TABLE"],id["LAMPE_CUISINE"],id["LAMPE_TOILETTE"],id["LAMPE_ESCALIER"]} -- IDs of lights to use in Simulation
--local Random_lights = {id["LAMPE_HALL"],id["LAMPE_CELLIER"],id["LAMPE_CH_AMIS"]} -- Reduced set for test purposes
local Lights_On_at_end_Simulation = 0; -- If next line is commented, no light will turn on after Simulation ends
-- local Lights_On_at_end_Simulation = id["LAMPE_COULOIR"]; -- ID of a light (Only One) to turn on after Simulation ends (at specified Stop_hour & Stop_minute). Comment this line to turn off this feature
local Lights_On_if_Simulation_deactivated = 0; -- If next line is commented, no light will turn on after Simulation is stopped (by putting Simu_presence to 0)
local Lights_On_if_Simulation_deactivated = id["LAMPE_HALL"]; -- ID of a light (Only One) to turn on after Simulation is stopped (Simulation_). Comment this line to turn off this feature
YAPS_Engine = {};
 YAPS_Engine.notifications = true;     -- send notifications
 YAPS_Engine.notificationTypes = {"push", "email"}; --notification types {"push", "email", "sms"} but they are overriden in the code
 YAPS_Engine.Activate_FreeSms = false;    -- activate push with Activate_FreeSms (Activate_Push must be true also)
 YAPS_Engine.smartphoneID = {id["PHONE_PAPA"]};  -- Smartphone Id to send push to. {id1, id2, id3}
 YAPS_Engine.userID = {id["ADMIN"]};     -- User Id to send email to. {id1, id2, id3}
 YAPS_Engine.sms = {
  ["VD_ID"] = 0,         -- Virtual Device ID
  ["VD_Button"] = "1",       -- Virtual Device Button
  ["VG_Name"] = "SMS"};       -- Global Variable Name
--------------------- USER SETTINGS END ----------------------------
----------------------ADVANCED SETTINGS-----------------------------
local Show_standard_debug = true; -- Debug displayed in white
local Show_extra_debug = true;  -- Debug displayed in orange
-------------------- DO NOT CHANGE CODE BELOW ----------------------
local Number_of_lights = #Random_lights;      -- numbers of light devices listed above
local Simulation = fibaro:getGlobal("Simu_presence");   --value of the global value: Simulation is on or off
local Manual_overide = fibaro:getGlobal("overideSimuSunset"); -- if = 1 then the Simulation is forced
local Start_simulation_time = fibaro:getValue(1, "sunsetHour"); --Start Simulation when sunset
local End_simulation_time,Sunrise_unix_hour,Sunset_unix_hour,Converted_var,Midnight,End_simulation_time_with_random_max_TurnOff,Sleep_between_TurnOff;
local Is_first_launch = true;
local NotifLoop = 0;
function Debug(color, message)
  fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, os.date("%a %d/%m", os.time()).." "..message, "span"));
function ExtraDebug(debugMessage)
 if ( Show_extra_debug ) then
  Debug( "orange", debugMessage);
function StandardDebug(debugMessage)
 if ( Show_standard_debug ) then
  Debug( "white", debugMessage);
function round(num, idp)
 local mult = 10^(idp or 0)
 return math.floor(num * mult + 0.5) / mult
function YAPS_Engine:notification(message, subject, param)
 local message = os.date("%H:%M", os.time()).." "..message or "<vide>";
 if YAPS_Engine.debug_messages then
  ExtraDebug("yellow", "Notification : "..message);
  if Activate_FreeSms then
   fibaro:setGlobal("Activate_FreeSms", message)
   ExtraDebug("Message ("..message..") sent to Activate_FreeSms");
 if param then
  for _, notif in ipairs(param) do
    ExtraDebug("grey", notif);
   -- Envoi Push
   if notif == "push" and YAPS_Engine.smartphoneID then
    for _, id in ipairs(YAPS_Engine.smartphoneID) do
      ExtraDebug("grey", "Send Push smartphone ID : "..id);
     fibaro:call(id, "sendPush", message);
   -- Envoi Email
   elseif notif == "email" and YAPS_Engine.userID then
    for _, id in ipairs(YAPS_Engine.userID) do
      ExtraDebug("grey", "Send Email user ID : "..id);
     fibaro:call(id, "sendEmail", subject, message);
   -- Envoi SMS
   elseif notif == "sms" and YAPS_Engine.sms then
     ExtraDebug("grey", "Send SMS : VD_ID="..(YAPS_Engine.sms["VD_ID"] or 0).." VD_Button="..(YAPS_Engine.sms["VD_Button"] or "0").." VG_Name="..(YAPS_Engine.sms["VG_Name"] or ""));
    fibaro:setGlobal(YAPS_Engine.sms["VG_Name"], message);
    if YAPS_Engine.sms["VD_ID"] and tonumber(YAPS_Engine.sms["VD_ID"])>0 and YAPS_Engine.sms["VD_Button"] and tonumber(YAPS_Engine.sms["VD_Button"])>0 then
     fibaro:call(YAPS_Engine.sms["VD_ID"], "pressButton", YAPS_Engine.sms["VD_Button"]);
 else
  Debug("orange", "Warning : no notification options given");
function YAPS_Engine:UnixTimeCalc(Converted_var, hour, min)
 local time = os.time();
 local date = os.date("*t", time);
 local year = date.year;
 local month = date.month;
 local day = date.day;
 unix_hour = os.time{year=year, month=month, day=day, hour=hour, min=min, sec=sec};
 ExtraDebug("converted "..Converted_var..": "..hour..":"..min.." to Unix Time: "..unix_hour..")")
 return unix_hour
function YAPS_Engine:ReverseUnixTimeCalc(Converted_var,hour)
 reverse_unix = os.date("%H:%M", hour)
 ExtraDebug("Reverse converted Unix Time of "..Converted_var.." : "..hour.." To: "..reverse_unix)
 return reverse_unix
function YAPS_Engine:EndTimeCalc()
 local hour,min
 ExtraDebug ("Current Unix Time: "..os.time())
 End_simulation_time = YAPS_Engine:UnixTimeCalc("Original planed End_simulation_time", Stop_hour, Stop_minute); -- generate End_simulation_time (changes at midnight) will not change during Simulation, only when ended
 Midnight = YAPS_Engine:UnixTimeCalc("Midnight", 00, 00);
 Sunset_unix_hour = fibaro:getValue(1,'sunsetHour');
 hour = string.sub(Sunset_unix_hour, 1 , 2);
 min = string.sub(Sunset_unix_hour,4);
 Sunset_unix_hour = (YAPS_Engine:UnixTimeCalc("Sunset", hour, min))+Sunset_offset*60;
 -- if stop hour is between 00 and 12h then add 24 hours to End_simulation_time
 if tonumber(Stop_hour) <= 12 and (os.time() >= End_simulation_time) then
  End_simulation_time = End_simulation_time + 24*60*60
  ExtraDebug ("stop hour <= 12, Added 24H to End_simulation_time (End_simulation_time is ending after midnignt)");
  ExtraDebug ("New End_simulation_time: "..End_simulation_time);
 if Random_max_TurnOff_duration ~= 0 and Number_of_lights > 1 then   -- if Simulation = 1 then slow turn off, else turn off all immediately
  Sleep_between_TurnOff = round((math.random(Random_max_TurnOff_duration)/(Number_of_lights-1)),1);
  Sleep_between_TurnOff = math.random(Random_max_TurnOff_duration)/(Number_of_lights-1);
  ExtraDebug("Calculated sleeping between each turn off: "..Sleep_between_TurnOff.." min");
 else
  Sleep_between_TurnOff = 0;
  ExtraDebug("No sleeping between turn off");
 End_simulation_time_with_random_max_TurnOff = End_simulation_time + ((Sleep_between_TurnOff*(Number_of_lights-1))*60)
 ExtraDebug("End_simulation_time_with_random_max_TurnOff: "..End_simulation_time_with_random_max_TurnOff);
 if ((os.time() < End_simulation_time) and (Sunset_unix_hour - End_simulation_time > 0) and (Is_first_launch == true)) then -- if calculation is done between midnight and End_simulation_time and sunset is wrongly calculated after endtime (at first start only)
  Sunset_unix_hour = Sunset_unix_hour - (24*60*60) + 70; -- remove 24h58m50s of sunsettime
  ExtraDebug ("launch after Midnight and before End_simulation_time, removed 24H to Sunset_unix_hour (Only at the first start)");
  ExtraDebug ("New SunsetTime: "..Sunset_unix_hour);
 Is_first_launch = false
-- Presence Simulation actions Main loop
function YAPS_Engine:Launch()
 YAPS_Engine:notification("Presence Simulation started. Will stop at: "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time", End_simulation_time).." + rand("..Random_max_TurnOff_duration.."min) : "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time_with_random_max_TurnOff", End_simulation_time_with_random_max_TurnOff), "Presence Simulator", {"push"}); -- push only
 StandardDebug("Presence Simulation started. Will stop at: "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time", End_simulation_time).." + rand("..Random_max_TurnOff_duration.."min) : "..YAPS_Engine:ReverseUnixTimeCalc("End_simulation_time_with_random_max_TurnOff", End_simulation_time_with_random_max_TurnOff));
 if Lights_always_on[1] ~= nil then YAPS_Engine:TurnOn(Lights_always_on); end
 while ((os.time() <= End_simulation_time) and (Simulation == "1")) or ((Manual_overide == "1")) do
  local random_light = tonumber(Random_lights[math.random(Number_of_lights)]) --choose a random light in the list
  local lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light in the list
  -- turn on the light if off or turn off if on
  if tonumber(lightstatus) == 0 then fibaro:call(random_light, 'turnOn') else fibaro:call(random_light, 'turnOff') end
  fibaro:sleep(1000); -- necessary to get back the new status, because HC2 is too fast :-)
  lightstatus = fibaro:getValue(random_light, 'value') --get the value of the random light after his update
  StandardDebug('light ID:'.. fibaro:getName(random_light) ..' status:'..lightstatus);
  local sleeptime = math.random(Random_max_duration*60000) --random sleep
  StandardDebug("Entering loop of " .. round(sleeptime/60000,2) .. " minutes");
  -- Allows to exit the scene if the Simu_presence global var changes to 0 during the random  sleep
   local counterexitSimulation = 200
    while (counterexitSimulation > 0) and ((os.time() <= End_simulation_time) or Manual_overide == "1") do
     counterexitSimulation = counterexitSimulation - 1;
     test_presence_state = fibaro:getGlobal("Simu_presence");
     Simulation = tonumber(test_presence_state); --verify the global value, if the virtual device is deactivated, the loop stops.
     --fibaro:debug("Simulation var state : " .. Simulation.." override var state : " .. Manual_overide);
     if Simulation == 0 then
      Manual_overide = fibaro:getGlobalValue("overideSimuSunset");
      if Simulation == 0 or Manual_overide == "0" then
      counterexitSimulation = 0
    fibaro:sleep(sleeptime/200);
   ExtraDebug("Exiting loop of "..round(sleeptime/60000,2).." minutes");
  local sleeptimemin = math.abs(sleeptime/60000)
  Simulation = fibaro:getGlobal("Simu_presence"); --verify the global value, if the virtual device is deactivated, the scene stops.
function YAPS_Engine:EndSimulation()
 if Lights_always_on[1] ~= nil then YAPS_Engine:TurnOff(Random_lights,Lights_always_on); end
 Debug("red","Presence Simulation deactivated");
 if (Simulation == "1") then
  Debug("yellow","Presence Simulation will restart tomorrow.");
  Debug("yellow","Sunset is around "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time around "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
  YAPS_Engine:notification("Presence Simulation will restart tomorrow. Sunset is around "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time around "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour), "Presence Simulator", {"push"}); -- push only
 NotifLoop = 0; -- will force main loop notifications at end of Simulation
function YAPS_Engine:ExitSimulation()
 --YAPS_Engine:notification("Presence Simulation is terminated", "Presence Simulator", {"push"}); -- push only
 Debug("red","Simu_presence = 0, Aborting Simulation scene");
 fibaro:abort();
function YAPS_Engine:TurnOff(group,group2)
 Debug("red","TurnOff All Simulation lights!");
 local name, id2;
 local ID_devices_group = group;
 if ID_devices_group ~= 0 then
  for i=1, #ID_devices_group do
   Simulation = fibaro:getGlobal("Simu_presence"); --verify the global value, if Simulation presence is deactivated
   if Simulation == "0" then Sleep_between_TurnOff = 0; end; -- if Simulation ended before End_simulation_time, then no turn off delay
   if i > 1 then -- wait Number of lights -1 (do not need to wait for the first TurnOff)
    StandardDebug("Sleeping "..Sleep_between_TurnOff.." minute(s) before next TurnOff");
    fibaro:sleep(Sleep_between_TurnOff*60000);
   id2 = tonumber(ID_devices_group);
   fibaro:call(id2, "turnOff");
   name = fibaro:getName(id2);
   if (name == nil or name == string.char(0)) then
    name = "Unknown"
   StandardDebug("Device: "..name.." Off ");
 Debug("red","TurnOff All Always_On lights!");
 local ID_devices_group = group2;
     name = "Unknown"
 if Lights_On_at_end_Simulation ~= 0 and Simulation == "1" then
  fibaro:call(Lights_On_at_end_Simulation, "turnOn");
  name = fibaro:getName(Lights_On_at_end_Simulation);
  --[[if (name == nil or name == string.char(0)) then
    name = "Unknown"
   end--]]
  Debug("red","Turned On light Lights_On_at_end_Simulation:");
  --Debug("white", name);
 if Lights_On_if_Simulation_deactivated ~= 0 and Simulation == "0" then
  fibaro:call(Lights_On_if_Simulation_deactivated, "turnOn");
  name = fibaro:getName(Lights_On_if_Simulation_deactivated);
    name = "Unknown"
  Debug("red","Turned On light Lights_On_if_Simulation_deactivated:");
function YAPS_Engine:TurnOn(group)
 Debug("red","Turning On Always_On lights:");
 local name, id2;
  fibaro:call(id2, "turnOn");
   name = "Unknown"
  StandardDebug("Device: "..name.." Turned On ");
 Debug("red","Now randomizing other lights...");
Debug("green", "Presence Simulation | v" .. version .. " Starting up");
Debug("green", "--------------------------------------------------------------------------");
------------------------ Main Loop ----------------------------------
-- first start notifications
YAPS_Engine:EndTimeCalc();
YAPS_Engine:notification("Scheduled presence Simulation at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour).." (Sunset: "..fibaro:getValue(1, "sunsetHour")..")", "Presence Simulator", {"email"}); -- mail only
Debug("green","Sunset is at "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
Debug("green","End of Simulation: "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time).." + random of "..Random_max_TurnOff_duration.."min");
Debug("green", "Checking for actions every minute.");
while true do -- Infinite loop of actions checking, hours calculations, notifications
 -- local Sunset_unix_hour = Midnight  -- un-comment this line when testing to force a start hour (or use Sunset_offset)
 if os.time() >= Sunset_unix_hour then -- define if nighttime (sunset = 1)
  sunset = 1
 else
  sunset = 0
  if sunset == 1 and (os.time() <= End_simulation_time) then
   Debug("yellow", "It's sunset time -> Simulation ON");
   YAPS_Engine:Launch();
   YAPS_Engine:EndSimulation();
  if Manual_overide == "1" then
   Debug("yellow", "Manual Override Activated -> Simulation ON");
  if Manual_overide == "0" and sunset == 0 and NotifLoop == 0 then
   Debug("yellow", "Sunset is at "..fibaro:getValue(1, "sunsetHour").." + Sunset Shift of "..Sunset_offset.."min = Start Time at "..YAPS_Engine:ReverseUnixTimeCalc("Sunset unix time", Sunset_unix_hour));
   Debug("yellow", "End of Simulation: "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time).." + random of "..Random_max_TurnOff_duration.."min = "..YAPS_Engine:ReverseUnixTimeCalc("End Simulation", End_simulation_time_with_random_max_TurnOff));
 if (Simulation == "0") then -- Condition to end Simulation
  YAPS_Engine:ExitSimulation();
 if NotifLoop <= 120 then --a waiting xx times the fibaro sleep below (2 hours) before resetting counter (and notifying)
  if NotifLoop == 120 then NotifLoop = 0 end
  if NotifLoop == 0 then
  ExtraDebug("Now, checking for actions every minute. Next notify: in 2 hours");
 fibaro:sleep(1*60*1000); -- wait 1 minutes before testing again the global vars below
 NotifLoop = NotifLoop + 1;
 Ou ce trouve le problème ?
Merci pour votre aide.
