TonyC Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Fibaro Home Center 2 v 4.024 BETA. Beta version is designed for user testing and soon will be released as official. WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window. This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1). If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start. 4.024: New Features Soft reconfiguration status available at Zwave Diagnostics Panel. Displaying number of system alert information, and improved the user interface clarity. Resolved Issues #0001943 Philips HUE adding new devices after plugin restart #0002251 Philips Hue plugin recreate all lamps each time the plugin is saved #0001882 [plugin] - slave device is broken if visibility is set to false #0001881 [plugin] - master device is broken if visibility is set to false #0002100: Temperature sensor from plugins doesn't work in heating linked device #0002064: [plugin] - action argc parameter possible bug in "types" xml #0001716 UBS reconfiguration does not work #0002069: Add new scene: the buttons names should be "Create" or "New" and not "Save" Known issues Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code. Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Breached sensor with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Plugin for Sony TV will not work with newest Sony Firmware Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly
Krikroff Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Ils ont corrigé trois de mes tickets
TonyC Posté(e) le 19 décembre 2014 Auteur Signaler Posté(e) le 19 décembre 2014 C'est aussi ça noà«l chez Fibaro...
Steven Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Sur combien ? Envoyé de mon portable grâce àmes petits doigts.
TeamFive38 Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Et moi qui ai mis la 23 ce matin, et passé l'apres-midi a reconfigurer ... Ben c'est repartis pour un tour
garfield Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Enfin je récupère la consommation d'énergie sur un Qubino 1 relai Par contre la température ne bouge pas Il a quand même fallu que je recréé le module
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Installation en cours Krikroff tu le tickets chez fibaro Je pense que tu doit être un des membres du forum officielle le plus actif
Krikroff Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 @Steven, je ne compte plus @Mprinfo, avec l'ambiance sur le fofo officiel je suis très calme depuis quelques temps.
Rocketlud Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Alors elle est bien cette version? On peut imaginer que le 6 soit une version stable? Ou il y a encore plein de bug?
PITP2 Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 @krikroff, ils concernaient quoi tes tickets ? Le fait de ne plus devoir désinstaller le plugin VS pour mettre à jour le firmware
fab971 Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Vous savez si le sismomètre du FIBARO FGMS001 fonctionne. Etant en Guadeloupe, j'aurai pu le tester avec un tremblement de terre qui a eu lieu il y a àpeine une demi-heure. Je crois que je vais me laisser tenter par cette version. 1
Lazer Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Hum, c'est pas normal ça. Au rythme des betas, on va avoir le v4.025 avant Noël.... imaginez si Fibaro comble nos espoirs, le niveau d'exigence qu'on va avoir après 1
fredo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 àmon avis, on aura la 25 avant le 25 !!!
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Bon pour une fois je vais croire au père Noël
Krikroff Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 @PITP2#0001882 [plugin] - slave device is broken if visibility is set to false#0001881 [plugin] - master device is broken if visibility is set to false#0002064: [plugin] - action argc parameter possible bug in "types" xmlEn revanche le SoftReconfigure sur les modules Qubino plante le moteur z-wave, c'est restauration obligatoire . Moi j'ai le problème que sur Qubino et je pense que Fibaro ne fera pas d'effort sur la prise en compte de ce bug: Qubino/Fibaro c'est la guerre ! Des gens ont le problème avec des modules Fibaro par exemple ?
PITP2 Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Je n'ai pas testé le softreconfigure sur des modules Fibaro mais sur d'autres aucun probleme (Tag Reader Benext , KeyFob, Danfoss)
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Krikroff as tu le beug sur le smoke dans les graph en 4.023 j'avais un decalage d un jours quand je mets le pointeur de la souris sur le graph samedi 19 au lieu de vendredi 19
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 La je peux pas testé soiree tel avec madame snif
Moicphil Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 mprinfo >> Merci d’éditer tes messages pour éviter de poster plusieurs fois à la suite. Tu es monté jusqu'à 6 sur un post.
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 Pour la mise a jour du firm des modules fibaro quelqu'un a des news ? Pourtant c'est dans la pub de la hc2
mprinfo Posté(e) le 19 décembre 2014 Signaler Posté(e) le 19 décembre 2014 @moicphil Dsl je vais faire attention
