Lazer Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Beta software changes list 4.020:Beta version is designed for user testing and soon will be released as official. WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start. New Features: Pre-Update Confirmation - installing update on 4.020 or newer will prompt user additional confirmation. Mesh Network Reconfiguration - available on Configuration -> Z-Wave Network Fixed Issues: Incidental marking devices as dead Horstmann Devices support Many other Z-Wave engine fixes Known Issues: Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code. Important! Remote access is NOT available for this version. Devices Polling may not work properly - devices state in UI may be refreshed only after action taken. Previous: Breached senser with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly Devices imported via Gateway Connection may have no icons Gateway Connection status of dead device between master and slave controller may be different Devices not properly configured on 3.X may not be converted properly Reconfiguration may not work properly in some cases On mobile clients devices may be visible in different categories than configured Advanced settings for some imported devices may not work properly Plugin for Sony TV will not work with newest Sony Firmware Horstmann Thermostat HRT4-ZW higher battery usage in some cases Doorlocks some functions may not work properly 2
BenjyNet Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 (modifié) Ouch ça a pas traîné ! Trop de soucis ...? Edit, j'ai bien mon sendPush/sendMail qui marche plus moi.. c'est la misère ça ! Modifié le 28 novembre 2014 par BenjyNet
Invité chris6783 Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 En tout cas ca a l'air centré sur le moteur Zwave. Une bonne nouvelle ! Et la liste des problèmes connus est plus honnête. Signe de changement ?
Lazer Posté(e) le 28 novembre 2014 Auteur Signaler Posté(e) le 28 novembre 2014 Sympa le changelog J'avais le problème de batterie sur le Secure SRT321 qui semble résolu (il faudra juste leur dire que Horstmann est devenu Secure ) Les évolutions du moteur Z-Wave ont l'air chouette. Je lance la mise à jour ...
Nico Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Lazer, sur la box de Lionnel je suppose du coup ? En tout cas je dis coooooollllll ! J'espère que les corrections du moteur Zwave règle le souci des FGMS, dernier frein pour moi pour passer en BETA, tout le reste étant ok dans ce que j'utilise... Allez, je rève que cela fonctionne... D'ailleurs Lazer, si tu as un petit FGMS je veux bien que tu tentes... Et curieux de voir ce qu'est la vue du réseau Zwave !!
BenjyNet Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Par contre leur fenêtre de mise àjour c'est toujours aussi la misère ! J'ai rien qui défile ! Update un progress : 0 (Alors que je sais que ça se fait en arrière plan !)
Krikroff Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Entre les plantages au boot (la faute aux plugins Lol), les processus zombie et les deadlocks (je sais pourquoi mon CPU était au max) pas vraiment possible de laisser la 4.019 en circulation et c'est bien mieux comme cela .
Lazer Posté(e) le 28 novembre 2014 Auteur Signaler Posté(e) le 28 novembre 2014 Benjy ouais moi aussi la fenetre de mise à jour est toujours pas terrible.... en plus en remote ça rame Nico oui avec le box de Lionel évidemment je ferai le test du FGMS ce soir
Krikroff Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 @BenjyNet, tu fais juste un CTRL+F5 et si cela ne marche toujours pas tu mets juste l'ip dans la barre d'adresse. F5 pour rafraichir au besoin....
mprinfo Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 normal on est en béta si on ne peut pas restaurer une sauvegarde c'est grave si ca réagi pas vite je pense qu'ils ont eu pas mal de réclamation Enfin Fibaro réagi :D 1
Lazer Posté(e) le 28 novembre 2014 Auteur Signaler Posté(e) le 28 novembre 2014 Prem's !!! c'est fait, je regarde ça
mprinfo Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 j' etais devenu roi du recovery pour restaurer une sauvegarde ;)
Lazer Posté(e) le 28 novembre 2014 Auteur Signaler Posté(e) le 28 novembre 2014 Toujours pas de vue du réseau Z-Wave. La nouvelle option permet juste de faire ce qu'on faisait en LUA :
mprinfo Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 si ca continu comme cela demain on a la version stable ???????
BenjyNet Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 RAM 26%, j'ai divisé par 2 avec la précédente beta CPU 1-2% comme d'hab.
mprinfo Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 petite astuce pour ne pas avoir de probléme avec le recovery et l'adresse IP dans votre box internet ajouter l'adresse mac de la HC2 a une adresse IP lors d'un recovery l' adresse IP ne changera pas
mprinfo Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 ca fais 10 mn que je viens de redémarrer ma box est toujours pas la 4.020 en vu
Lazer Posté(e) le 28 novembre 2014 Auteur Signaler Posté(e) le 28 novembre 2014 pour forcer la mise àjour : http://<IP>/services/startBetaUpgrade.php
Krikroff Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 @Benjy, pour la RAM c'est comme la V4.018 le cache n'est pas pris en compte . Les problèmes d'interblocages devraient être aussi réglés. Netatmo remonte de nouveau les bonnes informations. Tous mes vd marchent
Nico Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Ahhhhhh !!! Mais Krikroff, toi tes FGMS ont toujours marché, du coup pas un bon testeur pour moi Bon je vais tenter ce week-end tout de même je pense du coup, je sais pas, je le sens bien du coup...
carfnann Posté(e) le 28 novembre 2014 Signaler Posté(e) le 28 novembre 2014 Nico, je me lance, je te fais un retour
