Lazer Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Liste des modifications de la version beta 4.019: Beta version is designed for user testing and soon will be released as official. WARNING! After installing this upgrade backups from version 1.x and 3.x will be retained but hidden because they are incompatible with the version 4.x. In case of update from old version, v1.x, after that update all users will be deleted. Admin password will be reset. Also update to Beta software all devices will be automatically reconfigured to work with new system architecture. Reconfiguration progress will be shown in pop-up window.This update can last longer than previous. If this update lasts longer than 30 minutes, please go to main HC2 address (e.g. 192.168.0.1).If "System temporarily unavailable" text will appear during update, please wait - you will be redirected to the main page when all services start. New Functionalities: Configuration > Backup now is Backup & Recovery Recovery Memory Status - can be checked on Backup & Recovery Backups - information about compatibility with current HC version Resolved Issues: #0001359: For some reason 1 smoke sensor doesnt show black box info. #0001524: 3.902 Alpha - HUE plugin won't create new user #0002037: Cannot delete device, but after a restart the devices shows as being deleted #0002048: JSON ENCODE / DECODE doesn't work properly #0001920: [ERROR] 09:23:47: line 44: attempt to index global 'json' (a nil value) #0001699: panel energii #0001849: Fibaro Door and Window Sensors do not report #0001852: Unable to delete devices #0001861: Since upgrading no scenes work #0001877: HC2 stops working on 4.017 #0001709: When adding Foscam generic camera to plugin the password field is misspelled "Passwrod" should be "Password" #0001824: Aeon Switch with energy meter. No more energy measurement/logging after upgrade to 4.017 beta. #0001935: Notification of the battery status #0001963: Event panel refreshed while browsing #0001869: Fast scrolling in event history #0001894: Log messages do not span columns #0001655: Changing pages results in spinning wheel #0001815: Power calcutaion is only working in rooms with Fibaro Wall plugs #0001790: Virtual Device icon change causes a crash #0001834: Get error 502 and 503 after virtual device import #0001701: Controlled device is set to Air Conditioner on dimmers #0001962: UI crashed after creation of magic scene #0001966: setting " How frequently GPS position from the user?s iPhone should be collected" is not saved after reboot hc2 #0001888: Execution of lua commands #0001907: Danalock POL_ZES100 (Z-Wave Danalock Square) sowing but not functional #0001596: universal sensor has not the normal picture and dallas 18b20 temp does not work #0001652: uni bin sensor breach scene does not work #0001548: Nie dziaÅ‚a triger wÅ‚Ä…czenia wÅ‚Ä…cznika Duwi #0001812: HC2 doesn't respond anymore #0001593: Email address validation wont allow + to be used #0001651: HTML special characters being displayed in Virtual Device code #0001946: fibaro:getSelfId does not work #0001889: Unable to debug slider code #0001992: FGK-101 with a DS18B2 #0002005: After creation of a magic scene i'm unable to login to the fibaro home center (keeps loading) #0002023: Disarm sensors with scene Known Issues Breached sensoer with Arm Delay causes instant alarm after being armed Data range selection in event panel doesn't work properly For devices imported via Gateway Connection may have no icons Lien vers le commentaire Partager sur d’autres sites More sharing options...
acidric Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Je sens que je vais faire une connerie ;-) Envoyé de mon LG-D802 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rocketlud Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Des retours, des retours, des retours;) Lien vers le commentaire Partager sur d’autres sites More sharing options...
carfnann Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 heureusement je suis loin de ma box... oh dis donc ils ont corrigés le JSON Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 26 novembre 2014 Auteur Signaler Partager Posté(e) le 26 novembre 2014 Vous savez quoi ? Je viens de recevoir la box de Lionel... (pour rappel, sa box ne boote plus) La nuit va être longue (ou courte, selon le point de vue) 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Moicphil Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Lazer > lol ! j'en connais un qui va pas beaucoup dormir cette nuit ! Evolution intéressante : Voir la compatibilité du firmware : Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Mouais, je sais pas pourquoi mais je pense que je ne vais toujours pas l'installer. Je vois rien dans les issus qui corrige le problème d'id, donc je ne prend pas de risque mdr. Toujours rien de nouveau pour les devs. 3 semaines pour corriger une vingtaine de bug ( a se demander si les dev connaisse leur code sources) Encore une release avec des erreurs qu'ils connaissent. Enfin bref, je commence a trouver le temps long maintenant, je dirais même que je commence à être fatiguer. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
lionel Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 @Lazer Pour une fois que j ai un bon timing Ne te casse pas trop la tête avec la box Ps: par contre tu peux m envoyer un sms a toute heure de la nuit,si tu arrives àla sauvée Et merci encore et bon courage Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 - Attention: La mise à jour écrase visiblement les sources des Plugins, elle efface les "Main" mais pas les devices esclaves donc supprimez bien les Plugins (Tiers) avant d'appliquer la mise à jour au risque de vous retrouver avec des "devices" orphelins impossibles à supprimer (Erreur 403), après c'est la restauration . - La bibliothèque json (encode, decode, null) est fonctionnelle - Pour la partie "Recovery memory" vous avez ça aussi vous cf.capture ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyrka973 Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Breached sensoer with Arm Delay causes instant alarm after being armed lol Je passe mon tour Lien vers le commentaire Partager sur d’autres sites More sharing options...
PITP2 Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Je teste cela de suite @Krikroff, tu parles untiquement de ton plugin ou est ce valable pour sonos , tv etc ? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 - Attention: après restauration je n'ai plus mes backups visibles, même un backup manuel n'apparait pas dans la liste Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shad Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Bien le truc des checksums, sa aurait juste du être inclue des le départs mais bon ^^. Lien vers le commentaire Partager sur d’autres sites More sharing options...
lionel Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Si Krikroff dit Attention Rien ne va plus Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 1. Virer les plugins = OK 2. Cliquer sur Mise àjour = OK 3. Update In Progress...... NOTOK Putain ça avance pas leur barre de progression ! je suis toujours à0 après 15min :/ Lien vers le commentaire Partager sur d’autres sites More sharing options...
CaptainIgloo Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Pareil, cela avance pas vite ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
BenjyNet Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 (modifié) En fait, rien n'avance ! Je suis toujours resté à 0 et là je me suis dit : c'est pas possible, y'a un truc ! Alors dans la barre d'adresse j'ai retapé l'url de la HC2 et hop j'étais bien en 4.019b ! Putain va vraiment falloir qu'ils améliorent l'update, c'est pas la 1ere fois que ça me le fait ! Edit : Dans la page backup/recovery, j'ai bien ri Last verify: 1970-01-01 01:00:00 Modifié le 26 novembre 2014 par BenjyNet Lien vers le commentaire Partager sur d’autres sites More sharing options...
CaptainIgloo Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Ben ouvres une autre connexion et c'est fait en fait. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 26 novembre 2014 Auteur Signaler Partager Posté(e) le 26 novembre 2014 @Benjy, le 1er janvier 1970 00:00:00 UTC est un Timestamp Unix àzero, ça sent la variable qui n'est pas initialisée. Au moins tu appréciera qu'ils te l'ont affiché en GMT+1 heure française ... Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredo Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Salut les filles. oulala, je sais pas si ça vaut le coup de la faire celle-ci !!! Lien vers le commentaire Partager sur d’autres sites More sharing options...
Nico Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Bon bah coooooooooooolllllllllllllllllllllllllllll !!! J'espère juste que cela corrige les FGMS Mais on dirait que non, sauf si le moteur Zwave de la HC2 a été corrigé. Par contre ce qui dit Krikroff... Plus de recovery possible ??? Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Pas encore fait de recovery tout a l'heure sûrement. Juste que mon tableau de backup est désespérément vide je vais voir si le recovery fait réapparaître mes sauvegardes ... Envoyé de mon iPhone àl'aide de Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 De mieux en mieux... Première tentative de recovery: Unable to select database J’hésite entre pleurer ou me taper une bonne barre de rire ! EDIT: en fait j'ai pleuré de rire Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rocketlud Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Ouch pas cool du tout Lien vers le commentaire Partager sur d’autres sites More sharing options...
Krikroff Posté(e) le 26 novembre 2014 Signaler Partager Posté(e) le 26 novembre 2014 Après 4 ou 5 tentatives infructueuses, enfin le recovery avec toujours "Fonctionnalité temporairement indisponible" - Déplacement. - Téléchargement (il faut vite activer cette option monsieur Fibaro) 4 Lien vers le commentaire Partager sur d’autres sites More sharing options...
