Shad Posté(e) le 5 janvier 2014 Signaler Posté(e) le 5 janvier 2014 (modifié) Voici un script de rafal.m repris sur le forum officiel. Ce script permet de basé l'éclairage automatique d'une salle de bain, toilette ... Sur l'ouverture d'une porte pour un fgk-101. Je n'ai pas retesté ce script depuis les modifications de l'alarme, je l'ai modifier pour utiliser une variable globale. -- NOTICE TO CHANGE DEVICES ID's: --[[ %% properties 7 value 17 value %% globals --]] -- BATHROOM SCENE FUNCTIONALITY: -- No extra Global variables needed! -- Automatic light depending of opening and closing door -- Time to enter - detecting another situations, like cleaning bathroom -- NOTICE TO CHANGE DEVICES ID's: doorID = 7; lightID = 17; -- time to enter, longer time will detect as another situation, like: cleaning timeToEnter = 10; local light = fibaro:getValue(lightID, 'value'); local door = fibaro:getValue(doorID, 'value'); local armed, lastArmed = fibaro:get(doorID, 'armed'); local trigger = fibaro:getSourceTrigger(); if (fibaro:countScenes()>1) then fibaro:debug('Kill second scene!'); fibaro:abort(); end if (trigger['type']=='property') then -- door trigger if (trigger['deviceID']==tostring(doorID)) then -- door opened if (door=='1') then fibaro:debug('Door opened.'); if (armed=='0') then fibaro:call(lightID, 'turnOn'); fibaro:call(doorID, 'setArmed', '1'); fibaro:call(doorID, 'setArmed', '0'); fibaro:debug('Light on!'); end -- door closed elseif (door=='0') then fibaro:debug('Door closed.'); if (armed=='1' or (os.time()-lastArmed)>=timeToEnter) then fibaro:call(lightID, 'turnOff'); fibaro:call(doorID, 'setArmed', '0'); fibaro:debug('Light off, room empty!'); else fibaro:call(doorID, 'setArmed', '1'); fibaro:debug('Someone inside!'); end end -- light manual elseif (trigger['deviceID']==tostring(lightID) and (os.time()-lastArmed)>0) then -- light manual off if (light=='0') then if (door=='1') then -- when door are opened fibaro:call(doorID, 'setArmed', '1'); else -- when door are closed fibaro:call(doorID, 'setArmed', '0'); end fibaro:debug('Light manual off!'); -- light manual on elseif (light=='1') then fibaro:call(doorID, 'setArmed', '1'); fibaro:debug('Light manual on, arming...'); end end end Modifié le 16 janvier 2014 par moicphil Je me suis permi de modifié le titre (je l'ai passé en francais ) ;-) 1
Rem's Posté(e) le 16 mai 2014 Signaler Posté(e) le 16 mai 2014 Superbe réalisation, à l'ouverture et à la fermeture, les informations debug, c'est super pratique. En revanche, le script, comme tu l'avais supposé, déclenche l'alarme, ca fout un bordel et envoie un push (message d'erreur de la box). Est-il possible d'adapter ton script aux nouvelles fonctions de notre bel HC2. Merci pour tes infos.
Steven Posté(e) le 16 mai 2014 Signaler Posté(e) le 16 mai 2014 C'est malin, quand tu ouvre la porte, il l'arme et la désarme de suite. Cela pour savoir quand elle a été ouverte la dernière fois (lastArmed). Par contre si tu as une alarme... Quel bordel... Lol.
