Moicphil Posté(e) le 8 septembre 2014 Signaler Posté(e) le 8 septembre 2014 Les serveurs sont HS! Egalement pour le Bugtracker ... Warning: mysql_connect() [function.mysql-connect]: Lost connection to MySQL server at 'reading initial communication packet', system error: 110 in /home/klient.dhosting.pl/fibargroup/forum.fibaro.com/public_html/db/mysql4.php on line 48phpBB by Przemo : Critical Error Could not connect to the database.Lost connection to MySQL server at 'reading initial communication packet', system error: 110 APPLICATION ERROR #400Database connection failed. Error received from database was #2013: Lost connection to MySQL server at 'reading initial communication packet', system error: 113. Please use the "Back" button in your web browser to return to the previous page. There you can correct whatever problems were identified in this error or select another action. You can also click an option from the menu bar to go directly to a new section. Previous non-fatal errors occurred. Page contents follow. SYSTEM WARNING: 'mysql_connect() [function.mysql-connect]: Lost connection to MySQL server at 'reading initial communication packet', system error: 113' in '/home/klient.dhosting.pl/fibargroup/bugzilla.fibaro.com/public_html/library/adodb/drivers/adodb-mysql.inc.php' line 365
Moicphil Posté(e) le 8 septembre 2014 Auteur Signaler Posté(e) le 8 septembre 2014 Finalement c'est reviendu !...
Nico Posté(e) le 8 septembre 2014 Signaler Posté(e) le 8 septembre 2014 Pareil toute la journée, même home.fibaro plantait...
