HC3 & HC3L - 5.172.23 - BETA - 02/04/2025
Firmware 5.172.23
BETA
02/04/2025
Changelog
Version 5.172.23
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Important notice:
    Update to version 5.172.18 caused rare issues with HVAC devices override support and did reset the polling configuration for mains powered devices to default. Version 5.172.23 resolves those issues. Make sure to configure polling intervals again or restore previous version of the system before updating.
What's new:
Devices
    HeatIt Z-Temp3 support added.
    Fantem Home Energy Meter Gen 8 support added.
    Aeotec Home Energy Meter Gen5 2P (US region) support added.
    Added a possibility to change HVAC devices icons.
Gateway Connection
    Possibility to connect hubs from different networks based on provided IP.
Nice*
    Optimized network configuration for better performance.
    Domi WSC parameters template updated.
Other
    System boot-up procedure performance improvements.
Plugins
    Added support for Satel Integra 256 in old FW revision.
Scenes
    Default behavior for predefined scenario changed - from now no devices are selected by default.
Z-Wave
   Z-Wave radio module SDK updated for Yubii Home and Home Center 3 Light.
Zigbee
    Introduced the mechanism which prevents losing the network configuration in very rare cases.
    MOES Human Presence Sensor ZSS-QY-HP (and other revisions) support added.
Bug Fixes:
Access
    Installer does not see system notifications for administrator.
Backup
    Error while uploading a Cloud backup in rare cases.
Cameras
    Lack of local preview for some cameras in Safari browser.
Devices
    Custom icons do not work for CO Detector device type.
    Lack of correct icons for Silent Open and Silent Close actions on the control dialog.
    Thermostat Linked Device - fixed the issue when cooling and heating actor is the same device.
    Qubino Flush Dimmer 0-10V - fixed optional temperature sensor handling.
    Restored old sets of icons for some device types.
Energy Panel
    Error during saving Energy Panel settings in some cases.
Gateway Connection
    Issue with listing slaves list in large IP network.
    Restoring a backup after replacing a slave with new unit fixed.
    Stability improvements.
History
    Missing thermostat set-point name in history entities.
Nice*
    Fixed binding procedure from the mobile app for BiDi-Multisensor.
    Corrected parameters template for TT2NBD.
Other
    Small UI/UX fixes.
Plugins
    Missing IP field configuration in Philips Hue.
    Fixed issue with Nice Cameras support in scenes when passwords with special signs are used.
Quick Apps
    Dropdowns does not work correctly when new view is disabled for mobile application.
    Function setColorComponent doesn't refresh the view when custom color components are used.
    Template for Color Controller device type updated.
Scenes
    Fixed setting slats position for FGR-224/Rol-Control2 group in block scenes.
    Fixed issue in Custom Scenarios when FGKF-601 is used as a trigger.
Z-Wave
    Fixed issues with mesh network reconfiguration.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Thanks 1
Traduction en français:
Journal des modifications
Version 5.172.23
Merci d'utiliser notre passerelle ! Assurez-vous d'installer la dernière version pour profiter des nouvelles fonctionnalités et améliorations.
Avis important :
La mise à jour vers la version 5.172.18 a entraîné de rares problèmes avec la prise en charge du remplacement des appareils HVAC et a réinitialisé la configuration d'interrogation par défaut des appareils alimentés par le secteur. La version 5.172.23 corrige ces problèmes. Assurez-vous de reconfigurer les intervalles d'interrogation ou de restaurer la version précédente du système avant la mise à jour.
Nouveautés :
Appareils
Ajout de la prise en charge de HeatIt Z-Temp3.
Ajout de la prise en charge du compteur d'énergie domestique Fantem Gen 8.
Ajout de la prise en charge du compteur d'énergie domestique Aeotec Gen5 2P (région États-Unis).
Ajout de la possibilité de modifier les icônes des appareils HVAC.
Connexion à la passerelle
Possibilité de connecter des hubs de différents réseaux en fonction de l'adresse IP fournie.
Nice*
Configuration réseau optimisée pour de meilleures performances.
Mise à jour du modèle de paramètres Domi WSC.
Autre
Amélioration des performances de la procédure de démarrage du système.
Plugins
Prise en charge du Satel Integra 256 dans l'ancienne version du micrologiciel.
Scènes
Le comportement par défaut des scénarios prédéfinis a été modifié : aucun appareil n'est désormais sélectionné par défaut.
Z-Wave
Mise à jour du SDK du module radio Z-Wave pour Yubii Home et Home Center 3 Light.
Zigbee
Introduction d'un mécanisme empêchant la perte de la configuration réseau dans de très rares cas.
Prise en charge du capteur de présence humaine MOES ZSS-QY-HP (et autres versions).
Corrections de bugs :
Accès
L'installateur ne voit pas les notifications système pour l'administrateur.
Sauvegarde
Erreur lors du téléchargement d'une sauvegarde cloud dans de rares cas.
Caméras
Absence d'aperçu local pour certaines caméras dans le navigateur Safari.
Appareils
Les icônes personnalisées ne fonctionnent pas pour les détecteurs de CO.
Absence d'icônes correctes pour les actions d'ouverture et de fermeture silencieuses dans la boîte de dialogue de contrôle.
Appareil lié au thermostat : correction du problème lorsque les appareils de chauffage et de climatisation sont identiques.
Variateur encastré Qubino 0-10 V - Correction de la gestion des capteurs de température optionnels.
Restauration des anciens jeux d'icônes pour certains types d'appareils.
Panneau Énergie
Erreur lors de l'enregistrement des paramètres du Panneau Énergie dans certains cas.
Problème de liste des esclaves dans un réseau IP étendu.
Restauration d'une sauvegarde après le remplacement d'un esclave par un nouvel appareil corrigée.
Améliorations de la stabilité.
Historique
Nom de consigne du thermostat manquant dans les entités d'historique.
Nice*
Correction de la procédure de liaison depuis l'application mobile pour le multicapteur BiDi.
Modèle de paramètres corrigé pour TT2NBD.
Autre
Petites corrections d'interface utilisateur/expérience utilisateur.
Extensions
Configuration du champ IP manquante dans Philips Hue.
Correction d'un problème de prise en charge des caméras Nice dans les scènes lorsque des mots de passe avec des signes spéciaux sont utilisés.
Quick Apps
Les menus déroulants ne fonctionnent pas correctement lorsque la nouvelle vue est désactivée pour l'application mobile.
La fonction setColorComponent n'actualise pas la vue lorsque des composants de couleur personnalisés sont utilisés.
Modèle pour le type d'appareil Contrôleur de couleur mis à jour.
Scènes
Correction du réglage de la position des lamelles pour le groupe FGR-224/Rol-Control2 dans les scènes de blocs.
Correction d'un problème dans les scénarios personnalisés lorsque FGKF-601 est utilisé comme déclencheur.
Z-Wave
Correction de problèmes de reconfiguration du réseau maillé.
Problèmes connus :
Moteur Z-Wave 3.0
Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
* - Ne s'applique pas au HC3L (Home Center 3 Lite).
** - S'applique uniquement au moteur Z-Wave 3.0.
Modifié par fredokl
  • Thanks 2
C'est le jeu des 0 différences avec la précédente Beta qui était tellement béta qu'elle a été retirée :lol:
Je l'installe sur ma box de test pour voir.
