fredokl Posté(e) le 21 mars Signaler Posté(e) le 21 mars Firmware 5.172.18 BETA 21/03/2025 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. What's new: Devices HeatIt Z-Temp3 support added. Fantem Home Energy Meter Gen 8 support added. Aeotec Home Energy Meter Gen5 2P (US region) support added. Added a possibility to change HVAC devices icons. Gateway Connection Possibility to connect hubs from different networks based on provided IP. Nice* Optimized network configuration for better performance. Domi WSC parameters template updated. Other System boot-up procedure performance improvements. Plugins Added support for Satel Integra 256 in old FW revision. Scenes Default behavior for predefined scenario changed - from now no devices are selected by default. Z-Wave Z-Wave radio module SDK updated for Yubii Home and Home Center 3 Light. Zigbee Introduced the mechanism which prevents losing the network configuration in very rare cases. MOES Human Presence Sensor ZSS-QY-HP (and other revisions) support added. Bug Fixes: Access Installer does not see system notifications for administrator. Backup Error while uploading a Cloud backup in rare cases. Cameras Lack of local preview for some cameras in Safari browser. Devices Custom icons do not work for CO Detector device type. Lack of correct icons for Silent Open and Silent Close actions on the control dialog. Thermostat Linked Device - fixed the issue when cooling and heating actor is the same device. Qubino Flush Dimmer 0-10V - fixed optional temperature sensor handling. Restored old sets of icons for some device types. Energy Panel Error during saving Energy Panel settings in some cases. Gateway Connection Issue with listing slaves list in large IP network. Restoring a backup after replacing a slave with new unit fixed. Stability improvements. History Missing thermostat set-point name in history entities. Nice* Fixed binding procedure from the mobile app for BiDi-Multisensor. Corrected parameters template for TT2NBD. Other Small UI/UX fixes. Plugins Missing IP field configuration in Philips Hue. Fixed issue with Nice Cameras support in scenes when passwords with special signs are used. Quick Apps Dropdowns does not work correctly when new view is disabled for mobile application. Function setColorComponent doesn't refresh the view when custom color components are used. Template for Color Controller device type updated. Scenes Fixed setting slats position for FGR-224/Rol-Control2 group in block scenes. Fixed issue in Custom Scenarios when FGKF-601 is used as a trigger. Z-Wave Fixed issues with mesh network reconfiguration. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. 2
fredokl Posté(e) le 21 mars Auteur Signaler Posté(e) le 21 mars Firmware 5.172.18 BETA 21/03/2025 Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour votre système vers la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Nouveautés : Appareils Prise en charge de HeatIt Z-Temp3. Prise en charge du compteur d'énergie domestique Fantem Gen 8. Prise en charge du compteur d'énergie domestique Aeotec Gen5 2P (région États-Unis). Ajout de la possibilité de modifier les icônes des appareils CVC. Connexion à la passerelle Possibilité de connecter des hubs de différents réseaux en fonction de l'adresse IP fournie. Nice* Configuration réseau optimisée pour de meilleures performances. Mise à jour du modèle de paramètres Domi WSC. Autres Amélioration des performances de la procédure de démarrage du système. Plugins Prise en charge de Satel Integra 256 dans l'ancienne version du micrologiciel. Scènes Modification du comportement par défaut des scénarios prédéfinis : désormais, aucun appareil n'est sélectionné par défaut. Z-Wave Mise à jour du SDK du module radio Z-Wave pour Yubii Home et Home Center 3 Light. Zigbee Introduction d'un mécanisme empêchant la perte de la configuration réseau dans de très rares cas. Prise en charge du capteur de présence humaine MOES ZSS-QY-HP (et autres révisions). Corrections de bugs : Accès L'installateur ne voit pas les notifications système pour l'administrateur. Sauvegarde Erreur lors du téléchargement d'une sauvegarde cloud dans de rares cas. Caméras Absence d'aperçu local pour certaines caméras dans le navigateur Safari. Appareils Les icônes personnalisées ne fonctionnent pas pour les appareils de type détecteur de CO. Absence d'icônes correctes pour les actions d'ouverture et de fermeture silencieuses dans la boîte de dialogue de contrôle. Appareil lié au thermostat : correction du problème lorsque les appareils de chauffage et de climatisation sont identiques. Variateur encastré Qubino 0-10 V - Correction de la gestion des capteurs de température optionnels. Restauration des anciens jeux d'icônes pour certains types d'appareils. Panneau Énergie Erreur lors de l'enregistrement des paramètres du panneau Énergie dans certains cas. Connexion à la passerelle Problème de liste des esclaves dans un réseau IP étendu. Correction de la restauration d'une sauvegarde après le remplacement d'un esclave par un nouvel appareil. Amélioration de la stabilité. Historique Nom de consigne du thermostat manquant dans les entités d'historique. Nice* Correction de la procédure de liaison depuis l'application mobile pour BiDi-Multisensor. Modèle de paramètres corrigé pour TT2NBD. Autre Petites corrections d'interface utilisateur/expérience utilisateur. Plugins Configuration du champ IP manquante dans Philips Hue. Correction d'un problème de prise en charge des caméras Nice dans les scènes où des mots de passe avec des signes spéciaux sont utilisés. Applications rapides Les menus déroulants ne fonctionnent pas correctement lorsque la nouvelle vue est désactivée pour l'application mobile. La fonction setColorComponent n'actualise pas la vue lorsque des composants de couleur personnalisés sont utilisés. Le modèle pour le type d'appareil Contrôleur de couleur a été mis à jour. Scènes Correction du paramètre de position des lamelles pour le groupe FGR-224/Rol-Control2 dans les scènes de blocs. Correction d'un problème dans les scénarios personnalisés lorsque FGKF-601 est utilisé comme déclencheur. Z-Wave Correction de problèmes de reconfiguration du réseau maillé. Problèmes connus : Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0.
Lazer Posté(e) le 21 mars Signaler Posté(e) le 21 mars Clic clic clic Installé sur ma box de test, rien à signaler pour le moment, mais vu qu'elle ne fait pas grand chose...
flacon030 Posté(e) le 22 mars Signaler Posté(e) le 22 mars Mise a jour faite aussi a voir dans le temps comme d'habitude
TitiXsi Posté(e) le 22 mars Signaler Posté(e) le 22 mars Le 30/01/2025 à 14:33, fel-x a dit : Z-Wave Fixed issues with mesh network reconfiguration. Tiens ça pourrait résoudre les problème de devices qui ne se mettent pas à jour leur voisins... J'avais le cas avec les shelly (d'où les multiples déconnexions) Bon depuis, je n'ai plus de Shelly
fredokl Posté(e) le 22 mars Auteur Signaler Posté(e) le 22 mars Je vais attendre quelques jours pour avoir les premiers retours....
ericl78 Posté(e) le 23 mars Signaler Posté(e) le 23 mars Le forum est entrain de mourir ou quoi, plus rien !. Ou les produits deviennent géniaux ?
JLT Posté(e) jeudi à 22:23 Signaler Posté(e) jeudi à 22:23 Je ne sais si c'est lié mais la coïncidence avec la mise à jour est troublante : Depuis la mise à jour 5.172.18, perte du DSL (et donc internet) sur la Bbox ! Elle a été remplacée il y a 3 jours mais le phénomène persiste. Lorsque la HC3 est déconnectée de la BBox, plus de décrochage du DSL J'ai reconnecté la HC3 ce soir, après 24h de repos, et hop, c'est reparti pour la perte DSL/Internet ! Si je veux utiliser la HC3, je dois le faire via un routeur, ASUS, placé avant la BBox et déconnecté de celle-ci pour éviter la perte du DSL, pas très utile dans ce cas pour les connexions extérieures ! Un cas isolé ? 2
jjacques68 Posté(e) il y a 18 heures Signaler Posté(e) il y a 18 heures la mise à jour n'est plus dispo ? !! ? 1
fredokl Posté(e) il y a 17 heures Auteur Signaler Posté(e) il y a 17 heures Je confirme la mise à jour n'est plus disponible. Bien fait d'attendre moi.
