ericl78 Posté(e) le 28 novembre 2024 Signaler Posté(e) le 28 novembre 2024 (modifié) Firmware 5.171.13 BETA 28/11/2024 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Make sure that you are using the newset version of the mobile application for the best experience. What's new: Dashboard Added visual feedback for devices with power metering on the device tiles. Devices Performance improvements in binding processes from the mobile application. Heatit Z-Water2 device support added. Heatit Z-TRM6 DC device support added. Updated device dialog for Sound Switch device type. Added a hourglass icon for scheduled actions for HVAC devices. Improved handling of HVAC devices using Fahrenheit scale for temperature control. Elero Added support for legacy Combio JA Pulse device. Added support for Awning device role for various motor types. Nice* Updated chip SDK for stability and performance improvements. Other Updated definitions for binding instructions for the Yubii Home app. Implemented automatic restart of services in case of backup restoration failure and other errors. Quick Apps Improved loading time for content provided in the webview. Removed success toasts for webview content which covered the content of the Quick App. The exported QuickApp file now contains a device description. Added automatic code completion for RefreshStateSubscriber function. Scenes Function hub.setTimeout now returns a timeout ID that can be used to clear an ongoing timeout using the hub.clearTimeout. Z-Wave Various legacy devices support added to Z-Wave 3.0 engine.** Reconfiguration of the device now keeps original name of the devices entities.** Bug Fixes: Access The advanced user can't remove user's mobile device in Access settings even if right Access is granted. The installer can't upload a backup into the system. Small UI fixes in whole system for the advanced user depending on specific access rights. Dashboard Fixed issues with displaying large values on device tiles for sensors. Lack of state label for binary switches without power metering. Devices Fixed http error 404 when opening thermostat control dialog after deleting climate zone. The header in device protocol-specific notifications is incorrect. Fixed refreshing advanced parameter values when using mobile app device binding process. Inversion settings, device role and favorite positions are not restored in some cases after performing a soft-reconfiguration. Fixed an issue with setting the wake-up interval for battery devices to 0 in some cases after saving the configuration. Custom door lock icons are not displayed. LinkedDevice (binarySensor) does not update the last breach time. Elero UI fixes to the device binding process. Energy panel Billing periods comparsion - incorrect trend arrow status in UI. Garden Inconsistent behavior when saving settings for watering time when editing sequences. Gateway Connection Issue with Force Removing of the Z-Wave device from the Slave hub.** Nice* Rain detector state not always shows correct status for a Climatic Sensor. Other Fixed an issue with some translations refreshing on the fly when changing the Hub language. The e-mail notification from device added to Slave hub shows wrong device ID in the content. Changing home location using https does not work correctly in some cases. Plugins Fixed camera preview issue for the Nice Cameras plugin after changing the encoding from h265 to another one. Quick Apps Fixed an issue with cutting out dropdown content in new device control dialogs. Recovery UI fixes in the recovery interface on Linux based systems. Scenes Issues with saving scenes content via http API when content contains spaces. When adding a simple scenario via the Yubii Home App in installer mode, the description field is covered by the system keyboard. In some cases, in block scenes it is not possible to use push notifications for a specific mobile device. UI fixes in the Yubii Home scenario creator. It is not possible to use negative values in Energy Panel balance blocks. Z-Wave Removed not supported "Reconfigure" option for all Z-Wave devices in Z-Wave settings.** Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. En Français Maintenant Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations. Assurez-vous d'utiliser la nouvelle version de l'application mobile pour une expérience optimale. Nouveautés : Tableau de bord Ajout d'un feedback visuel pour les appareils avec mesure de puissance sur les tuiles de l'appareil. Appareils Amélioration des performances dans la liaison des processus depuis l'application mobile. Ajout de la prise en charge de l'appareil Heatit Z-Water2. Ajout de la prise en charge de l'appareil Heatit Z-TRM6 DC. Mise à jour de la boîte de dialogue des appareils pour le type d'appareil Sound Switch. Ajout d'une icône de sablier pour les actions programmées pour les appareils CVC. Amélioration de la gestion des appareils HVAC utilisant l'échelle Fahrenheit pour le contrôle de la température. Elero Ajout du support pour l'ancien dispositif Combio JA Pulse. Ajout de la prise en charge du rôle de l'appareil Awning pour différents types de moteurs. Nice* Mise à jour du SDK de la puce pour améliorer la stabilité et les performances. Autre Mise à jour des définitions pour les instructions de liaison pour l'application Yubii Home. Implémentation du redémarrage automatique des services en cas d'échec de la restauration de la sauvegarde et d'autres erreurs. Applications rapides Amélioration du temps de chargement pour le contenu fourni dans la webview. Suppression des toasts de réussite pour le contenu de la webview qui couvrait le contenu de l'application rapide. Le fichier QuickApp exporté contient désormais une description de l'appareil. Ajout de la complétion automatique du code pour la fonction RefreshStateSubscriber. Scènes La fonction hub.setTimeout renvoie maintenant un ID de timeout qui peut être utilisé pour effacer un timeout en cours en utilisant la fonction hub.clearTimeout. Z-Wave Ajout du support de divers périphériques anciens au moteur Z-Wave 3.0.** La reconfiguration du périphérique conserve désormais le nom original des entités du périphérique**. Corrections de bugs : Accès L'utilisateur avancé ne peut pas supprimer l'appareil mobile de l'utilisateur dans les paramètres d'accès même si l'accès droit est accordé. L'installateur ne peut pas télécharger une sauvegarde dans le système. Petites corrections de l'interface utilisateur dans l'ensemble du système pour l'utilisateur avancé en fonction des droits d'accès spécifiques. Tableau de bord Correction des problèmes d'affichage des grandes valeurs sur les tuiles des capteurs. Absence d'étiquette d'état pour les interrupteurs binaires sans mesure de puissance. Appareils Correction de l'erreur http 404 lors de l'ouverture de la boîte de dialogue de contrôle du thermostat après la suppression d'une zone climatique. L'en-tête des notifications spécifiques au protocole de l'appareil est incorrect. Correction de l'actualisation des valeurs des paramètres avancés lors de l'utilisation du processus de liaison des appareils de l'application mobile. Les paramètres d'inversion, le rôle de l'appareil et les positions favorites ne sont pas restaurés dans certains cas après avoir effectué une reconfiguration logicielle. Correction d'un problème avec le réglage de l'intervalle de réveil pour les dispositifs de batterie à 0 dans certains cas après avoir sauvegardé la configuration. Les icônes de verrouillage de porte personnalisées ne sont pas affichées. LinkedDevice (binarySensor) ne met pas à jour l'heure de la dernière infraction. Elero Corrections de l'interface utilisateur pour le processus de liaison des appareils. Panneau d'énergie Comparaison des périodes de facturation - statut incorrect de la flèche de tendance dans l'interface utilisateur. Jardin Comportement incohérent lors de la sauvegarde des paramètres pour le temps d'arrosage lors de la modification des séquences. Connexion à la passerelle Problème avec le retrait forcé du dispositif Z-Wave du hub esclave. Nice* L'état du détecteur de pluie n'indique pas toujours l'état correct pour un capteur climatique. Autre Correction d'un problème de rafraîchissement de certaines traductions à la volée lors du changement de langue du hub. La notification par e-mail d'un dispositif ajouté au hub esclave affiche un mauvais ID de dispositif dans le contenu. La modification de l'emplacement de la maison en utilisant https ne fonctionne pas correctement dans certains cas. Plugins Correction du problème de prévisualisation des caméras pour le plugin Nice Cameras après avoir changé l'encodage de h265 à un autre. Applications rapides Correction d'un problème de coupure du contenu de la liste déroulante dans les boîtes de dialogue de contrôle des nouveaux appareils. Récupération Correction de l'interface de récupération sur les systèmes basés sur Linux. Scènes Problèmes avec l'enregistrement du contenu des scènes via l'API http lorsque le contenu contient des espaces. Lors de l'ajout d'un scénario simple via l'application Yubii Home en mode installateur, le champ de description est couvert par le clavier du système. Dans certains cas, dans les scènes en bloc, il n'est pas possible d'utiliser les notifications push pour un appareil mobile spécifique. Corrections de l'interface utilisateur dans le créateur de scénario de Yubii Home. Il n'est pas possible d'utiliser des valeurs négatives dans les blocs d'équilibre du panneau d'énergie. Z-Wave Suppression de l'option « Reconfigurer » non supportée pour tous les appareils Z-Wave dans les paramètres Z-Wave.** Problèmes connus : Z-Wave Engine 3.0 Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas au HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. Modifié le 29 novembre 2024 par ericl78 3
TitiXsi Posté(e) le 28 novembre 2024 Signaler Posté(e) le 28 novembre 2024 Attention au titre, c'est une beta 😉 1
ROBBEJP Posté(e) le 29 novembre 2024 Signaler Posté(e) le 29 novembre 2024 Lol, tu peux encore la modifier en ajoutant RIP en plus... 😂 🤣 Ils viennent de la retirer !!! 1
ericl78 Posté(e) le 29 novembre 2024 Auteur Signaler Posté(e) le 29 novembre 2024 Message de Fibaro : Dear users, The Beta version of update 5.171 has been temporarily disabled. The update will be available again after resolving the reported issues with refreshing views for QuickApp. We would like to apologize for the inconvenience. Regards, FIBARO Team
Lazer Posté(e) le 29 novembre 2024 Signaler Posté(e) le 29 novembre 2024 Après les Stable-pas-Stable, voici les Beta-pas-Stable-non-plus, ils ont repris le rythme chez Fibaro 2 2
flacon030 Posté(e) le 29 novembre 2024 Signaler Posté(e) le 29 novembre 2024 (modifié) en tous les cas il semble qu'il se soit remis au travail... Et perso pour le moment la dernière stable semble l’être pour ma par Modifié le 29 novembre 2024 par flacon030 2
