fredokl Posté(e) le 25 novembre Signaler Posté(e) le 25 novembre (modifié) Firmware 5.170.16 STABLE 25/11/2024 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. IMPORTANT NOTICE Version 5.170.16 is a hotfix for version 5.170.13. The update resolves an issue that made it impossible to finish the first time configuration process without an internet connection. Main features: 1. New device control views A new way of controlling all device types from the Dashboard and preview in device settings for a better user experience. 2. Advanced user Introduction of a new type of user in the system with configurable access to system settings. From now on, the administrator can decide which parts of the configuration interface will be accessible to users who are not system owners. 3. Gateway Connection with Z-Wave Engine 3.0 Systems using the new Z-Wave engine can now use the Gateway Connection feature. 4. New icons sets for sensors, binary and multilevel actors System provides new sets of icons for presenting the devices and their states in more clear way. New icons apply to the following devices: - Binary Sensors - Multilevel Sensors - Binary Switches - Multilevel Switches. Make sure that you are using the newset version of the mobile application for the best experience. What's new: Access New UI for configuring access settings for normal users. Alarm By default, triggering an alarm will now result in sending a Critical Push (iOS) and Push (Android) for the new Yubii Home app. Climate A new way of direct zone control from the climate dashboard. Dashboard Adjusted icon sizes for better visibility. Devices Support for the dark theme for the new binding wizards in the mobile application. Updated and added new binding instructions to the binding wizards. Support for FGDW-002 in version 3.3 added. Updated some parameter templates for various supported devices. Minor UI/UX improvements in the binding wizards. Improvements in Linked Devices (blinds). Calibration of devices now available in advanced device settings. FGT-001 external sensor temperature offset setting removed. Added support for Zipato RFID.** Gateway Connection From now on, the upper limit for allowed slave hubs is set to 15. Nice* Added support for 2nd favorite position for Nice screens and blinds. Added a feature for synchronous movement of blinds and shutters using Bidirectional radio protocol when used in group actions. Other From now on, restoring a backup or switching the system won't disable Remote Access for support if it was enabled before the procedure. Minor UX and UI improvements. Plugins WakeOnLan plugin UI fixes. Improvements in Nice Cameras plugin for better streaming performance. Quick Apps Added the possibility to set custom views for child devices. Added the possibility to copy view definitions to the clipboard (works with HTTPS connections only). Added the possibility to add custom view elements to thermostat views. Improved webview performance. Remote users Added the possibility to download and upload backup for Support and Installer user. Scenes Support for the dark theme for Simple Scenarios. The Sound Switch device type added to Simple Scenarios. Added new sets of icons for scenarios. New icons relate to: - Garage Door - open and close - Gates - open and close - Shutter - open and close. Z-Wave User Code command class support added.** Simple AV Control command class support added.** Inclusion and configuration of supported devices performance improvements.** Added support for numerous old-gen devices (ZW300, ZW500 series).** Disabled blur on the Z-Wave console during the device-adding procedure. The Security S0 adding mode disabled by default.** Zigbee Improved performance for executing bulk actions. Improved device availability-check module (marking devices as not reachable). Support for MOES Human Presence Sensor ZSS-QY-HP added. Bug Fixes: Access Fixed access rights for Advanced user. Fixes in the UI for configuring rights for advanced user. Backup Fixed rare error during backup restoration. Cameras Fixed camera previews in some cases. Climate Fixed displaying values in Fahrenheit in the preview of the climate zone. Dashboard Fixed Drag&Drop for devices on dashboard, enabling the reordering of devices in room. Devices Fixed default icons for some device types. Toggle action support fixed for the multiposition switch device type. Fixed incorrect message when performing calibration of FGD-221 device.** Fixed setpoint graph for FGT-001, which was not correctly shown in some cases. Unable to add device in Security S2 if the PIN was incorrect (out of allowed range).** Minor UI fixes in FGR-224/Roll-Control 2 advanced settings. Refreshing advanced parameter values in the wizard binding procedure did not work correctly. Fixed setting favorite positions for some blinds. The icon for the Door lock changes according to the state of door lock. Fixed setting user codes on Yale, Kaadas and other doorlocks.** Fixed preview and tile view in dashboard for thermostats. Fixed status presentation on Door Locks icons in some cases. Fixed current override status presentation for thermostats control dialog. Fixed issue with automatic change of device icon based on selected role for some device types. Gateway Connection Fixed issue with special characters in passwords for the slave hubs. Update visibility for slave hub did not work correctly. Fixed issue with connecting a new Slave hub that occurred in 5.162 Beta. Fixed issue with accessing backups on the Slave hub in rare cases. History Some duplicated events removed. Lack of icon for some events from FGT-001. Nice* Fixed support for MHouse protocol gates with new hardware revision. BiDi-Multisensor is temporarily marked as disconnected when resetting some device parameters to default. Notifications Redundant intervals removed from the configuration page for event-type notifications. Other Minor translation fixes. Minor UI/UX fixes. User is logged out from the system after creating a backup. Issues with saving Sprinkler Schedule. Plugins Fixed preview for the Sonos plugin. Quick Apps Added QuickApp is placed in the incorrect room in some cases. Fixed issue with icons handling for some devices types like Weather provider. Remote users Fixed access for LUA Scenes for Support and Installer user. Recovery Fixed issue with updating the hub from Recovery from 5.140 to 5.153 Beta. Fixed issue with checking system version when using the Repair option. Rooms Fixed issue with setting the default room icon after removing a custom icon from the system. Cannot remove custom SVG icon in room settings. Custom room icon is not visible when editing the room settings. Fixed uploading custom icon for the room by Advanced user. Scenes When a new scene is added, the window does not scroll to the newly added element. Possibility to type too long a name for Simple Scenario, which blocks the possibility to save it. Lack of some scene icons after system restart in rare cases. Small UI fixes in Simple Scenarios. Main Z-Wave devices available in block scenes device selector. Fixed issue with Scene Activation feature in block scenes. Swapped triggering the scene on Doorlock state. Update Download progress bar visibility depends on the checkbox selection (beta). Z-Wave Error 500 in some rare cases during the Z-Wave device reconfiguration process. Requesting Neighbors update action not always triggers correctly. Fixed setting the device polling interval manually. BiDi-Zwave device is added with a wrong system role by default. Qubino 0-10V Dimmer parameters are being restored to default during inclusion. Resolved issue with displaying Advanced tab for Door lock device.** Fixed rare issue with starting the Z-Wave service when controller Node ID is different than 1. Solved issue with mesh network reconfiguration not working. Fixed issue with not hiding automatically console log after finishing adding or removing process. Zigbee Device removal procedure fixed. State of the light in the system is synced with the real light state for Ikea lights. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. * - Does not apply to HC3L (Home Center 3 Lite). ** - Applies only to Z-Wave 3.0 engine. En français: Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et améliorations. AVIS IMPORTANT La version 5.170.16 est un correctif pour la version 5.170.13. La mise à jour résout un problème qui rendait impossible la fin du premier processus de configuration sans connexion Internet. Principales caractéristiques : 1. Nouvelles vues de contrôle de l'appareil Une nouvelle façon de contrôler tous les types d'appareils à partir du tableau de bord et de prévisualiser dans les paramètres de l'appareil pour une meilleure expérience utilisateur. 2. Utilisateur avancé Introduction d'un nouveau type d'utilisateur dans le système avec un accès configurable aux paramètres système. À partir de maintenant, l'administrateur peut décider quelles parties de l'interface de configuration seront accessibles aux utilisateurs qui ne sont pas propriétaires du système. 3. Connexion de la passerelle avec Z-Wave Engine 3.0 Les systèmes utilisant le nouveau moteur Z-Wave peuvent désormais utiliser la fonction de connexion de passerelle. 4. Nouveaux ensembles d'icônes pour les capteurs, les acteurs binaires et multiniveaux Le système fournit de nouveaux ensembles d'icônes pour présenter les appareils et leurs états de manière plus claire. De nouvelles icônes s'appliquent aux appareils suivants : - Capteurs binaires - Capteurs à plusieurs niveaux - Commutateurs binaires - Commutateurs à plusieurs niveaux. Assurez-vous d'utiliser la version newset de l'application mobile pour la meilleure expérience. Quoi de neuf : Accès Nouvelle interface utilisateur pour configurer les paramètres d'accès pour les utilisateurs normaux. Alarme Par défaut, le déclenchement d'une alarme entraînera désormais l'envoi d'un Push critique (iOS) et d'un Push (Android) pour la nouvelle application Yubii Home. Climat Une nouvelle façon de contrôler directement les zones à partir du tableau de bord climatique. Tableau de bord Tailles d'icônes ajustées pour une meilleure visibilité. Appareils Prise en charge du thème sombre pour les nouveaux assistants de liaison dans l'application mobile. Mise à jour et ajout de nouvelles instructions de liaison aux assistants de liaison. Prise en charge de FGDW-002 dans la version 3.3 ajoutée. Mise à jour de certains modèles de paramètres pour divers appareils pris en charge. Améliorations mineures de l'interface utilisateur/UX dans les assistants de liaison. Améliorations des appareils liés (stores). L'étalonnage des appareils est maintenant disponible dans les paramètres avancés de l'appareil. FGT-001 réglage de décalage de la température du capteur externe supprimé. Ajout de la prise en charge de Zipato RFID. ** Connexion de la passerelle À partir de maintenant, la limite supérieure pour les hubs esclaves autorisés est fixée à 15. Nice* Ajout de la prise en charge de la 2e position préférée pour les beaux écrans et stores. Ajout d'une fonctionnalité pour le mouvement synchrone des stores et des volets à l'aide du protocole radio bidirectionnel lorsqu'il est utilisé dans des actions de groupe. Autre À partir de maintenant, la restauration d'une sauvegarde ou le changement de système ne désactivera pas l'accès à distance pour le support s'il a été activé avant la procédure. Améliorations mineures de l'expérience utilisateur et de l'interface utilisateur. Plugins Corrections de l'interface utilisateur du plugin WakeOnLan. Améliorations du plugin Nice Cameras pour de meilleures performances de streaming. Quick Apps Ajout de la possibilité de définir des vues personnalisées pour les appareils enfants. Ajout de la possibilité de copier les définitions de vue dans le presse-papiers (fonctionne uniquement avec les connexions HTTPS). Ajout de la possibilité d'ajouter des éléments de vue personnalisés aux vues du thermostat. Amélioration des performances de la vue Web. Utilisateurs distants Ajout de la possibilité de télécharger et de télécharger une sauvegarde pour l'utilisateur de support et d'installateur. Scènes Prise en charge du thème sombre pour les scénarios simples. Le type de périphérique Sound Switch ajouté à Simple Scenarios. Ajout de nouveaux ensembles d'icônes pour les scénarios. Les nouvelles icônes concernent : - Porte de garage - ouverte et fermée - Portes - ouvertes et fermées - Obturateur - ouvert et fermé. Z-Wave Ajout de la prise en charge de la classe de commande du code utilisateur. ** Prise en charge simple de la classe de commande AV Control ajoutée. ** Inclusion et configuration des améliorations des performances des appareils pris en charge. ** Ajout de la prise en charge de nombreux appareils d'ancienne génération (séries ZW300, ZW500). ** Désactivé le flou sur la console Z-Wave pendant la procédure d'ajout de périphérique. Le mode d'ajout de sécurité S0 est désactivé par défaut. ** Zigbee Amélioration des performances pour l'exécution d'actions groupées. Amélioration du module de vérification de la disponibilité de l'appareil (marquant les appareils comme non accessibles). Prise en charge du capteur de présence humaine MOES ZSS-QY-HP ajouté. Corrections de bugs : Accès Droits d'accès fixes pour l'utilisateur avancé. Corrections dans l'interface utilisateur pour configurer les droits pour l'utilisateur avancé. Sauvegarde Correction d'une erreur rare lors de la restauration de la sauvegarde. Caméras Correction des aperçus de l'appareil photo dans certains cas. Climat Correction de l'affichage des valeurs en Fahrenheit dans l'aperçu de la zone climatique. Tableau de bord Correction du glisser-déposer pour les appareils sur le tableau de bord, permettant la réorganisation des appareils dans la pièce. Appareils Correction des icônes par défaut pour certains types d'appareils. Prise en charge de l'action à bascule fixe pour le type de périphérique de commutation multiposition. Correction d'un message incorrect lors de l'étalonnage de l'appareil FGD-221. ** Graphique de point de consigne fixe pour FGT-001, qui n'a pas été correctement affiché dans certains cas. Impinu d'ajouter un appareil dans Security S2 si le code PIN était incorrect (hors de portée autorisée). ** Corrections mineures de l'interface utilisateur dans les paramètres avancés FGR-224/Roll-Control 2. L'actualisation des valeurs de paramètres avancés dans la procédure de liaison de l'assistant n'a pas fonctionné correctement. Correction du réglage des positions préférées pour certains stores. L'icône de la serrure de porte change en fonction de l'état de la serrure de porte. Correction du réglage des codes utilisateur sur Yale, Kaadas et autres serrures de porte. ** Aperçu fixe et vue en mosaïque dans le tableau de bord pour les thermostats. Correction de la présentation de l'état sur les icônes des serrures de porte dans certains cas. Correction de la présentation de l'état de remplacement actuel pour la boîte de dialogue de contrôle des thermostats. Correction d'un problème avec le changement automatique de l'icône de l'appareil en fonction du rôle sélectionné pour certains types d'appareils. Connexion de la passerelle Correction d'un problème avec les caractères spéciaux dans les mots de passe pour les hubs esclaves. La visibilité de mise à jour pour le hub esclave n'a pas fonctionné correctement. Correction d'un problème avec la connexion d'un nouveau hub Slave qui s'est produit dans 5.162 Beta. Correction d'un problème d'accès aux sauvegardes sur le hub Slave dans de rares cas. Historique Certains événements en double supprimés. Manque d'icône pour certains événements de FGT-001. Nice* Correction de la prise en charge des portes de protocole MHouse avec une nouvelle révision matérielle. BiDi-Multisensor est temporairement marqué comme déconnecté lors de la réinitialisation de certains paramètres de l'appareil par défaut. Notifications Intervalles redondants supprimés de la page de configuration pour les notifications de type événement. Autre Corrections mineures de traduction. Corrections mineures UI/UX. L'utilisateur est déconnecté du système après avoir créé une sauvegarde. Problèmes avec l'enregistrement du calendrier des gicleurs. Plugins Correction de l'aperçu pour le plugin Sonos. Quick Apps QuickApp ajouté est placé dans la mauvaise pièce dans certains cas. Correction d'un problème avec la gestion des icônes pour certains types d'appareils comme le fournisseur de météo. Utilisateurs distants Accès fixe pour les scènes LUA pour l'utilisateur de support et d'installateur. Recovery Correction d'un problème avec la mise à jour du hub de Recovery de 5.140 à 5.153 Beta. Correction d'un problème lors de la vérification de la version du système lors de l'utilisation de l'option de réparation. Pièces Correction d'un problème avec la définition de l'icône de la salle par défaut après la suppression d'une icône personnalisée du système. Impossible de supprimer l'icône SVG personnalisée dans les paramètres de la salle. L'icône de la salle personnalisée n'est pas visible lors de l'édition des paramètres de la salle. Correction de l'icône de téléchargement personnalisée pour la salle par l'utilisateur avancé. Scènes Lorsqu'une nouvelle scène est ajoutée, la fenêtre ne fait pas défiler jusqu'à l'élément nouvellement ajouté. Possibilité de taper trop longtemps un nom pour Simple Scenario, ce qui bloque la possibilité de l'enregistrer. Manque d'icônes de scène après le redémarrage du système dans de rares cas. Corrections de petites interfaces utilisateur dans des scénarios simples. Principaux appareils Z-Wave disponibles dans le sélecteur de périphériques de scènes de bloc. Correction d'un problème avec la fonction d'activation de scène dans les scènes de blocage. Échangé pour déclencher la scène à l'état Doorlock. Mise à jour La visibilité de la barre de progression du téléchargement dépend de la sélection de la case à cocher (bêta). Z-Wave Erreur 500 dans certains cas rares pendant le processus de reconfiguration de l'appareil Z-Wave. Demander l'action de mise à jour des voisins ne se déclenche pas toujours correctement. Correction du réglage manuel de l'intervalle d'interrogation de l'appareil. Le périphérique BiDi-Zwave est ajouté avec un mauvais rôle système par défaut. Les paramètres du gradateur Qubino 0-10V sont restaurés par défaut pendant l'inclusion. Problème résolu avec l'affichage de l'onglet Avancé pour le dispositif de verrouillage de porte. ** Correction d'un problème rare lors du démarrage du service Z-Wave lorsque l'ID du nœud du contrôleur est différent de 1. Résolution du problème avec la reconfiguration du réseau maillé qui ne fonctionnait pas. Correction d'un problème de ne pas masquage automatique du journal de la console après avoir terminé l'ajout ou la suppression du processus. Zigbee Correction de la procédure de retrait de l'appareil. L'état de la lumière dans le système est synchronisé avec l'état réel de la lumière pour les lumières Ikea. Problèmes connus : Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. * - Ne s'applique pas à HC3L (Home Center 3 Lite). ** - S'applique uniquement au moteur Z-Wave 3.0. Modifié le 25 novembre par fredokl 3
Lazer Posté(e) le 25 novembre Signaler Posté(e) le 25 novembre Ah le grand retour des versions stables pas stables Heureusement qu'on a des hotfix
fredokl Posté(e) le 25 novembre Auteur Signaler Posté(e) le 25 novembre (modifié) Un classique chez Fibaro! Pourquoi changer une méthode qui fonctionne? Ils nous tiennent en haleine à chaque mise à jour! Mieux qu'une série Netflix finalement...la suite au prochain épisode! Modifié le 25 novembre par fredokl
mprinfo Posté(e) le 25 novembre Signaler Posté(e) le 25 novembre Merci pour la traduction en français Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
