HC3 & HC3L - 5.162.60 - BETA - 23/09/2024
Firmware 5.162.60
BETA
23/09/2024
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New icons sets for sensors, binary and multilevel actors
System provides new sets of icons for presenting the devices and their states in more clear way. New icons apply to the following devices:
- Binary Sensors
- Multilevel Sensors
- Binary Switches
- Multilevel Switches.
Make sure that you are using the newset version of the mobile application for the best experience.
What's new:
Devices
Added support for Zipato RFID.**
Other
Minor UX and UI improvements.
Remote users
Added the possibility to download and upload backup for Support and Installer user.
Scenes
Added new sets of icons for scenarios. New icons relate to:
- Garage Door - open and close
- Gates - open and close
- Shutter - open and close.
Bug Fixes:
Access
Fixed access rights for Advanced user.
Climate
Fixed displaying values in Fahrenheit in the preview of the climate zone.
Dashboard
Fixed Drag&Drop for devices on dashboard, enabling the reordering of devices in room.
Devices
State of the light in the system is synced with the real light state for Ikea lights.
The icon for the Door lock changes according to the state of door lock.
Fixed setting user codes on Yale, Kaadas and other doorlocks.**
Fixed preview and tile view in dashboard for thermostats.
Other
Issues with saving Sprinkler Schedule.
Plugins
Fixed preview for the Sonos plugin.
Remote users
Fixed access for LUA Scenes for Support and Installer user.
Rooms
Fixed uploading custom icon for the room by Advanced user.
Z-Wave
Resolved issue with displaying Advanced tab for Door lock device.**
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Modifié par fredokl
  • Like 4
Firmware 5.162.60
BETA
23/09/2024
en français (google translate)
Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et améliorations.
Principales caractéristiques :
1. Nouveaux ensembles d'icônes pour les capteurs, les acteurs binaires et multi-niveaux
Le système fournit de nouveaux ensembles d'icônes pour présenter les appareils et leurs états de manière plus claire. De nouvelles icônes s'appliquent aux appareils suivants :
- Capteurs binaires
- Capteurs à plusieurs niveaux
- Commutateurs binaires
- Commutateurs à plusieurs niveaux.
Assurez-vous d'utiliser la version newset de l'application mobile pour la meilleure expérience.
Quoi de neuf :
Appareils
Ajout de la prise en charge de Zipato RFID. **
Autre
Améliorations mineures de l'expérience utilisateur et de l'interface utilisateur.
Utilisateurs distants
Ajout de la possibilité de télécharger et de télécharger une sauvegarde pour l'utilisateur de support et d'installateur.
Scènes
Ajout de nouveaux ensembles d'icônes pour les scénarios. Les nouvelles icônes concernent :
- Porte de garage - ouverte et fermée
- Portes - ouvertes et fermées
- Obturateur - ouvert et fermé.
Corrections de bugs :
Accès
Droits d'accès fixes pour l'utilisateur avancé.
Climat
Correction de l'affichage des valeurs en Fahrenheit dans l'aperçu de la zone climatique.
Tableau de bord
Correction du glisser-déposer pour les appareils sur le tableau de bord, permettant la réorganisation des appareils dans la pièce.
Appareils
L'état de la lumière dans le système est synchronisé avec l'état réel de la lumière pour les lumières Ikea.
L'icône de la serrure de porte change en fonction de l'état de la serrure de porte.
Correction du réglage des codes utilisateur sur Yale, Kaadas et autres serrures de porte. **
Aperçu fixe et vue en mosaïque dans le tableau de bord pour les thermostats.
Autre
Problèmes avec l'enregistrement du calendrier des gicleurs.
Plugins
Correction de l'aperçu pour le plugin Sonos.
Accès fixe pour les scènes LUA pour l'utilisateur de support et d'installateur.
Chambres
Correction de l'icône de téléchargement personnalisée pour la salle par l'utilisateur avancé.
Z-Wave
Problème résolu avec l'affichage de l'onglet Avancé pour le dispositif de verrouillage de porte. **
Problèmes connus :
Moteur Z-Wave 3.0
Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
* - Ne s'applique pas à HC3L (Home Center 3 Lite).
** - S'applique uniquement au moteur Z-Wave 3.0.
Modifié par fredokl
  • fredokl a modifié le titre en HC3 & HC3L - 5.162.60 - BETA - 23/09/2024
Bonjour à tous, de mon coté je suis revenu en arrière car cette version me pette mon intégration avec la danalock, il n'y a plus de changement  d'état.
J'ai une danalock V2 en version 1.3 suis en zwave v2.
Si quelqu'un à ce device je suis preneur d'info.
