HC3 & HC3L - 5.161.15 - BETA - 25/07/2024
Firmware 5.161.15
BETA
25/07/2024
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. New device control views
    A new way of controlling all device types from the Dashboard and preview in device settings for a better user experience.
2. Advanced user
    Introduction of a new type of user in the system with configurable access to system settings.
    From now on, the administrator can decide which parts of the configuration interface will be accessible to users who are not system owners.
3. Gateway Connection with Z-Wave Engine 3.0
    Systems using the new Z-Wave engine can now use the Gateway Connection feature.
What's new:
    Access
        New UI for configuring access settings for normal users.
    Alarm
        By default, triggering an alarm will now result in sending a Critical Push (iOS) and Push (Android) for the new Yubii Home app.
    Climate
        A new way of direct zone control from the climate dashboard.
    Dashboard
        Adjusted icon sizes for better visibility.
    Devices
        Support for the dark theme for the new binding wizards in the mobile application.
        Updated and added new binding instructions to the binding wizards.
        Support for FGDW-002 in version 3.3 added.
        Updated some parameter templates for various supported devices.
        Minor UI/UX improvements in the binding wizards.
        Improvements in Linked Devices (blinds).
        Calibration of devices now available in advanced device settings.
        FGT-001 external sensor temperature offset setting removed.
    Gateway Connection
        From now on, the upper limit for allowed slave hubs is set to 15.
    Nice*
        Added support for 2nd favorite position for Nice screens and blinds.
    Other
        From now on, restoring a backup or switching the system won't disable Remote Access for support if it was enabled before the procedure.
    Plugins
        WakeOnLan plugin UI fixes.
        Improvements in Nice Cameras plugin for better streaming performance.
    Quick Apps
        Added the possibility to set custom views for child devices.
        Added the possibility to copy view definitions to the clipboard (works with HTTPS connections only).
        Added the possibility to add custom view elements to thermostat views.
        Improved webview performance.
    Scenes
        Support for the dark theme for Simple Scenarios.
        The Sound Switch device type added to Simple Scenarios.
    Z-Wave
        User Code command class support added.**
        Simple AV Control command class support added.**
        Inclusion and configuration of supported devices performance improvements.**
        Added support for numerous old-gen devices (ZW300, ZW500 series).**
        Disabled blur on the Z-Wave console during the device-adding procedure.
        Disabling the Security S0 adding mode available.**
    Zigbee
        Improved performance for executing bulk actions.
        Improved device availability-check module (marking devices as not reachable).
        Support for MOES Human Presence Sensor ZSS-QY-HP added.
Bug fixes:
    Backup
        Fixed rare error during backup restoration.
    Cameras
        Fixed camera previews in some cases.
    Devices
        Fixed default icons for some device types.
        Toggle action support fixed for the multiposition switch device type.
        Fixed incorrect message when performing calibration of FGD-221 device.**
        Fixed setpoint graph for FGT-001, which was not correctly shown in some cases.
        Unable to add device in Security S2 if the PIN was incorrect (out of allowed range).**
        Minor UI fixes in FGR-224/Roll-Control 2 advanced settings.
        Refreshing advanced parameter values in the wizard binding procedure did not work correctly.
        Fixed setting favorite positions for some blinds.
    Gateway Connection
        Fixed issue with special characters in passwords for the slave hubs.
        Update visibility for slave hub did not work correctly.
    History
        Some duplicated events removed.
    Nice*
        Fixed support for MHouse protocol gates with new hardware revision.
        BiDi-Multisensor is temporarily marked as disconnected when resetting some device parameters to default.
    Notifications
        Redundant intervals removed from the configuration page for event-type notifications.
    Other
        Minor translation fixes.
        Minor UI/UX fixes.
        User is logged out from the system after creating a backup.
    Quick Apps
        Added QuickApp is placed in the incorrect room in some cases.
    Recovery
        Fixed issue with updating the hub from Recovery from 5.140 to 5.153 Beta.
        Fixed issue with checking system version when using the Repair option.
    Rooms
        Fixed issue with setting the default room icon after removing a custom icon from the system.
        Cannot remove custom SVG icon in room settings.
        Custom room icon is not visible when editing the room settings.
    Scenes
        When a new scene is added, the window does not scroll to the newly added element.
        Possibility to type too long a name for Simple Scenario, which blocks the possibility to save it.
        Lack of some scene icons after system restart in rare cases.
        Small UI fixes in Simple Scenarios.
        Main Z-Wave devices available in block scenes device selector.
        Fixed issue with Scene Activation feature in block scenes.
        Swapped triggering the scene on Doorlock state.
    Update
        Download progress bar visibility depends on the checkbox selection (beta).
    Z-Wave
        Error 500 in some rare cases during the Z-Wave device reconfiguration process.
        Requesting Neighbors update action not always triggers correctly.
        Fixed setting the device polling interval manually.
        BiDi-Zwave device is added with a wrong system role by default.
        Qubino 0-10V Dimmer parameters are being restored to default during inclusion.
    Zigbee
        Device removal procedure fixed.
Known issues:
    Z-Wave Engine 3.0
            Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Like 2
  • Thanks 1
Merci d'utiliser notre passerelle ! Veillez à mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et des améliorations.
Principales caractéristiques :
1. Nouvelles vues de contrôle des appareils
Une nouvelle façon de contrôler tous les types d'appareils à partir du tableau de bord et de l'aperçu dans les paramètres de l'appareil pour une meilleure expérience utilisateur.
2. Utilisateur avancé
Introduction d'un nouveau type d'utilisateur dans le système avec un accès configurable aux paramètres du système.
Désormais, l'administrateur peut décider quelles parties de l'interface de configuration seront accessibles aux utilisateurs qui ne sont pas propriétaires du système.
3. Connexion à la passerelle avec le moteur Z-Wave 3.0
Les systèmes utilisant le nouveau moteur Z-Wave peuvent désormais utiliser la fonction Gateway Connection.
Les nouveautés :
Accès
- Nouvelle interface utilisateur pour configurer les paramètres d'accès pour les utilisateurs normaux.
Alarme
- Par défaut, le déclenchement d'une alarme entraîne désormais l'envoi d'un Push critique (iOS) et d'un Push (Android) pour la nouvelle application Yubii Home.
Climat
- Une nouvelle façon de contrôler directement les zones à partir du tableau de bord climatique.
Tableau de bord
- Ajustement de la taille des icônes pour une meilleure visibilité.
Appareils
- Prise en charge du thème sombre pour les nouveaux assistants de reliure dans l'application mobile.
- Mise à jour et ajout de nouvelles instructions de fixation aux assistants de fixation.
- Prise en charge de FGDW-002 dans la version 3.3.
- Mise à jour de certains modèles de paramètres pour divers appareils pris en charge.
-Améliorations mineures de l'UI/UX dans les assistants de reliure.
- Améliorations dans les dispositifs liés (stores).
- L'étalonnage des appareils est désormais disponible dans les paramètres avancés de l'appareil.
- Le réglage du décalage de température du capteur externe FGT-001 a été supprimé.
- Désormais, la limite supérieure des hubs esclaves autorisés est fixée à 15.
Nice*
- Ajout de la prise en charge de la deuxième position favorite pour les écrans et les stores Nice.
Autre
- Désormais, la restauration d'une sauvegarde ou le changement de système ne désactivera pas l'accès à distance pour le support s'il était activé avant la procédure.
Plugins
Correction de l'interface utilisateur du plugin WakeOnLan.
Améliorations dans le plugin Nice Cameras pour une meilleure performance du streaming.
Applications rapides
Ajout de la possibilité de définir des vues personnalisées pour les appareils enfants.
Ajout de la possibilité de copier les définitions de vues dans le presse-papier (fonctionne avec les connexions HTTPS uniquement).
Ajout de la possibilité d'ajouter des éléments de vue personnalisés aux vues de thermostat.
Amélioration des performances des webviews.
Scènes
Prise en charge du thème sombre pour les scénarios simples.
Le type de périphérique Sound Switch a été ajouté aux scénarios simples.
Z-Wave
Ajout du support de la classe de commande User Code.**
Ajout du support de la classe de commande Simple AV Control.**
Amélioration des performances de l'inclusion et de la configuration des dispositifs pris en charge**.
Ajout de la prise en charge de nombreux dispositifs d'ancienne génération (série ZW300, ZW500).**
Désactivation du flou sur la console Z-Wave pendant la procédure d'ajout de périphérique.
Désactivation du mode d'ajout Security S0 disponible.**
Zigbee
Amélioration des performances lors de l'exécution d'actions de masse.
Amélioration du module de vérification de la disponibilité des dispositifs (marquage des dispositifs non joignables).
Ajout de la prise en charge du capteur de présence humaine MOES ZSS-QY-HP.
Corrections de bugs :
Sauvegarde
Correction d'une erreur rare lors de la restauration d'une sauvegarde.
Caméras
Correction des aperçus de caméra dans certains cas.
Appareils
Correction des icônes par défaut pour certains types d'appareils.
Correction de la prise en charge de l'action de basculement pour le type d'interrupteur multipositions.
Correction d'un message incorrect lors de l'étalonnage de l'appareil FGD-221.**
Correction du graphique du point de consigne pour FGT-001, qui ne s'affichait pas correctement dans certains cas.
Impossible d'ajouter un appareil dans Security S2 si le PIN était incorrect (hors de la plage autorisée).**
Corrections mineures de l'interface utilisateur dans les paramètres avancés de FGR-224/Roll-Control 2.
L'actualisation des valeurs des paramètres avancés dans la procédure de liaison de l'assistant ne fonctionnait pas correctement.
Correction du réglage des positions favorites pour certains stores.
Correction d'un problème avec les caractères spéciaux dans les mots de passe pour les concentrateurs esclaves.
La visibilité de la mise à jour pour le concentrateur esclave ne fonctionnait pas correctement.
Historique
Suppression de certains événements en double.
Nice*
Correction de la prise en charge des portes du protocole MHouse avec la nouvelle révision du matériel.
Le BiDi-Multisensor est temporairement marqué comme déconnecté lors de la réinitialisation par défaut de certains paramètres de l'appareil.
Notifications
Les intervalles redondants ont été supprimés de la page de configuration pour les notifications de type événement.
Autres
Corrections mineures de la traduction.
Corrections mineures de l'interface utilisateur.
L'utilisateur est déconnecté du système après avoir créé une sauvegarde.
L'application rapide ajoutée est placée dans la mauvaise pièce dans certains cas.
Récupération
Correction d'un problème lors de la mise à jour du hub de Recovery de 5.140 à 5.153 Beta.
Correction d'un problème de vérification de la version du système lors de l'utilisation de l'option de réparation.
Salles
Correction d'un problème lors de la définition de l'icône de salle par défaut après avoir supprimé une icône personnalisée du système.
Impossible de supprimer l'icône SVG personnalisée dans les paramètres de la salle.
L'icône de la salle personnalisée n'est pas visible lors de l'édition des paramètres de la salle.
Scènes
Lorsqu'une nouvelle scène est ajoutée, la fenêtre ne défile pas jusqu'à l'élément nouvellement ajouté.
Possibilité de taper un nom trop long pour un scénario simple, ce qui bloque la possibilité de le sauvegarder.
Absence de certaines icônes de scènes après le redémarrage du système dans de rares cas.
Petites corrections de l'interface utilisateur dans les scénarios simples.
Principaux dispositifs Z-Wave disponibles dans le sélecteur de dispositifs des scènes en bloc.
Correction d'un problème avec la fonction d'activation de scène dans les scènes en bloc.
Remplacement du déclenchement de la scène sur l'état de verrouillage de la porte.
Mise à jour
La visibilité de la barre de progression du téléchargement dépend de la sélection de la case à cocher (beta).
Z-Wave
Erreur 500 dans quelques rares cas pendant le processus de reconfiguration du périphérique Z-Wave.
L'action de mise à jour « Requesting Neighbors » ne se déclenche pas toujours correctement.
Correction du réglage manuel de l'intervalle d'interrogation du périphérique.
Le périphérique BiDi-Zwave est ajouté avec un mauvais rôle système par défaut.
Les paramètres du Qubino 0-10V Dimmer sont restaurés par défaut lors de l'inclusion.
Zigbee
Correction de la procédure de suppression des dispositifs.
Problèmes connus :
Z-Wave Engine 3.0
Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
* - ne s'applique pas au HC3L (Home Center 3 Lite)
** - s'applique uniquement au Z-Wave Engine 3.0
Tiens, ça faisait tellement longtemps que j'avais presque oublié que la HC3 était un appareil qu'on peut mettre à jour :2:
il y a une heure, ericl78 a dit :
Quick Apps
Han trop bien 😍
Il y a quelques temps pour des QA que je développais ça m'aurait été bien utile.
Ça va peut-être fixer mes Shelly wave qui perdent leurs voisins...
