HC3 & HC3L - 5.160.30 - STABLE - 16/04/2024
Firmware 5.160.30
STABLE
16/04/2024
Main features:
1. User scenarios
Users can now create their own scenarios (scenes) in the mobile application using a specially prepared addition wizard. To use scenarios, update your Yubii application to at least 1.21 version or install the new mobile app (description below).
2. New process for adding devices in the mobile app
From now on, users can more easily add their devices to the system via the mobile app using the new addition wizard. To use the new way of adding, install the new mobile application.
3. Changes for the new mobile application
App Store: https://apps.apple.com/app/id6477485519
Google Play: https://play.google.com/store/apps/details?id=com.niceforyou.yubii
  • Added new default icon sets for devices, scenes, and rooms.
  • New way of displaying Quick App’s content.
  • Possibility to use Quick App’s old style view for backward compatibility.
  • New look for Sonos and Husqvarna plugin.
  • New design for user scenarios.
What's new:
Devices
    Corrected the display of values for the device available updates counter.
    Removed unused roles for baseShutter and rollerShutter types.
    Added support for REMOTEC ZXT800 device.
    Added support for Heatit Z-TRM6 device.
    Added support for MCOHome Keypad Switch K-ES2 device.
    Added support for MCOHome OS11 and OS12 presence sensors.
    Added support for devices in Z-Wave 3.0 engine**:
        FGD-211
        FGS-221
        FGR-221
        FGS-211
        FGBS-321
        FGWPE-102
        FGWPI-121
    Removed redundant slat control for blind types that do not have such functionality.
Elero
    Updated the radio module firmware.
    Added support for old versions of RolTop blind drives.
Gateway connection
    Moved the central selection from advanced settings directly to the Z-Wave device addition screen.
Nice*
    Improvements for pairing Mono devices using existing remote.
    Reduced network load for better performance.
    Added support for automatic calibration for BiDi-Shutter and BiDi-Awning devices.
Other
    Improved error handling when adding a user template for a device.**
    Improved the operation of system notifications by updating their data according to the current system settings (room names, language, etc.).
    Introduced system optimizations to improve the performance of the hubs.
    Updated WLAN firmware.
Plugins
    Aligned plugins view with new application styling.
    Default Satel icons updated to new sets.
    Added support for Satel Integra 256.
QuickApps
    Aligned QuickApps view with new application styling.
    Added native view for the com.fibaro.player device type.
    Added handling uploadExternalIconSet() method for the com.fibaro.player.
Scenes
    Improved visuals for color sliders in new simple scenarios.
    Hidden the "True for a specified time" option for event-based conditions and triggers.
    Added a new look for the email's template sent from the block scenes.
    Improved the toggle action (on/off) of the Unio-868 device.
Z-Wave
   Improved service start time.
   Added support for devices:
  • ZVIDAR Z-TRV-V01
  • NICE Warm-Control
  • NICE Clima-Control
  • NICE Fan2-Control
  • NICE Fan4-Control
  • MCO OS11/OS12 for US and ANZ frequencies
    FGDW-002 support for version 3.3.
    Stability improvements.
    Improvements for network perfomance.**
    Updated the radio module firmware (YH/HC3L).
    Improved the process of adding Schlage BE369 device.**
    Enhanced communication during high network load and eliminated the "freezing" rare phenomenon of the Z-Wave engine.**
    Improved default parameters settings for Aeotec Home Energy Meters and Qubino 1p and 3p meters.
Bug Fixes:
Backup
    Fixed an issue displaying the login screen after creating a backup.
    Resolved issue of redundant hub restart when creating a backup.
Climate
    Fixed display of names for selected thermostats on selector.
    Fixed the offset between cooling and heating values for Fahrenheit units.
Devices
    Fixed the issue with setting inputs type for FGRGBW-442/RGBW-Control in RGBW/RGB mode.
    Redundant stop button for some of gates.
    Fixed custom icons for meters.
    Redundant duplicates of icons sets in some cases were removed.
    Favorite position icons does not work for some of simple shutters.
    Incorrect default FGWC icon in web interface.
    Corrected the way how Favorite Position state icon is displayed for multi-position switch device type.
    Saving of the slats angle in the favorite position for the FGR-224 has been improved.
    Fixed the appearance of the modal window for adding custom icons for multistate devices.
    Fibaro RGBW2/Nice RGBW-Control becomes unconfigured in rare cases.
    Heatit Z-Smoke no longer reports motion detection.
    Issues with controlling Fibaro RGBW1 after pairing the device.
    Fixed reconfiguration operation for Heatit ZTERM3 device.
    Minor stylistic fixes for slider displays.
    Improved operation of Unio 868 device with inverted logic option enabled.
    Fixed setting favorite colors for RGBW Linked Device.
    Fixed temperature and humidity hysteresis ranges in Linked Devices.
    Fixed an issue with restoring default parameters for Domii Climatic sensor after system restart.
    Fixed marking Domii climatic sensor (solar) as dead after central unit restart or update.
    Fixed 502 error when adding Elero devices.
FTI
    Error during setup of the installer while performing the FTI by mobile application.
Gateway connection
    Fixed status display and the problem of the Master gateway not restarting automatically after the upgrade.
    Improved network operation and DNS handling when linking hubs.
Linked devices
    Hysteresis settings for temperature and humidity have been improved - from now on it cannot be greater than the difference between the minimum and maximum values.
   Style improvements for Linked Devices – Choose Master device option.
Nice*
    Fixed support for Nice Home gates line.
    Optimized handling of battery operated devices.
    Network performance improvements.
    Nice polling interval restores to default value after disabling it.
    Fixed support for parameter 5 of the BiDi-Shutter device.
    Fixed an issue where devices paired with BiDi remote authorization using one channel do not respond until the hub is restarted.
Other
    Unable to create a room when custom icon is used during the process.
    Improved stability of WiFi driver for YH/HC3L hubs.
    UI fixes in device tree selector.
    Removed redundant "Back" button in new binding process in some cases.
    Fixes for bulk clear in Notifications panel.
    UI fixes in history panel.
    The appearance of the notification list after using the "Clear all" option has been improved.
    Fixed problems with changing the order of rooms in the interface.
    Fixed the problem of the login screen appearing in the interface after using the option to restore the gateway to factory settings.
    Random 502 error in webUI in some cases.
    System boot issue in very rare cases.
    Error 409 after adding again previously added Smart Start DSK.**
    Minor UX and UI improvements.
    Restricted Installer permissions for changes in the access settings.
    Fixed rounding values in Fahrenheit units for freeze and fire notifications.
    Improved the display of notification timestamps in the notification panel.
    Minor stylistic improvements to modal windows, user password reset email template, side menu buttons, and translations display.
    Fixed tariff display in the Energy panel for Brazilian, Portuguese and US English languages.
    Improved device removal from the mobile application for Z-Wave 3.0**.
    Improved Wi-Fi network stability for HC3L and YH hubs.
Plugins
    Fixed issues for loading control views for child of the plugin (ex. Philips Hue).
    Removed the DSC plugin due to incompatibility.
    Fixed connection error for Heos plugin.
    Minor translations fixes for Tedee plugin.
Quick Apps
    Fixed the issue with handling onLongPressDown and onLongPressReleased actions.
    Fixed issue with sending push messages.
    Support for long button press in Quick App.
    Fixed issue with file manager in the editor.
    Fixed error reporting in fibaro.setTimeout function.
    Improved selective clearing of the debug console.
    Fixed an issue with sending emails about suspicious login attempts with incorrect authorization in Quick App.
    Fixed background color for Quick App in dark mode.
Scenes
    Fixed non-working energy consumption block in block scenes.
    Fixed translations for some of the devices in the blocks.
    Fixes for running  LUA scenes.
    Improved display of CO sensor statuses when selecting triggers in block scenes.
    Fixed the error of deleting a scene that uses global variables.
    Fixed time value conversion in sunrise and sunset-related conditions in block scenes.
Users
    Improved assignment of devices for users in case of empty sections in Access Management.
    Fixed the functionality of granting access to remote actions for the Installer in specific cases.
    Improved display of statuses on the user list when inviting Remote Access users.
    Solved the issue of deleting user permissions for rooms after creating a new section.
Zigbee
   The Zigbee engine fails to start after WiFi network settings change in rare cases.
Z-Wave
    Fixed the default role setting after adding the FGRGBW-441device.**
    Fixed the update from version 25.25 to 27.27 for the FGRGBW-441 device for KR frequency.
    Fixed issue with resetting all parameters to default in rare cases.**
    Resolved issue with incorrect display of Z-Wave parameter values for HC3L central unit.
    Improved the display of the number of queued parameters for Z-Wave devices.
    Improved temperature setting actions for thermostats in relation to the precision supported by devices.
    Improved templates for Qubino 3-Phase/1-Phase Meter meters.
    Improved display of scales for some Qubino device endpoints.**
    Improved display of power consumption and energy for Qubino device.
    Fixed issue with adding old-generation Z-wave+ devices.**
    Fixed issue of inability to control some blinds from other manufacturers.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
Aeotec Home Energy Meters Gen5, 1-phase version does not allow to change some of the configuration parameters.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
Modifié par TonyC
  • Like 2
  • Thanks 1
et voilà en Français :=)
Firmware 5.160.30
STABLE
16/04/2024
Caractéristiques principales :
1. Scénarios utilisateur
Les utilisateurs peuvent maintenant créer leurs propres scénarios (scènes) dans l'application mobile en utilisant un assistant d'ajout spécialement préparé. Pour utiliser les scénarios, mettez à jour votre application Yubii avec au moins la version 1.21 ou installez la nouvelle application mobile (description ci-dessous).
2. Nouveau processus d'ajout d'appareils dans l'application mobile
Désormais, les utilisateurs peuvent plus facilement ajouter leurs appareils au système via l'application mobile en utilisant le nouvel assistant d'ajout. Pour utiliser la nouvelle méthode d'ajout, installez la nouvelle application mobile.
3. Changements pour la nouvelle application mobile
App Store : https://apps.apple.com/app/id6477485519
Google Play : https://play.google.com/store/apps/details?id=com.niceforyou.yubii
  • Ajout de nouveaux jeux d'icônes par défaut pour les appareils, les scènes et les pièces.
  • Nouvelle façon d'afficher le contenu de l'application rapide.
  • Possibilité d'utiliser l'ancien style d'affichage de l'application rapide à des fins de rétrocompatibilité.
  • Nouveau look pour les plugins Sonos et Husqvarna.
  • Nouveau design pour les scénarios d'utilisation.
Nouveautés :
Appareils
Correction de l'affichage des valeurs du compteur des mises à jour disponibles pour les appareils.
Suppression des rôles inutilisés pour les types baseShutter et rollerShutter.
Ajout de la prise en charge du dispositif REMOTEC ZXT800.
Ajout de la prise en charge de l'appareil Heatit Z-TRM6.
Ajout de la prise en charge de l'appareil MCOHome Keypad Switch K-ES2.
Ajout de la prise en charge des capteurs de présence MCOHome OS11 et OS12.
Ajout de la prise en charge des dispositifs dans le moteur Z-Wave 3.0** :
FGD-211
FGS-221
FGR-221
FGS-211
FGBS-321
FGWPE-102
FGWPI-121
Suppression du contrôle redondant des lamelles pour les types de stores qui n'ont pas cette fonctionnalité.
Elero
  • Mise à jour du micrologiciel du module radio.
  • Ajout de la prise en charge des anciennes versions des moteurs de stores RolTop.
  • Connexion à la passerelle
  • Déplacement de la sélection centrale des paramètres avancés directement vers l'écran d'ajout de périphérique Z-Wave.
Nice*
  • Amélioration de l'appairage des appareils Mono à l'aide de la télécommande existante.
  • Réduction de la charge du réseau pour une meilleure performance.
  • Ajout de la prise en charge du calibrage automatique pour les dispositifs BiDi-Shutter et BiDi-Awning.
  • Mise à jour du firmware du module radio.
Autre
  • Amélioration de la gestion des erreurs lors de l'ajout d'un modèle d'utilisateur pour un appareil.
  • Amélioration du fonctionnement des notifications du système en mettant à jour leurs données en fonction des paramètres actuels du système (noms des pièces, langue, etc.).
  • Introduction d'optimisations du système pour améliorer les performances des concentrateurs.
  • Mise à jour du firmware WLAN.
Plugins
  • Alignement de la vue des plugins avec le nouveau style de l'application.
  • Les icônes Satel par défaut ont été mises à jour avec les nouveaux jeux.
  • Ajout de la prise en charge du Satel Integra 256.
QuickApps
  • L'affichage des QuickApps a été aligné sur le nouveau style de l'application.
  • Ajout d'une vue native pour le type de périphérique com.fibaro.player.
  • Ajout de la gestion de la méthode uploadExternalIconSet() pour le type de périphérique com.fibaro.player.
Scènes
  • Amélioration de l'aspect visuel des curseurs de couleur dans les nouveaux scénarios simples.
  • Masquage de l'option " True for a specified time " pour les conditions et les déclencheurs basés sur des événements.
  • Ajout d'une nouvelle apparence pour le modèle d'e-mail envoyé à partir des scènes de bloc.
  • Amélioration de l'action de basculement (marche/arrêt) du dispositif Unio-868.
Z-Wave
Amélioration de l'heure de démarrage du service.
Ajout d'un support pour les dispositifs :
  • ZVIDAR Z-TRV-V01
  • NICE Warm-Control
  • Contrôle NICE Fan2
  • Contrôle NICE Fan4
  • MCO OS11/OS12 pour les fréquences US et ANZ
Support FGDW-002 pour la version 3.3.
Améliorations de la stabilité.
Améliorations de la performance du réseau.**
Mise à jour du firmware du module radio (YH/HC3L).
Amélioration du processus d'ajout du dispositif Schlage BE369.**
Amélioration de la communication en cas de charge élevée du réseau et élimination du phénomène rare de "gel" du moteur Z-Wave.**
Amélioration des paramètres par défaut pour les compteurs d'énergie domestique Aeotec et les compteurs Qubino 1p et 3p.
Corrections de bugs :
Sauvegarde
  • Correction d'un problème d'affichage de l'écran de connexion après la création d'une sauvegarde.
  • Résolution d'un problème de redémarrage redondant du hub lors de la création d'une sauvegarde.
Climat
  • Correction de l'affichage des noms des thermostats sélectionnés sur le sélecteur.
  • Correction du décalage entre les valeurs de refroidissement et de chauffage pour les unités Fahrenheit.
Appareils
  • Correction du problème lié au réglage du type d'entrée pour le FGRGBW-442/RGBW-Control en mode RGBW/RGB.
  • Bouton d'arrêt redondant pour certaines portes.
  • Correction des icônes personnalisées pour les compteurs.
  • Les doublons redondants des jeux d'icônes ont été supprimés dans certains cas.
  • Les icônes de position favorite ne fonctionnent pas pour certains volets simples.
  • Icône FGWC par défaut incorrecte dans l'interface web.
  • Correction de l'affichage de l'icône de l'état de la position favorite pour le type d'interrupteur multipositions.
  • La sauvegarde de l'angle des lamelles dans la position favorite pour le FGR-224 a été améliorée.
  • Correction de l'apparence de la fenêtre modale pour l'ajout d'icônes personnalisées pour les dispositifs à plusieurs états.
  • Fibaro RGBW2/Nice RGBW-Control se déconfigure dans de rares cas.
  • Heatit Z-Smoke ne signale plus la détection de mouvement.
  • Problèmes avec le contrôle de Fibaro RGBW1 après l'appairage du dispositif.
  • Correction de l'opération de reconfiguration pour l'appareil Heatit ZTERM3.
  • Corrections stylistiques mineures pour les écrans coulissants.
  • Amélioration du fonctionnement de l'appareil Unio 868 avec l'option de logique inversée activée.
  • Correction de la configuration des couleurs favorites pour l'appareil RGBW Linked Device.
  • Correction des plages d'hystérésis de température et d'humidité dans les dispositifs liés.
  • Correction d'un problème avec la restauration des paramètres par défaut pour le capteur climatique Domii après le redémarrage du système.
  • Correction du marquage du capteur climatique Domii (solaire) comme mort après le redémarrage ou la mise à jour de l'unité centrale.
  • Correction de l'erreur 502 lors de l'ajout de dispositifs Elero.
FTI
  • Erreur lors de la configuration de l'installateur lors de l'exécution du FTI par l'application mobile.
  • Correction de l'affichage de l'état et du problème de redémarrage automatique de la passerelle maître après la mise à jour.
  • Amélioration du fonctionnement du réseau et de la gestion du DNS lors de la liaison des hubs.
Appareils liés
Les paramètres d'hystérésis pour la température et l'humidité ont été améliorés - dorénavant, ils ne peuvent pas être supérieurs à la différence entre les valeurs minimales et maximales.
Améliorations de style pour les appareils liés - Choisir l'option de l'appareil maître.
Nice*
  • Correction de la prise en charge de la ligne de portes Nice Home.
  • Optimisation de la gestion des appareils fonctionnant sur batterie.
  • Amélioration des performances du réseau.
  • L'intervalle d'interrogation de Nice rétablit la valeur par défaut après l'avoir désactivé.
  • Correction de la prise en charge du paramètre 5 du dispositif BiDi-Shutter.
  • Correction d'un problème où les dispositifs couplés avec l'autorisation à distance BiDi utilisant un canal ne répondent pas jusqu'à ce que le hub soit redémarré.
Autres problèmes
  • Impossible de créer une pièce lorsque l'icône personnalisée est utilisée pendant le processus.
  • Amélioration de la stabilité du pilote WiFi pour les hubs YH/HC3L.
  • Correction de l'interface utilisateur dans le sélecteur d'arborescence.
  • Suppression du bouton "Retour" redondant dans le processus de nouvelle liaison dans certains cas.
  • Correction de l'effacement en bloc dans le panneau des notifications.
  • Corrections de l'interface utilisateur dans le panneau de l'historique.
  • L'apparence de la liste des notifications après l'utilisation de l'option "Effacer tout" a été améliorée.
  • Correction des problèmes liés à la modification de l'ordre des pièces dans l'interface.
  • Correction du problème d'apparition de l'écran de connexion dans l'interface après l'utilisation de l'option de restauration des paramètres d'usine de la passerelle.
  • Erreur 502 aléatoire dans l'interface web dans certains cas.
  • Problème de démarrage du système dans de très rares cas.
  • Erreur 409 après l'ajout d'un Smart Start DSK.** précédemment ajouté.
  • Améliorations mineures de l'UX et de l'UI.
  • Restriction des permissions de l'installateur pour les changements dans les paramètres d'accès.
  • Correction des valeurs arrondies en unités Fahrenheit pour les notifications de gel et d'incendie.
  • Amélioration de l'affichage des horodatages de notification dans le panneau de notification.
  • Améliorations stylistiques mineures apportées aux fenêtres modales, au modèle d'e-mail de réinitialisation du mot de passe utilisateur, aux boutons du menu latéral et à l'affichage des traductions.
  • Correction de l'affichage des tarifs dans le panneau Énergie pour les langues brésilienne, portugaise et anglaise.
  • Amélioration de la suppression des dispositifs depuis l'application mobile pour Z-Wave 3.0**.
  • Amélioration de la stabilité du réseau Wi-Fi pour les hubs HC3L et YH.
Plugins
  • Correction des problèmes de chargement des vues de contrôle pour les enfants du plugin (ex. Philips Hue).
  • Suppression du plugin DSC pour cause d'incompatibilité.
  • Correction d'une erreur de connexion pour le plugin Heos.
  • Corrections de traductions mineures pour le plugin Tedee.
Applications rapides
  • Correction du problème avec la gestion des actions onLongPressDown et onLongPressReleased.
  • Correction du problème lié à l'envoi de messages push.
  • Prise en charge de l'appui long sur un bouton dans l'application rapide.
  • Correction d'un problème avec le gestionnaire de fichiers dans l'éditeur.
  • Correction du rapport d'erreur dans la fonction fibaro.setTimeout.
  • Amélioration de l'effacement sélectif de la console de débogage.
  • Correction d'un problème lié à l'envoi d'e-mails concernant des tentatives de connexion suspectes avec une autorisation incorrecte dans l'application rapide.
  • Correction de la couleur d'arrière-plan de l'application rapide en mode sombre.
Scènes
  • Correction du bloc de consommation d'énergie non fonctionnel dans les scènes de blocs.
  • Correction des traductions pour certains appareils dans les blocs.
  • Correction de l'exécution des scènes LUA.
  • Amélioration de l'affichage de l'état des capteurs de CO lors de la sélection des déclencheurs dans les scènes en bloc.
  • Correction de l'erreur de suppression d'une scène qui utilise des variables globales.
  • Correction de la conversion de la valeur de l'heure dans les conditions liées au lever et au coucher du soleil dans les scènes en bloc.
  • Utilisateurs
  • Amélioration de l'attribution de dispositifs aux utilisateurs en cas de sections vides dans la gestion des accès.
  • Correction de la fonctionnalité d'octroi de l'accès aux actions à distance pour l'installateur dans des cas spécifiques.
  • Amélioration de l'affichage des statuts dans la liste des utilisateurs lors de l'invitation d'utilisateurs d'accès à distance.
  • Résolution du problème de la suppression des autorisations des utilisateurs pour les salles après la création d'une nouvelle section.
Zigbee
  • de rares cas, le moteur Zigbee ne démarre pas après une modification des paramètres du réseau WiFi.
Z-Wave
  • Correction du paramètre de rôle par défaut après l'ajout du FGRGBW-441device.**
  • Correction de la mise à jour de la version 25.25 à 27.27 pour le dispositif FGRGBW-441 pour la fréquence KR.
  • Correction du problème de réinitialisation de tous les paramètres par défaut dans de rares cas**.
  • Résolution du problème d'affichage incorrect des valeurs des paramètres Z-Wave pour l'unité centrale HC3L.
  • Amélioration de l'affichage du nombre de paramètres en file d'attente pour les dispositifs Z-Wave.
  • Amélioration des actions de réglage de la température pour les thermostats par rapport à la précision supportée par les dispositifs.
  • Amélioration des modèles pour les compteurs Qubino 3-Phase/1-Phase.
  • Amélioration de l'affichage des échelles pour certains terminaux Qubino.**
  • Amélioration de l'affichage de la consommation électrique et de l'énergie pour les appareils Qubino.
  • Correction d'un problème lié à l'ajout de dispositifs Z-wave+ d'ancienne génération**.
  • Correction de l'impossibilité de contrôler certains stores d'autres fabricants.
Problèmes connus :
Z-Wave Engine 3.0
Certains dispositifs Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave.
Les compteurs d'énergie domestique Aeotec Gen5, version monophasée, ne permettent pas de modifier certains paramètres de configuration.
* - Ne s'applique pas au HC3L (Home Center 3 Lite).
** - S'applique uniquement au moteur Z-Wave 3.0.
  • Like 2
FW 5.160.30 Upgrade fait, tout en restant sur yubbi 1.21.1.
Premier retour, Design des QA assez sympa.
Le nouveau jeu d'icones est également sympa avec plus de cohérence entre eux.
A suivre !
Je commence à m'inquiéter un peu...
c'est la 2ème mise à jour que j'essaye de faire sans succès...
La mise à jour se fait bien, mais après les CPU s'affolent à un point que plus rien ne réagit.
Même l'interface WEB devient inutilisable.
C'était la même chose avec la version précédente.
Et le recovery depuis l'IHM plante. Suis obligé de passer par les boutons  de la box...
Vais je devoir rester en 5.152.24 ???
:15::(
Remonte le problème sur le forum Fibaro.
Sur ma box de test, aucun souci à signaler, pas de changement coté CPU et RAM, c'est stable.
je me demande si ça vient pas du zigbee...
parce que la première minute y a pas de soucis.
c'est après que ça part en vrille...
Et le zigbee ne démarre pas tout de suite justement...
oui demain je vais poster sur leur forum...
il rame à mourir leur forum ce soir !!
si j'ai un moment, je reset le zigbee et re-teste la mise à jour...
Oui leur forum rame depuis quelques jours (mais c'est toujours mieux que le notre sur lequel plus personne ne peut se connecter.... :rolleyes: )
Sinon oui clairement le Zigbee est tout buggué dans cette version, sur le forum officiel ils conseillent carrément de faire un retour arrière si utilisation du Zigbee :huh:
Si je comprends bien, c'est la possibilité de créer des scènes depuis l'application mobile, alors que traditionnellement c'est uniquement depuis l'interface Web.
En fait c'était déjà dispo depuis quelques versions. Je m'en sers quand je me dis tiens ça serai bien de... En 1min c'est créé. Ensuite je la reprends via l'administration et la paufine en l'UA comme les autres. Mais le code généré en lua est très condensé.
Le 24/04/2024 à 19:56, TitiXsi a dit :
Cette merdouille ... Il y a plusieurs version de Chipset sur ces HC3 ?
si y a un lien, ça va être marrant l'avenir...
De mon côté cette update tourne très bien. Je trouve même le ZigBee plus fiable, moins de modules qui se perdent et que je dois réveiller régulièrement.
Envoyé de mon 23078PND5G en utilisant Tapatalk
il y a une heure, Dragoniacs a dit :
Ici, je serai un peu plus modéré surtout sur le Zwave (je n'ai pas de Zigbee).
Mes devices sont de plus en plus loin de la HC3 en terme de noeuds..
Avant j'avais 1 ou 2 devices qui était à 4 noeuds, aujourd'hui j'en ai 8...
(Ne pas tenir compte de mes Télécommande Nodon qui ne renvoient pas ces infos)
Est-ce que quelqu'un à constaté quelque chose de similaire ?
deuxième tentative du support sans succès.
Mon soucis va être remonté chez les développeurs... selon leur dernier message.
Donc 2 possibilités, où quelqu'un se penche sérieusement sur le problème ou il tombe dans les oubliettes...
A suivre...
Alors...
Ils ont ré intervenu une 3ème fois, avec les développeurs.
Le problème est réglé.
Un QA était à l'origine.
Ils ont désactivé le QA et c'est OK.
Sauf que c'est LE QA qu'il fallait pas désactivé :) :(
Il analyse le refreshState (un GEA perso en gros) qui déclenche tout ce qu'il y a à déclencher ...
Donc je mène mon enquête...
Ce QA récupère AUSSI les logs de la box (debug, trace, warning, error) pour les envoyer en base de données.
Mais depuis une mise à jour précédente, ils ont changé qqch dans leur manière de traiter le debug car c'est ça qui me faisait freezer la box.
J'ai une redondance sans fin des infos, car quand je traite la première info de log du resfreshState, une nouvel ligne dans le debug se mettait en place (indépendant de ma volonté ??? je sais pas pourquoi ???)
en gros ça fini comme ça : (enfin ça fini jamais)
le chiffre est l'ID 48xxx est l'ID du log
[15.05.2024] [18:58:02] [DEBUG] [QA_759_RERESHSTATES V2]: 48095 onInit
[15.05.2024] [18:58:02] [DEBUG] [QA_759_RERESHSTATES V2]: 48096 48095 onInit
[15.05.2024] [18:58:02] [DEBUG] [QA_759_RERESHSTATES V2]: 48097 48096 48095 onInit
[15.05.2024] [18:58:02] [DEBUG] [QA_759_RERESHSTATES V2]: 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:02] [DEBUG] [QA_759_RERESHSTATES V2]: 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48107 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48108 48107 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48109 48108 48107 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48110 48109 48108 48107 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
[15.05.2024] [18:58:03] [DEBUG] [QA_759_RERESHSTATES V2]: 48111 48110 48109 48108 48107 48106 48105 48104 48103 48102 48101 48099 48098 48097 48096 48095 onInit
et la je n'affiche rien du log, imaginez le message en plus !! :o
Donc je comprends toujours pas ce qu'il se passe avec ces log,
ça marchait très bien avant !
Je continue à creuser,
c'est pas très compliqué pourtant, et je vois pas où ça peut foirer...
Mais je sens bien que pour archiver mes log, il va falloir le faire depuis les QA qui le nécessite et plus depuis le RefreshState...
En attendant je n'archive plus ces logs...
  • Thanks 1
  • Sad 1
Avant de tomber en panne cela fonctionnait.
C'est toujours comme cela que l'on explique une panne
Envoyé de mon Pixel 8 Pro en utilisant Tapatalk
  • Haha 3
