HC3 & HC3L - 5.154.37 - BETA - 11/03/2024
Firmware 5.154.37
BETA
11/03/2024
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Nice*
    Improvements for pairing Mono devices using existing remote.
    Reduced network load for better performance.
QuickApps
    Aligned QuickApps view with new application styling.
    Added native view for the com.fibaro.player device type.
    Added handling uploadExternalIconSet() method for the com.fibaro.player.
Scenes
    Improved visuals for color sliders in new simple scenarios.
Plugins
    Aligned plugins view with new application styling.
    Default Satel icons updated to new sets.
Z-Wave
   Improved service start time.
Bug Fixes:
Devices
    Fixed the issue with setting inputs type for FGRGBW-442/RGBW-Control in RGBW/RGB mode.
    Redundant stop button for some of gates.
    Fixed custom icons for meters.
    Redundant duplicates of icons sets in some cases were removed.
    Favorite position icons does not work for some of simple shutters.
    Incorrect default FGWC icon in web interface.
    Corrected the way how Favorite Position state icon is displayed for multi-position switch device type.
Nice*
    Fixed support for MyHome gates line.
Other
    Unable to create a room when custom icon is used during the process.
    Improved stability of WiFi driver for YH/HC3L hubs.
    UI fixes in device tree selector.
    Removed redundant "Back" button in new binding process in some cases.
    Fixes for bulk clear in Notifications panel.
    UI fixes in history panel.
Quick Apps
    Fixed the issue with handling onLongPressDown and onLongPressReleased actions.
    Hue picker does not send correctly blue color component value.
Scenes
    Fixed the Time Range condition in new simple scenarios.
    Adjusted temperature control range for thermostats in new simple scenarios.
    UI/UX fixes for new simple scenarios.
Plugins
    Fixed random freeze of communication in Satel plugin.
    Mute/Unmute commands on Sonos plugin are reversed.
    Fixed issues for loading control views for child of the plugin (ex. Philips Hue).
Zigbee
   The Zigbee engine fails to start after WiFi network settings change in rare cases.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Thanks 2
Pour les allergiques à l'anglais (Google Traduction, faut pas pousser non plus!:2:)
Firmware 5.154.37
BETA
11/03/2024
Merci d'avoir utilisé notre passerelle ! Assurez-vous de mettre à jour vers la dernière version pour profiter de nouvelles fonctionnalités et d'améliorations.
Quoi de neuf :
Nice*
Améliorations pour le jumelage des appareils Mono à l'aide de la télécommande existante.
Réduction de la charge du réseau pour de meilleures performances.
QuickApps
Vue QuickApps alignée avec le nouveau style d'application.
Ajout d'une vue native pour le type de périphérique com.fibaro.player.
Ajout de la méthode de gestion uploadExternalIconSet() pour le com.fibaro.player.
Scènes
Visuels améliorés pour les curseurs de couleur dans de nouveaux scénarios simples.
Plugins
Vue alignée des plugins avec un nouveau style d'application.
Icônes Satel par défaut mises à jour vers de nouveaux ensembles.
Z-Wave
Amélioration de l'heure de début du service.
Corrections de bugs :
Appareils
Correction du problème de réglage du type d'entrée pour FGRGBW-442/RGBW-Control en mode RGBW/RGB.
Bouton d'arrêt redondant pour certaines portes.
Correction d'icônes personnalisées pour les compteurs.
Dans certains cas, les doublons redondants des jeux d'icônes ont été supprimés.
Les icônes de position préférée ne fonctionnent pas pour certains volets simples.
Icône FGWC par défaut incorrecte dans l'interface web.
Correction de la façon dont l'icône d'état de position préférée est affichée pour le type de périphérique de commutation multi-positions.
Nice*
Correction de la prise en charge de la ligne de portes MyHome.
Autre
Impossible de créer une pièce lorsque l'icône personnalisée est utilisée pendant le processus.
Amélioration de la stabilité du pilote WiFi pour les concentrateurs YH/HC3L.
Corrections de l'interface utilisateur dans le sélecteur d'arborescence de l'appareil.
Suppression du bouton "Retour" redondant dans le nouveau processus de reliure dans certains cas.
Corrections pour l'effacement en vrac dans le panneau Notifications.
Corrections de l'interface utilisateur dans le panneau d'historique.
QuickApps
Correction du problème avec la gestion des actions onLongPressDown et onLongPressReleased.
Le sélecteur de teinte n'envoie pas correctement la valeur du composant de couleur bleue.
Scènes
Correction de la condition de la plage de temps dans de nouveaux scénarios simples.
Plage de contrôle de la température ajustée pour les thermostats dans de nouveaux scénarios simples.
Corrections UI/UX pour de nouveaux scénarios simples.
Plugins
Correction d'un gel aléatoire de la communication dans le plugin Satel.
Les commandes Mute/Unmute sur le plugin Sonos sont inversées.
Correction de problèmes de chargement des vues de contrôle pour l'enfant du plugin (ex. Philips Hue).
Zigbee
Le moteur Zigbee ne démarre pas après que les paramètres du réseau WiFi ont changé dans de rares cas.
* - Ne s'applique pas à HC3L (Home Center 3 Lite).
** - S'applique uniquement au moteur Z-Wave 3.0.
