Quick App - Pilotage climatisation PAC Mitsubishi en local avec ESP32
bonjour
Je viens de commander un nouveau ESP32
Tous la phase de test se passe bien avec le test.yaml
Je peut faire un ping
et quant je veux passer a la programmation avec le fichier Mitsubishi-emaes.yaml,  j'ai ce message
flacon030@Mac-mini-M2-Pro ESPHome % esphome run mitsubishi-emaes.yaml
INFO ESPHome 2023.12.9
INFO Reading configuration mitsubishi-emaes.yaml...
INFO Generating C++ source...
Traceback (most recent call last):
  File "/Library/Frameworks/Python.framework/Versions/3.12/bin/esphome", line 8, in <module>
    sys.exit(main())
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 1041, in main
    return run_esphome(sys.argv)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 1028, in run_esphome
    rc = POST_CONFIG_ACTIONS[args.command](args, config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 458, in command_run
    exit_code = write_cpp(config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 192, in write_cpp
    generate_cpp_contents(config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 204, in generate_cpp_contents
    CORE.flush_tasks()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/core/__init__.py", line 679, in flush_tasks
    self.event_loop.flush_tasks()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 246, in flush_tasks
    next(task.iterator)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 184, in wrapped
    await coro(conf)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 80, in coro
    ret = yield from _flatten_generator(gen)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 118, in _flatten_generator
    val = gen.send(to_send)
  File "/Users/flacon030/Documents/ESPHome/.esphome/external_components/3b4567cc/components/mitsubishi_heatpump/climate.py", line 101, in to_code
    serial = HARDWARE_UART_TO_SERIAL[PLATFORM_ESP8266][config[CONF_HARDWARE_UART]]
KeyError: 'esp8266'
Modifié par flacon030
Ouh là là, c'est du chinois tout ça
Tu as dû avoir quelque chose qui s'est mal passé durant l'installation de la suite de compilation ESPHome.
Essaye de tout effacer et reprendre au début, car là je n'ai aucune idée du problème.
EDIT : c'est normal le
KeyError: 'esp8266'
tout en bas ?
C'est de l'ESP32 qu'on utilise normalement... tu n'aurais pas juste une couille dans ton fichier de config YAML ?
Modifié par Lazer
comment vérifier le fichier de config YAML?
Je viens de tous réinstaller python avec la dernière version ESPHOME, mais j'ai toujours le même message d'erreur
Je me demande si j'ai la bonne carte hardware de ESP32
https://www.amazon.fr/dp/B08BTLYSTM?ref=ppx_yo2ov_dt_b_fed_asin_title
Je pense que l’erreur viens de la plutot
C'est exactement le même microcontrôleur que j'ai commandé, donc ça devrait être bon.
Dans ton fichier YAML, tu n'as pas une référence à esp8266 qui traine ?
Si le test.yaml passe, je ne vois pas pourquoi ça ne passerait pas ensuite...
cela avance un peut
j'ai tous réinstaller sur une autre machine
a présent j'ai ce message
emaes@eMAES ESPHome % esphome run mitsubishi-emaes.yaml
INFO ESPHome 2024.10.2
Failed config
ota.unknown: [source mitsubishi-emaes.yaml:33]
  'ota' requires a 'platform' key but it was not specified.
  password: !secret ota_password
Ah ça avance :)
Là tu dois juste avoir un petit problème d'erreur de syntaxe dans ton fichier de configuration et/ou le fichier de mots de passes.
ça a peut être changé....
Je viens de regarder le fichier exemple de la page 1 contient à la fois ota, et à la fois platform, sauf que le platform est dans climate.
La doc en ligne te donne les valeurs possibles pour le paramètre platform dans ota : esphome ou http_request... à tester.
Sinon, tu peux essayer de virer complètement ota, tu ne pourras pas faire les mises à jour à distance par Wi-Fi, mais ce n'est pas nécessaire, au pire tu devras rebrancher le module en USB sur le PC (c'est d'ailleurs pour ça que j'avais anticipé, dans mon tuto, avec la "rallonge" permettant de déporter le module ESP de la carte mère du split pour le débrancher facilement)
Modifié par Lazer
j'ai essayer de supprimer la ligne OTA , la compilation commence et plante
et j'ai la même chose en ajoutant
ota:
  - platform: esphome
flacon030@Mac-mini-M2-Pro ESPHome % esphome run mitsubishi-room.yaml
INFO Reading configuration mitsubishi-room.yaml...
INFO Core config, version or integrations changed, cleaning build files...
INFO Deleting .esphome/build/mitsubishi-room/.pioenvs
INFO Deleting .esphome/build/mitsubishi-room/.piolibdeps
INFO Compiling app...
Processing mitsubishi-room (board: wemos_d1_mini32; framework: arduino; platform: platformio/espressif32@5.4.0)
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.1.4
INFO Installing esphome/AsyncTCP-esphome @ 2.1.4
Unpacking  [####################################]  100%
Library Manager: AsyncTCP-esphome@2.1.4 has been installed!
INFO AsyncTCP-esphome@2.1.4 has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
Library Manager: ESPAsyncWebServer-esphome@3.2.2 has been installed!
INFO ESPAsyncWebServer-esphome@3.2.2 has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.5
INFO Installing bblanchon/ArduinoJson @ 6.18.5
Library Manager: ArduinoJson@6.18.5 has been installed!
INFO ArduinoJson@6.18.5 has been installed!
Library Manager: Installing git+https://github.com/SwiCago/HeatPump#5d1e146771d2f458907a855bf9d5d4b9bf5ff033
INFO Installing git+https://github.com/SwiCago/HeatPump#5d1e146771d2f458907a855bf9d5d4b9bf5ff033
git version 2.39.5 (Apple Git-154)
Cloning into '/Users/flacon030/.platformio/.cache/tmp/pkg-installing-afrp6viz'...
remote: Enumerating objects: 1242, done.
remote: Counting objects: 100% (111/111), done.
remote: Compressing objects: 100% (75/75), done.
remote: Total 1242 (delta 52), reused 82 (delta 36), pack-reused 1131 (from 1)
Receiving objects: 100% (1242/1242), 460.21 KiB | 3.01 MiB/s, done.
Resolving deltas: 100% (618/618), done.
HEAD is now at 5d1e146 Merge pull request #209 from dzungpv/master
Library Manager: HeatPump@1.0.0+sha.5d1e146 has been installed!
INFO HeatPump@1.0.0+sha.5d1e146 has been installed!
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.4
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- ArduinoJson @ 6.18.5
|-- HeatPump @ 1.0.0+sha.5d1e146
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate_mode.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate_traits.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select_call.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select_traits.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/web_server.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/web_server_v1.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
In file included from src/esphome.h:26,
                 from src/esphome/components/mitsubishi_heatpump/espmhp.h:20,
                 from src/esphome/components/mitsubishi_heatpump/espmhp.cpp:21:
src/esphome/components/mitsubishi_heatpump/espmhp.h:182:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_operating_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:182:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:183:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_idle_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:183:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:184:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_ping_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:184:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:185:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::time_point<std::chrono::steady_clock>> last_remote_temperature_sensor_update_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:185:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:186:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::time_point<std::chrono::steady_clock>> last_ping_request_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:186:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'virtual void MitsubishiHeatPump::control(const esphome::climate::ClimateCall&)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:252:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
     if (last_remote_temperature_sensor_update_.has_value()) {
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:252:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_temperature(float)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:625:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
         last_remote_temperature_sensor_update_ =
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:625:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:628:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
         last_remote_temperature_sensor_update_.reset();
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:628:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::ping()':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:636:5: error: 'last_ping_request_' was not declared in this scope
     last_ping_request_ = std::chrono::steady_clock::now();
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_operating_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:641:5: error: 'remote_operating_timeout_' was not declared in this scope
     remote_operating_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:641:5: note: suggested alternative: 'set_remote_operating_timeout_minutes'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_idle_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:646:5: error: 'remote_idle_timeout_' was not declared in this scope
     remote_idle_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:646:5: note: suggested alternative: 'set_timeout'
     set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_ping_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:651:5: error: 'remote_ping_timeout_' was not declared in this scope
     remote_ping_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:651:5: note: suggested alternative: 'set_timeout'
     set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::enforce_remote_temperature_sensor_timeout()':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:9: error: 'remote_ping_timeout_' was not declared in this scope
     if (remote_ping_timeout_.has_value() && last_ping_request_.has_value()) {
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:9: note: suggested alternative: 'set_timeout'
         set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:45: error: 'last_ping_request_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:28: error: 'remote_operating_timeout_' was not declared in this scope
         this->operating_ ? remote_operating_timeout_ : remote_idle_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:28: note: suggested alternative: 'set_remote_operating_timeout_minutes'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:56: error: 'remote_idle_timeout_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:56: note: suggested alternative: 'set_timeout'
                                                        set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:671:13: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:671:13: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
Compiling .pioenvs/mitsubishi-room/src/esphome/core/application.cpp.o
*** [.pioenvs/mitsubishi-room/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o] Error 1
=================================================================================================== [FAILED] Took 5.84 seconds ===================================================================================================
bonjour
J'ai essayé a nouveau avec de nouvelles carte ESP32 j'ai toujours le même résultat comme ci dessus
La différence que j'ai avec toi c'est que je suis pour "pip3 Install esphome" en Version: 2024.10.2 au lieu de 2022.11.5 pour toi
et je suis en python 3.13 au lieu de 3.11
du coup je me demande si la version "pip installée esphome" 2024.10.2 n'aurait pas de modifications qui fait que ton fichier "mitsubishi-room.yaml" ne fonctionne plus?
car le fichier test.yaml fonctionne comme il faut
Peut être, je ne sais pas du tout en fait.
Mais je pense plutôt à une modification de la syntaxe du YAML comme je l'ai évoqué dans mon message précédent, as-tu essayé les modifications comme je l'ai suggéré ?
Le 26/10/2024 à 15:27, Lazer a dit :
Dommage...
Tu n'as pas un autre PC pour tester ?
Je vois que tu es sous MacOS, peut être qu'avec Windows ou Linux le compilateur se comporte différemment ?
J'ai essayé sous unbuntu 22.03 et windows 11 et c'est toujours le même résultat
flacon030@ubuntu-2204:~/Documents/ESPHome$ esphome run mitsubishi-emaes.yaml
INFO ESPHome 2024.10.3
Processing mitsubishi-emaes (board: wemos_d1_mini32; framework: arduino; platform: platformio/espressif32@5.4.0)
Downloading  [####################################]  100%
git version 2.34.1
Cloning into '/home/flacon030/.platformio/.cache/tmp/pkg-installing-454rino4'...
Receiving objects: 100% (1242/1242), 460.21 KiB | 4.11 MiB/s, done.
Dependency Graph
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPmDNS @ 2.0.0
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/climate/climate.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/climate/climate_mode.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/climate/climate_traits.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/select/select.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/select/select_call.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/select/select_traits.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/web_server/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/web_server/web_server.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/web_server/web_server_v1.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/wifi/wifi_component.cpp.o
     set_timeout
     set_timeout
         set_timeout
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
                                                        set_timeout
Compiling .pioenvs/mitsubishi-emaes/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
*** [.pioenvs/mitsubishi-emaes/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o] Error 1
=================================== [FAILED] Took 23.06 seconds ===================================
j'ai fait un essai sous unbuntu 22.04 et sous windows 11 et c'est toujours la même chose.
Apparemment c'est la version ESPHome de juin 2024 qui a tout pété : https://github.com/geoffdavis/esphome-mitsubishiheatpump/issues/152
Ils disent que la compilation crashe quand on utilise UART2, ce qui le cas dans notre montage...
Il y a des solutions qui sont données, mais je n'ai ni le courage ni le temps de tester tout ça maintenant.... je me demande si en attendant, le mieux n'est pas de trouver un moyen de downgrader à la version précédente de ESPHome.
déjà cela me rassure, cela ne viens pas de moi
reste a voir comment downgrader esphome
ou attendre une nouvelle version
car l'hiver arrive et il me reste deux split a convertir en ESP32
bon j'ai downgrader esphome en version esphome 2023.7.1
je n'ai pas réussi a aller plus bas
https://pypi.org/project/esphome/2023.7.1/
Mais cela ne fonctionne toujours pas
j'ai aussi essayer de dowgrader wheel en 0.38.4
https://pypi.org/project/wheel/0.45.0/#history
Je commence a en avoir marre...
Si une âme charitable pouvait programmer mes deux ESP32 je lui en serais reconnaissant
Je peut lui envoyer les deux cartes et je peut remunerer le travail si il le faut
Merci d'avance au volontaire
ça m'inquiète cette histoire, car ça veut dire qu'on ne sait plus compiler les firmwares...
Il faut que j'essaye de trouver du temps pour creuser le sujet, mais je ne garantie pas que ça soit tout de suite...
Merci je continue de mon coté pour essayer de trouver une solution
Car en l'état actuel a mon avis ce QA ne peut plus être mis en place
petite avancé
je viens de réussir a compiler l'ESP32
que se soit avec python ou (esphome sous HA en ajoutant un nouvelle ESP32 pour avoir ota: password, api: key)
- J'arrive a faire fonctionner la clim sur le connecteur CN105 mais pas sur le CN110 (cela ne m'arrange pas... mais cela fera l'affaire en attendant mieux)
- cela ne fonctionne qu'avec l'ESP32 que j'ai acheter sur alixepress mais pas ceux de amazone
https://fr.aliexpress.com/item/32858054775.html?spm=a2g0o.order_list.order_list_main.20.246f5e5bDE8bNB&gatewayAdapt=glo2fra
- Je pense qu'il faut mettre tx_pin : 16, et rx_pin:17 (a essayer)et non 3 et 4 (j'ai du me tromper j'ai du inverser les fils pour que cela fonctionne donc c'est: tx_pin : 17, et rx_pin:16)
- reste a essayer de lancer la mise en place du QA sous HC3 car l’interface web de l'esp32 n'est pas la même, il y a plus d'options
Cela ne semble pas fonctionner??
https://forum.hacf.fr/t/piloter-sa-pompe-a-chaleur-mitsubishi-en-local-avec-une-sonde-deportee/8544/101
substitutions:
  friendly_name: clim-emaes
esphome:
  platform: ESP32
uart:
  baud_rate: 2400
  tx_pin: 17
  rx_pin: 16
external_components:
  - source: github://echavet/MitsubishiCN105ESPHome
ota:
  - platform: esphome
    password: "xxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  power_save_mode: none
  manual_ip:
    static_ip: 192.168.1.xxx
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "${friendly_name} ESP Fallback Hotspot"
    password: "Killer060+"
captive_portal:
# Enable Web server.
web_server:
  port: 80
# Enable logging
logger:
  hardware_uart: UART1
  level: INFO
  logs:
    EVT_SETS : INFO
    WIFI : INFO
    MQTT : INFO
    WRITE_SETTINGS : INFO
    SETTINGS : INFO
    STATUS : INFO
    CN105Climate: WARN
    CN105: INFO
    climate: WARN
    sensor: WARN
    chkSum : INFO
    WRITE : WARN
    READ : WARN
    Header: INFO
    Decoder : INFO
    CONTROL_WANTED_SETTINGS: INFO
#  level: DEBUG
#  logs:
#    EVT_SETS : DEBUG
#    WIFI : INFO
#    MQTT : INFO
#    WRITE_SETTINGS : DEBUG
#    SETTINGS : DEBUG
#    STATUS : INFO
#    CN105Climate: WARN
#    CN105: DEBUG
#    climate: WARN
#    sensor: WARN
#    chkSum : INFO
#    WRITE : WARN
#    READ : WARN
#    Header: INFO
#    Decoder : DEBUG
#    CONTROL_WANTED_SETTINGS: DEBUG
# Sync time with Home Assistant.
time:
  - platform: homeassistant
# Sensors with general information.
sensor:
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    name: ${name} WiFi Signal
    update_interval: 60s
# Text sensors with general information.
text_sensor:
  # Expose ESPHome version as sensor.
  - platform: version
    name: ${name} ESPHome Version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
# Create a button to restart the unit from HomeAssistant. Rarely needed, but can be handy.
button:
  - platform: restart
    name: "Restart ${friendly_name}"
climate:
  - platform: cn105
    icon: mdi:heat-pump
    update_interval: 4s # Defaut 500ms
    visual:
      min_temperature: 15
      max_temperature: 31
      temperature_step:
        target_temperature: 0.5
        current_temperature: 0.1
    compressor_frequency_sensor:
      name: ${name} Compressor Frequency
    vertical_vane_select:
      name: ${name} Vertical Vane
    horizontal_vane_select:
      name: ${name} Horizontal Vane
    isee_sensor:
    # The remote_temperature_timeout setting allows the unit to revert back to the internal temperature measurement
    # if it does not receive an update in the specified time range (highly recommended if using remote temperature updates)
    remote_temperature_timeout: 30min
    # debounce_delay adds a small delay to the command processing to account for some HomeAssistant buttons that may send
    # repeat commands too quickly. A shorter value creates a more responsive UI, a longer value protects against repeat commands
    debounce_delay : 500ms
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxx"
  services:
    # Ajouter une valeur de température comme si c'était un capteur externe
    # Créer une automatisation qui envoie la température d'un capteur
    # chaque fois qu'une nouvelle valeur est détectée
    - service: set_remote_temperature_clim_rdc
      variables:
        temperature: float
      then:
        # Select between the C version and the F version
        # Uncomment just ONE of the below lines. The top receives the temperature value in C,
        # the bottom receives the value in F, converting to C here.
        - lambda: 'id(hp).set_remote_temperature(temperature);'
#        - lambda: 'id(hp).set_remote_temperature((temperature - 32.0) * (5.0 / 9.0));'
    # Revenir à l'utilisation du capteur interne
    - service: use_internal_temperature_clim_rdc
      then:
        - lambda: 'id(hp).set_remote_temperature(0);'
  • 3 semaines après...
Petit recap
J'ai réussi a compilé l'ESP32 avec la config yaml ci dessus
cela fonctionne avec l'adresse ip de l'ESP32
cela fonctionne avec ESP home sous home assistant
je viens d'installer le QA avec le debug activé car il ne fonctionne pour avec la HC3
voici les logs
[02.12.2024] [18:21:47] [TRACE] [QA_MITSUBISHI_1077]:
[02.12.2024] [18:21:47] [TRACE] [QA_MITSUBISHI_1077]: QuickApp Mitsubishi v2.00 - Initialization - Parent device
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: Using tools library v2.30
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: Using ESPHome library v2.00
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: Temperature device ID not defined, using internal temperature sensor
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure("tcp", "192.168.1.80", 6053)
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "HomeassistantServiceMap" => field "key" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "HomeassistantServiceMap" => field "value" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ListEntitiesServicesArgument" => field "name" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ListEntitiesServicesArgument" => field "type" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "bool_" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "legacy_int" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "float_" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "string_" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "int_" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "bool_array" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "int_array" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "float_array" ignored
[02.12.2024] [18:21:47] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "ExecuteServiceArgument" => field "string_array" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothServiceData" => field "uuid" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothServiceData" => field "legacy_data" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothServiceData" => field "data" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothLERawAdvertisement" => field "address" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothLERawAdvertisement" => field "rssi" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothLERawAdvertisement" => field "address_type" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothLERawAdvertisement" => field "data" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTDescriptor" => field "uuid" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTDescriptor" => field "handle" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTCharacteristic" => field "uuid" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTCharacteristic" => field "handle" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTCharacteristic" => field "properties" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTCharacteristic" => field "descriptors" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTService" => field "uuid" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTService" => field "handle" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "BluetoothGATTService" => field "characteristics" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "VoiceAssistantAudioSettings" => field "noise_suppression_level" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "VoiceAssistantAudioSettings" => field "auto_gain" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "VoiceAssistantAudioSettings" => field "volume_multiplier" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "VoiceAssistantEventData" => field "name" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:configure() option message_id not found for message "VoiceAssistantEventData" => field "value" ignored
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome library v2.00 successfully initialized
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome URL : tcp://192.168.1.80:6053
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: Refresh interval : 60 seconds
[02.12.2024] [18:21:48] [DEBUG] [QA_MITSUBISHI_1077]: Using internal temperature sensor
[02.12.2024] [18:21:51] [DEBUG] [QA_MITSUBISHI_1077]: loop(60)
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:setDeviceNotification()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:checkVG()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:setVG()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:iif()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:split()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:deepCompare()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:urlencode()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:distributeViewLayoutItems()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:isNil()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:getSlider()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:getDurationInString()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:searchViewLayoutItem()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:round()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:updateSlider()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:getDeviceNotification()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:saveViewLayout()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:addViewLayoutItem()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:getViewLayoutItemIndex()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:WOL()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:base64()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:isNotNil()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:isNumber()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:createVG()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:deleteVariable()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:removeViewLayoutItem()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:deepFilter()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:getDeviceIdByName()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: Optimize tools:optimize()
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: init(function())
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:getDeviceInfo(table[2])
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI("DeviceInfoRequest", {}, "DeviceInfoResponse", true, false, table[2])[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI() New TCP connection
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:connect(table[2])
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:connect() connect() success
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI("DeviceInfoRequest", {}, "DeviceInfoResponse", true, false, table[2])[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI() New ESPHome login
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:login(table[2])
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI("HelloRequest", {"client_info":"Fibaro HC3-00003815"}, "HelloResponse", true, false, table[2]
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:transmit("HelloRequest", {"client_info":"Fibaro HC3-00003815"}, table[2])[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:buildPacket("HelloRequest", {"client_info":"Fibaro HC3-00003815"})
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:buildPacket() message "HelloRequest" => id 1
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:buildPacket() field name = "client_info" / field type = "string" / field value = "Fibaro HC3-00003815"
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:buildPacket() wire LEN id = 2 => "010" / field id = 1 => "00001" ==//==> tag = Hex "0a" => "00001010"
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:transmit() packet ASCII : .....Fibaro HC3-00003815
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:transmit() packet HEX : 00 15 01 0a 13 46 69 62 61 72 6f 20 48 43 33 2d 30 30 30 30 33 38 31 35
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:transmit() write() success
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:receive(table[2]
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:receive() read() success : 22 bytes
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:receive() packet ASCII : ....Bad indicator byte
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:receive() packet HEX : 01 00 13 01 42 61 64 20 69 6e 64 69 63 61 74 6f 72 20 62 79 74 65
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:fetchResponse("Bad indicator byte")
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:fetchResponse() data size = 22
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:fetchResponse() message_count = 0 - data_size = 22 - index = 1
[02.12.2024] [18:21:52] [WARNING] [QA_MITSUBISHI_1077]: ESPHome:fetchResponse() Invalid ESPHome packet
[02.12.2024] [18:21:52] [ERROR] [QA_MITSUBISHI_1077]: ESPHome:receive() fetchResponse() failed : Invalid ESPHome packet
[02.12.2024] [18:21:52] [ERROR] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI() Receive failed : Invalid ESPHome packet
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:nativeAPI() request message "HelloRequest" removed from queue at index1
[02.12.2024] [18:21:52] [ERROR] [QA_MITSUBISHI_1077]: ESPHome:login() HelloRequest error() : Invalid ESPHome packet
[02.12.2024] [18:21:52] [DEBUG] [QA_MITSUBISHI_1077]: ESPHome:disconnect()
[02.12.2024] [18:21:52] [ERROR] [QA_MITSUBISHI_1077]: Can't get ESPHome device info : Invalid ESPHome packet
[02.12.2024] [18:21:52] [TRACE] [QA_MITSUBISHI_1077]: Update label "LabelDebug" to " Invalid ESPHome packet "
[02.12.2024] [18:21:52] [WARNING] [QA_MITSUBISHI_1077]: Mitsubishi virtuel / graph is now dead
Ouh là là, c'est pas bon ça, l'ESP32 qui répond un paquet inconnu, comme si le protocole avait changé....
Pas le choix pour l'instant, il va falloir trouver le moyen de downgrader pour revenir à l'ancienne version de ESPHome... parce que reprendre le développement du QA, ça ne risque pas d'arriver avant un bon moment... pas du tout le temps pour ça en ce moment, surtout que son code LUA est loin d'être simple...
