Quick App - Pilotage climatisation PAC Mitsubishi en local avec ESP32
Lazer
bonjour
Je viens de commander un nouveau ESP32
Tous la phase de test se passe bien avec le test.yaml
Je peut faire un ping
et quant je veux passer a la programmation avec le fichier Mitsubishi-emaes.yaml,  j'ai ce message
flacon030@Mac-mini-M2-Pro ESPHome % esphome run mitsubishi-emaes.yaml
INFO ESPHome 2023.12.9
INFO Reading configuration mitsubishi-emaes.yaml...
INFO Generating C++ source...
Traceback (most recent call last):
  File "/Library/Frameworks/Python.framework/Versions/3.12/bin/esphome", line 8, in <module>
    sys.exit(main())
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 1041, in main
    return run_esphome(sys.argv)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 1028, in run_esphome
    rc = POST_CONFIG_ACTIONS[args.command](args, config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 458, in command_run
    exit_code = write_cpp(config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 192, in write_cpp
    generate_cpp_contents(config)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 204, in generate_cpp_contents
    CORE.flush_tasks()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/core/__init__.py", line 679, in flush_tasks
    self.event_loop.flush_tasks()
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 246, in flush_tasks
    next(task.iterator)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/__main__.py", line 184, in wrapped
    await coro(conf)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 80, in coro
    ret = yield from _flatten_generator(gen)
  File "/Library/Frameworks/Python.framework/Versions/3.12/lib/python3.12/site-packages/esphome/coroutine.py", line 118, in _flatten_generator
    val = gen.send(to_send)
  File "/Users/flacon030/Documents/ESPHome/.esphome/external_components/3b4567cc/components/mitsubishi_heatpump/climate.py", line 101, in to_code
    serial = HARDWARE_UART_TO_SERIAL[PLATFORM_ESP8266][config[CONF_HARDWARE_UART]]
KeyError: 'esp8266'
Modifié par flacon030
Ouh là là, c'est du chinois tout ça
Tu as dû avoir quelque chose qui s'est mal passé durant l'installation de la suite de compilation ESPHome.
Essaye de tout effacer et reprendre au début, car là je n'ai aucune idée du problème.
EDIT : c'est normal le
KeyError: 'esp8266'
tout en bas ?
C'est de l'ESP32 qu'on utilise normalement... tu n'aurais pas juste une couille dans ton fichier de config YAML ?
Modifié par Lazer
comment vérifier le fichier de config YAML?
Je viens de tous réinstaller python avec la dernière version ESPHOME, mais j'ai toujours le même message d'erreur
Je me demande si j'ai la bonne carte hardware de ESP32
https://www.amazon.fr/dp/B08BTLYSTM?ref=ppx_yo2ov_dt_b_fed_asin_title
Je pense que l’erreur viens de la plutot
C'est exactement le même microcontrôleur que j'ai commandé, donc ça devrait être bon.
Dans ton fichier YAML, tu n'as pas une référence à esp8266 qui traine ?
Si le test.yaml passe, je ne vois pas pourquoi ça ne passerait pas ensuite...
cela avance un peut
j'ai tous réinstaller sur une autre machine
a présent j'ai ce message
emaes@eMAES ESPHome % esphome run mitsubishi-emaes.yaml
INFO ESPHome 2024.10.2
Failed config
ota.unknown: [source mitsubishi-emaes.yaml:33]
  'ota' requires a 'platform' key but it was not specified.
  password: !secret ota_password
ça a peut être changé....
Je viens de regarder le fichier exemple de la page 1 contient à la fois ota, et à la fois platform, sauf que le platform est dans climate.
La doc en ligne te donne les valeurs possibles pour le paramètre platform dans ota : esphome ou http_request... à tester.
Sinon, tu peux essayer de virer complètement ota, tu ne pourras pas faire les mises à jour à distance par Wi-Fi, mais ce n'est pas nécessaire, au pire tu devras rebrancher le module en USB sur le PC (c'est d'ailleurs pour ça que j'avais anticipé, dans mon tuto, avec la "rallonge" permettant de déporter le module ESP de la carte mère du split pour le débrancher facilement)
Modifié par Lazer
j'ai essayer de supprimer la ligne OTA , la compilation commence et plante
et j'ai la même chose en ajoutant
ota:
  - platform: esphome
flacon030@Mac-mini-M2-Pro ESPHome % esphome run mitsubishi-room.yaml
INFO Reading configuration mitsubishi-room.yaml...
INFO Core config, version or integrations changed, cleaning build files...
INFO Deleting .esphome/build/mitsubishi-room/.pioenvs
INFO Deleting .esphome/build/mitsubishi-room/.piolibdeps
INFO Compiling app...
Processing mitsubishi-room (board: wemos_d1_mini32; framework: arduino; platform: platformio/espressif32@5.4.0)
Library Manager: Installing esphome/AsyncTCP-esphome @ 2.1.4
INFO Installing esphome/AsyncTCP-esphome @ 2.1.4
Unpacking  [####################################]  100%
Library Manager: AsyncTCP-esphome@2.1.4 has been installed!
INFO AsyncTCP-esphome@2.1.4 has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
INFO Installing esphome/ESPAsyncWebServer-esphome @ 3.2.2
Library Manager: ESPAsyncWebServer-esphome@3.2.2 has been installed!
INFO ESPAsyncWebServer-esphome@3.2.2 has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.5
INFO Installing bblanchon/ArduinoJson @ 6.18.5
Library Manager: ArduinoJson@6.18.5 has been installed!
INFO ArduinoJson@6.18.5 has been installed!
Library Manager: Installing git+https://github.com/SwiCago/HeatPump#5d1e146771d2f458907a855bf9d5d4b9bf5ff033
INFO Installing git+https://github.com/SwiCago/HeatPump#5d1e146771d2f458907a855bf9d5d4b9bf5ff033
git version 2.39.5 (Apple Git-154)
Cloning into '/Users/flacon030/.platformio/.cache/tmp/pkg-installing-afrp6viz'...
remote: Enumerating objects: 1242, done.
remote: Counting objects: 100% (111/111), done.
remote: Compressing objects: 100% (75/75), done.
remote: Total 1242 (delta 52), reused 82 (delta 36), pack-reused 1131 (from 1)
Receiving objects: 100% (1242/1242), 460.21 KiB | 3.01 MiB/s, done.
Resolving deltas: 100% (618/618), done.
HEAD is now at 5d1e146 Merge pull request #209 from dzungpv/master
Library Manager: HeatPump@1.0.0+sha.5d1e146 has been installed!
INFO HeatPump@1.0.0+sha.5d1e146 has been installed!
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.4
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- ArduinoJson @ 6.18.5
|-- HeatPump @ 1.0.0+sha.5d1e146
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate_mode.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/climate/climate_traits.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/core.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/gpio.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/esp32/preferences.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/json/json_util.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_esp32.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_host.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/logger/logger_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select_call.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/select/select_traits.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/list_entities.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/web_server.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server/web_server_v1.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/mitsubishi-room/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
In file included from src/esphome.h:26,
                 from src/esphome/components/mitsubishi_heatpump/espmhp.h:20,
                 from src/esphome/components/mitsubishi_heatpump/espmhp.cpp:21:
src/esphome/components/mitsubishi_heatpump/espmhp.h:182:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_operating_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:182:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:183:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_idle_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:183:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:184:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::duration<long long, std::ratio<60>>> remote_ping_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:184:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:185:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::time_point<std::chrono::steady_clock>> last_remote_temperature_sensor_update_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:185:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.h:186:14: error: 'optional' in namespace 'std' does not name a template type
         std::optional<std::chrono::time_point<std::chrono::steady_clock>> last_ping_request_;
src/esphome/components/mitsubishi_heatpump/espmhp.h:186:9: note: 'std::optional' is only available from C++17 onwards
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'virtual void MitsubishiHeatPump::control(const esphome::climate::ClimateCall&)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:252:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
     if (last_remote_temperature_sensor_update_.has_value()) {
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:252:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_temperature(float)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:625:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
         last_remote_temperature_sensor_update_ =
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:625:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:628:9: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
         last_remote_temperature_sensor_update_.reset();
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:628:9: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::ping()':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:636:5: error: 'last_ping_request_' was not declared in this scope
     last_ping_request_ = std::chrono::steady_clock::now();
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_operating_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:641:5: error: 'remote_operating_timeout_' was not declared in this scope
     remote_operating_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:641:5: note: suggested alternative: 'set_remote_operating_timeout_minutes'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_idle_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:646:5: error: 'remote_idle_timeout_' was not declared in this scope
     remote_idle_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:646:5: note: suggested alternative: 'set_timeout'
     set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::set_remote_ping_timeout_minutes(int)':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:651:5: error: 'remote_ping_timeout_' was not declared in this scope
     remote_ping_timeout_ = std::chrono::minutes(minutes);
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:651:5: note: suggested alternative: 'set_timeout'
     set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp: In member function 'void MitsubishiHeatPump::enforce_remote_temperature_sensor_timeout()':
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:9: error: 'remote_ping_timeout_' was not declared in this scope
     if (remote_ping_timeout_.has_value() && last_ping_request_.has_value()) {
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:9: note: suggested alternative: 'set_timeout'
         set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:656:45: error: 'last_ping_request_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:28: error: 'remote_operating_timeout_' was not declared in this scope
         this->operating_ ? remote_operating_timeout_ : remote_idle_timeout_;
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:28: note: suggested alternative: 'set_remote_operating_timeout_minutes'
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:56: error: 'remote_idle_timeout_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:669:56: note: suggested alternative: 'set_timeout'
                                                        set_timeout
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:671:13: error: 'last_remote_temperature_sensor_update_' was not declared in this scope
src/esphome/components/mitsubishi_heatpump/espmhp.cpp:671:13: note: suggested alternative: 'enforce_remote_temperature_sensor_timeout'
Compiling .pioenvs/mitsubishi-room/src/esphome/core/application.cpp.o
*** [.pioenvs/mitsubishi-room/src/esphome/components/mitsubishi_heatpump/espmhp.cpp.o] Error 1
=================================================================================================== [FAILED] Took 5.84 seconds ===================================================================================================
bonjour
J'ai essayé a nouveau avec de nouvelles carte ESP32 j'ai toujours le même résultat comme ci dessus
La différence que j'ai avec toi c'est que je suis pour "pip3 Install esphome" en Version: 2024.10.2 au lieu de 2022.11.5 pour toi
et je suis en python 3.13 au lieu de 3.11
du coup je me demande si la version "pip installée esphome" 2024.10.2 n'aurait pas de modifications qui fait que ton fichier "mitsubishi-room.yaml" ne fonctionne plus?
car le fichier test.yaml fonctionne comme il faut
Peut être, je ne sais pas du tout en fait.
Mais je pense plutôt à une modification de la syntaxe du YAML comme je l'ai évoqué dans mon message précédent, as-tu essayé les modifications comme je l'ai suggéré ?
Le 26/10/2024 à 15:27, Lazer a dit :
