HC3 & HC3L - 5.150.15 - STABLE - 08/11/2023
HC3 & HCL - 5.150.15 - STABLE - 08-11-2023
IMPORTANT NOTICE
    When upgrading the system from version 5.141 Beta, an error may occur during backup procedure. The system will restart, but will remain on the old version. The solution can be found here:
        HC3: bit.ly/46w8Awu
        HC3L: bit.ly/3S6noh1
        Yubii Home: bit.ly/406dNbV
Main features:
1. Added Auto and Manual Mode support for Elero devices.
    From now on, for devices that support mode switching, you can exclude specific devices from automation (such as scenes or profiles) by changing a single option in the sidebar.
2. Added Z-Wave Network Diagnostics tab.
    Now, for both versions of the Z-Wave engine, the system allows for the analysis of traffic and network issues for diagnostic purposes.
3. Added Support for Nice and Elero devices in Gateway connection.
    As part of expanding the system's capabilities, support for Nice and Elero protocols has been added in Gateway Connection feature, improving connectivity between hubs.
4. Added Support for Nice and Elero devices in Gateway connection.
    The list of mobile devices has been redesigned in the access settings. Access to newly added alarm zones, climate zones, and profiles is now automatically granted to a new user if the 'all' option is selected.
    Information about the last synchronization with the cloud service is now visible on the users' list. New selection controls have been added to facilitate granting access to specific devices, scenes, zones, and profiles.
    Additionally, a fast and easy method for inviting users to the system has been introduced.
What's new:
Backup
    Performance improvements for backup list and status requests.
Dashboard
    Added the ability for the administrator account to hide "Add Device" and "Add Scene" tiles on the dashboard in general hub settings.
Devices
    Binary rain sensor is now available as an optional device for the sprinkler to prevent from watering.
    Improvements to device adding visuals.
    Added the ability to filter system notifications by supported notification channels.
    Improved support for the Aeotec Multi-Sensor 6 (soft-reconfiguration required).
    The camera preview tab is available only if a camera device has been configured.
    Improvements to Roller Shutter linked devices.
    Improved navigation for scene creation from device advanced settings.
    Organized roles for blinds in Linked Devices.
    Organized the list of roles and categories for devices.
    Added hysteresis settings for humidity controller and thermostats in Linked Devices.
    The integration of the Qubino 1Phase and 3Phase meters has been simplified to improve handling in the system.
Elero
    Improvements for waking up Elero devices.
Energy
    Improved selection menu for energy meter configuration under energy panel settings.
    Improved tooltip readability for tariffs in the Energy Panel.
    Power measurements for hidden devices are now excluded by default.
FTI
    Added information during FTI if user is not able to change Z-Wave engine version when some devices are already added to the system.
    Added the ability to restore user backups saved in the Cloud during the FTI process.
    Improved Z-Wave engine selection during FTI for hubs no longer connected to the Master gateway.
Garden
    Added the ability to perform a sequence test and manually start irrigation from the Garden Panel.
Nice
    Improvements in handling dead devices.
    Added support for partial opening state for gates.
    Added support for battery-operated devices synchronization.
Other
    New tooltips visuals.
    Added a notification for automatic system restore in case of instability.
    Limited recovery loop in case of both systems failure.
    Hidden sensors can now be selected as primary sensors in rooms.
    Reboot is no longer needed after the first system configuration.
    Minor UX and UI improvements.
    Improvements in user password validation.
    Refreshed modal appearance in the interface.
    Increased character limit for variables in the hub.
    Database optimizations.
Profiles
    Removed redundant actions for Elero venetian blinds.
Quick Apps
    Improved auto-naming of QuickApp elements and labels.
    Added switch support.
    Added dropdown list support.
    Changes for control identifiers.
    A RefreshStateSubscriber class has been added to handle system events with methods for subscribing, unsubscribing, and starting/stopping event listening, providing better control over event-based actions.
Scenes
    Added support for custom thermostat modes to the block scene editor.
    Improved the "True for specified" time option setting for conditions in the block scene editor.
    Added the ability to manually start watering sequences from a scene.
    In block scenes, added new blocks related to the energy panel: Current Production, Current Consumption, and Current Balance.
    Added automatic authorization for API of system elements in Lua.
Update
    Added sorting the list of available updates for devices.**
    Hub update section moved to Settings -> General.
    Device update section moved to Settings -> Devices.
    Minor translations fixes.
Zigbee
    Added default naming of newly paired devices.
    Updated general compatibility with devices on the market.
    Added possibility to force removing of not working Zigbee devices.
    Added support for smoke, pressure, gas, volatile organic compounds, vibration, and presence sensors.
    Added support for device role settings.
    Added support for device's temperature sensors.
Z-Wave
    Stability improvements.**
    Improvements in "marking as dead" function.**
    Added support for Qubino Flush Shutter DC devices.
    Changed the default wake-up interval value for known old-generation devices.
    Updated support for Aeon Multisensor 6.
    Added pin support for Danalock V3 lock.
    Introduced fixes for removing damaged Z-Wave nodes.**
    Added support for old-generation FGFS-101 and FGK-101.
Bug Fixes:
Backups
    Fixed behavior for local backup limit.
    Fixed occasional backup execution issues.
Climate
    Unable to edit climate schedules if a thermostat in that zone is hidden.
    Resolved an issue with thermostat handling from the climate panel for Fahrenheit units.
Dashboard
    Removed redundant buttons for multilevel switches from the sidebar.
    Permanent "Transfer Ok" caption on device tile for Elero devices in rare cases.
    Incorrect presentation of color temperature control for Zigbee devices.
Devices
    Fixed Z-Wave devices parameters values scaling after the "Reset all" action.
    Hidden tiles for the Smart Implant device no longer stay hidden in certain situations.**
    Qubino 3-phase meter has redundant tiles presenting voltage per phase (soft-reconfiguration required).
    FGT-001 setpoint graph not always correctly drawn.
    Downloading the device template loops in some cases.
    Fixed color controller handling in Linked Devices.
    Fixes for Linked Device support for blinds.
    Fixed linked devices entities list after opening the "General" tab in devices settings.
Elero*
    Inversion settings for awning and pergolas does not work correctly.
Energy
    Fixed issues with generating a weekly savings graph incorrectly.
Gateway Connection
    Walli Controller configuration from slave gateway issue.
    Changing the description of the device added to the slave does not work.
    Setting favorite position for devices from slave gateway does not work.
    Fixed the inability to configure Lifeline association for devices from Slave hub in some cases.
Nice
    After restart of the gateway system overwrites parameters for BiDi-Multi Sensor to default.
    Fixes for handling parameters for BiDi-Multisensor.
    Resolved issues with Nice ON4E remotes.
    Partial opening button missing for Nice gates.
    Missing waiting icon for pending actions when changing parameters for sleeping devices.
    Improved handling of low battery notifications for BiDi-Multisensor.
    Fixed Nice device handling after backup restoration.
    Fixes for device parameter configuration mechanism.
Other
    Issues with securely added devices before the migration to HC3.
    Addressed database overgrowth issues.
    Corrected language version for status messages in Recovery mode for selected scenarios.
    Fixed password character count validation to 10 characters.
    Remote access granted to support extended to 14 days.
    Minor UX and UI fixes.
    Occasional issue with web interface content not loading.
    Overwriting room categories to "Other" during editing in the modal.
Plugins
    Added RTSP stream support in web UI for Dahua plugin.
    Incorrect reporting of Tedee lock status during temporary loss of cloud services.
    Fixed handling of latch retraction for Tedee lock.
    Fixed generating a new authorization code for Tedee lock.
    Minor fixes in Dahua camera plugin configuration.
    Fixes for CoolAutomation plugin.
Quick Apps
    Fixed assigning QuickApps to rooms when adding a new integration from the Dashboard.
    Fixed Fahrenheit handling for thermostat-type QuickApps.
    Fixed handling of special characters for secret-type variables.
Scenes
    Addressed issues with lua scenes on autostart that didn't work in selected scenarios.
    Fixed control for Fan Modes in thermostats when triggered from block scenes.
    Filled out missing translations for thermostat actions in block scenes.
    Fixed renaming scenes from the editor.
    Fixed action handling for thermostats (temporary schedule override).
Update
    Next device target can now be updated from a file without reconfiguration.**
    Fixed a bug producing incorrect status of the first target file during an update for a sleeping device.**
Users
    Fixed granting permissions for empty rooms.
    Stylistic fixes for dark theme in access management.
Zigbee
    The Philips Hue color setting when device is turned off does not work.
    Fixes for forcing device removal.
    Improved ZigBee device counter in the configuration tab.
Z-Wave
    Fixed temperature conversion for the first Fahrenheit reading.
    Fixed estimated next device wakeup time display.
    Improved communication performance.
    Added support for new versions of MCO devices - MH-S412, MH-DT411.
    Eliminated issues with zeroing wakeup time for FGD-002.
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
    Simplified integration of the Qubino 1Phase and 3Phase meters will be available in next hub version.
* - Does not apply to HC3L (Home Center 3 Lite).
** - Applies only to Z-Wave 3.0 engine.
  • Thanks 3
Je n'avais jamais remarqué qu'on avait une popup sur l'interface Yubii lors de mise à dispo d'une mise à jour de la box.. C'est nouveau ou j'avais raté ça ?
Sinon, elle est bien noté stable dans l'interface
-> Update en cours
Modifié par TitiXsi
Première remarque, les graphiques on migrés de l'onglet Avancé à Général...
Deuxième remarque, les graphiques sont HS, il manque la fin de la journée...
3ème remarque : Diagnostoqie Zwave, j'ai plein de problèmes :D
Capture.thumb.PNG.6d93139b5cc222c30f945a321bda6274.PNGCapture.thumb.PNG.e943ee5a9d4bd1418a040cfa70123921.PNG
A suivre :D
Tiens mes T° branchés sur mes Qubino, FP et switch ne fonctionnent plus ... Chauffage dans les choux :wacko:
Edit : Tous les energy meter des modules Qubino ne fonctionnent plus non plus ...
Une réussite ce passage de Beta à Stable ...
Modifié par TitiXsi
Il y a 3 heures, mprinfo a dit :
Han :13:
J'ai hate de tester ça :D
Mise à jour effectuée hier soir également.
Tour semble correct ce matin... sous réserve d'un véritable examen de la situation.
Mes rapports nocturne et matinal de "mise en sommeil" et de "réveil de la maison sont cohérents.
Heureux d'apprendre la prise en charge complète du Multisensor 6 d'Aeotec (remplacés depuis presque un an par les v7... - mais bon, j'en ai plusieurs donc bon à prendre).
J'irai visiter aussi le diagnostic z-wave... entre autres, car il y a pas mal de choses qui ont bougé (évolué ?).
les retours de  @TitiXsi ne me donnent pas envie de faire l'upgrade.
Heureusement qu'il y a ceci
Il y a 19 heures, mprinfo a dit :
du coup, j'hésite ...
Il y a 1 heure, jojo a dit :
Je suis repassé en arrière en 1 clic et 15min après tout est ok (5.140.17), j'ai contacté le support, ils m'ont demandés le modèle de tous mes qubino :
ZMNHBD1 (double switch 2*4A)
ZMNHVD1 (Dimmer 0-10v)
ZMNHAD1 (simple switch 10A)
ZMNHJD1 (Fil pilote 6 ordres)
A suivre...
Côté Panneau Z-Wave, j'ai effectivement mon seul Qubino (un ZMNHLA2, rescapé de mes débuts avec la HC2) qui est signalé comme n'étant point correctement configuré.
J'ai donc soumis au support...
Au passage, je trouve ce (nouveau ?) panneau Z-Wave bien pratique pour les soucis liés aux modules.
Je vais avoir quelques ajustements à effectuer.
Pour le ZMNHLA2 c'est "normal", c'est le fameux module Qubino Fil Pilote dont le firmware est buggué et l'inclusion ne s'est jamais passée correctement, donc logique qu'il ressorte en non-configuré. Ce n'est pas spécifique à cette version de la HC3.
Il y a 23 heures, Lazer a dit :
Han :13:
Pour utiliser RefreshStateSubscriber, voir la doc sur le forum officiel :
https://forum.fibaro.com/topic/69400-any-description-for-refreshstatesubscriber/#comment-271642
L'intérêt est de simplifier le déclenchement des QuickApps sur événements, sans avoir à mettre en oeuvre le mécanisme refreshStates que j'avais décrit ici :
  • Like 2
Il y a 2 heures, Lazer a dit :
D'après ce que j'ai pu constater, les modules notes non configuré dans les version précédente étaient quand même fonctionnels. Sauf que là c'est plus le cas... Est-ce une volonté de fibaro de maximiser la fiabilité et donc de ne plus dialoguer (ou limiter le dialogue) avec ces modules ?
Je ne sais pas si c'est lié, mais je perds aussi souvent mes modules de température Zigbee....
Envoyé de mon M2012K11AG en utilisant Tapatalk
Salut à tous,
J'ai besoin d'aide svp ?
J'ai une HC3 en version Beta 5.141.59 elle fonctionne parfaitement bien sauf que impossible de lancer quelles que mises à jour que ce soit.
La migration vers la beta suivante échoue et la migration vers la stable qui vient d'arriver pareil !
J'ai le message qui me dit : creating backup... stopping services
et puis au bout de 1 min, elle redémarre sans faire la mise à jour.
J'ai essayé sans faire de backup et c'est la même chose.
Même quand je demande simplement in reboot de ma box, elle ne redémarre pas proprement, elle s'arrête à 25% et reviens sur la page de login.
Une idée ? un diag à faire ? forcer la mise à jour depuis le rescue mode ?  je ne sais pas !!!
Mais à côté de ça, elle st totalement opérationnelle
Merci pour votre aide
  • Sad 1
Il y a 3 heures, Dragoniacs a dit :
Souvent, ca signifie quoi ? tu dois réactiver un truc, ca se remets tout seul, ca limite le dialogue donc moins de refresh ?
Clairement, la valeur temp & hum n'est pas remontée vers la HC3 depuis la mise à jour hier.... et un clic sur le capteur ne change rien.
Sur la version stable précédente, j'avais quelques pertes de communication (1 fois par semaine), mais un clic sur le capteur suffisait à le réveiller.
Du coup, je restaure ma version précédente.
il y a 10 minutes, Yannick a dit :
Salut à tous,
Contacte le support Fibaro, je crois que le bug du backup est un bug connu
Sinon tu lances la mise à jour sans backup préalable, mais c'est plus risqué car pas de retour arrière possible.
