Updating HC2 variable value based on the changes of HC3 variable value
Hi All,
I'd like to synchro some variables of HC3 towards HC2: for example I have global variable "Test1" in HC3 and I'd like to set its value to the "twin" global variable" in HC2.
The frequency of synchro is not a problem, I know that it will be sufficient set the interval for the starting of the dedicated "synchro scene"...
Currently I am able to execute the copy value of HC2 variable to HC3 "twin" variable, but I need only of the viceversa :-(
Exactly I'd like execute this "synchro" by a dedicated Lua scene (in HC3?)
Can you suggest me how to proceed?
Thanks in advance
Yuri
