Lazer Posté(e) le 27 janvier 2023 Signaler Posté(e) le 27 janvier 2023 5.131.52 BETA Important Notice Installation of this version is not recommend for systems using Gateway Connection feature. Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. New way of controlling devices from Dashboard sidebar Completely redesigned control of color controllers. Support of color temperature setting for the Zigbee devices. 2. New predefined scenarios designed to control lights based on time conditions and gates status What's new: Climate Added possibility to assign temperature sensors for climate zones. Added battery level indicators on devices tiles. Dashboard Possibility to add devices from the dashboard. Devices Optimised procedure for adding devices for all protocols. Improved UI/UX and performance for device page filters. Added filters clearing mechanism when leaving the page. Added the description field for every device type. Redesigned family of devices view. Energy Modified page layout for energy meters configuration in panel settings. Gateway connection Added an option to define Slave IP address manually. Added additional redundancies for unexpected changes in network configuration. Nice* Improved support for OXIBD status updates. Added generic support for legacy Bidirectional shutters. Improved support for device specific notifications. Other Improved algorithm for gateway overheating notifications. Minor UI/UX improvements. Plugins Added support for pulling the latch for the Tedee door lock. Improvements for Heat Activator plugin. Quick Apps Added support for the Base Shutter device type. Scenes Added the filters for Scenes page. Added "tolerance" option for Energy Panel block scenes. Improved blocks content loading performance for large systems. Added the description field for every scene type. Changed the order of steps for Scenarios. Update Added possibility to update all devices. Added additional warning before upgrading to the beta version of the hub. Zigbee Improved generic support for lights and color controllers. Z-Wave Added handling of suspended device interview during the adding procedure for battery-powered devices.** Support for different revisions of the Aeotec Multisensor 6. Support for the ZW800 series MCO IR2900 thermostat. Support for the Everspring SP103.** Bug fixes: Climate The zone control freezes if the last setpoint is set at 5:00am. Devices Issues with the display of some configuration parameters values. Elero* The RolSolar device is incorrectly marked as disconnected. Using favorite positions in group actions does not work. Energy Energy charts are malformed occasionally. Negative energy consumption data in the panel after clearing the energy data in some cases. Negative power consumption values for "Grid consumption" setting in some cases. FTI No masking of Wi-Fi password during the first configuration on Firefox. Gateway Connection Connection issues in specific network configurations. Nice* Losing possibility to control devices in some cases. Fixed issue with binding some mono-directional devices. Custom icons for mono-directional devices not visible. Other Added possibility to enable remote access for support from recovery system. Standard user cannot remove interactive push. Issues with controlling the linked-device thermostat in some configurations. System crash while deleting a non-existing notification. Wrong time in history after the change from winter time to summer time. Adding more than one Other device by clicking the add button excessively. The state of devices is not refreshed when pressed run scene button without refreshing the page. Other UI/UX fixes. Plugins Lack of live preview for Helios 2N plugin. Profiles Incorrect display of climate panel settings. Incorrect display of sliders in profiles settings. Quick Apps Secret variable value visible in the webUI after saving. Scenes Elero RolMotion blind is controlled even if excluded from a simple scenario. Incorrect display of sliders in block scenes. Cannot edit Scenarios via mobile app in remote connection. Zigbee Wrong time unit during the adding process. Z-Wave No possibility to update Z-Wave devices added in Security mode. Lack of handling unsolicited reports from devices using CC Basic.** Issues with updating devices from file in some cases.** Incorrect default role for the Zooz ZAC36 valve. Improved adding procedure when using S2U security level.** The exclusion process cannot be closed after an error has occurred. Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 1 1 1
jjacques68 Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 Il y a 10 heures, Lazer a dit : Added possibility to assign temperature sensors for climate zones. cela voudrait dire qu'il va y avoir une vrai regulation de la température ?
Lazer Posté(e) le 28 janvier 2023 Auteur Signaler Posté(e) le 28 janvier 2023 C'est quoi une "vraie" régulation pour toi ? PID ? J'en doute...
flacon030 Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 (modifié) Bon chez moi c'est une vrai catastrophe Il y a des lenteurs pas possible, et en plus cela plante la box Je vais essayer de revenir en arrière Modifié le 28 janvier 2023 par flacon030
jjacques68 Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 il y a 7 minutes, Lazer a dit : PID ? J'en doute... oui tout à fait. ben j'ai fais la mise à jour, ajouté les sondes de tempértures dans les zones, mais visiblement ... se passe pas grand chose.
flacon030 Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 (modifié) Bon j'ai fait un e deuxième tentative et cela fonctionne presque... Une petite anomalie constaté En câble internet je n'ai pas accès au panneau de configuration de la HC3, or en wifi c'est OK Mais c'est toujours très instable la HC3 n’arrête pas de redémarrer, donc je reviens a la version précédente Pour moi cette version est a oublier C'est la première fois que cela m'arrive depuis que je teste les versions bêta Modifié le 28 janvier 2023 par flacon030
ericl78 Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 Hi Pour moi, installée depuis hier soir, RAS
mprinfo Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 Va falloir que je la fasse cette mise à jourMais pas motivéRien que le fait d'allumer l'ordi pour la faire ça me fatigue Envoyé de mon BLA-L29 en utilisant Tapatalk 1
jerome_clamart Posté(e) le 28 janvier 2023 Signaler Posté(e) le 28 janvier 2023 Bonsoir, Plantage de la sauvegarde en ethernet. Retour par un recovery. Je change de navigateur pour retenter le passage mais la mise à jour n'est plus proposée. J'attends la suivante pour voir.
mprinfo Posté(e) le 29 janvier 2023 Signaler Posté(e) le 29 janvier 2023 la mise a jour n'est plus disponible J'ai l’impression que fibaro est redevenu Fibaro 2
jjacques68 Posté(e) le 29 janvier 2023 Signaler Posté(e) le 29 janvier 2023 bon... chez moi elle tourne pour le moment !
flacon030 Posté(e) le 29 janvier 2023 Signaler Posté(e) le 29 janvier 2023 (modifié) C'est que je ne devais pas être le seul a avoir rencontrer des problèmes Modifié le 30 janvier 2023 par flacon030
chrisalex Posté(e) le 29 janvier 2023 Signaler Posté(e) le 29 janvier 2023 effectivement cette MAJ n'est plus dispo ... aurait elle été retirée pour cause de soucis trop nombreux?
Domodial Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 Heureusement que je l'ai loupé (plus dispo non plus) sinon j'aurais encore tout grillé
flacon030 Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 (modifié) c’était une version alpha poussé par erreur https://forum.fibaro.com/topic/64376-important-update-513152-unavailable/ Il est fortement conseillé de revenir en arrière (chose que j'ai fait) Modifié le 30 janvier 2023 par flacon030
Yannick Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 salut les amis, j'ai une question d'ordre pratique sur les modules ZIGBEE et particulièrement des ampoules ? j'en ai intégrée quelques unes.. qui fonctionnent parfaitement, mais j'en ai 3 qui ont bien été intégrées et que je ne vois plus dans ma box. donc je me dis je vais relancer l'intégration... rien ne se passe...Je me dis je vais réinitialiser tout le réseau ZIGBEE.. je m'execute et pis bien rien. Comme si les modules déjà intégrés n'avaient pas la possibilités d'être exclus.. y a une astuce ????
Yannick Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 ah bah non rien j'ai trouvé, il faut les éteindre et les rallumer plusieurs fois jusqu'à ce qu'elles clignottent.. ça peut servir !!
jjacques68 Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 il y a une heure, Yannick a dit : y a une astuce ???? j'ai le même soucis, impossible d'exclure les modules zigbee si ils ne répondent plus. j'en ai 2 que je n'arrive pas à supprimer.
Lazer Posté(e) le 30 janvier 2023 Auteur Signaler Posté(e) le 30 janvier 2023 Il y a 6 heures, flacon030 a dit : c’était une version alpha poussé par erreur https://forum.fibaro.com/topic/64376-important-update-513152-unavailable/ Il est fortement conseillé de revenir en arrière (chose que j'ai fait) Et bien... cette version Alpha aura au moins eu un mérite, c'est de me faire apparaitre mon premier message "Le système a récupéré d'une erreur inattendue" : Du coup... on en parlait récemment, pas sûr que ça soit un problème hardware comme je le suggérais, vu qu'une simple mise à jour de firmware permet de faire apparaitre ce message. Je laisse tourner encore quelques jours, on verra si le problème se reproduit.. Puis je ferai un retour arrière, et on verra si le problème disparait. Heureusement que c'est sur ma box de test.
henri-allauch Posté(e) le 30 janvier 2023 Signaler Posté(e) le 30 janvier 2023 (modifié) Ca alors ce problème est de plus en plus étrange Je viens de tourner 30 jours sans REBOOT puis plouf "le canard est toujours vivant" Modifié le 30 janvier 2023 par henri-allauch
Bloug Posté(e) le 31 janvier 2023 Signaler Posté(e) le 31 janvier 2023 Il y a 15 heures, flacon030 a dit : c’était une version alpha poussé par erreur https://forum.fibaro.com/topic/64376-important-update-513152-unavailable/ Il est fortement conseillé de revenir en arrière (chose que j'ai fait) Citation If you are experiencing any issues regarding the performance of 5.131.52 firmware and you are willing to be a part of this firmware version troubleshooting, you can reach us at support@fibaro.com where your ticket will be forwarded to the developers to take immediate action to diagnose the issue* je vais pas faire le complotiste mais j'ai l'impression que c'est une fausse vrai erreur ... pour tester a grande echelle non ? Un air de déjà vu avec le vaccin Covid !.... Le vaccins est au point et sans danger MAIS si vous souhaitez nous faire part des effets indésirables qu'il provoque systématiquement en cas d'injection, envoyez nous un mail at Co.Baye.gouv. 1 1
ericl78 Posté(e) le 31 janvier 2023 Signaler Posté(e) le 31 janvier 2023 pour moi, avec mes 71 modules, ras avec cette version, elle tourne bien A suivre
jjacques68 Posté(e) le 31 janvier 2023 Signaler Posté(e) le 31 janvier 2023 il y a 16 minutes, ericl78 a dit : pour moi, avec mes 71 modules, ras avec cette version, elle tourne bien idem
Yannick Posté(e) le 2 février 2023 Signaler Posté(e) le 2 février 2023 Le 30/01/2023 à 20:11, jjacques68 a dit : j'ai le même soucis, impossible d'exclure les modules zigbee si ils ne répondent plus. j'en ai 2 que je n'arrive pas à supprimer. Salut @jjacques68, tu as vu après j'ai mis l'astuce. il faut les débrancher et les rebrancher électriquement plusieurs fois de suite jusqu'à ce qu'elles se mettent à fader
