Les Childs pour les Nuls
Bloug
@jang
I just did a test with your example library and ....
You did it again ! :lol:
At the first recording of the main I have the creation of the children. At the next recording there is again the creation of 6 additional children .
Is it still a problem with my Hc3 :huh:!?
Well, of course there was a small problem with my code.... Try this version
The load and creation of children is protected with a pcall.
do
  local childID = 'ChildID'
  local classID = 'ClassName'
  local defChildren
  local children = {}
  local undefinedChildren = {}
  local createChild = QuickApp.createChildDevice
  class 'QwikAppChild'(QuickAppChild)
  function QwikAppChild:__init(device)
    QuickAppChild.__init(self, device)
    self:debug("Instantiating object ",device.name)
    local uid = self:getVariable(childID) or ""
    if defChildren[uid] then
      children[uid]=self               -- Keep table with all children indexed by uid. uid is unique.
    else                               -- If uid not in our children table, we will remove this child
      undefinedChildren[#undefinedChildren+1]=self.id
  function QuickApp:createChildDevice(uid,props,interfaces,className)
    __assert_type(uid,'string')
    __assert_type(className,'string')
    props.initialProperties = props.initialProperties or {}
    local qas = {{name=childID,value=uid},{name=classID,value=className}}
    props.initialProperties.quickAppVariables = qas
    props.initialInterfaces = interfaces
    self:debug("Creating device ",props.name)
    return createChild(self,props,_G[className])
  local function getVar(child,varName)
    for _,v in ipairs(child.properties.quickAppVariables or {}) do
      if v.name==varName then return v.value end
    return ""
  function QuickApp:loadExistingChildren(chs)
    __assert_type(chs,'table')
    local stat,err = pcall(function()
        defChildren = chs
        self.children = children
        function self.initChildDevices() end
        local cdevs,n = api.get("/devices?parentId="..self.id) or {},0 -- Pick up all my children
        for _,child in ipairs(cdevs) do
          local uid = getVar(child,childID)
          local className = getVar(child,classID)
          local childObject = _G[className] and _G[className](child) or QuickAppChild(child)
          self.childDevices[child.id]=childObject
          childObject.parent = self
      end)
    if not stat then self:error("loadExistingChildren:"..err) end
  function QuickApp:createMissingChildren()
        for uid,data in pairs(defChildren) do
          if not self.children[uid] then
            local props = {
              name = data.name,
              type = data.type,
            self:createChildDevice(uid,props,data.interfaces,data.className)
      end)
    if not stat then self:error("createMissingChildren:"..err) end
  function QuickApp:removeUndefinedChildren()
    for _,deviceId in ipairs(undefinedChildren) do -- Remove children not in children table
      self:removeChildDevice(deviceId)
-- 1 - Definition of class
class 'Class_Temp'(QwikAppChild) -- Class NOM_Temps pour "com.fibaro.temperatureSensor"
-- 2 - Class constructor
function Class_Temp:__init(device)
  QwikAppChild.__init(self, device)
-- 3 - Definition of children
local myChildren = {    -- Unique ID (uid) -> child initialization data, in our case the name
  ["Child_Temps1"] = {
    name="Température1", type="com.fibaro.temperatureSensor", className='Class_Temp',
    interfaces = {'battery'},
  ["Child_Temps2"] = {
    name="Température2", type="com.fibaro.temperatureSensor", className='Class_Temp',
  ["Child_Temps3"] = {
    name="Température3", type="com.fibaro.temperatureSensor", className='Class_Temp',
  ["Child_Temps4"] = {
    name="Température4", type="com.fibaro.temperatureSensor", className='Class_Temp',
  ["Child_Temps5"] = {
    name="Température5", type="com.fibaro.temperatureSensor", className='Class_Temp',
  ["Child_Temps6"] = {
    name="Température6", type="com.fibaro.temperatureSensor", className='Class_Temp',
-- 4 - Initialization of children
function QuickApp:onInit()
  self:loadExistingChildren(myChildren)
  self:createMissingChildren()
  self:removeUndefinedChildren()
  self:update_child("Child_Temps5")       -- example, update child with uid 'Child_Temps5'
--  for uid,_ in pairs(self.children) do  -- update all children
--    self:update_child(uid)
--  end
-- 5 - Accessing children
function QuickApp:update_child(uid)
  local default_temp = 37               --- pour l'ex du tuto
  local default_log = " I'm bad "       --- pour l'ex du tuto
  self.children[uid]:updateProperty("value", default_temp)
  self.children[uid]:updateProperty("log", default_log)
à payer les retraites des "old" :98:
C'est un QuickApp enfant, ça permet de puis un QuickApp parent de gérer plusieurs enfants, avec le même code LUA.
Exemples : Une station Netatmo : un module parent qui va chercher les infos sur le cloud Netatmo, et qui met à jour tous les enfants, avec un enfant pour chaque capteur : température, humidité, pression, etc
  • 6 mois après...
Hello, bravo pour le détail, j'ai une question naïve ... Comment trouver la liste des Types disponible pour les Childs ? :unsure:
Edit :
Je crois que j'ai trouvé : https://manuals.fibaro.com/document/hc3-quick-apps/
Modifié par TitiXsi
En fait la liste officielle est sur l'API de ta box :
/api/quickApp/availableTypes
En pratique, on a même constaté que tu peux utiliser certains types non listés dans l'API précédente.
C'est à dire qu'un QuickApp peut utiliser n'importe quel type disponible sur la box, incluant donc tous les types des différents modules Z-Waves, Zigbee, etc.
Voir :
/api/devices/hierarchy
En plus cette dernière liste a le bon gout d'être hiérarchisée, ce qui est intéressant pour découvrir les relations entre les modules de type proche.
