ericl78 Posté(e) le 24 novembre 2022 Signaler Posté(e) le 24 novembre 2022 (modifié) IMPORTANT NOTICE Version 5.130.64 is a hotfix of 5.130.45, it fixes following issues: Some cases encountered system booting issue after update. Scenes page hangs in some cases. Stability improvements. Thermostats do not always respond to manual setting from the climate panel. Minor UX improvements. Modifié le 24 novembre 2022 par ericl78 1
ericl78 Posté(e) le 24 novembre 2022 Auteur Signaler Posté(e) le 24 novembre 2022 mise à jour effectuée, ultra rapide ! RAS pour l'instant
fredokl Posté(e) le 24 novembre 2022 Signaler Posté(e) le 24 novembre 2022 Le changelog complet en anglais: Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. IMPORTANT NOTICE Version 5.130.64 is a hotfix of 5.130.45, it fixes following issues: Some cases encountered system booting issue after update. Scenes page hangs in some cases. Stability improvements. Thermostats do not always respond to manual setting from the climate panel. Minor UX improvements. Main features: 1. Redesigned the way user access settings works From now on, it is possible to grant access to devices and scenes by entire sections or rooms in the system. Access to newly added devices and scenes will be automatically granted if an entire section or room is selected. New user will automatically have access to the entire system from the beginning. 2. Scenes can be assigned to rooms From now on, all types of scenes can be assigned to rooms, not just categories. 3. Z-Wave devices exclusion wizard Z-Wave exclusion is now available in new wizard style. Additionally there is an option to start exclusion directly from failed inclusion process. What's new: Devices Added Gateway filter to devices list. Added possibility to filter out power metering devices from mobile application energy panel. Changed UI for icons selection. Heatit ZM Single Relay 16A support. Heatit ZM Thermostat 16A support. Heatit Z-Push Wall Controller support. Heatit Leakage Stopper support. Network Automatic selection of network connection type in FTI if only one is available. Nice* Optimized support for OXIBD module. Other Optimized trim of events database. Performance improvements. Added system notification about potential performance loss due overheating. Added possibility to clear all system notifications at once. Profiles Changed UI for icons selection. Quick Apps Power sensor device type added to QuickApps. Removed password saving option in browser for secret variables. Rooms Changed UI for icons selection. Scenes Added validation for time inputs in block scenes. Devices used in scenarios and hidden later are now shown on the devices list. Scenes name limit is changed to 60 characters. Changed UI for icons selection. Update Translations support for devices Update Service.** Devices update now available using remote access. Z-Wave Performance improvements.** Bug fixes: Alarm Some alarm scenes are not listed in Alarm tab. Climate Panel Some devices set to "Hold" in manual mode returns to schedule anyway after 7 days. Climate zone deactivation does not work for some device types. Dashboard Favorite position label defined by user is not used on dashboard tiles and sidebar. Alarm status "dots" on sensors tiles does not change color according to current zone state. Scrolling long names does not always show the full text on device tiles. Devices Issue with displaying current values of bit-mask type configuration parameters. Cannot navigate to child device using "parent-child" tree when filters are enabled. Newly added device is not visible when filters are set. After adding a camera, modal for adding "other devices" stays open. Wrong battery status for Sensative strip Guard 700 in some cases. Binary sensor cannot be used for Video Gate linked device. Missing possibility to sort devices using battery level. Minor fixes in UX for new devices filters. Missing support for some actions related with color control (fading, enhancing, stop color change). HeatIt ZM Thermostat 16A set-point issue requires reconfiguration to work properly (introduced in 5.121.28 beta). Elero* Devices are marked as dead during binding procedure in rare cases. Gateway Connection Incorrect role handling for FIBARO RGBW 1. Missing possibility to exclude device from slave gateway. Nice* Redundant "Stop" button for gates on control dialog in mobile application. Removed redundant step in "pairing a remote in gateway" binding process. Other Fixed Recovery UI issues in German language. Wrong display of "not used" RAM value in diagnostics. Not saved system language during FTI in some cases. Notifications creation time is calculated according to browser time, not system one. Mismatched translations when leaving Recovery mode. Some cases encountered system booting issue after update (introduced in 5.121.28 beta). Incorrect notification about HC3 gateway overheating (introduced in 5.121.28 beta). Newly added devices access issues for mobile app and web interface users (introduced in 5.121.28 beta). Quick Apps Missing logs in console after page refresh. Quick App sprinkler device type is not supported in Garden Panel. QuickApps content loading issue while using the remote connection (introduced in 5.121.28 beta). Scenes Unnecessary popup with "unsaved changes" in some cases for Scenarios. Update Impossible to start second update for battery-operated device.** Last target in devices update stays in "In Progress" status even if whole process ended.** Z-Wave Engine crash in some cases during multiple network management operations.** Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 1
fredokl Posté(e) le 24 novembre 2022 Signaler Posté(e) le 24 novembre 2022 Et la version française (google translate): Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et améliorations. AVIS IMPORTANT La version 5.130.64 est un correctif de 5.130.45, il corrige les problèmes suivants : Certains ont rencontré un problème de démarrage du système après la mise à jour. La page des scènes se bloque dans certains cas. Améliorations de la stabilité. Les thermostats ne répondent pas toujours au réglage manuel du panneau de climatisation. Améliorations mineures de l'UX. Caractéristiques principales: 1. Refonte du fonctionnement des paramètres d'accès utilisateur. Désormais, il est possible d'accorder l'accès aux appareils et aux scènes par des sections ou des pièces entières du système. L'accès aux appareils et scènes nouvellement ajoutés sera automatiquement accordé si une section ou une pièce entière est sélectionnée. Le nouvel utilisateur aura automatiquement accès à l'ensemble du système depuis le début. 2. Les scènes peuvent être attribuées à des pièces. Désormais, tous les types de scènes peuvent être attribués à des pièces, pas seulement des catégories. 3. Assistant d'exclusion des appareils Z-Wave. L'exclusion Z-Wave est désormais disponible dans un nouveau style d'assistant. De plus, il existe une option pour démarrer l'exclusion directement à partir du processus d'inclusion ayant échoué. Quoi de neuf: Dispositifs Filtre de passerelle ajouté à la liste des appareils. Ajout de la possibilité de filtrer les appareils de mesure de puissance à partir du panneau d'énergie de l'application mobile. Modification de l'interface utilisateur pour la sélection des icônes. Prise en charge du relais simple Heatit ZM 16A. Prise en charge du thermostat Heatit ZM 16A. Prise en charge du contrôleur mural Heatit Z-Push. Support Heatit Leakage Stopper. Réseau Sélection automatique du type de connexion réseau dans FTI si un seul est disponible. Nice* Prise en charge optimisée du module OXIBD. Autre Garniture optimisée de la base de données des événements. Amélioration des performances. Ajout d'une notification système concernant une perte de performances potentielle due à une surchauffe. Ajout de la possibilité d'effacer toutes les notifications du système à la fois. Profils Modification de l'interface utilisateur pour la sélection des icônes. Quick Apps Type de périphérique de capteur de puissance ajouté aux QuickApps. Suppression de l'option d'enregistrement du mot de passe dans le navigateur pour les variables secrètes. Pièces Modification de l'interface utilisateur pour la sélection des icônes. Scènes Ajout de la validation des entrées de temps dans les scènes de bloc. Les appareils utilisés dans les scénarios et masqués ultérieurement sont désormais affichés dans la liste des appareils. La limite du nom des scènes est passée à 60 caractères. Modification de l'interface utilisateur pour la sélection des icônes. Mise à jour Prise en charge des traductions pour le service de mise à jour des appareils.** La mise à jour des appareils est désormais disponible via l'accès à distance. Z-Wave Amélioration des performances.** Corrections de bogues : Alarme Certaines scènes d'alarme ne sont pas répertoriées dans l'onglet Alarme. Panneau climatique Certains appareils réglés sur "Hold" en mode manuel reviennent quand même à la programmation après 7 jours. La désactivation de la zone climatique ne fonctionne pas pour certains types d'appareils. Tableau de bord L'étiquette de position favorite définie par l'utilisateur n'est pas utilisée sur les vignettes du tableau de bord et la barre latérale. Les "points" d'état d'alarme sur les tuiles des capteurs ne changent pas de couleur en fonction de l'état actuel de la zone. Le défilement des noms longs n'affiche pas toujours le texte complet sur les vignettes de l'appareil. Dispositifs Problème d'affichage des valeurs actuelles des paramètres de configuration de type masque de bits. Impossible d'accéder à l'appareil enfant à l'aide de l'arborescence "parent-enfant" lorsque les filtres sont activés. Le périphérique nouvellement ajouté n'est pas visible lorsque les filtres sont définis. Après l'ajout d'une caméra, la fenêtre modale d'ajout d'"autres appareils" reste ouverte. Mauvais état de la batterie pour Sensative strip Guard 700 dans certains cas. Le capteur binaire ne peut pas être utilisé pour le périphérique lié à Video Gate. Possibilité manquante de trier les appareils en fonction du niveau de la batterie. Corrections mineures dans UX pour les nouveaux filtres d'appareils. Prise en charge manquante pour certaines actions liées au contrôle des couleurs (estompage, amélioration, arrêt du changement de couleur). Le problème de point de consigne du thermostat HeatIt ZM 16A nécessite une reconfiguration pour fonctionner correctement (introduit dans la version bêta 5.121.28). Elero* Les appareils sont marqués comme morts pendant la procédure de liaison dans de rares cas. Connexion passerelle Gestion incorrecte des rôles pour FIBARO RGBW 1. Possibilité manquante d'exclure l'appareil de la passerelle esclave. Nice* Bouton "Stop" redondant pour les portes sur la boîte de dialogue de contrôle dans l'application mobile. Suppression de l'étape redondante dans le processus de liaison "couplage d'une télécommande dans la passerelle". Autre Correction des problèmes d'interface utilisateur de récupération en langue allemande. Mauvais affichage de la valeur RAM "non utilisée" dans le diagnostic. Langue du système non enregistrée pendant FTI dans certains cas. L'heure de création des notifications est calculée en fonction de l'heure du navigateur, et non du système. Traductions incompatibles lors de la sortie du mode de récupération. Certains cas ont rencontré un problème de démarrage du système après la mise à jour (introduit dans la version bêta 5.121.28). Notification incorrecte concernant la surchauffe de la passerelle HC3 (introduite dans la version bêta 5.121.28). Problèmes d'accès aux appareils nouvellement ajoutés pour les utilisateurs d'applications mobiles et d'interfaces Web (introduits dans la version bêta 5.121.28). Applications rapides Journaux manquants dans la console après l'actualisation de la page. Le type d'appareil d'arrosage Quick App n'est pas pris en charge dans Garden Panel. Problème de chargement de contenu QuickApps lors de l'utilisation de la connexion à distance (introduit dans la version bêta 5.121.28). Scènes Popup inutile avec "modifications non enregistrées" dans certains cases pour Scénarios. Mise à jour Impossible de lancer la deuxième mise à jour pour les appareils fonctionnant sur batterie.** La dernière cible dans la mise à jour des appareils reste à l'état "En cours" même si tout le processus est terminé.** Z-Wave Plantage du moteur dans certains cas lors de plusieurs opérations de gestion de réseau.** Problèmes connus: Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. * - ne s'applique pas au HC3L (Home Center 3 Lite) ** - s'applique uniquement au moteur Z-Wave 3.0 1
mprinfo Posté(e) le 24 novembre 2022 Signaler Posté(e) le 24 novembre 2022 Super et merci pour la version française Envoyé de mon BLA-L29 en utilisant Tapatalk
jojo Posté(e) le 24 novembre 2022 Signaler Posté(e) le 24 novembre 2022 pour les icônes, est-il possible de voir/éditer les icônes multiples : binary switch (une pour ON et une pour OFF), interrupteur multi-niveau (0%, 10%, 20% ...). A chaque fois on ne voit qu'une icône, et pas les autres.
Lazer Posté(e) le 25 novembre 2022 Signaler Posté(e) le 25 novembre 2022 @jojo ça c'est un bug de l'application mobile, pas de l'interface Web.
jjacques68 Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 (modifié) MAJ en cours... [...] RAS pour le moment. Modifié le 26 novembre 2022 par jjacques68
Lazer Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 Non seulement c'est une beta, mais en plus c'est un correctif "hotfix" de la beta précédente qui présentait des bugs bloquants. Depuis environ 1 ou 2 mois, Fibaro se remet à sortir des mises à jour de firmwares très instables, y compris la version stable précédente (que je n'ai pas installé du coup), donc méfiance. 1
Sowliny Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 Je suis toujours en 5.120 (une éternité ?)... Une des raisons qui auraient pu me pousser à tenter une version supérieure, mais instable, était la prise en charge du module Heatit ZM16. Mais la 5.120 permet malgré tout une reconnaissance (peut-être minimale ?) très acceptable de ce module. Au moins pour un ON/OFF basique, ce qui me convient ("gestion" d'un radiateur d'appoint à bain d'huile). Ma HC3 bosse correctement (j'oserai dire qu'elle ronronne...) Il y a 4 heures, Lazer a dit : donc méfiance Voilà, tout est dit...
Lazer Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 Voilà, pareil, 5.120, la dernière vraie stable
jojo Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 Le 25/11/2022 à 12:29, Lazer a dit : @jojo ça c'est un bug de l'application mobile, pas de l'interface Web. non, non, je parle dans l'interface WEB, dans la config de l'appareil. Ce serait une fonctionnalité qui n'existe pas (ou que je n'ai pas trouvé comment faire)
Lazer Posté(e) le 26 novembre 2022 Signaler Posté(e) le 26 novembre 2022 (modifié) Mais... euh... ça a toujours été possible, c'est juste que l'interface de gestion des icôn es a changé : Pour un Binary switch : Pour un multilevel switch : Ou alors je ne comprends toujours pas ce que tu cherches ?!? Modifié le 26 novembre 2022 par Lazer 1
jojo Posté(e) le 27 novembre 2022 Signaler Posté(e) le 27 novembre 2022 oui, j'ai presque réussi à me faire comprendre ... Ce que tu montres, c'est pour AJOUTER des nouvelles icônes (ça je savais faire) Mais ce que j'aimerais faire, c'est EDITER un set d'icônes existant (et quand tu as ajouté les 10 icônes pour un multilevel switch (par exemple)) tu ne vois (évidemment) qu'une seule des 10 icônes chargées, mais comment pouvoir voir (et éditer) ces icônes ? Suis-je plus clair ?
Lazer Posté(e) le 27 novembre 2022 Signaler Posté(e) le 27 novembre 2022 Ah... dans ce cas c'est comme sur la HC2, il faut créer un nouveau set de 10 icônes... Tu ne peux pas modifier un jeu d’icône existant, ça n'a jamais été possible.
jojo Posté(e) le 27 novembre 2022 Signaler Posté(e) le 27 novembre 2022 c'est en effet ce que je faisais, et j'aurais trouvé sympa que cette fonctionnalité (au min en DISPLAY) apparaisse ... (ce serait un bon incitent pour mon prochain upgrade)
WENS Posté(e) le 28 novembre 2022 Signaler Posté(e) le 28 novembre 2022 L'interface ne me met pas que c'est une version Beta pourtant ?
jojo Posté(e) le 28 novembre 2022 Signaler Posté(e) le 28 novembre 2022 si tu cliques sur "voir le journal des modifications", ils disent que c'est un HitFix. Peux-être ils le disent quand on clique sur "télécharger la mise à jour", mais je n'ai pas osé ...
WENS Posté(e) le 28 novembre 2022 Signaler Posté(e) le 28 novembre 2022 Il y a 1 heure, jojo a dit : si tu cliques sur "voir le journal des modifications", ils disent que c'est un HitFix. Peux-être ils le disent quand on clique sur "télécharger la mise à jour", mais je n'ai pas osé ... Parce que Beta normalement il est mis a coté du numéro de version. J'ai pas osé non plus :p
flacon030 Posté(e) le 29 novembre 2022 Signaler Posté(e) le 29 novembre 2022 (modifié) j'ai osée et elle est en bleu comme une version final et non comme une bêta qui en principe est en rouge Je pense qu'elle est considéré chez fibaro comme une final Modifié le 29 novembre 2022 par flacon030
Kana-chan Posté(e) le 29 novembre 2022 Signaler Posté(e) le 29 novembre 2022 Pareil, je l'ai vu en bleue et je n'ai eu nul part de mention de BETA.
ericl78 Posté(e) le 2 décembre 2022 Auteur Signaler Posté(e) le 2 décembre 2022 bonsoir Dans le développement d'un Quickapp, lorsque vous recherchez les structures d'un module zwave, plus rien n'apparait ! idem chez vous ?
Lazer Posté(e) le 2 décembre 2022 Signaler Posté(e) le 2 décembre 2022 Il y a quoi normalement dans structure ? Je n'ai pas souvenir d'avoir jamais vu ça
Lazer Posté(e) le 2 décembre 2022 Signaler Posté(e) le 2 décembre 2022 Réponse : la liste des devices avec les propriétés lisibles et les méthodes exécutables Je n'avais jamais fait attention à ça !! Et je confirme que c'est bien présent sur la dernière vraie stable connue : 5.120 Et absent sur les versions récentes (stable ou beta on ne sais pas trop du coup....) : 5.130.xxx
