HC3 & HC3L - 5.130.61 - BETA - 18/11/2022
HC3 & HCL - 5.130.61 - BETA - 18/11/2022
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
IMPORTANT NOTICE
Version 5.130.61 is a hotfix of 5.130.45, it fixes following issues:
Some cases encountered system booting issue after update.
Scenes page hangs in some cases.
Stability improvements.
Minor UX improvements.
Main features:
1. Redesigned the way user access settings works
From now on, it is possible to grant access to devices and scenes by entire sections or rooms in the system.
Access to newly added devices and scenes will be automatically granted if an entire section or room is selected.
New user will automatically have access to the entire system from the beginning.
2. Scenes can be assigned to rooms
From now on, all types of scenes can be assigned to rooms, not just categories.
3. Z-Wave devices exclusion wizard
Z-Wave exclusion is now available in new wizard style.
Additionally there is an option to start exclusion directly from failed inclusion process.
What's new:
Devices
    Added Gateway filter to devices list.
    Added possibility to filter out power metering devices from mobile application energy panel.
    Changed UI for icons selection.
    Heatit ZM Single Relay 16A support.
    Heatit ZM Thermostat 16A support.
    Heatit Z-Push Wall Controller support.
    Heatit Leakage Stopper support.
Network
    Automatic selection of network connection type in FTI if only one is available.
Nice*
    Optimized support for OXIBD module.
Other
    Optimized trim of events database.
    Performance improvements.
    Added system notification about potential performance loss due overheating.
    Added possibility to clear all system notifications at once.
Profiles
Quick Apps
    Power sensor device type added to QuickApps.
    Removed password saving option in browser for secret variables.
Rooms
Scenes
    Added validation for time inputs in block scenes.
    Devices used in scenarios and hidden later are now shown on the devices list.
    Scenes name limit is changed to 60 characters.
Update
    Translations support for devices Update Service.**
    Devices update now available using remote access.
Z-Wave
    Performance improvements.**
Bug fixes:
Alarm
    Some alarm scenes are not listed in Alarm tab.
Climate Panel
    Some devices set to "Hold" in manual mode returns to schedule anyway after 7 days.
    Climate zone deactivation does not work for some device types.
Dashboard
    Favorite position label defined by user is not used on dashboard tiles and sidebar.
    Alarm status "dots" on sensors tiles does not change color according to current zone state.
    Scrolling long names does not always show the full text on device tiles.
Devices
    Issue with displaying current values of bit-mask type configuration parameters.
    Cannot navigate to child device using "parent-child" tree when filters are enabled.
    Newly added device is not visible when filters are set.
    After adding a camera, modal for adding "other devices" stays open.
    Wrong battery status for Sensative strip Guard 700 in some cases.
    Binary sensor cannot be used for Video Gate linked device.
    Missing possibility to sort devices using battery level.
    Minor fixes in UX for new devices filters.
    Missing support for some actions related with color control (fading, enhancing, stop color change).
    HeatIt ZM Thermostat 16A set-point issue requires reconfiguration to work properly (introduced in 5.121.28 beta).
Elero*
    Devices are marked as dead during binding procedure in rare cases.
Gateway Connection
    Incorrect role handling for FIBARO RGBW 1.
    Missing possibility to exclude device from slave gateway.
Nice*
    Redundant "Stop" button for gates on control dialog in mobile application.
    Removed redundant step in "pairing a remote in gateway" binding process.
Other
    Fixed Recovery UI issues in German language.
    Wrong display of "not used" RAM value in diagnostics.
    Not saved system language during FTI in some cases.
    Notifications creation time is calculated according to browser time, not system one.
    Mismatched translations when leaving Recovery mode.
    Some cases encountered system booting issue after update (introduced in 5.121.28 beta).
    Incorrect notification about HC3 gateway overheating (introduced in 5.121.28 beta).
    Newly added devices access issues for mobile app and web interface users (introduced in 5.121.28 beta).
Quick Apps
    Missing logs in console after page refresh.
    Quick App sprinkler device type is not supported in Garden Panel.
    QuickApps content loading issue while using the remote connection (introduced in 5.121.28 beta).
Scenes
    Unnecessary popup with "unsaved changes" in some cases for Scenarios.
Update
    Impossible to start second update for battery-operated device.**
    Last target in devices update stays in "In Progress" status even if whole process ended.**
Z-Wave
    Engine crash in some cases during multiple network management operations.**
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Like 2
HC3 & HCL - 5.130.61 - BÊTA - 18/11/2022
Merci d’utiliser notre passerelle! Assurez-vous de mettre à jour vers la dernière version pour profiter des nouvelles fonctionnalités et améliorations.
AVIS IMPORTANT
La version 5.130.61 est un correctif de 5.130.45, il résout les problèmes suivants:
Certains cas ont rencontré un problème de démarrage du système après la mise à jour.
La page Scènes se bloque dans certains cas.
Améliorations de la stabilité.
Améliorations mineures de l’expérience utilisateur.
Caractéristiques principales:
1. Refonte du fonctionnement des paramètres d’accès utilisateur
Désormais, il est possible d’accorder l’accès aux appareils et aux scènes par des sections ou des pièces entières du système.
L’accès aux appareils et aux scènes nouvellement ajoutés sera automatiquement accordé si une section ou une pièce entière est sélectionnée.
Le nouvel utilisateur aura automatiquement accès à l’ensemble du système dès le début.
2. Les scènes peuvent être assignées aux salles
Désormais, tous les types de scènes peuvent être affectés à des salles, pas seulement à des catégories.
3. Assistant d’exclusion des appareils Z-Wave
L’exclusion Z-Wave est désormais disponible dans un nouveau style d’assistant.
En outre, il existe une option pour démarrer l’exclusion directement du processus d’inclusion échoué.
Quoi de neuf:
Périphériques
ajoutés Filtre de passerelle à la liste des périphériques.
Ajout de la possibilité de filtrer les appareils de mesure de puissance du panneau d’énergie de l’application mobile.
Modification de l’interface utilisateur pour la sélection des icônes.
Prise en charge de Heatit ZM Single Relay 16A.
Support du thermostat Heatit ZM 16A.
Prise en charge du contrôleur mural Heatit Z-Push.
Prise en charge du bouchon de fuite Heatit.
Réseau
Sélection automatique du type de connexion réseau dans FTI si une seule est disponible.
Nice*
Prise en charge optimisée du module OXIBD.
Autre
Base de données d’événements de découpage optimisée.
Amélioration des performances.
Ajout d’une notification système sur la perte de performance potentielle due à une surchauffe.
Ajout de la possibilité d’effacer toutes les notifications système à la fois.
Interface utilisateur modifiée des profils
Quick Apps Type de capteur de puissance ajouté à QuickApps
Option d’enregistrement de mot de passe supprimée dans le navigateur pour les variables secrètes.
Interface utilisateur modifiée des salles
Scènes Ajout de la validation pour les entrées de temps dans les scènes de
bloc.
Les appareils utilisés dans les scénarios et masqués ultérieurement sont désormais affichés dans la liste des périphériques.
La limite de noms de scènes passe à 60 caractères.
Prise en charge des traductions de mises à jour pour les appareils Update Service.**
La mise à jour des appareils est désormais disponible via l’accès à
distance.
Améliorations des performances Z-Wave
Bogue:
Alarme Certaines scènes d’alarme ne sont pas répertoriées dans l’onglet Alarme
Panneau
climatique Certains appareils réglés sur « Hold » en mode manuel revient à la planification de toute façon après 7 jours.
La désactivation de la zone climatique ne fonctionne pas pour certains types d’appareils.
Tableau de bord L’étiquette de position favorite définie par l’utilisateur n’est pas utilisée sur les vignettes et la barre latérale du tableau de bord
Les « points » d’état de l’alarme sur les vignettes des capteurs ne changent pas de couleur en fonction de l’état actuel de la zone.
Le défilement des noms longs n’affiche pas toujours le texte intégral sur les vignettes de périphérique.
Périphériques
Problème avec l’affichage des valeurs actuelles des paramètres de configuration de type masque de bits.
Impossible d’accéder à l’appareil enfant à l’aide de l’arborescence « parent-enfant » lorsque les filtres sont activés.
Le périphérique nouvellement ajouté n’est pas visible lorsque les filtres sont définis.
Après l’ajout d’une caméra, le modal pour ajouter « autres appareils » reste ouvert.
Mauvais état de la batterie pour Sensative strip Guard 700 dans certains cas.
Le capteur binaire ne peut pas être utilisé pour le périphérique lié à Video Gate.
Possibilité manquante de trier les appareils en fonction du niveau de la batterie.
Corrections mineures dans l’expérience utilisateur pour les nouveaux filtres d’appareils.
Prise en charge manquante de certaines actions liées au contrôle des couleurs (décoloration, amélioration, arrêt du changement de couleur).
Le problème de point de consigne du thermostat HeatIt ZM 16A nécessite une reconfiguration pour fonctionner correctement (introduit dans la version bêta de la version 5.121.28).
Elero*
Les appareils sont marqués comme morts pendant la procédure de liaison dans de rares cas.
Connexion
de passerelle Gestion incorrecte des rôles pour FIBARO RGBW 1.
Possibilité manquante d’exclure l’appareil de la passerelle esclave.
Nice*
Bouton « Stop » redondant pour les portes sur la boîte de dialogue de contrôle dans l’application mobile.
Suppression de l’étape redondante du processus de liaison « couplage d’une passerelle distante ».
Autres
problèmes résolus de l’interface utilisateur de récupération en allemand.
Affichage incorrect de la valeur de RAM « non utilisée » dans les diagnostics.
Langue système non enregistrée pendant FTI dans certains cas.
Le temps de création des notifications est calculé en fonction du temps du navigateur, et non du système.
Traductions incompatibles lorsque vous quittez le mode de récupération.
Certains cas ont rencontré un problème de démarrage du système après la mise à jour (introduit dans la version bêta 5.121.28).
Notification incorrecte concernant la surchauffe de la passerelle HC3 (introduite dans la version bêta de la version 5.121.28).
Problèmes d’accès aux appareils nouvellement ajoutés pour les utilisateurs d’applications mobiles et d’interfaces Web (introduits dans la version bêta de la version 5.121.28).
Applications rapides
Journaux manquants dans la console après l’actualisation de la page.
Le type d’appareil d’arrosage Quick App n’est pas pris en charge dans Garden Panel.
Problème de chargement de contenu QuickApps lors de l’utilisation de la connexion à distance (introduit dans la version bêta 5.121.28).
Scènes
Popup inutile avec des « modifications non enregistrées » dans certains cas pour les scénarios.
Mise à jour Impossible de démarrer la deuxième mise à jour pour l’appareil fonctionnant sur batterie.**La dernière cible dans la mise à jour
des appareils reste à l’état « En cours » même si tout le processus est terminé.**
Z-Wave
Engine tombe en panne dans certains cas lors de plusieurs opérations de gestion de réseau.**
Problèmes connus :
Z-Wave Engine 3.0
Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave.
La connexion Gateway n’est pas disponible dans la nouvelle version du moteur Z-Wave.
* - ne s’applique pas au HC3L (Home Center 3 Lite)
** - s’applique uniquement à Z-Wave Engine 3.0
