fredokl Posté(e) le 12 octobre 2022 Signaler Partager Posté(e) le 12 octobre 2022 (modifié) Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. Redesigned the way user access settings works From now on, it is possible to grant access to devices and scenes by entire sections or rooms in the system. Access to newly added devices and scenes will be automatically granted if an entire section or room is selected. New user will automatically have access to the entire system from the beginning. 2. Scenes can be assigned to rooms From now on, all types of scenes can be assigned to rooms, not just categories. 3. Z-Wave devices exclusion wizard Z-Wave exclusion is now available in new wizard style. Additionally there is an option to start exclusion directly from failed inclusion process. What's new: Devices Added Gateway filter to devices list. Added possibility to filter out power metering devices from mobile application energy panel. Changed UI for icons selection. Heatit ZM Single Relay 16A support. Heatit ZM Thermostat 16A support. Heatit Z-Push Wall Controller support. Heatit Leakage Stopper support. Network Automatic selection of network connection type in FTI if only one is available. Nice* Optimized support for OXIBD module. Other Optimized trim of events database. Performance improvements. Added system notification about potential performance loss due overheating. Added possibility to clear all system notifications at once. Profiles Changed UI for icons selection. Quick Apps Power sensor device type added to QuickApps. Removed password saving option in browser for secret variables. Rooms Changed UI for icons selection. Scenes Added validation for time inputs in block scenes. Devices used in scenarios and hidden later are now shown on the devices list. Scenes name limit is changed to 60 characters. Changed UI for icons selection. Update Translations support for devices Update Service.** Devices update now available using remote access. Z-Wave Performance improvements.** Bug fixes: Alarm Some alarm scenes are not listed in Alarm tab. Climate Panel Some devices set to "Hold" in manual mode returns to schedule anyway after 7 days. Climate zone deactivation does not work for some device types. Dashboard Favorite position label defined by user is not used on dashboard tiles and sidebar. Alarm status "dots" on sensors tiles does not change color according to current zone state. Scrolling long names does not always show the full text on device tiles. Devices Issue with displaying current values of bit-mask type configuration parameters. Cannot navigate to child device using "parent-child" tree when filters are enabled. Newly added device is not visible when filters are set. After adding a camera, modal for adding "other devices" stays open. Wrong battery status for Sensative strip Guard 700 in some cases. Binary sensor cannot be used for Video Gate linked device. Missing possibility to sort devices using battery level. Minor fixes in UX for new devices filters. Missing support for some actions related with color control (fading, enhancing, stop color change). Elero* Devices are marked as dead during binding procedure in rare cases. Gateway Connection Incorrect role handling for FIBARO RGBW 1. Missing possibility to exclude device from slave gateway. Nice* Redundant "Stop" button for gates on control dialog in mobile application. Removed redundant step in "pairing a remote in gateway" binding process. Other Fixed Recovery UI issues in German language. Wrong display of "not used" RAM value in diagnostics. Not saved system language during FTI in some cases. Notifications creation time is calculated according to browser time, not system one. Mismatched translations when leaving Recovery mode. Quick Apps Missing logs in console after page refresh. Quick App sprinkler device type is not supported in Garden Panel. Scenes Unnecessary popup with "unsaved changes" in some cases for Scenarios. Update Impossible to start second update for battery-operated device.** Last target in devices update stays in "In Progress" status even if whole process ended.** Z-Wave Engine crash in some cases during multiple network management operations.** Known issues: Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 Modifié le 12 octobre 2022 par Lazer Version BETA Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredokl Posté(e) le 12 octobre 2022 Auteur Signaler Partager Posté(e) le 12 octobre 2022 Traduction par Google translate: Merci d'utiliser notre passerelle ! Assurez-vous de mettre à jour la dernière version pour profiter des nouvelles fonctionnalités et améliorations. Caractéristiques principales: 1. Refonte du fonctionnement des paramètres d'accès utilisateur Désormais, il est possible d'accorder l'accès aux appareils et aux scènes par des sections ou des pièces entières du système. L'accès aux appareils et scènes nouvellement ajoutés sera automatiquement accordé si une section ou une pièce entière est sélectionnée. Le nouvel utilisateur aura automatiquement accès à l'ensemble du système depuis le début. 2. Les scènes peuvent être attribuées à des pièces Désormais, tous les types de scènes peuvent être attribués à des pièces, pas seulement des catégories. 3. Assistant d'exclusion des appareils Z-Wave L'exclusion Z-Wave est désormais disponible dans un nouveau style d'assistant. De plus, il existe une option pour démarrer l'exclusion directement à partir du processus d'inclusion ayant échoué. Quoi de neuf: Dispositifs Filtre de passerelle ajouté à la liste des appareils. Ajout de la possibilité de filtrer les appareils de mesure de puissance à partir du panneau d'énergie de l'application mobile. Modification de l'interface utilisateur pour la sélection des icônes. Prise en charge du relais simple Heatit ZM 16A. Prise en charge du thermostat Heatit ZM 16A. Prise en charge du contrôleur mural Heatit Z-Push. Support Heatit Leakage Stopper. Réseau Sélection automatique du type de connexion réseau dans FTI si un seul est disponible. Agréable* Prise en charge optimisée du module OXIBD. Autre Garniture optimisée de la base de données des événements. Amélioration des performances. Ajout d'une notification système concernant une perte de performances potentielle due à une surchauffe. Ajout de la possibilité d'effacer toutes les notifications du système à la fois. Profils Modification de l'interface utilisateur pour la sélection des icônes. Applications rapides Type de périphérique de capteur de puissance ajouté aux QuickApps. Suppression de l'option d'enregistrement du mot de passe dans le navigateur pour les variables secrètes. Pièces Modification de l'interface utilisateur pour la sélection des icônes. Scènes Ajout de la validation des entrées de temps dans les scènes de bloc. Les appareils utilisés dans les scénarios et masqués ultérieurement sont désormais affichés dans la liste des appareils. La limite du nom des scènes est passée à 60 caractères. Modification de l'interface utilisateur pour la sélection des icônes. Mise à jour Prise en charge des traductions pour le service de mise à jour des appareils.** La mise à jour des appareils est désormais disponible via l'accès à distance. Z-Wave Amélioration des performances.** Corrections de bogues : Alarme Certaines scènes d'alarme ne sont pas répertoriées dans l'onglet Alarme. Panneau climatique Certains appareils réglés sur "Hold" en mode manuel reviennent quand même à la programmation après 7 jours. La désactivation de la zone climatique ne fonctionne pas pour certains types d'appareils. Tableau de bord L'étiquette de position favorite définie par l'utilisateur n'est pas utilisée sur les vignettes du tableau de bord et la barre latérale. Les "points" d'état d'alarme sur les tuiles des capteurs ne changent pas de couleur en fonction de l'état actuel de la zone. Le défilement des noms longs n'affiche pas toujours le texte complet sur les vignettes de l'appareil. Dispositifs Problème d'affichage des valeurs actuelles des paramètres de configuration de type masque de bits. Impossible d'accéder à l'appareil enfant à l'aide de l'arborescence "parent-enfant" lorsque les filtres sont activés. Le périphérique nouvellement ajouté n'est pas visible lorsque les filtres sont définis. Après l'ajout d'une caméra, la fenêtre modale d'ajout d'"autres appareils" reste ouverte. Mauvais état de la batterie pour Sensative strip Guard 700 dans certains cas. Le capteur binaire ne peut pas être utilisé pour le périphérique lié à Video Gate. Possibilité manquante de trier les appareils en fonction du niveau de la batterie. Corrections mineures dans UX pour les nouveaux filtres d'appareils. Prise en charge manquante pour certaines actions liées au contrôle des couleurs (estompage, amélioration, arrêt du changement de couleur). Elero* Les appareils sont marqués comme morts pendant la procédure de liaison dans de rares cas. Connexion passerelle Gestion incorrecte des rôles pour FIBARO RGBW 1. Possibilité manquante d'exclure l'appareil de la passerelle esclave. Agréable* Bouton "Stop" redondant pour les portes sur la boîte de dialogue de contrôle dans l'application mobile. Suppression de l'étape redondante dans le processus de liaison "couplage d'une télécommande dans la passerelle". Autre Correction des problèmes d'interface utilisateur de récupération en langue allemande. Mauvais affichage de la valeur RAM "non utilisée" dans le diagnostic. Langue du système non enregistrée pendant FTI dans certains cas. L'heure de création des notifications est calculée en fonction de l'heure du navigateur, et non du système. Traductions incompatibles lors de la sortie du mode de récupération. Applications rapides Journaux manquants dans la console après l'actualisation de la page. Le type d'appareil d'arrosage Quick App n'est pas pris en charge dans Garden Panel. Scènes Popup inutile avec "modifications non enregistrées" dans certains cas pour les scénarios. Mise à jour Impossible de lancer la deuxième mise à jour pour les appareils fonctionnant sur batterie.** La dernière cible dans la mise à jour des appareils reste à l'état "En cours" même si tout le processus est terminé.** Z-Wave Plantage du moteur dans certains cas lors de plusieurs opérations de gestion de réseau.** Problèmes connus: Moteur Z-Wave 3.0 Certains appareils Z-Wave ne sont pas entièrement compatibles avec la nouvelle version du moteur Z-Wave. La connexion à la passerelle n'est pas disponible dans la nouvelle version du moteur Z-Wave. * - ne s'applique pas au HC3L (Home Center 3 Lite) ** - s'applique uniquement au moteur Z-Wave 3.0 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 12 octobre 2022 Signaler Partager Posté(e) le 12 octobre 2022 Attention version BETA (j'ai édité le titre) 2 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) le 12 octobre 2022 Signaler Partager Posté(e) le 12 octobre 2022 Oui Beta, installée comme d'habitude, RAS, rapide, pas de prb pour l'instant Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 12 octobre 2022 Signaler Partager Posté(e) le 12 octobre 2022 Pas fan du tout du nouveau panneau de sélection d’icône... C'est tout petit riquiqui, on y voit rien Je ne comprends pas la logique de faire ça... Et l'affichage des icônes (toujours elles) de tous les modules sur le dashboard principal est d'une lenteur.... Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredokl Posté(e) le 12 octobre 2022 Auteur Signaler Partager Posté(e) le 12 octobre 2022 (modifié) Bon, aussitôt installé, aussitôt désinstallé! Après avoir fait la mise à jour, la box disait être en surchauffe et redémarrait systématiquement. J'ai quand même réussi à restaurer ma sauvegarde. Pour info, je n'ai ni déplacé la box, ni installé une source chaleur à proximité. Étrange. EDIT: Tout fonctionne parfaitement avec la version stable. Modifié le 12 octobre 2022 par fredokl 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
Lazer Posté(e) le 13 octobre 2022 Signaler Partager Posté(e) le 13 octobre 2022 Étrange. Pas de problème de surchauffe, CPU, ou RAM sur ma box de test. Assez peu utilisée il est vrai... Lien vers le commentaire Partager sur d’autres sites More sharing options...
flacon030 Posté(e) le 13 octobre 2022 Signaler Partager Posté(e) le 13 octobre 2022 perso tous semble OK pour le moment, a suivre dans les prochains jours... Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredokl Posté(e) le 13 octobre 2022 Auteur Signaler Partager Posté(e) le 13 octobre 2022 Bon... Je ne sais pas ce qu'il s'est passé alors. Je ne vais pas tenter le diable et attendre une autre version. Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) le 13 octobre 2022 Signaler Partager Posté(e) le 13 octobre 2022 (modifié) Il y a 2 heures, fredokl a dit : Bon... Je ne sais pas ce qu'il s'est passé alors. Je ne vais pas tenter le diable et attendre une autre version. Itou ! Ma HC3 est "en prod" et fonctionne plutôt bien en ce moment. Je ne vais donc pas tenter non plus... La seule chose qui me chagrine est la prise en charge du module Heatit ZM (16A), mais le mode "par défaut" de la 5.120.10 suffira peut-être ? Modifié le 13 octobre 2022 par Sowliny ajout, orthographe Lien vers le commentaire Partager sur d’autres sites More sharing options...
fredokl Posté(e) le 14 octobre 2022 Auteur Signaler Partager Posté(e) le 14 octobre 2022 Je reviens avec mon problème de surchauffe. Apparement le même problème a été signalé sur le forum officiel par un utilisateur. Il pense à une fausse alerte mais bon, on en sait rien finalement. https://forum.fibaro.com/topic/62486-no-restart-after-update-to-5121-beta/?do=findComment&comment=254979 Lien vers le commentaire Partager sur d’autres sites More sharing options...
ericl78 Posté(e) le 14 octobre 2022 Signaler Partager Posté(e) le 14 octobre 2022 et vlan, une nouvelle version vient de sortir, contenant des patchs. Mise à jour effectuée ras 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 14 octobre 2022 Signaler Partager Posté(e) le 14 octobre 2022 5.121.41 (beta) Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. IMPORTANT NOTICE Version 5.121.41 is a hotfix of 5.121.28, it fixes following issues: Some cases encountered system booting issue after update. Newly added devices access issues for mobile app and web interface users. Envoyé de mon BLA-L29 en utilisant Tapatalk Lien vers le commentaire Partager sur d’autres sites More sharing options...
flacon030 Posté(e) le 15 octobre 2022 Signaler Partager Posté(e) le 15 octobre 2022 perso c'est la météo de la HC3 qui ne semble plus se mettre a jour Lien vers le commentaire Partager sur d’autres sites More sharing options...
Sowliny Posté(e) le 18 octobre 2022 Signaler Partager Posté(e) le 18 octobre 2022 Finalement, le ZM SR16 de Heatit est bien reconnu, au moins pour les fonctions On/Off. Lien vers le commentaire Partager sur d’autres sites More sharing options...
