mprinfo Posté(e) le 22 avril 2022 Signaler Posté(e) le 22 avril 2022 HC2 & HCL - 4.621 - BETA - 21/04/2022 Liste des modifications de la version beta 4.621:Important notice: All devices previously added to the system that received support need to be reconfigured. New improvements: - Support for https protocol. - Support for MCO MH-S31x & MH-S22x ZW700 series. - Support for MCO MH3901-Z version 2.1. - Support for Qubino 3-Phase Smart Meter. - Support for Heiman Gas Sensor (HS1CG) version 1.1 & 1.2. - Support for Donexon radiator thermostat. - Support for other Z-Wave devices supported by Home Center 3. - System stability improvements. Resolved issues: - Z-Wave service stops responding after updating to 4.620 and using previously added thermostat. - Few instances of Thermostat & Heating Zone plugin results in system crash. - In some cases, Home Center Lite gateway stops responding after some time. - Losing master-slave synchronization after some time in gateway connection mode. - Master gateway does not detect "central scene" actions on devices added to connected gateways. - Connected slave gateway need manual synchronization to restore its connection. - Incorrect default values of FIBARO Heat Controller configuration parameters. - Sending setProtection action to external sensor of FIBARO Heat Controller result in system crash. - Issues with thermostat controlled by Alexa voice assistant. - Issue with taking a camera snapshot and sending to e-mail. - Sending empty notification if this notification was previously removed. - No possibility to use custom icons uploaded in one of the previous firmware versions. - Tedee lock plugin stops responding after some time and needs rebooting the gateway. - Cannot manually set a date later than 2021-12-31. - No pin for setting location via remote access
speedoxx007 Posté(e) le 23 avril 2022 Signaler Posté(e) le 23 avril 2022 Installé RAS. Enfin https Envoyé de mon SM-G998B en utilisant Tapatalk
Nico Posté(e) le 23 avril 2022 Signaler Posté(e) le 23 avril 2022 Nickel ça. Et ils ont ramené tous les périf. Zwave ajouté depuis dans la HC3 ???
speedoxx007 Posté(e) le 5 mai 2022 Signaler Posté(e) le 5 mai 2022 Selon le forum officiel ce sera le cas dès la version 4.630.
Cardane Posté(e) le 5 mai 2022 Signaler Posté(e) le 5 mai 2022 cool, mais si on pouvait aussi avoir le TLS sur tcp pour la HC3 ce serait génial...
mprinfo Posté(e) le 5 mai 2022 Auteur Signaler Posté(e) le 5 mai 2022 Nouvelle mise à jour 4.630 stable disponible pour votre HC2Envoyé de mon BLA-L29 en utilisant Tapatalk 1
