HC3 & HC3L - 5.102.23 - BETA - 07/04/2022
HC3 & HCL3 - 5.102.23 - BETA - 07/04/2022
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. System supports adding of the Nice, Elero and Z-Wave devices from mobile application
Additionally new Z-wave devices adding procedure in webUI is introduced.
2. Introduced new way of controlling devices using dialogs on Favorites screen in mobile application
3. New Scenes category called "Scenarios" for easy control of shutters and blinds according to sunset and sunrise triggers
Possibility to configure "morning" and "evening" scenarios with few clicks.
System supports altering configuration of those Scenarios via mobile application.
4. Zigbee protocol support*
First public beta version of Zigbee protocol support now available for tests purpose.
Support for limited types of devices with focus on lighting.
What's new :
Dashboard
Added logs on device tiles related to transmitting commands for Nice and Elero devices.
Devices
Support for MCO ZW700 series devices.
Improved handling of hold actions on sidebar buttons for shutters and venetian blinds.
Elero*
Improvements for pairing process.
Improved support for Elero Dimmer.
Modified descriptions for pairing process.
Added possibility to pair unknown device type to the system.
Nice*
New styling for Nice devices pairing process.
Improvements in protocol auto-detection function.
Improved support of BiDi-Shutter and BiDi-Awning devices.
Added possibility to calibrate BiDi-Shutter and BiDi-Awning devices from settings.
Added notification about issues during device configuration after paring.
Added displaying favorite positions states on BiDi devices.
Plugins
Reorganisation of plugins categories.
Profiles
Support for new "Scenarios" in profiles.
Quick Apps
Added possibility to edit "secret" variable in QuickApps.
Scenes
Added possibility to enable or disable the scene from edit window.
Z-Wave
Updated certified Z-Wave manufacturers list in Z-Wave engines.
Improvements for Z-Wave database size management.**
Bug fixes:
Dashboard
No automatic refresh of power consumption on devices sidebar.
Fixed issue with displaying states for shutters on devices sidebar.
Devices
Inputs state for Smart Implant not reported correctly.**
Devices added via Smart Start are not visible in the system until reboot.**
Protection settings for Z-Wave devices fixed.
Issues with thermostats support when using climate panel.**
Elero*
Wrong device configuration if timeout occurred during binding procedure.
Issues with controlling devices after update from 5.072.25 beta.
Energy
Excluding production devices from the Energy Panel does not work.
Network
Internet connection status is not stable.
Nice*
Not migrated device roles for Nice Mono devices added in the system on 5.080.
Other
Issue with booting up the hub after update to 5.101 Beta.
Nice and Elero devices not counted in number of devices in backup.
Plugins
Impossible to configure EnvisaLink plugin.
Profiles
Using Walli devices ring actions causes system crash.
QuickApps
Partially white background in mobile view in dark style.
Fixed visibility for functions declarations.
Scenes
Fixed visibility for functions declarations in Lua code.
Known issues:
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
Heureusement qu'ils ne l'ont pas publié le 1er avril sinon on le l'aurait pas cru :2:
Sinon quelques correctifs de petits bugs pénibles, c'est toujours bon à prendre.... tout cela ressemble à une très bonne mise à jour.
Qui a des modules Zigbee en type lumière pour tester ?
Hue, Ikea, etc...
mise à jour effectuer, RAS.
Je vais essayer le zigbee, mais quoi acheter ? avez vous une idée de la liste des devices compatibles?
Pourquoi veux tu acheter de zigbee ?
L'implantation du zigbee est intéressante pour ceux qui on des devices zigbee styles Philips Hue.
Juste pour essayer, la curiosité, rien d'autre.
J'ai 69 devices Zwave, pour le 70 eme, un Zigbee :=)
Oui j'allais faire la même remarque que @mprinfo
Après à la limite le Zigbee pourrait être intéressant pour certains modules qui n'existent pas en Z-Wave, comme par exemple certains thermomètres muraux avec écran intégré, ou autre appareils de mesure de la qualité de l'air. Mais je doute qu'ils soient reconnus avant un petit moment par la HC3, car Fibaro semble assez clair sur la compatibilité limitée avec les modules d'éclairage dans un premier temps.
Et d'ici à ce que ça évolue, si ça se trouve Matter sera enfin sorti, et Zigbee aura disparu. Bon après avec les nombreux retards, on n'est plus sûr de rien...
Oui sur la hc3 c'est ok
Par contre ma lampe Hue n'a aucun bouton pour l'inclusion c'est un vieux modèle
Bah les Hue c'est top tout de même pour beaucoup de lampes sur pieds etc. Moi je ne mets que ça, car en Zwave rien de simple pour faire ça, surtout si on veut du jeux de couleur, juste ingérable. Avec Hue cela fonctionne juste tip top, simple, efficace, et énorme gamme.
@nico on ne critique pas les hues
J'essaie juste d'inclure une lampe Hue sur la hc3
C'est pas possible de bloquer les membres qui sont encore sous hc2 afin qu'ils ne poluent pas les topics de la hc3
  • Haha 1
Il y a 17 heures, mprinfo a dit :
Salut à tous, @mprinfo tu mets ta box en inclusion zigbee, tu allumes/éteins ta hue 2/3/4 fois, l'inclusion peut prendre un peu de temps, donc attendre un peu et pas trop se speeder  :) . Il faut être certain qu'elle soit bien exclue de son hub d'origine, sinon tu ne pourras pas.
C'est un coup de main à prendre mais au bout de qlqs unes on s'y fait :)
Pascal, je répondais au post de Lazer  Qui n'aiment pas le Zigbee
Dit moi ce qu'il aime ça ira plus vite
Nico je plaisantais
il y a 48 minutes, Nico a dit :
Pascal, je répondais au post de Lazer :) Qui n'aiment pas le Zigbee :)
Euh... j'ai juste dit que je n'ai pas de Hue et que je ne sais pas répondre à la question de mprinfo, c'est tout.
Pour compléter, si je n'ai pas de Hue, ce n'est pas parce que ça fonctionne avec Zigbee, mais pour d'autres raisons que j'ai déjà expliqué plusieurs fois sur le forum. La principale étant qu'on ne peut les contrôler avec un interrupteur mural classique. Le prix aussi. Et puis je n'ai pas besoin de couleurs, donc aucun intérêt des Hue pour mon utilisation. Faut pas chercher plus loin...
Moi je mettrai bien les bandes lumineuses hue dans mon jardin.... Si elles n'étaient pas a 100€ le mètre
Elle a l'air top cette upgrade en tout cas
Envoyé de mon M2012K11AG en utilisant Tapatalk
@Lazer, cela fait un moment qu'on peut contrôler les Hue avec un interrupteur classique avec leur module Hue, 65 € le pack de 2 :)
Et sinon tu mets du Zwave derrière les inter et tu pilotes depuis la box.
Après moi je ne fais rien de tout ça, tout mon éclairage d'ambiance est full automatique, car sinon au final tu ne l'utilise jamais. Et du coup en full auto, c'est top. Je parle bien d'éclairage d'ambiance, sur des spots ou autres lampes au plafond, c'est une hérésie.
Outre les lumières Hue, Trådfri et Osram, sur le forum officiel ils disent que certains capteurs Zigbee sont compatibles, et ça c'est intéressant car il y a des modules bien pratiques et sans équivalents en Z-Wave (et pas cher en prime)... ou alors chez MCO Home mais  qui nécessitent une alimentation, pas toujours pratique au mur.
Xiaomi Mijia Smart Temperature
Aqara TVOC :
Les petits capteurs température et humidité avec l'affichage LCD me conviendraient bien pour remplacer les eversping ST814
