HC3 & HCL3 - 5.101.19 - BETA - 14/03/2022
Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
What's new:
Alarm
Added checking sensors status before arming the alarm.
Dashboard
Added translations for thermostat modes on dashboard tiles and sidebar.
Added possibility to open device settings directly from device tile.
Improved styling of units for sensors on dashboard and sidebar.
Changed icon for opening sidebar from device tile.
Devices
Updated parameters template for Nice BiDi-Shutter and Nice BiDi-Awning.
Added support for Eurotronic Air Quality Sensor.
Improved handling of long operations for Color Controllers and Multilevel Switches.**
Added support for new revisions of Fibaro devices.
Default configuration for RGBW441 set as RGBW after adding device to the system.
Added rounding for virtual power consumption values.
Added support for Donexon thermostatic valve.**
Custom parameters for Z-Wave devices sorted by ID.
Elero*
Improvements for pairing process.
Improved polling mechanism for Elero devices.
Energy
Warning about unsaved changes in Panel Settings.
Added support for declaring fixed cost for a period.
General
Optimized calculation of sunrise/sunset time.
Network
Improved changing network settings between DHCP and Static.
Nice*
Added possibility to Read, Set default and Reset all parameters in devices settings.
Changed default role for mono-directional devices from remotes to Blinds/Gates.
Added requesting current parameters values during pairing process.
Added possibility to configure and use favourite position for mono-directional devices.
Other
Improved auto-logging feature.
Plugins
Thermostat & Heating Zone plugin optimization.
Added possibility to set the URL manually for Dahua plugin.
Quick Apps
Changed function calling format (backwards compatible).
Changed auto-complete function for new function format in Lua.
Scenes
Changed functions calling format (backwards compatible).
Changed auto-complete function for new functions format in Lua.
Added icons for group actions.
Changed font color in dark-mode of Lua editor.
Update
Added reconfiguration button for device after successful update.**
Z-Wave devices update process improvements.
Z-Wave
Improved handing of communication errors.
Optimized service start-up.
Bug fixes:
Alarm
Unnecessary notification about wrong pin when trying to disarm the system.
Cameras
Inactive camera preview tab after saving device settings.
Dashboard
No automatic refresh of color components on device sidebar.**
Missing polish translations for states of simple shutter.
Devices
Missing barrier role for simple shutter device type.
Issue with adding Fibaro devices (Wall Plug UK, Smart Module, BiDi-ZWave) in Security Mode.
Rejected association settings visible on the list until page refresh.**
Power graphs in advanced tab do not scale when zooming.
Uploading custom icon for Fibaro CO Sensor not possible.
No possibility to change parameters in Z-Wave devices if "use template for parameters" is disabled.
Issue with opening 1P Smart Meter Qubino configuration.**
Incorrect devices grouping on settings page for QuickApps and Linked Devices.
Additional not applicable icons for devices.
Redundant device roles for Walli Roller Shutter and Roller Shutter 3.
Diagnostics
Issue with starting reconfiguration from Z-Wave tab.**
CPU graphs issues.
Energy
Wrong rounding of percentage consumption on Savings tab.
Production devices listed on Top consuming devices and on devices list on Savings tab.
Gateway Connection
Changing Fan Mode for thermostats from slave gateway is not possible.
General
Home location settings change does not alter sunrise/sunset calculation.
Location map does not show if longitude/latitude is out of range.
History
Device icon does not correspond with the state from history.
Network
No information about possible connection loss after changing network settings.
Nice*
Not migrated device roles for Nice Mono devices added in the system on 5.080.
Nice Mono devices added on 5.080 lost the icons after updating to 5.100.
Issue with pairing some Nice Mono devices.
Notifications
Devices icons in wrong states on notifications list.
Non-admin user cannot remove notifications.
Other
Additional credentials popup during log-in in some cases.
Text in reboot modal not centered on Safari browser.
Rejecting custom icons upload if file extension is in uppercase.
Plugins
Removed additional button on sidebar for Fibaro Intercom.
Scenes
Scene does not start in specific configuration when trigger is used in more than one scene.
Differences between calls in Scenes and QuickApps.
Update
No translations of errors for devices update service.**
Known issues:
Nice*
After adding Nice device page refresh is required.
Z-Wave Engine 3.0
Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
Gateway connection is not available in the new Z-Wave engine version.
* - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
Mise à jour installés sans encombre sur ma box de test :)
Je ne comprend pas bien ce que ça implique :
Citation
Ça fait tout drôle de voir un changelog Fibaro qui résout des bugs avec des modules Qubino :13:
Pas mal l'accès direct aux paramètres des modules depuis le dashboard, ça manquait, maintenant c'est comme sur HC2 :)
Si tu n'es pas pressé cela arrivera un jour ou pas
Je pense que ça ne sera jamais implémenter vu comment cela évolue
Peut-être est il déjà là et on ne le sait pas. Qui sait :)
Plaisanteries mis à part, je pense que ça ne devrait plus trop tarder, mais ce n'est que mon avis, je pensais vraiment que cette version allait l'embarquer, mais me suis trompu :) .
Modifié par TonyC
Qu'en pense ton petit doigt ? :D
C'est très certainement encore trop buggé pour être partagé publiquement ne serait-ce qu'en Beta.
Déjà que le moteur Z-Wave v3 est en beta publique depuis l'année dernière.... faut pas être pressé.
De toute façon perso je ne comprends même pas pourquoi Fibaro perd son temps avec Zigbee, la mort de ce protocole a été annoncée.
Il sera instantanément remplacé par Thread le jour où Matter sera officiellement lancé. La plupart des fabricants qui utilisent Zigbee actuellement ont déjà annoncé la transition prochaine vers Thread.
Espérons pour Fibaro que les briques logicielles de bases ne soient pas trop différentes, et que le temps investi sur Zigbee leur permettra de faire un portage rapide vers Thread. Mais vu qu'ils n'ont rien annoncé en ce sens, je ne suis pas très optimiste...
  • Haha 1
Faut jamais écouter mon petit doigt :)
Tu as raison, faudra espérer que si investissement il y a eut sur zigbee, ils pourront capitaliser dessus au passage sur thread, enfin s'ils y vont, ce dont je doute pas (ça me rassure de dire ça) :) .
L'un d'entre vous qui aurait fait cet update et ayant des QA créant des childs de type switch pourrait-il essayer de le lancer en générant les childs (longue phrase ... ) ?
J'ai eu à le faire et le résultat n'est pas beau, les childs perdent leur interfaces.
Je n'en ai pas d'autre en stock de ce type et je ne sais pas si c'est mon QA ou une régression.
@mprinfo c'est avec ton QA que j'ai eu le problème.
J'ai raconté la même histoire sur le fofo officiel, j'espère que quelqu'un aura le courage d'y jeter un oeil.
Merci pour vos retours !
Faut que j'arrête l'apéro ...
EDIT:
Coupable trouvé, j'ai mis à jour mes switchs aujourd'hui et l'un d'entre eux a un gros bug, le QA ne pouvait plus piloter le port et ce dernier ne remonte plus la charge. j'ai suspecté à tors fibaro...
chose étrange c'est ok sur les autres switches, les modèles sont différent mais la version du firmware est la même. Je vais me plaindre sur le fofo ubiquiti :)
Modifié par TonyC
Slt, depuis hier soir 3 tentatives, interminable rebooting ...heureusement que l'auto-réparation se déclenche au bout d'un moment. mais y a un truc qui cloche ...
Mise à jour sans soucis.
(je fais toujours un reboot avant l'installation.)
Le logiciel est à jour.
Actuel: 5.101.19 (beta)
Modifié par Baudouin
Mise à jour effectuée, rapide, RAS.
Pour moi, Zigbee ne sortira jamais sur nos HC3, protocole déjà mort !
Peut être le bluetooth ????
Bonsoir
Maintenant, dans les QA ou scenes les if, then, end, ... ne sont plus en noir mais en rouge, bonjour la lecture de nos programmes,
Please, faite marche arrière sur ce point
il y a 1 minute, mprinfo a dit :
Tu fais du copié collé systématiquement de tout ? ou tu as un truc pour prendre notepad++ comme éditeur principal ?
Je prends notepad comme éditeur
Puis je fais un ctrl a pour tout sélectionner est ensuite un copier coller
il y a 20 minutes, mprinfo a dit :
Oui, ce que je pensais, je vais tester, merci à toi. Pas trop lourd ?
Ctrl+A
Ctrl+C
Alt+Tab
Ctrl+A
Ctrl+V
C'est un coup à prendre, mais ça va vite, et ça permet de profiter de Notepad++ avec sa coloration syntaxique personnalisable, ses outils rapides de recherche/remplacer, tabulations, etc.
