UniFi Network Application 7.0.23
Overview
* You can find the 7.0.20, 7.0.21 and 7.0.22 release notes/changelogs here, here and here.
Bugfixes
  • Fix issue where RADIUS authentication was not working when using the default auth server.
  • Fix issue where Traffic Rules Region matching option was available, will be back in a future release.
  • Fix changing VLAN-Only Networks to a regular Corporate Network.
Additional information
Please report any issues you encounter with this release using the Report Bug form.
(Recommended) - Create an up-to-date backup before upgrading your UniFi Network Application settings in the event any issues are encountered.
  • Existing UniFi Network Applications must be on one of the following versions in order to upgrade directly to this version:
7.0.23 and earlier 7.0.x versions.
6.5.55 and earlier 6.5.x versions.
6.4.54 and earlier 6.4.x versions.
6.3.51 and earlier 6.3.x versions.
6.2.26 and earlier 6.2.x versions.
6.1.71 and earlier 6.1.x versions.
6.0.45 and earlier 6.0.x versions.
5.14.25 and earlier 5.14.x versions.
5.13.33 and earlier 5.13.x versions.
5.12.72 and earlier 5.12.x versions.
5.11.52 and earlier 5.11.x versions.
5.10.27 and earlier 5.10.x versions.
5.9.33 and earlier 5.9.x versions.
5.8.30 and earlier 5.8.x versions.
5.7.28 and earlier 5.7.x versions.
5.6.42 and earlier 5.6.x versions.
Most earlier versions are also supported for direct upgrade, going back to 3.1.0.
  • UniFi Network Application updates may cause your adopted devices to reprovision.
  • An updated/current version of Java 8 must be installed on the system hosting the UniFi Network Application. Java 9 and later are not yet supported.
  • As of UniFi Network Application version 5.9, if using Cloud Access, the host system/device requires outbound 8883/tcp to be open/unrestricted. Find up-to-date port requirements here.
  • Minimum supported device firmware for U6-Series devices is 5.29.0, UAP/USW is 4.0.9, and for USG it's 4.4.34.
  • If you have any 'service dns forwarding options' configuration defined in config.gateway.json, it will overwrite the provisioning of statically defined name servers, leaving you with no DNS. Either remove the 'service dns forwarding options' portion of config.gateway.json, or add additional 'options' lines defining name servers, such as 'server=1.1.1.1', 'server=8.8.8.8', etc.
Microsoft Windows specific
  • Users running 64-bit Windows should only have 64-bit Java installed. If you have 32-bit Java installed then we recommend uninstalling it.
macOS Specific
  • We stopped bundling Java as of UniFi Network 5.11.47. If you're installing that release or later please make sure you have manually installed a current release of Java 8 beforehand. Only the Java Runtime Environment (JRE) is required.
  • Oracle JRE 8 offers the simplest path as it will simply "just work" without requiring any changes. We may investigate alternative JVMs and update this message accordingly.
Debian/Ubuntu specific
  • For Debian/Ubuntu users installing via our repo, please update your APT source (see HERE).
  • We support MongoDB 3.6 since 5.13.10, older UniFi Network Application versions only support up to MongoDB 3.4.
Le contrôleur unifi vient de passer en version 7
Je viens de l'installer aucun probléme pour le moment, l'api n'a pas l'air d'avoir été modifier
  • 4 semaines après...
UniFi Network Application 7.0.25
Overview
* You can find the 7.0.20, 7.0.21, 7.0.22 and 7.0.23 release notes/changelogs hereherehere and here.
Bugfixes
  • Fix unable to resume the default network.
  • Fix rare upgrade issue for those upgrading from version 4.x.
  • Fix Internet Source IP in the Network settings, preventing users from changing static IP.
  • Fix unable to edit and create Traffic Restrictions.
7.0.25 and earlier 7.0.x versions.
macOS Specific
UniFi Network Application 7.1.61
18135k
CommentFollow
Overview
  • Add Teleport VPN (Requires firmware version 1.12.x/2.4.x or newer). (not available for UXG)
  • Add Traffic Routes (Requires UDM/UXG firmware version 1.12.8/2.4.x or newer)
  • Add Switch Ports Insights and bulk-port editing.
  • Improve Search & Filters on the Devices/Clients/Notifications page.
  • Improve Traffic statistics.
  • Improve UX for Global AP Settings.
  • Improve WiFi Statistics UX.
Improvements
  • Add AP widget for UniFi clients.
  • Add MIMO column in the Clients page.
  • Add 802.1x ID/VLAN column in the Clients page.
  • Add warning for HTTPS limitation when Facebook WiFi is selected.
  • Add IPv6 support for UID VPN.
  • Add multi-search to Devices, UniFi Devices & Notifications.
  • Add missing WAN DHCP Client options.
  • Add confirmation dialog to disable the AP meshing setting.
  • Add option to forget clients.
  • Add IP validation before setting a Honeypot IP.
  • Add information if WAN IP is a local IP when configuring a VPN.
  • Add max DHCP Lease Range validation for Network form.
  • Allow Client connect to lock APs only if selected AP is stable.
  • Improve the Advanced adoption UX.
  • Improve fixed IP Address error message.
  • Improve wireless uplink adoption stability.
  • Improve Settings Search page highlight.
  • Improve display of the channel value in the WiFiman table and property panel.
  • Update the device manage section UX.
  • Update USW-Pro-Aggregation property panel.
  • Update unrecognized client icons.
  • Update RPS Anomalies list.
  • Update countries and territories in Country restrictions.
  • Update default Gateway ARP Cache timeout to 10 minutes.
  • Update Settings Search UX.
  • Update DPI Signatures (Requires 1.12.15 or newer).
  • Update Log4j to 2.17.2.
  • Enable debug terminal for USP RPS.
  • Show offline Non-Network devices on the Device page
  • Show Link Quality as experience for UBB's.
  • Show what Radio is used for the Link in the UBB property panel.
  • Show USW-Flex-Mini memory usage in the devices table.
  • Display Clients/Guests at the top of the Device panel.
  • Display Device Capacity for Cloud Console.
  • Display last seen in the uptime column.
  • Replace (unsupported) Power Utilization with Memory Usage for USP-Strip/Plug.
  • Re-organize clients side panel overview.
  • Process device updates less frequently on larger setups.
  • Close U-LTE setup wizard final screen when U-LTE is adopted.
  • Do not include offline devices in the Lock AP device capability check.
  • Remove Network dropdown under Settings for Gateways, which already exists under Overview.
  • Unlock Client locked to Access Point if it was forgotten.
Bugfixes
  • Fix issue where limited admins cannot access the application in rare cases.
  • Fix issue where admin notifications were sent, although disabled.
  • Fix missing validation for DHCPv6 Range.
  • Fix issue where Honeypot Alert source IP and service column were empty.
  • Fix issue where “Provision” and “Open Terminal” toggle were not grayed out for offline devices.
  • Fix issue where channel width shows blank when configured via mobile apps.
  • Fix issue in RF Scan output.
  • Fix inability to set Fixed IP addresses for a client on sites with L3 Switches.
  • Fix connected downlink incorrectly reported as isolated.
  • Fix firewall IP range validation.
  • Fix tiny theme images on the Safari browser.
  • Fix SMTP settings are ignored when sending mail.
  • Fix checkbox value for disabled Multicast DNS Setting.
  • Fix missing default sorting for Port and IP Groups.
  • Fix incorrect time format for device firmware update check.
  • Fix AP Group selection.
  • Fix incorrect warning messages when UBB is upgrading.
  • Fix missing custom upgrade for UXG.
  • Fix missing services configuration for USP-RPS/UXG-Pro.
  • Fix port remapping issues with UXG/USG.
  • Fix uplink device showing itself in port diagram tooltips.
  • Fix device is downgraded during adoption.
  • Fix Utilization chart shouldn't surpass 100%.
  • Fix missing Clients/Guests for UXG.
  • Fix UBB LED configuration.
  • Fix issue preventing provisioning Firewall rules, Traffic Rules, and Traffic Routes with paused Networks.
  • Fix issue when the user can’t edit Threat Management settings.
  • Fix issue where devices connected to the port with LAG enabled do not reconnect after the application update.
  • Fix issue where Site-to-Site VPN connection is stalling in rare cases.
  • Fix issue where Honeypot hits with Detect Only setting for Threat management don't send notifications to users.
  • Fix issue where incorrect System Sensitivity was set when enabling Threat management.
  • Fix issue where Guest Hotspot Profile couldn't be saved in rare cases.
  • Fix issues in Switch port insights on Safari browser.
  • Fix Country Restriction limit for UXG.
  • Fix issue where DHCP Guarding option was not available in Network settings.
  • Fix missing information in device columns if the device has an update available.
  • Fix issue where changes were not saved when changing Access Point Channel Optimization setting.
  • Fix issue where APs Wireless Meshing setting unexpectedly resets to "Auto" value.
  • Fix issue where Multi-factor authentication with non-default method failed on the Remote Access portal.
  • Fix issue where Firewall & Security Settings cannot be saved.
  • Fix issue where Guest Hotspot vouchers cannot be printed.
  • Fix issue where Time Range for Traffic Rule cannot cover nighttime.
  • Fix device image size for devices with long names.
  • Fix page crashes when switching between sites in rare cases.
  • Fix issue where "Down Pkts/Bytes" was listed twice.
  • Fix issue where AP settings are incorrect temporary after making some changes.
  • Fix an issue where the Auto Update dialog showed up twice.
  • Fix issue where Min. Data Rate Control for 2.4 GHz in WiFi settings cannot be enabled.
  • Fix issue where Internet settings reset to Auto when adding DDNS entries.
  • Fix old reference to Connectivity Monitor in the max SSID's tooltip.
  • Fix issue where WiFi Guest Network Type could revert to Standard.
  • Fix missing Client MAC address in client property panel when the client is offline.
  • Fix issue where certain admins cannot edit certain settings after restoring from a backup.
  • Fix the issue where System Settings can't be saved.
  • Fix issue where default port profiles were not read-only.
  • Fix unable to open device property panels for disabled/disconnected devices.
  • Disable AP Nightly Channel Optimization Toggle if the global AP setting is disabled.
  • Disable the Wireless Meshing setting if it can not be turned on.
  • Disable DPI service if Traffic Identification is disabled.
  • Hide interface options for not supported devices in Port Forwarding form.
  • Show DPI Restrictions for supported consoles if any existing rule exists.
  • Prevent situation when UBB AP data were shown as Station and the other way round; also show correct wired/wireless uplink type.
Known issues
  • Image for the USG-Pro-4 in the dashboard is missing.
  • Editing traffic rules with offline clients selected is not possible.
7.1.61 and earlier 7.1.x versions.
7.0.26 and earlier 7.0.x versions.
macOS Specific
Checksums
b6b14e1da0c6dd8526a752af5e61b091 *UniFi-installer.exe
40c19ffe82f7d63ede0b0c2bd5bae041 *UniFi.pkg
846e6debc45c5dce84563f6e0efcec94 *UniFi.unix.zip
a50d1d67e03902cc3e696ccbf32c208f *unifi_sysvinit_all.deb
601df32736f41e40a80a3e472450a3e1 *unifi_sh_api
