UniFi OS - Dream Machines 4.0.18
Important Notes
Bundled application
Improvements
  • Added support for Shadow Auto Failover with DS-Lite connections.
  • Improved Remote Access connection resiliency.
  • Improved username validation when creating a UI Account through the setup wizard.
  • Improved compatibility with some 3rd party SFP modules.
  • Improved device stability.
Bugfixes
  • Fixed gateway configuration issues in rare cases.
  • Fixed incorrect elapsed time when restoring backups.
  • Fixed an issue where remote logging stops working in rare cases.
  • Fixed RADIUS issues when a username contains a space.
  • Fixed PPPoE connection issues in rare cases.
  • [UDM] Fixed an issue where you couldn't completely delete all characters when configuring the WiFi name in the setup wizard.
  • [UDM] Fixed an issue where the WiFi channel and width changed after an RF scan.
UniFi Network Application 8.4.57
Improvements
  • Added ability to specify NAS ID in WiFi Settings.
  • Added custom server option for DNS Shield.
  • Requires a UniFi (Cloud) Gateway with firmware version 4.0 or newer.
  • Improved Packet Capture user experience.
  • Improved default filtering for the Clients page.
  • Now defaults to Online.
  • Improved application performance on large setups.
  • Improved user experience on the Topology page on larger setups.
  • Now defaults to not showing clients if there are more than 50 devices when opening the page for the first time.
  • Removed max capture size setting for Packet Captures.
  • Reduced the mDNS network limit for the UniFi Express to a maximum of 2 networks.
  • Moved Channelization to WiFi settings.
Bugfixes
  • Fixed an issue where VLAN settings from profiles were incorrectly applied on LAN ports on UniFi Gateways and Enterprise Fortress Gateways.
  • Fixed an issue where deleting a site also removes admins from all other sites in rare cases.
  • Fixed an issue where auto backups were failing on setups that were set up with UniFi Network 8.2 or newer.
  • Fixed an issue where the new WiFi Password requirements for Brazil were also applied on Access Points.
UniFi Network Application 8.4.59
Bugfixes
  • Fixed the inability to start a Packet Capture on APs with a Network Override configured.
  • Fixed an issue where Column re-ordering was not saved in the Clients page.
  • Fixed the inability to load Network Settings in rare cases.
  • 5 mois après...
