Sakkhho Posté(e) le 12 juillet Signaler Partager Posté(e) le 12 juillet Faut faire la demande mais la personne qui vends l onu le fait pour toi. 1 Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 17 août Auteur Signaler Partager Posté(e) le 17 août UniFi OS - Dream Machines 4.0.18 Important Notes Bundled application UniFi Network 8.3.32 Improvements Added support for Shadow Auto Failover with DS-Lite connections. Improved Remote Access connection resiliency. Improved username validation when creating a UI Account through the setup wizard. Improved compatibility with some 3rd party SFP modules. Improved device stability. Bugfixes Fixed gateway configuration issues in rare cases. Fixed incorrect elapsed time when restoring backups. Fixed an issue where remote logging stops working in rare cases. Fixed RADIUS issues when a username contains a space. Fixed PPPoE connection issues in rare cases. [UDM] Fixed an issue where you couldn't completely delete all characters when configuring the WiFi name in the setup wizard. [UDM] Fixed an issue where the WiFi channel and width changed after an RF scan. Lien vers le commentaire Partager sur d’autres sites More sharing options...
mprinfo Posté(e) le 17 août Auteur Signaler Partager Posté(e) le 17 août UniFi Network Application 8.4.57 Improvements Added ability to specify NAS ID in WiFi Settings. Added custom server option for DNS Shield. Requires a UniFi (Cloud) Gateway with firmware version 4.0 or newer. Improved Packet Capture user experience. Improved default filtering for the Clients page. Now defaults to Online. Improved application performance on large setups. Improved user experience on the Topology page on larger setups. Now defaults to not showing clients if there are more than 50 devices when opening the page for the first time. Removed max capture size setting for Packet Captures. Reduced the mDNS network limit for the UniFi Express to a maximum of 2 networks. Moved Channelization to WiFi settings. Bugfixes Fixed an issue where VLAN settings from profiles were incorrectly applied on LAN ports on UniFi Gateways and Enterprise Fortress Gateways. Fixed an issue where deleting a site also removes admins from all other sites in rare cases. Fixed an issue where auto backups were failing on setups that were set up with UniFi Network 8.2 or newer. Fixed an issue where the new WiFi Password requirements for Brazil were also applied on Access Points. UniFi Network Application 8.4.59 Bugfixes Fixed the inability to start a Packet Capture on APs with a Network Override configured. Fixed an issue where Column re-ordering was not saved in the Clients page. Fixed the inability to load Network Settings in rare cases. Lien vers le commentaire Partager sur d’autres sites More sharing options...
