mprinfo Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 HC3 & HCL3 - 5.092.19 - BETA - 22/12/2021 Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements. Main features: 1. Improvements for Energy Panel 2. Block Scenes releated to Energy Panel 3. Bug fixes and improvements for Elero and Nice devices What's new: Access Possibility of setting another PIN to be used for integrations in user's alarm settings. Dashboard Distinction of actions sent on click and hold & release of open/close buttons. New icon of unavailable device. Devices Disabled logging energy consumption for hidden root endpoints of the device. Separated configuration of saving energy to database from using data in energy panel. New com.fibaro.multiPositionSwitch device type support. Support for MCO MH3901-Z version 2.1. Support for Heiman Gas Sensor (HS1CG) version 1.1 & 1.2. Elero* Possibility to skip waiting for limit switch report when setting the favourite position. Possibility to retry configuration of favourite position after passing the desired level. Possibility of re-editing the device configuration during the adding wizard. Forced polling of added device after finishing its configuration. Forced polling of the device after setting favourite position. Synchronous pairing of Elero devices in Nice/Elero settings. Displaying manufacturer, model, and version in device settings. Silent move feature when used in scenes for Elero RolMotion device. Energy History tab in Panel Settings allowing to remove energy data. Possibility of adding additional costs in Expenses tab of Panel Settings. Redesigned interface of setting the installation cost in Panel Settings. Overall costs added in Expenses tab are considered when calculating returns. Graphical representation of configured rates in Tariff tab of Panel Settings. Marking the same time ranges when comparing two periods in Savings tab. Improvements for displaying charts in Savings tab. Nice* User-friendly names and tooltips for Nice device adding mode configuration dialog. Displaying manufacturer and model in device settings. Notifications Notifications set in device settings may be sent only to specified users. Other Ability to call device actions, scenes and emit custom events via GET method of HTTP API. Quick Apps Expanded list of available binary sensors. Added os.clock library. Scenes New category of block scenes - Energy. Creating scenes based on summary consumption/production/balance of energy. Creating scenes based on energy consumed by given device/room/category. Creating scenes based on active rate of tariff. Update Expanded view of available device firmware update.** Displaying detailed device update process status.** Bug fixes: Devices Device polling time interval displays incorrectly. Main energy meter energy consumption is not displayed in device advanced tab. FIBARO Smart Implant central scene support does not work correctly. Removed the polling interface where not applicable. Possibility to run multiple times an active device update process.** Cannot save value of parameter added manually.** Incorrect inputs support of FIBARO RGBW Controller. Device icons do not update properly when switching tabs. Icon of gate with positioning is not set automatically. Cannot download device template. Elero* In some cases, one device is not paired when pairing multiple devices. Cannot stop pairing process after occurrence of timeout. Redundant stop button for rotating slats. Energy No possibility to change filter after filtering room or category with no data. Invisible labels in Ecology tab when using dark theme. Incorrect plant equivalent chart value. Gateway Connection Icon changed for device added to slave gateway is not saved. Updating device added to slave is terminated by updating device added to master. Resetting the Z-Wave network is applied only to master gateway. Favourite position of device added to slave gateway is not saved. Incorrect update status of slave gateways. History Events are displayed even though saving events to history was disabled. Network In some cases, Wi-Fi network disconnects and does not reconnect automatically. Nice* Some Nice Mono devices have incorrect device type after performing update. No possibility to close the adding dialog while binding new device. Scene triggered by Mono remote does not control Mono shutter. Notifications Fixed titles of notification templates about opening/closing. Other Possibility of entering into inoperable recovery mode via remote access. In some cases recovery mode is not fully loaded. Plugins Fixes for Philips Hue plugin related to speed of adjusting brightness. Fixes for Tedee plugin related to unexpected disconnection. Fixes for Fibaro Heat Activator plugin. Profiles In some cases, switching the profile results in an error. Quick Apps Connection does not close when using http client. Scenes Removing device used in the middle of the scene results that scene does not fully run. Known issues: Sceny The energy block scenes feature is a first version which may contain some issues. Z-Wave Engine 3.0 Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine. Gateway connection is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite)** - applies only to Z-Wave Engine 3.0 on is not available in the new Z-Wave engine version. * - does not apply to HC3L (Home Center 3 Lite) ** - applies only to Z-Wave Engine 3.0 4
Lazer Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Mise à jour passée sur la box de dev sans souci Le nouveau type "com.fibaro.multiPositionSwitch" me plait bien car il pourrait typiquement correspondre aux 6 états d'un module Fil Pilote. Malheureusement non sélectionnable lors de la création d'un QuickApp, il faudrait que j'essaye de l'injecter en modifiant le JSON à la main. 1
TonyC Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 En prime un père noël, c'est il pas mignon Merci @mprinfo ! Je l'ai installé cette aprem RAS, ça me corrige un bug un peu gênant sur le main dashboard qui ramait pas mal depuis la version qui optimisait l'affichage dashboard devices et pleins d'autres sur la gestion des gateways slaves et c'est cool ! 1
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 Ben chez moi la HC3 ne fais que de rebooter Enfin redémarrage des services en boucle 1
Krikroff Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Le 22/12/2021 à 17:45, Lazer a dit : Le nouveau type "com.fibaro.multiPositionSwitch" me plait bien car il pourrait typiquement correspondre aux 6 états d'un module Fil Pilote. Malheureusement non sélectionnable lors de la création d'un QuickApp, il faudrait que j'essaye de l'injecter en modifiant le JSON à la main. Développer Déjà testé, et pour exactement la même raison que toi 2
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 alors voila ce que cela donne chez moi impossible de me connecter avec mon mot de passe
Krikroff Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Hum, tu as testé j'imagine un redémarrage complet ?
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 Oui c'est la première chose que j'ai fais C'est pas bien grave elle me sert juste pour des tests le reste est sur ma bonne vieille HC2
TonyC Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Essaye peut être de vider ton cache, pas certain que ça fonctionne mais sait on jamais.
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 C'est fait aussi par contre elle n'est pas lier a cloud de fibaro ça peut venir peut être de la Punaise après 3 redémarrage cela fonctionne Et merde non je suis arrivé sur l'interface mais la je peux rien faire On dirait un soucis avec un scénario magique écrit en rouge et la je viens de me faire jeté
TonyC Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Mince !! j'espère que tu as un fichier local de backup
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 C'est un box de test et je sauvegarde tout mes QA en plusieurs exemplaire pas de soucis pour cela il n'y a que 2 modules Zwave et je crois que j'ai une sauvegarde Elle me bombarde de mail comme quoi la box a redémarrer
Lazer Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Connecte toi avec un port série dessus (private joke) 2
Lazer Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 Le 22/12/2021 à 19:07, Krikroff a dit : Déjà testé, et pour exactement la même raison que toi Développer Tu as une vue du QA dans l'application mobile, comment ça se comporte ?
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 C'est réparer je fais quoi je recommence la mise à jour Soyons fou je refais le mise à jour
TonyC Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 ben si c'est une box de test alors y'a pas trop de risque. J'ai un comportement étrange sur une scène que je n'arrive pas arrêter. J'ai beau tout essayer, rien à faire, je viens de rebooter. A surveiller...
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 Après mise a jour même soucis je pense que c'est une scène qui merde Je vais faire une réparation puis désactivé les scènes puis mise a jour
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 toujours pareil juste après le redémarrage des services j'arrive a me logué si je me dépêche et après j'ai le redémarrage des services environ 10s
TonyC Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 restore la version précédente, désactive ta magic scene qui met un magic bordel et upgrade de nouveau, étrange qu'une magic scene mette la grouille à ce point!
mprinfo Posté(e) le 22 décembre 2021 Auteur Signaler Posté(e) le 22 décembre 2021 je sais même pas si j'ai une scène magique sur la box je fais un restore et je désactive les scènes puis une mise à jour je vous tiens au jus
couillerot Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 RAS pour le moment... Stef
Krikroff Posté(e) le 22 décembre 2021 Signaler Posté(e) le 22 décembre 2021 @Lazer, comme pour toutes nouvelles fonctionnalités… pas marche 1
